Manjaro slow shutdown/reboot - about 1 to 2 min
Hi guys,
I have some issue my manjaro taking a long time to shutdown.
I’m using :
- KDE
- my storage are on BTRFS and NTFS
Here’s my configuration :
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=c165fba9-48bd-4593-b8a0-7b3227d29192 rw rootflags=subvol=@ quiet
    resume=UUID=29b846e9-85e4-48e4-929f-95494190d61f udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASRock model: Z77 Pro3 serial: <superuser required>
    UEFI: American Megatrends v: P1.40 date: 07/05/2012
  Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2831 high: 3483 min/max: 1600/3900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 3417 2: 2727 3: 2561
    4: 2767 5: 2451 6: 2301 7: 3483 8: 2948 bogomips: 54418
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel IvyBridge GT2 [HD Graphics 4000] vendor: ASRock driver: i915
    v: kernel ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0162 class-ID: 0380
  Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nvidia v: 510.60.02
    alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:2182 class-ID: 0300
  Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-1.5:3 chip-ID: 046d:081b class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: i915,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5280x1080 s-dpi: 92 s-size: 1458x301mm (57.40x11.85")
    s-diag: 1489mm (58.61")
  Monitor-1: DP-0 pos: primary,top-center res: 1920x1080 dpi: 92
    size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
  Monitor-2: DVI-D-0 pos: bottom-r res: 1680x1050 hz: 60 dpi: 90
    size: 473x296mm (18.62x11.65") diag: 558mm (21.97") modes: N/A
  Monitor-3: HDMI-0 pos: bottom-l res: 1680x1050 hz: 60 dpi: 90
  OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASRock
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:1aeb class-ID: 0403
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: yes
  Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: ASUSTeK
    driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp2s0 state: dormant mac: <filter>
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr1 state: down mac: <filter>
  Local Storage: total: 1.82 TiB used: 81.84 GiB (4.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZRX-00A8LB0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1A01
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: SSD serial: <filter> rev: 4B6Q scheme: GPT
  ID-1: / raw-size: 223.05 GiB size: 223.05 GiB (100.00%)
    used: 73.89 GiB (33.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
    used: 25.8 MiB (8.6%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 223.05 GiB size: 223.05 GiB (100.00%)
  ID-4: /var/log raw-size: 223.05 GiB size: 223.05 GiB (100.00%)
  ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdb5 maj-min: 8:21
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 41 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
  Processes: 316 Uptime: 6m wakeups: 0 Memory: 15.52 GiB
  used: 6.88 GiB (44.3%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1378 lib: 395 Shell: Zsh
  v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
journalctl -p 3 -b :
mai 07 16:24:12 stickman-pc kernel: usb 2-1.6: device descriptor read/64, error -32
(for this error, i’ve readed that is a common error that happen with an external device that hasn’t be powered off correctly. It seems to be not a problem here)
I had the same issue on both of my kernel “5.4 and 5.15”.
I’m using a dualboot with windows 10 (had no issue with my windows 10 shutdown).
Regards,
Stickman
reboot your pc, and then run this command:
journalctl --boot -1 --no-pager
and check the logs after 'System is powering down.`
here’s the output :
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Timestamp:  10652
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Config_timestamp:  5703
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Window: 35651589
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Root: 484
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Rotation:  "Rotate_0"
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Size ID: 65535
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Size:  5280 1080
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         SizeMM:  1458 301
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper: RRNotify_CrtcChange
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         CRTC:  442
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Mode:  445
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Geometry:  0 15 1680 1050
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Timestamp:  10854
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         CRTC:  440
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Mode:  460
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Geometry:  1680 0 1920 1080
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper: RRScreenChangeNotify
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper: RRNotify_OutputChange
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Timestamp:  11036
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Output:  444
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         CRTC:  441
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Connection:  "Connected"
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Subpixel Order:  0
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xcb.helper:         Output:  458
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: XRandRCrtc  441  m_configTimestamp update 0  =>  5703
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: XRandRCrtc  442  m_configTimestamp update 0  =>  10652
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: XRandRCrtc  440  m_configTimestamp update 0  =>  10854
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: XRandROutput 444 update
         m_connected: 0
         m_crtc XRandRCrtc(0x55a5be4ea1a0)
         CRTC: 441
         MODE: 445
         Connection: 0
         Primary: false
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: Output 444 : connected = true , enabled = true
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: XRandROutput 458 update
         m_connected: 0
         m_crtc XRandRCrtc(0x55a5be4ea380)
         CRTC: 440
         MODE: 460
         Connection: 0
         Primary: true
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: Output 458 : connected = true , enabled = true
         m_connected: 0
         CRTC: 441
         MODE: 445
         Connection: 0
         Primary: false
         m_connected: 0
         CRTC: 440
         MODE: 460
         Connection: 0
         Primary: true
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.30' (uid=1000 pid=1303 comm="/usr/bin/matray --delay")
mai 07 17:17:19 stickman-pc systemd[1127]: Starting Virtual filesystem service...
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.gtk.vfs.Daemon'
mai 07 17:17:19 stickman-pc systemd[1127]: Started Virtual filesystem service.
mai 07 17:17:19 stickman-pc kded5[1188]: Registering ":1.35/StatusNotifierItem" to system tray
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.38' (uid=1000 pid=1303 comm="/usr/bin/matray --delay")
mai 07 17:17:19 stickman-pc systemd[1127]: Starting Accessibility services bus...
