Manjaro sway install error: crc32c_intel not supported anymore
I just ran into a error installing Manjaro sway regarding mkinitcpio.
I had to use the latest unstable image for wayland to work on the StarBook Mk VII. (manjaro-sway-25.0.0-unstable-250601-linux614.iso)
Unfortunately Calamares fails to install, here is the relevant log section:
2025-06-02 - 14:27:03 [1]:     ERROR: Installation failed: "External command finished with errors."
2025-06-02 - 14:27:03 [6]:     .. - message: "External command finished with errors."
2025-06-02 - 14:27:03 [6]:     .. - details: Command <i>mkinitcpio</i> finished with exit code 1.
Output:
==> Building image from preset: /etc/mkinitcpio.d/linux614.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.14-x86_64 -g /boot/initramfs-6.14-x86_64.img
==> Starting build: '6.14.9-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [encrypt]
==> ERROR: module not found: 'crc32c_intel'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.14-x86_64.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Running post hooks
  -> Running post hook: [sbctl]
Secureboot key directory doesn't exist, not signing!
==> Post processing done
==> Building image from preset: /etc/mkinitcpio.d/linux614.preset: 'fallback'
  -> -k /boot/vmlinuz-6.14-x86_64 -g /boot/initramfs-6.14-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.14-x86_64-fallback.img'
2025-06-02 - 14:27:03 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
Someone on AW had the same problem: topic id=304822 Link to thread
The suggested fix is to remove crc32c_intel from the mkinitcpio.conf MODULES but I don’t know how I have to conduct this for it to work with the Calamares installation process.
It also seems that the crc32_intel module is included through the filesystems hook.
I tried to replace that in /etc/mkinitcpio.conf before running Calamares but that seems to have no effect.
Mod edit: Added the link I believe you refer to. If this is not the correct one, please let us know either via reply or PM (or edit your post to remove it).
Also fixed a couple of typos. :wink:
Do you know that you need it?
The reason for the error message is likely that you have it explicitly mentioned in your:
grep ^MODULES /etc/mkinitcpio.conf
The function may not be a module anymore, but built in.
But I don’t know that - it’s just speculation as of now.
I didn’t look at the linux614 (yet) - it is present in linux612 and lower.
The module crc32c_intel is removed on newer kernels. crc32c is used now as builtin module, since crc32c_intel is now integrated. Therefore: remove the entry.
Adding to what @megavolt said:
as I understand, this is during installation - and the Calamares installer does “choke” on it, doesn’t complete
Before starting the installation, edit the file (even though you are on a live system), remove the entry, save.
It will reflect the change for the duration of this one boot.
Yeah, I thought that too and tried that.
The crc32c_intel wasn’t included in the config in the first place but the filesystem hook was so I removed that (and included btrfs by hand instead).
But I still see the Running build hook: [filesystem] log line with the error afterwards.
I suspected that Calamares mounted the filesystem separately for the installation and thus won’t see the change.
Any Idea?
Ok, so my ignorance of how the installer works has been demonstrated. :grimacing:
No more ideas from me.
I believe you were still somehow right though missing a part but OP misread your directions which were to remove the crc32c_intel (the part you missed was to replace crc32c_intel with crc32c if its present or to add it if its not).
@embediver you can put it on a line on its own at the top of the file :point_down:
A snippet of the beginning from mine
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(usbhid xhci_hcd)
MODULES=(crc32c)
In any case DO NOT REMOVE the filesystem hook. I would advise to leave the HOOKS= line alone at installation unless you have a very specific reason like encryption in mind to do so.
You can see more on this issue here
From what I remember from installing to real hardware, MODULES was always empty, since there was no need to explicitly load any modules in early boot (initrd).
Of course, if there is a module named/mentioned which does not actually exist, that would cause an error.
As I like to see things for myself, I’m downloading that ISO right now and will test install it in a VM …
I tried Sway before, but it wouldn’t really work in my VM.
I “blamed” it on Wayland back then - but I don’t really know.
It kinda works, with graphics glitches.
There is only modules pertaining to this being run in a VM in MODULES in /etc/mkinitcpio.conf.
no crc32c_intel
But the installation fails at the same point with the same error as for @embediver
Even basic investigating proves difficult because I’m totally unfamiliar with the sway environment and because the terminal output is laggy and glitchy in my VM.
Perhaps in TTY, but:
I don’t know where the want for crc32c_intel during installation may come from.
I think something is not up-to-date on your system?
  1. ensure your iso-profiles repo is up-to-date
  2. make sure you manjaro-tools-git is up-to-date
I vaguely recall the crc module being added to mkinitcpio by the installer when you select btrfs as the file system.
A calamares module is responsible for this action - a corresponding merge request has been created.
