Manjaro stopped working after some time
Hello guys!
My manjaro xfce stops working after some amount of time. Just the screen snoozes and I cannot do anything ( I am restarting by pressing power btn ). Thanks in advance!
Have you tried monitoring your RAM usage?
Thanks for the quick reply!
I have not. But this happens when I open many apps. Ok I will try to measure ram usage opening many apps. Thanks!
@maycne.sonahoz I monitored the ram usage around max 2.7G out of 3.7 with (firefox (3, 4 tabs), vsscode, and one terminal) and kept using it for my work. It has just happened. I think it is not due to ram ( I don’t know exactly )
Best regards
That’s not a lot of RAM. Do you have a Swap set up?
Also please provide your system information as explained in the guide above.
No I have not Swap set up
Please post command output as formatted text, as detailed in the guide linked above.
RAM: total: 3.72 GiB used: 2.46 GiB (66.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required
@maycne.sonahoz
Do you have related errors in the system journal?
There’s your problem. 4 GiB of RAM — you state 3.7 GiB but that’s because you lose some RAM to the onboard GPU and some memory addresses to the PCI memory gap — is absolutely too little to be running a modern 64-bit GNU/Linux system without swap, and especially so if you’re going to be using any heavyweight web browsers like Firefox or Chromium/Chrome with more than one tab open.
If you want to run that system without swap, then you’ll need at least 12 to 16 GiB of RAM — even 8 GiB would already work, albeit that it would be tight — but not 4 GiB.
So you must either increase the RAM or create a swap device. I recommend at least 8 GiB of swap in your case.
If you don’t have room for a swap partition, then you can use a swap file instead. There are several tutorials here at the forum on how to set that up, as well as that the Arch Wiki has excellent information about it.
[devalyus@devalyus ~]$ journalctl --boot=-1 --priority=3 --catalog --no-pager
Aug 18 10:09:47 devalyus kernel: NVRM: The NVIDIA GeForce 710M GPU installed in this system is
                                 NVRM:  supported through the NVIDIA 390.xx Legacy drivers. Please
                                 NVRM:  visit http://www.nvidia.com/object/unix.html for more
                                 NVRM:  information.  The 515.65.01 NVIDIA driver will ignore
                                 NVRM:  this GPU.  Continuing probe...
Aug 18 10:10:08 devalyus kernel: NVRM: The NVIDIA GeForce 710M GPU installed in this system is
Aug 18 10:10:35 devalyus lightdm[1002]: gkr-pam: unable to locate daemon control file
Aug 18 10:11:19 devalyus pulseaudio[1119]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Aug 18 10:32:12 devalyus kernel: NVRM: The NVIDIA GeForce 710M GPU installed in this system is
Aug 18 10:32:19 devalyus lightdm[2105]: gkr-pam: unable to locate daemon control file
Aug 18 12:16:00 devalyus systemd-coredump[8748]: [🡕] Process 8672 (telegram-deskto) of user 1000 dumped core.