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.a11y.Bus'
mai 07 17:17:19 stickman-pc systemd[1127]: Started Accessibility services bus.
mai 07 17:17:19 stickman-pc org_kde_powerdevil[1236]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mai 07 17:17:19 stickman-pc org_kde_powerdevil[1236]: org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the ac
tion is not supported
mai 07 17:17:19 stickman-pc at-spi-bus-launcher[1374]: dbus-daemon[1374]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=1239 comm="/usr/bin/xembedsniproxy")
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.freedesktop.portal.Desktop' unit='xdg-desktop-portal.service' requested by ':1.30' (uid=1000 pid=1303 comm="/usr/bin/ma
tray --delay")
mai 07 17:17:19 stickman-pc systemd[1127]: Starting Portal service...
mai 07 17:17:19 stickman-pc at-spi-bus-launcher[1374]: dbus-daemon[1374]: Successfully activated service 'org.a11y.atspi.Registry'
mai 07 17:17:19 stickman-pc at-spi-bus-launcher[1376]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
mai 07 17:17:19 stickman-pc org_kde_powerdevil[1236]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.freedesktop.portal.Documents' unit='xdg-document-portal.service' requested by ':1.41' (uid=1000 pid=1377 comm="/usr/lib
/xdg-desktop-portal")
mai 07 17:17:19 stickman-pc systemd[1127]: Starting flatpak document portal service...
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.freedesktop.impl.portal.PermissionStore' unit='xdg-permission-store.service' requested by ':1.43' (uid=1000 pid=1384 co
mm="/usr/lib/xdg-document-portal")
mai 07 17:17:19 stickman-pc systemd[1127]: Starting sandboxed app permission store...
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
mai 07 17:17:19 stickman-pc systemd[1127]: Started sandboxed app permission store.
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.portal.Documents'
mai 07 17:17:19 stickman-pc systemd[1127]: Started flatpak document portal service.
mai 07 17:17:19 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gnome' unit='xdg-desktop-portal-gnome.service' requested by ':1.41' (uid=1000 pid=1377
comm="/usr/lib/xdg-desktop-portal")
mai 07 17:17:19 stickman-pc systemd[1127]: Starting Portal service (GNOME implementation)...
mai 07 17:17:19 stickman-pc kded5[1188]: Registering ":1.44/StatusNotifierItem" to system tray
mai 07 17:17:19 stickman-pc kded5[1188]: Registering ":1.37/StatusNotifierItem" to system tray
mai 07 17:17:19 stickman-pc plasmashell[1240]: kf.plasma.quick: Applet preload policy set to 1
mai 07 17:17:19 stickman-pc kscreen_backend_launcher[1250]: kscreen.xrandr: Emitting configChanged()
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9237] dhcp4 (enp5s0): state changed new lease, address=192.168.0.29
mai 07 17:17:19 stickman-pc avahi-daemon[819]: Joining mDNS multicast group on interface enp5s0.IPv4 with address 192.168.0.29.
mai 07 17:17:19 stickman-pc avahi-daemon[819]: New relevant interface enp5s0.IPv4 for mDNS.
mai 07 17:17:19 stickman-pc avahi-daemon[819]: Registering new address record for 192.168.0.29 on enp5s0.IPv4.
mai 07 17:17:19 stickman-pc audit: BPF prog-id=21 op=LOAD
mai 07 17:17:19 stickman-pc audit[912]: SYSCALL arch=c000003e syscall=321 success=yes exit=28 a0=5 a1=7fff1b33be90 a2=80 a3=7fff1b33be90 items=0 ppid=1 pid=912 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=
(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
mai 07 17:17:19 stickman-pc kernel: audit: type=1334 audit(1651936639.919:106): prog-id=21 op=LOAD
mai 07 17:17:19 stickman-pc kernel: audit: type=1300 audit(1651936639.919:106): arch=c000003e syscall=321 success=yes exit=28 a0=5 a1=7fff1b33be90 a2=80 a3=7fff1b33be90 items=0 ppid=1 pid=912 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fs
uid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
mai 07 17:17:19 stickman-pc kernel: audit: type=1327 audit(1651936639.919:106): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
mai 07 17:17:19 stickman-pc audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9262] device (enp5s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9277] device (enp5s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9279] device (enp5s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9283] manager: NetworkManager state is now CONNECTED_LOCAL
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9287] manager: NetworkManager state is now CONNECTED_SITE
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9287] policy: set 'Connexion filaire 1' (enp5s0) as default for IPv4 routing and DNS
mai 07 17:17:19 stickman-pc NetworkManager[912]: <info>  [1651936639.9289] policy: set 'Connexion filaire 1' (enp5s0) as default for IPv6 routing and DNS
mai 07 17:17:19 stickman-pc dbus-daemon[821]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=912 comm="/usr/bin/NetworkManager --no-da
emon")
mai 07 17:17:19 stickman-pc dbus-daemon[821]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
mai 07 17:17:19 stickman-pc dnsmasq[1102]: reading /etc/resolv.conf
mai 07 17:17:19 stickman-pc dnsmasq[1102]: using nameserver 109.88.203.3#53
mai 07 17:17:19 stickman-pc dnsmasq[1102]: using nameserver 62.197.111.140#53
mai 07 17:17:19 stickman-pc dnsmasq[1102]: using nameserver 2a02:2788:fff0:7::3#53
mai 07 17:17:19 stickman-pc dnsmasq[1102]: using nameserver 2a02:2788:fff0:5::140#53
mai 07 17:17:20 stickman-pc NetworkManager[912]: <info>  [1651936640.0250] device (enp5s0): Activation: successful, device activated.
