Manjaro-sway getting logged out
Thanks for this nice setup! One thing that’s a problem for me and I couldn’t google its solution is, that I leave my computer and when I come back my session is ended and I’m logged out, i.e. I find myself in the display manager. Is this a known issue or even a feature? If so how could I prevent this. (I don’t mean a lock screen but being logged out.) Thanks for any help.
Well, that sounds inconvenient;
Perhaps the relevant settings need a tweak or two.
I’m not a Sway user, so where those specific settings might be, I can’t say. Nonetheless, I’m sure someone will help when they are able.
In the meantime, please provide system information as described (below), and take some time to learn a little about the forum (useful links also below).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
  Kernel: 6.6.88-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=df430096-4fc2-465d-ba66-f1f4f2c677af rw quiet apparmor=1
    security=apparmor resume=UUID=776258ea-507a-4363-b0cd-292e63ba2e05
    udev.log_priority=3
  Desktop: Sway v: 1.10.1 with: waybar tools: swayidle avail: swaylock vt: 2
    lm: greetd Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21MACTO1WW v: ThinkPad E16 Gen 2
  Mobo: LENOVO model: 21MACTO1WW serial: <superuser required>
    part-nu: LENOVO_MT_21MA_BU_Think_FM_ThinkPad E16 Gen 2
    uuid: <superuser required> UEFI: LENOVO v: R2JET39W(1.16 )
    date: 12/23/2024
  ID-1: BAT0 charge: 58.8 Wh (100.0%) condition: 58.8/57.0 Wh (103.1%)
    volts: 13.1 min: 11.3 model: Sunwoda L23D3PG2 type: Li-poly serial: <filter>
    status: full cycles: 1
  System RAM: total: 32 GiB available: 30.82 GiB used: 4.76 GiB (15.4%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 16 GiB speed: 5600 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M425R2GA3EB0-CWMOL
    serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
    serial: <filter>
  Missing: Required tool dmidecode not installed. Check --recommends
  Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: 24 MiB note: check
  Speed (MHz): avg: 3627 min/max: 400/4400:4700:3800:2500 scaling:
    driver: intel_pstate governor: performance cores: 1: 3627 2: 3627 3: 3627
    4: 3627 5: 3627 6: 3627 7: 3627 8: 3627 9: 3627 10: 3627 11: 3627 12: 3627
    13: 3627 14: 3627 15: 3627 16: 3627 17: 3627 18: 3627 19: 3627 20: 3627
    21: 3627 22: 3627 bogomips: 131824
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+
    ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3
    chip-ID: 30c9:00c2 class-ID: fe01 serial: <filter>
  Display: wayland server: Xwayland v: 24.1.6 compositor: Sway v: 1.10.1
    driver: gpu: i915 d-rect: 6000x3040 display-ID: 1
  Monitor-1: HDMI-A-1 pos: primary,top-left model: Lenovo G34w-30
    serial: <filter> built: 2022 res: mode: 3440x1440 hz: 60 scale: 112% (1.12)
    to: 3057x1280 dpi: 110 gamma: 1.2 chroma: red: x: 0.675 y: 0.310 green:
    x: 0.275 y: 0.655 blue: x: 0.153 y: 0.075 white: x: 0.314 y: 0.329
    size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: 3440x1440,
    2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 76
  Monitor-2: eDP-1 pos: bottom-r model: California Institute of 0x160E
    built: 2021 res: mode: 2560x1600 hz: 60 scale: 150% (1.5) to: 1706x1066
    dpi: 189 gamma: 1.2 chroma: red: x: 0.647 y: 0.329 green: x: 0.298
    y: 0.596 blue: x: 0.137 y: 0.059 white: x: 0.310 y: 0.329
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 2560x1600
  API: EGL Message: EGL data requires eglinfo. Check --recommends.