                                                 Module linux-vdso.so.1 with build-id 15c48e8c72ad1b981d55e5c548007224f45150b1
                                                 Module libqsvgicon.so with build-id b0c07ab868adf23b8c63f6b53a2f4fc36c28a1c3
                                                 Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
                                                 Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
                                                 Module libvulkan.so.1 with build-id dd97393da4f886994c9dfc153b35ea6d906f57ff
                                                 Module libdrm_nouveau.so.2 with build-id 78e99e753be2b598acf02a6f30bc6615a6a3067f
                                                 Module libdrm_amdgpu.so.1 with build-id e03ead624f04700b1fd00df43863fecfb1ff8b72
                                                 Module libelf.so.1 with build-id 5ba0792747dce7480d031794ed90c620da72dbff
                                                 Module libdrm_radeon.so.1 with build-id 5c9c31961c5f0dd9b40cb3e134b8d9189ee59fbb
                                                 Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
                                                 Module libLLVM-14.so with build-id 16d23f3ab6fb7269b2f13a9932a2a7ec4b1d5104
                                                 Module crocus_dri.so with build-id 247f930d52c9b9e6d6e140462136d983b0b617da
                                                 Module libxshmfence.so.1 with build-id d9b3ce4edb0b6a0818bcc57dda020d2da5e3c895
                                                 Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
                                                 Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
                                                 Module libXxf86vm.so.1 with build-id b8b37b0c66be0a760a8491e3c86a00c4efdc825d
                                                 Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
                                                 Module libglapi.so.0 with build-id a5ca7bec18ce3ff85c63b88bd43a7884ea95a1f7
                                                 Module libGLX_mesa.so.0 with build-id 6721ac15576bf0a0a4d5a29429915cb88cdf5426
                                                 Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
                                                 Module libqxcb-glx-integration.so with build-id 432018083dd1bfffdbcfc2acd6fe05eb1058c665
                                                 Module libFLAC.so.8 with build-id 3637a78858507a848ee0a48c50902c943e5bc58f
                                                 Module libasyncns.so.0 with build-id 3ed7e52f247b08f1dff19aef6a253ee4c5c785c0
                                                 Module libsndfile.so.1 with build-id 407b2376cac1726631e3f7360a9337901be04ec0
                                                 Module libpulsecommon-16.1.so with build-id 17e5c781f557e60fbc789cb631816a4a29230f4a
                                                 Module libpulse.so.0 with build-id 0c1618cb1e11cc14128914e45965433374cbd10e
                                                 Module libspa-journal.so with build-id d2d6013bfa1b9deaae18ce450cd049d171b317ce
                                                 Module libspa-support.so with build-id ac45ac61b6e9900c8a54ba6e179d75e8bd55b5f5
                                                 Module libwebpdemux.so.2 with build-id 181ecf1a79aa805a45cce672f3f229570eca9f26
                                                 Module libqwebp.so with build-id 936387f42ed908f4f164715bdac882d7f024bf1d
                                                 Module libqwbmp.so with build-id 15682f891193f756c1bcad5b4b23b5f039a853c2
                                                 Module libqtiff.so with build-id da147410d00a0cae2a31660e96330a72623c05da
                                                 Module libqtga.so with build-id b6e4d12de794ec52e71308ee60ae3542dd8645f7
                                                 Module libqsvg.so with build-id 7b749f3177de0a75e69d517cd529ca220ad7d1e8
                                                 Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
                                                 Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
                                                 Module libqmng.so with build-id ee9ddfc723fe61f0e07a1bd2851968b15d0b2b0c
                                                 Module libqjpeg.so with build-id 49a31795ce5d9f405a4ce7b83c205fea46114b5a
                                                 Module libjasper.so.6 with build-id 920c93104c2081399a4d6334e239cc0fa14bc4b2
                                                 Module libqjp2.so with build-id 53e51f2134d7a4eafc3e82c3592a5f3cfcb57651
                                                 Module libqico.so with build-id aab8073bf01db5861238662a26b48c5dfd90c62c
                                                 Module libqicns.so with build-id 34aa0f6180b55beec78aaff874a79e3f13c01ab4
                                                 Module libqgif.so with build-id 88017653d1179b77666054c40152c0e086ee9ce6
                                                 Module libcomposeplatforminputcontextplugin.so with build-id 6b4c3794e524bfb628df7df424525b3732f692eb
                                                 Module libgvfscommon.so with build-id 2cfa9a05d5e376857a2dacaf4893238a88eefb9e
                                                 Module libgvfsdbus.so with build-id f6f918ab413a1eaaa77134863653c4382b7cf8de
                                                 Module libltdl.so.7 with build-id d05fc2173e22a4b5374a1f80b548ae5c0926e079
                                                 Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
                                                 Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
                                                 Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
                                                 Module libcanberra-gtk3.so.0 with build-id 2e99c78f79bea4bc67ccd9a9f8fed562f89599ee
                                                 Module libcanberra-gtk-module.so with build-id cc626937222c6ce3f7bb45dbe6e862d0b1efba01
                                                 Module libxkbfile.so.1 with build-id dc74ddc73cb1178f037cdc608f7029a0bc9f69a1
                                                 Module libxklavier.so.16 with build-id cefd678b3d270e389f50a9686ad2db83a8c67494
                                                 Module libgnomekbd.so.8 with build-id 7a75c84337b94141ae6bdf56da86a5a6f72343bf
                                                 Module libgnomekbdui.so.8 with build-id eeb3039b3aa71b38849fb1b3d2e97acb9edab6d4
                                                 Module libxapp.so.1 with build-id 37ec2cd0a10b801e46a990db9b6ec04a9e8b1f8b
                                                 Module libxapp-gtk3-module.so with build-id 52f3ac7cccb19903e4c8eedd9054273f622333f5
                                                 Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
                                                 Module libsqlite3.so.0 with build-id e35d23d9eef4b99c931412b3a1355e333fcb10a5
                                                 Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
                                                 Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
                                                 Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
                                                 Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
                                                 Module libtracker-sparql-3.0.so.0 with build-id 75ab4f2e3b5c479b5c4fc62793bf398ee28f4ab7
                                                 Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
                                                 Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
                                                 Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
                                                 Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
                                                 Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
                                                 Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
                                                 Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
                                                 Module libqgtk3.so with build-id b0b6c09095888b18ff632fc68f9c29829162f651
                                                 Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
                                                 Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