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
mai 07 17:17:20 stickman-pc systemd[1127]: Started Portal service (GNOME implementation).
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Supervising 1 threads of 1 processes of 1 users.
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.kde' unit='plasma-xdg-desktop-portal-kde.service' requested by ':1.41' (uid=1000 pid=13
77 comm="/usr/lib/xdg-desktop-portal")
mai 07 17:17:20 stickman-pc systemd[1127]: Starting Xdg Desktop Portal For KDE...
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.kde.ksystemstats' unit='plasma-ksystemstats.service' requested by ':1.26' (uid=1000 pid=1240 comm="/usr/bin/plasmashell
mai 07 17:17:20 stickman-pc systemd[1127]: Starting Track hardware statistics...
mai 07 17:17:20 stickman-pc NetworkManager[912]: <info>  [1651936640.1204] manager: NetworkManager state is now CONNECTED_GLOBAL
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_cpu" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_cpu.so"
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_disk" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_disk.so"
mai 07 17:17:20 stickman-pc NetworkManager[912]: <info>  [1651936640.2209] manager: startup complete
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.impl.portal.desktop.kde'
mai 07 17:17:20 stickman-pc systemd[1127]: Started Xdg Desktop Portal For KDE.
mai 07 17:17:20 stickman-pc xdg-desktop-portal-kde[1428]: xdp-kde: Desktop portal registered successfully
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gtk' unit='xdg-desktop-portal-gtk.service' requested by ':1.41' (uid=1000 pid=1377 comm
mai 07 17:17:20 stickman-pc systemd[1127]: Starting Portal service (GTK/GNOME implementation)...
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Found unsupported GPU: /sys/devices/pci0000:00/0000:00:02.0
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_gpu" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_gpu.so"
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_lmsensors" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_lmsensors.so"
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_memory" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_memory.so"
mai 07 17:17:20 stickman-pc audit[912]: USYS_CONFIG pid=912 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="enp5s0" ifindex=2 args=500 pid=1429 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? t
erminal=? res=success'
mai 07 17:17:20 stickman-pc NetworkManager[912]: <info>  [1651936640.3798] audit: op="statistics" interface="enp5s0" ifindex=2 args="500" pid=1429 uid=1000 result="success"
mai 07 17:17:20 stickman-pc kernel: audit: type=1111 audit(1651936640.375:107): pid=912 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="enp5s0" ifindex=2 args=500 pid=1429 uid=1000 result=success exe="/usr/bin/Network
Manager" hostname=? addr=? terminal=? res=success'
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
mai 07 17:17:20 stickman-pc systemd[1127]: Started Portal service (GTK/GNOME implementation).
mai 07 17:17:20 stickman-pc audit[912]: USYS_CONFIG pid=912 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="wlp2s0" ifindex=3 args=500 pid=1429 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? t
mai 07 17:17:20 stickman-pc NetworkManager[912]: <info>  [1651936640.3967] audit: op="statistics" interface="wlp2s0" ifindex=3 args="500" pid=1429 uid=1000 result="success"
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_network" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_network.so"
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_osinfo" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_osinfo.so"
mai 07 17:17:20 stickman-pc ksystemstats[1429]: Loaded plugin "ksystemstats_plugin_power" from file "/usr/lib/qt/plugins/ksystemstats/ksystemstats_plugin_power.so"
mai 07 17:17:20 stickman-pc kernel: audit: type=1111 audit(1651936640.392:108): pid=912 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="wlp2s0" ifindex=3 args=500 pid=1429 uid=1000 result=success exe="/usr/bin/Network
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.kde.ksystemstats'
mai 07 17:17:20 stickman-pc systemd[1127]: Started Track hardware statistics.
mai 07 17:17:20 stickman-pc systemd[1127]: Started PipeWire Multimedia Service.
mai 07 17:17:20 stickman-pc NetworkManager[912]: <info>  [1651936640.4153] audit: op="statistics" interface="wlp2s0" ifindex=3 args="500" pid=1429 uid=1000 result="success"
mai 07 17:17:20 stickman-pc systemd[1127]: Started PipeWire Media Session Manager.
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Successfully made thread 1446 of process 1446 owned by '1000' high priority at nice level -11.
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Supervising 2 threads of 2 processes of 1 users.
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Successfully made thread 1448 of process 1447 owned by '1000' RT at priority 20.
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Supervising 3 threads of 3 processes of 1 users.
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Successfully made thread 1449 of process 1446 owned by '1000' RT at priority 20.
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Supervising 4 threads of 3 processes of 1 users.
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating service name='org.freedesktop.secrets' requested by ':1.41' (uid=1000 pid=1377 comm="/usr/lib/xdg-desktop-portal")
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.secrets'
mai 07 17:17:20 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.portal.Desktop'
mai 07 17:17:20 stickman-pc systemd[1127]: Started Portal service.
mai 07 17:17:20 stickman-pc plasmashell[1240]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
mai 07 17:17:20 stickman-pc plasmashell[1240]: trying to show an empty dialog
mai 07 17:17:20 stickman-pc plasmashell[1240]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:118:19: QML Loader: Binding loop detected for property "height"
mai 07 17:17:20 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
mai 07 17:17:20 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:41: TypeError: Cannot read property 'length' of undefined
mai 07 17:17:20 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/FullRepresentation.qml:22:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
mai 07 17:17:20 stickman-pc plasmashell[1240]: qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
mai 07 17:17:20 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/FullRepresentation.qml:23:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
mai 07 17:17:20 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
mai 07 17:17:20 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml:54:9: Unable to assign [undefined] to int
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Successfully made thread 1468 of process 1256 owned by '1000' RT at priority 5.