  Info: Tools: de: kscreen-doctor wl: swaymsg, way-displays, wdisplays
    x11: xprop
  Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  API: ALSA v: k6.6.88-1-MANJARO status: kernel-api tools: N/A
  Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: Intel vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:550b class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 1.84 TiB used: 51.57 GiB (2.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TEM4X169N
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 61700A30 temp: 33.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SSK model: Portable SSD 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: 1000 scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 21.28 GiB (21.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: linux
    uuid: df430096-4fc2-465d-ba66-f1f4f2c677af
  ID-2: /boot/efi raw-size: 4 GiB size: 3.99 GiB (99.80%)
    used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 7AF4-B212
  ID-3: /data raw-size: 634.87 GiB size: 623.83 GiB (98.26%)
    used: 30.3 GiB (4.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: data uuid: 57895ec8-8b1b-4b9e-9eed-67dc14404b02
  ID-1: swap-1 type: partition size: 65 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 776258ea-507a-4363-b0cd-292e63ba2e05
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 150 GiB fs: ntfs label: windows
    uuid: 10A6C04B0BAF1396
  ID-2: /dev/sda1 maj-min: 8:1 size: 585.94 GiB fs: ext4 label: N/A
    uuid: 284aa97a-6786-488c-b5e1-2b6fb134b192
  ID-3: /dev/sda2 maj-min: 8:2 size: 345.57 GiB fs: vfat label: N/A
    uuid: 950E-64A8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:659a class-ID: ef00 serial: <filter>
  Device-2: 3-7:3 info: Luxvisions Innotech Integrated RGB Camera
    type: video driver: uvcvideo interfaces: 5 rev: 2.0
  Device-3: 3-10:5 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Device-1: 4-1:2 info: Silicon Motion - Taiwan (formerly Feiya ) SSK SSD
    type: mass storage driver: uas interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 090c:2320 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
Processes:
  CPU top: 5 of 404
  1: cpu: 3.2% command: firefox pid: 8412 mem: 589.6 MiB (1.8%)
  2: cpu: 2.7% command: firefox pid: 14598 mem: 773.2 MiB (2.4%)
  3: cpu: 0.6% command: firefox pid: 8616 mem: 174.1 MiB (0.5%)
  4: cpu: 0.5% command: firefox pid: 15594 mem: 260.2 MiB (0.8%)
  5: cpu: 0.4% command: sway pid: 7546 mem: 132.6 MiB (0.4%)
  Memory top: 5 of 404
  1: mem: 773.2 MiB (2.4%) command: firefox pid: 14598 cpu: 2.7%
  2: mem: 589.6 MiB (1.8%) command: firefox pid: 8412 cpu: 3.2%
  3: mem: 270.6 MiB (0.8%) command: firefox pid: 12171 cpu: 0.1%
  4: mem: 260.2 MiB (0.8%) command: firefox pid: 15594 cpu: 0.5%
  5: mem: 245.3 MiB (0.7%) command: firefox pid: 14137 cpu: 0.2%
  Processes: 404 Power: uptime: 59m states: freeze,mem,disk suspend: s2idle
    image: 12.32 GiB services: upowerd Init: systemd v: 257 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: alacritty
    inxi: 3.3.38
Sounds to me like a broken suspend process. Manjaro’s Settings for Sway will lock your session after time and then suspend. Check the journal for more information.
suspending “by hand” is my current workaround; i.e. that seems to work.
these where the error messages this morning (de) right after it happened
Mai 12 06:39:38 tp pcmanfm-qt[242466]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
it diddn’t
 Available platform plugins are: wayland-egl, eglfs, wayland, xcb, minimal, vkkhrdisplay, offscreen, vnc, linuxfb, minimalegl.
Mai 12 06:39:38 tp systemd-coredump[242481]: [🡕] Process 242466 (pcmanfm-qt) of user 1000 dumped core.
Stack trace of thread 242466:
#0  0x00007ff9646a5624 n/a (libc.so.6 + 0x97624)
#1  0x00007ff96464bba0 raise (libc.so.6 + 0x3dba0)
#2  0x00007ff964633582 abort (libc.so.6 + 0x25582)
#3  0x00007ff964e910b5 n/a (libQt6Core.so.6 + 0x910b5)
#4  0x00007ff964e91f65 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x91f65)
#5  0x00007ff9656e217b n/a (libQt6Gui.so.6 + 0xe217b)
#6  0x00007ff9657915c8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x1915c8)
#7  0x00007ff964f5ec9d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x15ec9d)
#8  0x00007ff96579165e _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x19165e)
#9  0x00007ff9660f9c26 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf9c26)
#10 0x0000557a3564c16d n/a (/usr/bin/pcmanfm-qt + 0x2416d)
#11 0x00007ff964635488 n/a (libc.so.6 + 0x27488)
#12 0x00007ff96463554c __libc_start_main (libc.so.6 + 0x2754c)
#13 0x0000557a3564f675 n/a (/usr/bin/pcmanfm-qt + 0x27675)
Stack trace of thread 242468:
#0  0x00007ff9646abbe2 n/a (libc.so.6 + 0x9dbe2)
#1  0x00007ff96469fe33 n/a (libc.so.6 + 0x91e33)
#2  0x00007ff96469fe74 n/a (libc.so.6 + 0x91e74)
#3  0x00007ff96471aa06 ppoll (libc.so.6 + 0x10ca06)
#4  0x00007ff965569f67 n/a (libglib-2.0.so.0 + 0xc1f67)
#5  0x00007ff965505615 g_main_context_iteration (libglib-2.0.so.0 + 0x5d615) #6  0x00007ff9651cd59d _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3cd59d)
#7  0x00007ff964f65376 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x165376)
#8  0x00007ff96505a4b9 _ZN7QThread4execEv (libQt6Core.so.6 + 0x25a4b9)
#9  0x00007ff96684f8de n/a (libQt6DBus.so.6 + 0x2e8de)
#10 0x00007ff9650e44ff n/a (libQt6Core.so.6 + 0x2e44ff)
#11 0x00007ff9646a3708 n/a (libc.so.6 + 0x95708)
#12 0x00007ff964727aac n/a (libc.so.6 + 0x119aac)
Mai 12 06:39:38 tp foot[242517]: server: failed to read socket option from passed file descriptor: Socket operation on non-socket
Mai 12 06:39:38 tp foot[242517]: fdm: failed to unregister FD=5 from epoll: Bad file descriptor
Mai 12 06:39:38 tp foot[242517]: fdm: failed to unregister FD=4 from epoll: Bad file descriptor
Mod edit: Please always place code or command output within a preformatted text box. See links previously given to learn how. Corrected for you, this once. No charge.
today’s upgrade seems to have fixed the issue