                                                 Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
                                                 Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
                                                 Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
                                                 Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
                                                 Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
                                                 Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
                                                 Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
                                                 Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
                                                 Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
                                                 Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
                                                 Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
                                                 Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
                                                 Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
                                                 Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
                                                 Module libQt6XcbQpa.so.6 with build-id 00ee0016416a9efd73bedf88d1052c7e89279b3c
                                                 Module libqxcb.so with build-id 59f74c026fb16aefc51209d9d62478bc3c359924
                                                 Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
                                                 Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
                                                 Module libdl.so.2 with build-id 2b416df8fd62af5dc5e987b11d99a5d0f772b440
                                                 Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
                                                 Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
                                                 Module libpangoft2-1.0.so.0 with build-id 4a5a975bc9e397294c88738430515901a51c304c
                                                 Module libtiff.so.5 with build-id 5f020a8eb30e12c2e4012d0cb50da9480c7b5d34
                                                 Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
                                                 Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
                                                 Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
                                                 Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
                                                 Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
                                                 Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
                                                 Module libresolv.so.2 with build-id 5c4d9f10ee9ce5e768e5b910e6b430f352a7aae1
                                                 Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
                                                 Module libkrb5support.so.0 with build-id 15f223925ef59dee4379ebbc0fcd14eda9ba81a2
                                                 Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
                                                 Module libk5crypto.so.3 with build-id cc77a742cb62447a53d98285b41558b8acd92866
                                                 Module libkrb5.so.3 with build-id 371cc767dacb17cb42c9c44b88eebbed5ee9a756
                                                 Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
                                                 Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
                                                 Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
                                                 Module libgomp.so.1 with build-id e1c1ddb2ee2191806fc1cd8d7fe15cd28e2f24a8
                                                 Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
                                                 Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
                                                 Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
                                                 Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
                                                 Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
                                                 Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
                                                 Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
                                                 Module libmvec.so.1 with build-id 1b5508a5298c324c58e71364ccc609534f836835
                                                 Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
                                                 Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
                                                 Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
                                                 Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
                                                 Module libpango-1.0.so.0 with build-id a971a5fed3b8b9cf076fe5edb9a9f04ced3da211
                                                 Module libpangocairo-1.0.so.0 with build-id 37f75358f8778498bcc26a1658107953d9495255
                                                 Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
                                                 Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
                                                 Module libpcre2-16.so.0 with build-id 68a5c2d52b45bfa6b1e93d2766e80094f52d9ebf
                                                 Module libb2.so.1 with build-id e39ae9514401c72c0e5cafa1abe0741360c22e87
                                                 Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
                                                 Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
                                                 Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
                                                 Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
                                                 Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
                                                 Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
                                                 Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
                                                 Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
                                                 Module libQt6DBus.so.6 with build-id c91e8565a1a66577ce8d602c495047d7665f960e
                                                 Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
                                                 Module libEGL.so.1 with build-id d4e8037e21617b4005fd99bf9464b3d3f4c3dd35
                                                 Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
                                                 Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
                                                 Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
                                                 Module libgssapi_krb5.so.2 with build-id 292f1ce32161c0ecc4a287bc8494d5d7c420a03f
                                                 Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
                                                 Module libOpenGL.so.0 with build-id 7f93e82811551958e394b5d6854951acb88907bf
                                                 Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
                                                 Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
                                                 Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
                                                 Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
                                                 Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
                                                 Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
                                                 Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
                                                 Module libpthread.so.0 with build-id b966d4b239433c89ca36c0938381e2d92cd47639
                                                 Module libBlocksRuntime.so without build-id.