mai 07 17:17:20 stickman-pc rtkit-daemon[1273]: Supervising 5 threads of 3 processes of 1 users.
mai 07 17:17:21 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.47' (uid=1000 pid=1399 comm="pamac checkupdates -q --re
fresh-tmp-files-dbs --us")
mai 07 17:17:21 stickman-pc systemd[1127]: Starting Virtual filesystem metadata service...
mai 07 17:17:21 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.gtk.vfs.Metadata'
mai 07 17:17:21 stickman-pc systemd[1127]: Started Virtual filesystem metadata service.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Supervising 5 threads of 3 processes of 1 users.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Successfully made thread 1478 of process 1256 owned by '1000' RT at priority 5.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Supervising 6 threads of 3 processes of 1 users.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Successfully made thread 1479 of process 1256 owned by '1000' RT at priority 5.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Supervising 7 threads of 3 processes of 1 users.
mai 07 17:17:21 stickman-pc pulseaudio[1256]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
mai 07 17:17:21 stickman-pc systemd[1127]: Started Sound Service.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Successfully made thread 1485 of process 1256 owned by '1000' RT at priority 5.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Supervising 8 threads of 3 processes of 1 users.
mai 07 17:17:21 stickman-pc rtkit-daemon[1273]: Successfully made thread 1486 of process 1256 owned by '1000' RT at priority 5.
mai 07 17:17:21 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
mai 07 17:17:21 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml:54:9: Unable to assign [undefined] to int
mai 07 17:17:22 stickman-pc plasmashell[1240]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
mai 07 17:17:22 stickman-pc plasmashell[1240]: Entry is not valid "org.kde.elisa.desktop" QSharedPointer(0x5568df619f00)
mai 07 17:17:22 stickman-pc plasmashell[1240]: Entry is not valid "org.kde.elisa.desktop" QSharedPointer(0x5568de286520)
mai 07 17:17:22 stickman-pc plasmashell[1240]: libpng warning: iCCP: known incorrect sRGB profile
mai 07 17:17:22 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:531:9: QML Label: Binding loop detected for property "height"
mai 07 17:17:22 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:486:13: QML Label: Binding loop detected for property "height"
mai 07 17:17:22 stickman-pc plasmashell[1240]: trying to show an empty dialog
mai 07 17:17:22 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
mai 07 17:17:22 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
mai 07 17:17:22 stickman-pc plasmashell[1240]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml:54:9: Unable to assign [undefined] to int
mai 07 17:17:22 stickman-pc plasmashell[1240]: qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
mai 07 17:17:22 stickman-pc plasmashell[1240]: Error: cannot change the containment to AppletsLayout
mai 07 17:17:22 stickman-pc plasmashell[1240]: Both point size and pixel size set. Using pixel size.
mai 07 17:17:22 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:54:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property
"minimumWidth"
mai 07 17:17:22 stickman-pc plasmashell[1240]: Plasma Shell startup completed
mai 07 17:17:22 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:553:5: QML Label: Binding loop detected for property "height"
mai 07 17:17:22 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2052, resource id: 4194348, major code: 18 (ChangeProperty), minor code: 0
mai 07 17:17:22 stickman-pc plasmashell[1240]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.no
tifications/contents/ui/NotificationHeader.qml"
mai 07 17:17:22 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.freedesktop.Notifications'
mai 07 17:17:23 stickman-pc kded5[1188]: Registering "org.kde.StatusNotifierHost-1240" as system tray
mai 07 17:17:23 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
mai 07 17:17:23 stickman-pc plasmashell[1240]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
mai 07 17:17:23 stickman-pc plasmashell[1240]: trying to show an empty dialog
mai 07 17:17:23 stickman-pc plasmashell[1240]: Error: cannot change the containment to AppletsLayout
mai 07 17:17:23 stickman-pc plasmashell[1240]: Both point size and pixel size set. Using pixel size.
mai 07 17:17:23 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
mai 07 17:17:23 stickman-pc nexposeconsole.rc[924]: Starting NeXpose security console: nexposeconsole
mai 07 17:17:23 stickman-pc systemd[1]: Started Security Console Service.
mai 07 17:17:23 stickman-pc systemd[1]: Reached target Multi-User System.
mai 07 17:17:23 stickman-pc systemd[1]: Reached target Graphical Interface.
mai 07 17:17:23 stickman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nexposeconsole comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:17:23 stickman-pc systemd[1]: Starting TLP system startup/shutdown...
mai 07 17:17:23 stickman-pc kernel: kauditd_printk_skb: 1 callbacks suppressed
mai 07 17:17:23 stickman-pc kernel: audit: type=1130 audit(1651936643.612:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nexposeconsole comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:17:23 stickman-pc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mai 07 17:17:23 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:17:23 stickman-pc kernel: audit: type=1131 audit(1651936643.779:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? re
s=success'
mai 07 17:17:24 stickman-pc tlp[1570]: Applying power save settings...done.
mai 07 17:17:24 stickman-pc tlp[1570]: Setting battery charge thresholds...done.
mai 07 17:17:24 stickman-pc systemd[1]: Finished TLP system startup/shutdown.
mai 07 17:17:24 stickman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:17:24 stickman-pc systemd[1]: Startup finished in 2.908s (kernel) + 13.099s (userspace) = 16.007s.
