I have just updated Manjaro and rebooted, now it is stuck at the /dev/nvme0p2… screen. (or /dev/sda…).
No error messages there. According to some other post I switched to tty2 with ctrl+alt+f2, logged in as root and tried to reinstall the nvidia drivers using mhwd -i -f pci video-nvidia-470xx, mhwd -a pci nonfree 0300 and mhwd -f -i pci video-nvidia. Non of those work however, they all return an error message.
Error: target not found: linux514-nvidia(-470xx (for the -470xx command))
Error: pacman failed
Error script failed
mhwd -li returns, only the video-linux driver installed.
Any suggestions on how to solve the problem are much appreciated!
Then reboot into 5.15. Press Esc during boot to get into grub menu > advanced options and boot with 5.15. Double check your running kernel is not 5.14 then remove it:
uname -r #to check kernel version
sudo mhwd-kernel -r linux514