                                                 Module libsoxr.so.0 with build-id 9e49936ed807c1e52705b88d5d71706fe11d9ed1
                                                 Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
                                                 Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
                                                 Module libva-x11.so.2 with build-id 904eb0006b0ef7a4bcd560b9e016711066e410b8
                                                 Module libva-drm.so.2 with build-id 58df7fa92e899fee0c784db7a9fc68bb107156b6
                                                 Module libssh.so.4 with build-id 8490056688e60790230f9d990c439b181236e9b6
                                                 Module libsrt.so.1.5 with build-id e0257a95fa45af0edf2fe5b684abb7d2c171637d
                                                 Module libgnutls.so.30 with build-id 816201e11cc13561e1272b96a1c7cdb97ae59997
                                                 Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
                                                 Module libbluray.so.2 with build-id 45acd9f36bdb3438c5cb9cc74da71fee2ab2fee0
                                                 Module libmodplug.so.1 with build-id b00dcb12e7d2d5882b4fa414295eba449875dae4
                                                 Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
                                                 Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
                                                 Module libmfx.so.1 with build-id d817dae78e0662e7206a66a41843a66cf0fb0b2f
                                                 Module libva.so.2 with build-id 86d5ae6b358ba79962131649d99e42e1ba669501
                                                 Module libxvidcore.so.4 with build-id 43bc390a7842a7ca3a0302e93442ea561d7f013a
                                                 Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
                                                 Module libx264.so.164 with build-id 1ebb8708f2101bd1c95b701142163133e8dac465
                                                 Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
                                                 Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
                                                 Module libtheoradec.so.1 with build-id 19d321fd5455c7b7611ca9602a804b496124e06f
                                                 Module libtheoraenc.so.1 with build-id cde750f0621140f313e4ef4e5f212e662f24a38b
                                                 Module libSvtAv1Enc.so.1 with build-id d95f643a00090915d6f17c27a84a031c45e819f3
                                                 Module libspeex.so.1 with build-id fd7a3d6df98e453f2513c929f26950060ec8ff48
                                                 Module librav1e.so.0 with build-id 5f8fc2c271f0d96480ab1c71447e038a66aa1c57
                                                 Module libopenjp2.so.7 with build-id 5fa7037f0c932c285735dbcd42365abe6c3abb05
                                                 Module libopencore-amrnb.so.0 with build-id 6690c607f7a7480e92f8690974e7e30575428cb1
                                                 Module libmp3lame.so.0 with build-id 19eef0793322b522143e4f8e602197f1a22be3f4
                                                 Module libgsm.so.1 with build-id 4e1e1890ec2f93119f1a2ecb3312741cbd1ea84c
                                                 Module libaom.so.3 with build-id 2b5b58e482957529f8b14aecb5b2acc21362d04d
                                                 Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
                                                 Module librsvg-2.so.2 with build-id 1cb5dfb747cdb53ba90f504acbe23de518c29ad9
                                                 Module libopencore-amrwb.so.0 with build-id 8d1526cc5d013c2638ad4588e7582e3cc7559ff8
                                                 Module libdav1d.so.6 with build-id a93560a23a7f1def734a3cf54f09eadd7c3c46e9
                                                 Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
                                                 Module libwebp.so.7 with build-id 96dd01a02a3b0b4dae0d744fc3200fd36f1c2148
                                                 Module libwebpmux.so.3 with build-id c987ad73c6cbbfcdb4d632ead20256769852066e
                                                 Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
                                                 Module ld-linux-x86-64.so.2 with build-id 5492655bffbf172ed8a07f285f760ead38f09404
                                                 Module libc.so.6 with build-id 7d4293a9bbe1f068ab7ae807c2d9377395eb5b41
                                                 Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