mai 07 17:17:24 stickman-pc kernel: audit: type=1130 audit(1651936644.125:112): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:17:25 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
mai 07 17:17:25 stickman-pc plasmashell[1240]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
mai 07 17:17:25 stickman-pc kded5[1188]: Registering ":1.30/org/ayatana/NotificationItem/matray" to system tray
mai 07 17:17:27 stickman-pc plasmashell[1240]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
mai 07 17:17:27 stickman-pc systemd[1127]: Started Chromium - Navigateur Web.
mai 07 17:17:28 stickman-pc kded5[1188]: Registering ":1.61/org/ayatana/NotificationItem/dropbox_client_1549" to system tray
mai 07 17:17:28 stickman-pc dbus-daemon[821]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.62' (uid=1000 pid=1927 comm="/usr/lib/chromium/chromium --enable-crashpad")
mai 07 17:17:28 stickman-pc dbus-daemon[821]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Unit dbus-org.bluez.service not found.
mai 07 17:17:28 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Activating service name='org.kde.kwalletd5' requested by ':1.64' (uid=1000 pid=1927 comm="/usr/lib/chromium/chromium --enable-crashpad")
mai 07 17:17:28 stickman-pc kwalletd5[2003]: kf.wallet.kwalletd: Lacking a socket, pipe: 0 env: 0
mai 07 17:17:28 stickman-pc dbus-daemon[1149]: [session uid=1000 pid=1149] Successfully activated service 'org.kde.kwalletd5'
mai 07 17:17:28 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4657, resource id: 83886085, major code: 18 (ChangeProperty), minor code: 0
mai 07 17:17:28 stickman-pc kwalletd5[2019]: kf.wallet.kwalletd: Lacking a socket, pipe: 0 env: 0
mai 07 17:17:28 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4689, resource id: 83886085, major code: 18 (ChangeProperty), minor code: 0
mai 07 17:17:30 stickman-pc baloo_file_extractor[2194]: kf.baloo: Found "/home/stickman/Dropbox/.dropbox.cache" in the ContentIndexingDB, although it should be skipped
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5607, resource id: 88080390, major code: 18 (ChangeProperty), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5620, resource id: 41943155, major code: 19 (DeleteProperty), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5623, resource id: 41943155, major code: 19 (DeleteProperty), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5624, resource id: 41943155, major code: 18 (ChangeProperty), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5625, resource id: 41943155, major code: 19 (DeleteProperty), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5626, resource id: 41943155, major code: 19 (DeleteProperty), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5627, resource id: 41943155, major code: 19 (DeleteProperty), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5628, resource id: 41943155, major code: 7 (ReparentWindow), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5629, resource id: 41943155, major code: 6 (ChangeSaveSet), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5630, resource id: 41943155, major code: 2 (ChangeWindowAttributes), minor code: 0
mai 07 17:17:30 stickman-pc kwin_x11[1191]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5631, resource id: 41943155, major code: 10 (UnmapWindow), minor code: 0
mai 07 17:17:39 stickman-pc systemd[1127]: Started Konsole - Terminal.
mai 07 17:17:39 stickman-pc kwin_x11[1191]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
mai 07 17:17:50 stickman-pc systemd[1]: systemd-hostnamed.service: Deactivated successfully.
mai 07 17:17:50 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:17:50 stickman-pc kernel: audit: type=1131 audit(1651936670.422:113): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes
s'
mai 07 17:17:50 stickman-pc xdg-desktop-portal-kde[1428]: xdp-kde-background: GetAppState called: no parameters
mai 07 17:17:50 stickman-pc audit: BPF prog-id=0 op=UNLOAD
mai 07 17:17:50 stickman-pc kernel: audit: type=1334 audit(1651936670.515:114): prog-id=0 op=UNLOAD
mai 07 17:17:50 stickman-pc kernel: audit: type=1334 audit(1651936670.515:115): prog-id=0 op=UNLOAD
mai 07 17:17:50 stickman-pc kernel: audit: type=1334 audit(1651936670.515:116): prog-id=0 op=UNLOAD
mai 07 17:18:02 stickman-pc systemd-logind[823]: System is rebooting.
mai 07 17:18:02 stickman-pc polkitd[822]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.30, object path /org/kde/PolicyKit1/AuthenticationAgent, locale fr_FR.UTF-8) (disconnected from bus)
mai 07 17:18:02 stickman-pc sddm[928]: Authentication error: "Process crashed"
mai 07 17:18:02 stickman-pc sddm[928]: Auth: sddm-helper crashed (exit code 15)
mai 07 17:18:02 stickman-pc sddm[928]: Auth: sddm-helper exited with 15
mai 07 17:18:02 stickman-pc sddm[928]: Display server stopping...
mai 07 17:18:02 stickman-pc kglobalaccel5[1224]: The X11 connection broke (error 1). Did the X11 server die?
mai 07 17:18:02 stickman-pc kded5[1188]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
mai 07 17:18:02 stickman-pc systemd[1127]: plasma-kglobalaccel.service: Main process exited, code=exited, status=1/FAILURE
mai 07 17:18:02 stickman-pc systemd[1127]: plasma-kglobalaccel.service: Failed with result 'exit-code'.
mai 07 17:18:02 stickman-pc kscreen_backend_launcher[1250]: The X11 connection broke (error 1). Did the X11 server die?
