I’m having issues with the waybar on Manjaro Sway. After starting my PC and logging in, the waybar fails to start. If I press mod+shift+c to reload sway, only then does the waybar initialize. I tried to remedy the issue by including both exec swaybar
as well as
bar {
swaybar_command waybar
in ~/.config/waybar/config
, as per this link, however neither successfully start waybar after a reboot. However, when I do a sway reload, I get both the Manjaro themed waybar in addition to a default style waybar!
I’ve found a few posts about this issue on Reddit and here on the Manjaro forums, however no one has supplied a satisfactory solution to the issue.
This is an issue for me as I specifically desire to create a custom waybar. Because of the fact that reloading initializes TWO waybars, I cannot simply reload sway to fix the issue.
I would greatly appreciate any input on how to fix this issue!