                                                 Module libm.so.6 with build-id efeea58692a42176201df89f034aa4295a77ce74
                                                 Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
                                                 Module libQt6Core.so.6 with build-id 7102a2aab456a931771a93296118da3ff75a5aa9
                                                 Module libQt6Gui.so.6 with build-id e02e344e24b7e602e16e83d07756783ab8bb6694
                                                 Module libQt6WaylandClient.so.6 with build-id 1f6b546f8dc614396fbe45a217d251f4acba2b33
                                                 Module libQt6Svg.so.6 with build-id 77fcf3332682849c81a575435dec136329905074
                                                 Module libQt6Network.so.6 with build-id 96b81e807682e5779c8d3894935a756105541a00
                                                 Module libQt6Widgets.so.6 with build-id 415f061076f512b27bcccef23d94ab4592a40b58
                                                 Module libQt6OpenGL.so.6 with build-id fe21d42d5316c8723b710e1f9b4d0c54298acb0d
                                                 Module libQt6OpenGLWidgets.so.6 with build-id d76d35c2d2d3e244c087dabd715216dd993e8599
                                                 Module libQt6Core5Compat.so.6 with build-id 3cb36c9deb5023cd789bffd1520f8f7445acc118
                                                 Module libjemalloc.so.2 without build-id.
                                                 Module libxcb-screensaver.so.0 with build-id 4d5a6af1ab98837aa548553f064ca9b57f071972
                                                 Module libxcb-record.so.0 with build-id e1c5afbf22f2133c714d84f20910f0cb176f3886
                                                 Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
                                                 Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
                                                 Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
                                                 Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
                                                 Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
                                                 Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
                                                 Module libsigc-2.0.so.0 with build-id 6b1f9f8e4d7ad41a0a5ac1c861dbab8616010a32
                                                 Module libglibmm-2.4.so.1 with build-id 3241cbe97a421e2a8ca818c39bff023ad2c5147c
                                                 Module libgiomm-2.4.so.1 with build-id 24344f9756d585ddbf54ce979be287a77446dec7
                                                 Module libxxhash.so.0 with build-id b2fe8c87974563e45accc1507deaeb1af7b398a1
                                                 Module libdispatch.so without build-id.
                                                 Module libswresample.so.3 with build-id 1686600b5ddbb9aaa311af78ce22414238d2f5a8
                                                 Module libswscale.so.5 with build-id f50d7b750afc41e5c016596b4ba2a62c063cd4c1
                                                 Module libavutil.so.56 with build-id 4555dce49cfc4adb7e21528ca37a9278f5e49c64
                                                 Module libavformat.so.58 with build-id 6f6c88f09802af71a820a1babb20be28f3125d13
                                                 Module libavcodec.so.58 with build-id ab055f751bda677d280699d828b170add357ee13
                                                 Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
                                                 Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
                                                 Module libXtst.so.6 with build-id 35c7f3daf454834acb724e6bd1664b0a2e9a6494
                                                 Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
                                                 Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
                                                 Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
                                                 Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
                                                 Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
                                                 Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
                                                 Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
                                                 Module libvpx.so.7 with build-id accaef32c955264d758e0348e7da476c5979d711
                                                 Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
                                                 Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