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Session 1 of User stickman...
mai 07 17:18:02 stickman-pc systemd[1]: Removed slice Slice /system/getty.
mai 07 17:18:02 stickman-pc systemd[1]: Removed slice Slice /system/modprobe.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped target Graphical Interface.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped target Smart Card.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped target Sound Card.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped target Timer Units.
mai 07 17:18:02 stickman-pc systemd[1]: logrotate.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Daily rotation of log files.
mai 07 17:18:02 stickman-pc systemd[1]: man-db.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Daily man-db regeneration.
mai 07 17:18:02 stickman-pc systemd[1]: pamac-cleancache.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Monthly clean packages cache.
mai 07 17:18:02 stickman-pc systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Generate mirrorlist weekly.
mai 07 17:18:02 stickman-pc systemd[1]: shadow.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Daily verification of password and group files.
mai 07 17:18:02 stickman-pc systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Daily Cleanup of Temporary Directories.
mai 07 17:18:02 stickman-pc systemd[1]: updatedb.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Daily locate database update.
mai 07 17:18:02 stickman-pc systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Closed LVM2 poll daemon socket.
mai 07 17:18:02 stickman-pc systemd[1]: systemd-coredump.socket: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Closed Process Core Dump Socket.
mai 07 17:18:02 stickman-pc systemd[1]: systemd-rfkill.socket: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
mai 07 17:18:02 stickman-pc pulseaudio[1256]: ICE I/O error handler called
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Save/Restore Sound Card State...
mai 07 17:18:02 stickman-pc systemd[1]: Starting Generate shutdown-ramfs...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Simple Desktop Display Manager...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Load/Save Random Seed...
mai 07 17:18:02 stickman-pc systemd[1127]: plasma-kscreen.service: Main process exited, code=exited, status=1/FAILURE
mai 07 17:18:02 stickman-pc systemd[1127]: plasma-kscreen.service: Failed with result 'exit-code'.
mai 07 17:18:02 stickman-pc systemd[1]: Stopping TLP system startup/shutdown...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Disk Manager...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Daemon for power management...
mai 07 17:18:02 stickman-pc systemd[1]: rtkit-daemon.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc udisksd[1263]: udisks daemon version 2.9.4 exiting
mai 07 17:18:02 stickman-pc kernel: audit: type=1131 audit(1651936682.142:117): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc systemd[1]: alsa-restore.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc at-spi-bus-launcher[1376]: X connection to :0 broken (explicit kill or server shutdown).
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Save/Restore Sound Card State.
mai 07 17:18:02 stickman-pc kernel: audit: type=1131 audit(1651936682.145:118): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc systemd[1]: systemd-random-seed.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Load/Save Random Seed.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc at-spi-bus-launcher[1374]: dbus-daemon[1374]: Activating service name='org.a11y.atspi.Registry' requested by ':1.1' (uid=1000 pid=1265 comm="/usr/lib/kactivitymanagerd")
mai 07 17:18:02 stickman-pc systemd-logind[823]: Session 1 logged out. Waiting for processes to exit.
mai 07 17:18:02 stickman-pc systemd[1]: udisks2.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1127]: xdg-desktop-portal-gnome.service: Main process exited, code=exited, status=1/FAILURE
mai 07 17:18:02 stickman-pc systemd[1127]: xdg-desktop-portal-gnome.service: Failed with result 'exit-code'.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Disk Manager.
mai 07 17:18:02 stickman-pc kernel: audit: type=1131 audit(1651936682.149:119): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succ
ess'
mai 07 17:18:02 stickman-pc kernel: audit: type=1131 audit(1651936682.149:120): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc pulseaudio[1256]: X11 I/O error handler called
mai 07 17:18:02 stickman-pc audit[1256]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=2 pid=1256 comm="pulseaudio" exe="/usr/bin/pulseaudio" sig=11 res=1
mai 07 17:18:02 stickman-pc pulseaudio[1256]: X11 I/O error exit handler called, preparing to tear down X11 modules
mai 07 17:18:02 stickman-pc kernel: pulseaudio[1256]: segfault at 557d34bce992 ip 00007f376db8a467 sp 00007fff8ce64660 error 4 in libICE.so.6.3.0[7f376db85000+e000]
mai 07 17:18:02 stickman-pc kernel: Code: 00 00 00 41 54 48 8d 35 aa 93 00 00 31 c0 55 48 89 fd 48 83 ec 08 8b 57 1c bf 02 00 00 00 e8 e0 e0 ff ff 48 8b 45 00 48 89 ef <ff> 90 80 00 00 00 48 89 ef 41 89 c4 ff 15 bf e9 00 00 48 83 c4 08
mai 07 17:18:02 stickman-pc kernel: audit: type=1701 audit(1651936682.152:121): auid=1000 uid=1000 gid=1001 ses=2 pid=1256 comm="pulseaudio" exe="/usr/bin/pulseaudio" sig=11 res=1
mai 07 17:18:02 stickman-pc kernel: audit: type=1131 audit(1651936682.162:122): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc kded5[1188]: The X11 connection broke: I/O error (code 1)
mai 07 17:18:02 stickman-pc systemd[1]: upower.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Daemon for power management.
