Manjaro-sway-settings depends on obsolete xcursor-breeze (conflict breeze-cursors5)
Problème
sudo pacman -Syu bloque :
:: la suppression de xcursor-breeze casse la dépendance « xcursor-breeze » requise par manjaro-sway-settings
Diagnostic technique
$ pactree -r manjaro-sway-settings
manjaro-sway-settings # RIEN d'autre ne dépend
$ pacman -Ql manjaro-sway-settings
/etc/sway/ # configs critiques
$ grep "include.*etc/sway" ~/.config/sway/config
25:include /etc/sway/definitions
→ suppression casse Sway
Solution workaround
IgnorePkg = xcursor-breeze # /etc/pacman.conf
Mais mettez à jour dépendances manjaro-sway-settingsbreeze-cursors5
Versions :
xcursor-breeze-5.27.12-1breeze-cursors5-5.27.12-2
The current version of manjaro-sway-settings does not depend on it. It means you’re also behind there.
Thanks for your answer ! It seems I somehow lost the repo…
I did this and managed to update manjaro-sway-settings:
sudo manjaro-sway-mirrors  :check_mark:
[sudo] Mot de passe de fred :
updated /etc/pacman.d/manjaro-sway.repo.conf
now referencing /etc/pacman.d/manjaro-sway.repo.conf from /etc/pacman.conf
