Manjaro takes ages to boot on my computer
chris@chris ~]$ systemd-analyze blame
5min 12.726s systemd-fsck@dev-disk-by\x2duuid-cc1265a1\x2d3a30\x2d4626\x2d8605\x2dccf1db077266.service
3.849s NetworkManager-wait-online.service
3.826s systemd-modules-load.service
841ms docker.service
759ms dev-nvme0n1p4.device
561ms data.mount
336ms containerd.service
307ms NetworkManager.service
297ms systemd-udev-trigger.service
287ms udisks2.service
180ms systemd-journal-flush.service
159ms systemd-rfkill.service
157ms user@1000.service
157ms ldconfig.service
148ms systemd-remount-fs.service
143ms cups.service
138ms plymouth-quit-wait.service
118ms plymouth-start.service
109ms lvm2-monitor.service
103ms upower.service
100ms modprobe@fuse.service
93ms systemd-tmpfiles-setup.service
89ms systemd-fsck@dev-disk-by\x2duuid-2210\x2d1829.service
77ms polkit.service
76ms systemd-journald.service
76ms systemd-tmpfiles-clean.service
74ms systemd-udevd.service
70ms systemd-journal-catalog-update.service
66ms systemd-vconsole-setup.service
64ms plymouth-quit.service
61ms systemd-logind.service
56ms systemd-user-sessions.service
54ms systemd-tmpfiles-setup-dev-early.service
53ms modprobe@drm.service
51ms dbus-broker.service
50ms systemd-sysusers.service
48ms dev-hugepages.mount
48ms kmod-static-nodes.service
47ms dev-mqueue.mount
46ms modprobe@configfs.service
46ms systemd-tmpfiles-setup-dev.service
46ms systemd-timesyncd.service
45ms sys-kernel-debug.mount
44ms logrotate.service
40ms ModemManager.service
40ms systemd-update-done.service
38ms plymouth-read-write.service
38ms sys-kernel-tracing.mount
36ms systemd-sysctl.service
33ms boot-efi.mount
30ms bluetooth.service
29ms alsa-restore.service
26ms user-runtime-dir@1000.service
23ms systemd-update-utmp.service
23ms systemd-random-seed.service
21ms modprobe@loop.service
19ms docker.socket
16ms sys-fs-fuse-connections.mount
15ms power-profiles-daemon.service
13ms nordvpnd.socket
11ms tmp.mount
9ms sys-kernel-config.mount
7ms rtkit-daemon.service
5ms modprobe@dm_mod.service
3ms proc-sys-fs-binfmt_misc.mount
I have no idea what systemd-fsck@dev-disk-by\x2duuid-cc1265a1\x2d3a30\x2d4626\x2d8605\x2dccf1db077266.service is.
Random other info that might help
[chris@chris ~]$ inxi --full --admin --filter --width
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7979a6d6-d005-47e1-ad73-56e8f5bef7ab rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-F GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 0904 date: 09/14/2018
Info: model: Intel Core i3-8350K bits: 64 type: MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF4
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 32013
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 545.29.06
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 2 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
s-diag: 868mm (34.19")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 3440x1440 hz: 50 dpi: 110
size: 797x333mm (31.38x13.11") modes: 3440x1440
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.276 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 545.29.06
device-ID: 10de:1b81 surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Razer USA Barracuda Pro 2.4
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14.1:4 chip-ID: 1532:053a class-ID: 0301
serial: <filter>
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF-ID-1: br-617af164e82b state: down mac: <filter>
IF-ID-2: br-ecd3e317c94b state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:2 chip-ID: 2357:0604
Local Storage: total: 2.73 TiB used: 693.57 GiB (24.8%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EURX-63T0FY0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
ID-1: / raw-size: 833.56 GiB size: 819.4 GiB (98.30%)
used: 225.29 GiB (27.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
used: 25.6 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.26 GiB used: 13.24 GiB (42.4%)
Processes: 264 Power: uptime: 2h 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1360 libs: 431 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: konsole inxi: 3.3.33
Not sure if there are any other logs I should be aweare of that might be helpful in this situation