mai 07 17:18:02 stickman-pc systemd-coredump[2370]: Failed to connect to coredump service: Connection refused
mai 07 17:18:02 stickman-pc systemd[1127]: xdg-desktop-portal-gtk.service: Main process exited, code=exited, status=1/FAILURE
mai 07 17:18:02 stickman-pc systemd[1127]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
mai 07 17:18:02 stickman-pc audit: BPF prog-id=0 op=UNLOAD
mai 07 17:18:02 stickman-pc kernel: audit: type=1334 audit(1651936682.185:123): prog-id=0 op=UNLOAD
mai 07 17:18:02 stickman-pc kernel: audit: type=1334 audit(1651936682.185:124): prog-id=0 op=UNLOAD
mai 07 17:18:02 stickman-pc systemd[1127]: pulseaudio.service: Main process exited, code=dumped, status=11/SEGV
mai 07 17:18:02 stickman-pc systemd[1127]: pulseaudio.service: Killing process 1482 (gmain) with signal SIGKILL.
mai 07 17:18:02 stickman-pc systemd[1127]: pulseaudio.service: Killing process 1483 (dconf worker) with signal SIGKILL.
mai 07 17:18:02 stickman-pc systemd[1127]: pulseaudio.service: Failed with result 'core-dump'.
mai 07 17:18:02 stickman-pc mkinitcpio[2357]: ==> Starting build: none
mai 07 17:18:02 stickman-pc mkinitcpio[2357]:   -> Running build hook: [sd-shutdown]
mai 07 17:18:02 stickman-pc systemd[1]: tlp.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped TLP system startup/shutdown.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped target Multi-User System.
mai 07 17:18:02 stickman-pc systemd[1]: pkgfile-update.timer: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped pkgfile database update timer.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped target Login Prompts.
mai 07 17:18:02 stickman-pc kernel: audit: type=1131 audit(1651936682.252:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc ModemManager[915]: <info>  caught signal, shutting down...
mai 07 17:18:02 stickman-pc postgres[946]: 2022-05-07 17:18:02.260 CEST [946] LOG:  a reçu une demande d'arrêt rapide
mai 07 17:18:02 stickman-pc postgres[946]: 2022-05-07 17:18:02.262 CEST [946] LOG:  annulation des transactions actives
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Modem Manager...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Periodic Command Scheduler...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Virtualization daemon...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Security Console Service...
mai 07 17:18:02 stickman-pc systemd[1]: Stopping PostgreSQL database server...
mai 07 17:18:02 stickman-pc postgres[946]: 2022-05-07 17:18:02.265 CEST [946] LOG:  processus en tâche de fond « logical replication launcher » (PID 981) a quitté avec le code de sortie 1
mai 07 17:18:02 stickman-pc systemd[1]: libvirtd.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: libvirtd.service: Unit process 1102 (dnsmasq) remains running after unit stopped.
mai 07 17:18:02 stickman-pc systemd[1]: libvirtd.service: Unit process 1103 (dnsmasq) remains running after unit stopped.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Virtualization daemon.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc postgres[976]: 2022-05-07 17:18:02.267 CEST [976] LOG:  arrêt en cours
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Virtual Machine and Container Registration Service...
mai 07 17:18:02 stickman-pc avahi-daemon[819]: Got SIGTERM, quitting.
mai 07 17:18:02 stickman-pc avahi-daemon[819]: Leaving mDNS multicast group on interface virbr1.IPv4 with address 192.168.100.1.
mai 07 17:18:02 stickman-pc avahi-daemon[819]: Leaving mDNS multicast group on interface enp5s0.IPv6 with address 2a02:2788:7d4:66b:163:27:9a78:5e73.
mai 07 17:18:02 stickman-pc avahi-daemon[819]: Leaving mDNS multicast group on interface enp5s0.IPv4 with address 192.168.0.29.
mai 07 17:18:02 stickman-pc avahi-daemon[819]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
mai 07 17:18:02 stickman-pc avahi-daemon[819]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
mai 07 17:18:02 stickman-pc systemd[1]: systemd-machined.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Virtual Machine and Container Registration Service.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-machined comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc nexposeconsole.rc[2426]: Shutting down NeXpose security console: Waiting for Nexpose console to exit
mai 07 17:18:02 stickman-pc crond[820]: (CRON) INFO (Shutting down)
mai 07 17:18:02 stickman-pc avahi-daemon[819]: avahi-daemon 0.8 exiting.
mai 07 17:18:02 stickman-pc systemd[1]: cronie.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Periodic Command Scheduler.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc systemd[1]: avahi-daemon.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc postgres[946]: 2022-05-07 17:18:02.289 CEST [946] LOG:  le système de base de données est arrêté
mai 07 17:18:02 stickman-pc systemd[1]: session-1.scope: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Session 1 of User stickman.
mai 07 17:18:02 stickman-pc systemd[1]: session-1.scope: Consumed 26.517s CPU time.
mai 07 17:18:02 stickman-pc systemd[1]: Stopping User Manager for UID 1000...
mai 07 17:18:02 stickman-pc systemd-logind[823]: Removed session 1.
mai 07 17:18:02 stickman-pc systemd[1127]: Activating special unit Exit the Session...
mai 07 17:18:02 stickman-pc systemd[1127]: pulseaudio.service: Stop job pending for unit, skipping automatic restart.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Chromium - Navigateur Web...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Konsole - Terminal...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped target Main User Target.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Accessibility services bus...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping D-Bus User Message Bus...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping User preferences database...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Virtual filesystem service...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Virtual filesystem metadata service...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Bluetooth OBEX service...
mai 07 17:18:02 stickman-pc kactivitymanagerd[1265]: The X11 connection broke (error 1). Did the X11 server die?
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping PipeWire Media Session Manager...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping KActivityManager Activity manager Service...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Track hardware statistics...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Xdg Desktop Portal For KDE...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Sound Service.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping Portal service...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping flatpak document portal service...