                                                 Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
                                                 Module libpipewire-0.3.so.0 with build-id b91e7a1d107726d205723f63f1671760c3aaaf19
                                                 Module libopenal.so.1 with build-id 1d65d05a177dc2c1b81de25e53b9b04e528655cf
                                                 Module librnnoise.so.0 with build-id 1cf07a38d4180758d2ac38b72dca99e494f1ef3b
                                                 Module libminizip.so.1 with build-id 0785202fbd0261af699c78770961bf72fb3fb817
                                                 Module libhunspell-1.7.so.0 with build-id 7caac66c224c3c73f5dab058dde688c5d05df15d
                                                 Module telegram-desktop with build-id 3dee2f9ab4d2d06cb5d1016434c0df0ce98ad501
                                                 Stack trace of thread 8745:
                                                 #0  0x00007f0726b254dc n/a (libc.so.6 + 0x884dc)
                                                 #1  0x00007f0726ad5998 raise (libc.so.6 + 0x38998)
                                                 #2  0x00007f0726abf53d abort (libc.so.6 + 0x2253d)
                                                 #3  0x00007f0726e27833 _ZN9__gnu_cxx27__verbose_terminate_handlerEv (libstdc++.so.6 + 0x99833)
                                                 #4  0x00007f0726e33cfc _ZN10__cxxabiv111__terminateEPFvvE (libstdc++.so.6 + 0xa5cfc)
                                                 #5  0x00007f0726e33d69 _ZSt9terminatev (libstdc++.so.6 + 0xa5d69)
                                                 #6  0x00007f0726e34aa7 __cxa_pure_virtual (libstdc++.so.6 + 0xa6aa7)
                                                 #7  0x000055a56c4ec65d n/a (telegram-desktop + 0x14ee65d)
                                                 #8  0x00007f072707ebdc n/a (libQt6Core.so.6 + 0xb9bdc)
                                                 #9  0x00007f07270545a4 _ZNK14QMessageLogger7warningEPKcz (libQt6Core.so.6 + 0x8f5a4)
                                                 #10 0x00007f072705f680 n/a (libQt6Core.so.6 + 0x9a680)
                                                 #11 0x00007f072711f24e _ZN14QObjectPrivateD0Ev (libQt6Core.so.6 + 0x15a24e)
                                                 #12 0x000055a56d4d8cdb n/a (telegram-desktop + 0x24dacdb)
                                                 #13 0x000055a56bd5d303 n/a (telegram-desktop + 0xd5f303)
                                                 #14 0x000055a56b84f500 n/a (telegram-desktop + 0x851500)
                                                 #15 0x000055a56bd2cd5f n/a (telegram-desktop + 0xd2ed5f)
                                                 #16 0x000055a56bd36841 n/a (telegram-desktop + 0xd38841)
                                                 #17 0x00007f072910313f n/a (libdispatch.so + 0x3613f)
                                                 #18 0x00007f0726b2378d n/a (libc.so.6 + 0x8678d)
                                                 #19 0x00007f0726ba48e4 __clone (libc.so.6 + 0x1078e4)
                                                 Stack trace of thread 8673:
                                                 #0  0x00007f0726b20346 n/a (libc.so.6 + 0x83346)
                                                 #1  0x00007f0726b22e64 pthread_cond_timedwait (libc.so.6 + 0x85e64)
                                                 #2  0x00007f0728833e74 n/a (libjemalloc.so.2 + 0x2de74)
                                                 #3  0x00007f0728833816 n/a (libjemalloc.so.2 + 0x2d816)
                                                 #4  0x00007f07288336b9 n/a (libjemalloc.so.2 + 0x2d6b9)
                                                 #5  0x00007f0726b2378d n/a (libc.so.6 + 0x8678d)
                                                 #6  0x00007f0726ba48e4 __clone (libc.so.6 + 0x1078e4)
                                                 Stack trace of thread 8695:
                                                 #0  0x00007f0726b97e9f __poll (libc.so.6 + 0xfae9f)
                                                 #1  0x00007f072b5dd281 n/a (libopenal.so.1 + 0x81281)
                                                 #2  0x00007f070f5a046c pa_mainloop_poll (libpulse.so.0 + 0x1d46c)
                                                 #3  0x00007f070f5aa42c pa_mainloop_iterate (libpulse.so.0 + 0x2742c)
                                                 #4  0x00007f070f5aa4e1 pa_mainloop_run (libpulse.so.0 + 0x274e1)
                                                 #5  0x00007f072b5dd412 n/a (libopenal.so.1 + 0x81412)
                                                 #6  0x00007f0726e642f3 execute_native_thread_routine (libstdc++.so.6 + 0xd62f3)
                                                 #7  0x00007f0726b2378d n/a (libc.so.6 + 0x8678d)
                                                 #8  0x00007f0726ba48e4 __clone (libc.so.6 + 0x1078e4)
                                                 Stack trace of thread 8676:
                                                 #1  0x00007f0728b9bf68 n/a (libglib-2.0.so.0 + 0xaaf68)
                                                 #2  0x00007f0728b43392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
                                                 #3  0x00007f0728b433e2 n/a (libglib-2.0.so.0 + 0x523e2)
                                                 #4  0x00007f0728b75405 n/a (libglib-2.0.so.0 + 0x84405)
                                                 Stack trace of thread 8677:
                                                 #3  0x00007f07288335f3 n/a (libjemalloc.so.2 + 0x2d5f3)
                                                 #4  0x00007f0726b2378d n/a (libc.so.6 + 0x8678d)
                                                 #5  0x00007f0726ba48e4 __clone (libc.so.6 + 0x1078e4)
                                                 Stack trace of thread 8744:
                                                 #1  0x00007f0726b2b31b n/a (libc.so.6 + 0x8e31b)
                                                 #2  0x00007f072910499f n/a (libdispatch.so + 0x3799f)
                                                 #3  0x00007f0729103387 n/a (libdispatch.so + 0x36387)
                                                 Stack trace of thread 8683:
                                                 #0  0x00007f0726ba4d06 epoll_wait (libc.so.6 + 0x107d06)
                                                 #1  0x00007f072910b9b8 n/a (libdispatch.so + 0x3e9b8)
                                                 #2  0x00007f0729102ab5 n/a (libdispatch.so + 0x35ab5)
                                                 #3  0x00007f0729102a0b n/a (libdispatch.so + 0x35a0b)
                                                 #4  0x00007f07291030b3 n/a (libdispatch.so + 0x360b3)
                                                 Stack trace of thread 8746:
                                                 Stack trace of thread 8681:
                                                 #3  0x00007f07272f54d2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3304d2)
                                                 #4  0x00007f07270e1014 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x11c014)
                                                 #5  0x00007f07271c1cbe _ZN7QThread4execEv (libQt6Core.so.6 + 0x1fccbe)
                                                 #6  0x00007f071a3feecf n/a (libQt6DBus.so.6 + 0x31ecf)
                                                 #7  0x00007f072722c4f1 n/a (libQt6Core.so.6 + 0x2674f1)
                                                 #8  0x00007f0726b2378d n/a (libc.so.6 + 0x8678d)
                                                 #9  0x00007f0726ba48e4 __clone (libc.so.6 + 0x1078e4)
                                                 Stack trace of thread 8675:
                                                 Stack trace of thread 8678:
                                                 #2  0x00007f0728b451cf g_main_loop_run (libglib-2.0.so.0 + 0x541cf)
                                                 #3  0x00007f0728d97acc n/a (libgio-2.0.so.0 + 0x108acc)
                                                 Stack trace of thread 8679:
                                                 Stack trace of thread 8672:
                                                 #0  0x00007f072b72f497 n/a (libhunspell-1.7.so.0 + 0x2a497)
                                                 #1  0x00007f072b72faa5 _ZN8HunspellD1Ev (libhunspell-1.7.so.0 + 0x2aaa5)
                                                 #2  0x000055a56d3b5d8a n/a (telegram-desktop + 0x23b7d8a)
                                                 #3  0x000055a56b84f5f3 n/a (telegram-desktop + 0x8515f3)
                                                 #4  0x00007f0726ad7e35 n/a (libc.so.6 + 0x3ae35)
                                                 #5  0x00007f0726ad7fb0 exit (libc.so.6 + 0x3afb0)
                                                 #6  0x00007f0726ac02d7 n/a (libc.so.6 + 0x232d7)
                                                 #7  0x00007f0726ac038a __libc_start_main (libc.so.6 + 0x2338a)
                                                 #8  0x000055a56b843a25 n/a (telegram-desktop + 0x845a25)
░░ Subject: Process 8672 (telegram-deskto) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 8672 (telegram-deskto) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Aug 18 12:33:55 devalyus kernel: NVRM: The NVIDIA GeForce 710M GPU installed in this system is
Aug 18 12:34:10 devalyus lightdm[9156]: gkr-pam: unable to locate daemon control file
These are error logs
Thank you for the guidance. I am a beginner in Linux. Thanks u very much!