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping sandboxed app permission store...
mai 07 17:18:02 stickman-pc NetworkManager[912]: <info>  [1651936682.2973] modem-manager: ModemManager no longer available
mai 07 17:18:02 stickman-pc ModemManager[915]: <info>  ModemManager is shut down
mai 07 17:18:02 stickman-pc obexd[1248]: Terminating
mai 07 17:18:02 stickman-pc systemd[1]: ModemManager.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Modem Manager.
mai 07 17:18:02 stickman-pc systemd[1]: Stopping Authorization Manager...
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Unmounted /run/user/1000/doc.
mai 07 17:18:02 stickman-pc systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Unmounted /run/user/1000/gvfs.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped D-Bus User Message Bus.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped User preferences database.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Bluetooth OBEX service.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Virtual filesystem service.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped flatpak document portal service.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped sandboxed app permission store.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Xdg Desktop Portal For KDE.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Virtual filesystem metadata service.
mai 07 17:18:02 stickman-pc systemd[1]: postgresql.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped PostgreSQL database server.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=postgresql comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped PipeWire Media Session Manager.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopping PipeWire Multimedia Service...
mai 07 17:18:02 stickman-pc pipewire[1446]: Asked to handle disabled watch: 0x55b7f0774790 19
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped PipeWire Multimedia Service.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped KActivityManager Activity manager Service.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Portal service.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Chromium - Navigateur Web.
mai 07 17:18:02 stickman-pc systemd[1127]: app-chromium-1463d86238ef4f78b7663ddd067154d0.scope: Consumed 8.738s CPU time.
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Konsole - Terminal.
mai 07 17:18:02 stickman-pc systemd[1127]: app-org.kde.konsole-2a22f4e4166a4f739cba988cc45fca6e.scope: Consumed 1.020s CPU time.
mai 07 17:18:02 stickman-pc systemd[1127]: Removed slice User Core Session Slice.
mai 07 17:18:02 stickman-pc systemd[1127]: session.slice: Consumed 1.193s CPU time.
mai 07 17:18:02 stickman-pc systemd[1]: polkit.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Stopped Authorization Manager.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc mkinitcpio[2357]: ==> Build complete.
mai 07 17:18:02 stickman-pc systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
mai 07 17:18:02 stickman-pc systemd[1]: Finished Generate shutdown-ramfs.
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:02 stickman-pc systemd[1127]: Stopped Accessibility services bus.
mai 07 17:18:02 stickman-pc sddm[928]: Display server stopped.
mai 07 17:18:02 stickman-pc sddm[928]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
mai 07 17:18:02 stickman-pc sddm[928]: Removing display ":0" ...
mai 07 17:18:02 stickman-pc sddm[928]: Adding new display on vt 1 ...
mai 07 17:18:02 stickman-pc sddm[928]: Loading theme configuration from ""
mai 07 17:18:02 stickman-pc sddm[928]: Display server starting...
mai 07 17:18:02 stickman-pc sddm[928]: Adding cookie to "/var/run/sddm/{1824aae0-8d85-40ff-b766-800480d24939}"
mai 07 17:18:02 stickman-pc sddm[928]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{1824aae0-8d85-40ff-b766-800480d24939} -noreset -displayfd 18
mai 07 17:18:03 stickman-pc systemd[1127]: Stopped Track hardware statistics.
mai 07 17:18:03 stickman-pc systemd[1127]: Removed slice User Background Tasks Slice.
mai 07 17:18:03 stickman-pc systemd[1127]: background.slice: Consumed 1.094s CPU time.
mai 07 17:18:03 stickman-pc systemd[1127]: Stopped target Basic System.
mai 07 17:18:03 stickman-pc systemd[1127]: Stopped target Paths.
mai 07 17:18:03 stickman-pc systemd[1127]: Stopped target Sockets.
mai 07 17:18:03 stickman-pc systemd[1127]: Stopped target Timers.
mai 07 17:18:03 stickman-pc systemd[1127]: Closed D-Bus User Message Bus Socket.
mai 07 17:18:03 stickman-pc systemd[1127]: Closed GnuPG network certificate management daemon.
mai 07 17:18:03 stickman-pc systemd[1127]: Closed GCR ssh-agent wrapper.
mai 07 17:18:03 stickman-pc systemd[1127]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
mai 07 17:18:03 stickman-pc systemd[1127]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
mai 07 17:18:03 stickman-pc systemd[1127]: Closed GnuPG cryptographic agent (ssh-agent emulation).
mai 07 17:18:03 stickman-pc systemd[1127]: Closed GnuPG cryptographic agent and passphrase cache.
mai 07 17:18:03 stickman-pc systemd[1127]: Closed p11-kit server.
mai 07 17:18:03 stickman-pc systemd[1127]: Closed PipeWire Multimedia System Socket.
mai 07 17:18:03 stickman-pc systemd[1127]: Closed Sound System.
mai 07 17:18:03 stickman-pc systemd[1127]: Removed slice User Application Slice.
mai 07 17:18:03 stickman-pc systemd[1127]: app.slice: Consumed 10.076s CPU time.
mai 07 17:18:03 stickman-pc systemd[1127]: Reached target Shutdown.
mai 07 17:18:03 stickman-pc systemd[1127]: Finished Exit the Session.
mai 07 17:18:03 stickman-pc systemd[1127]: Reached target Exit the Session.
mai 07 17:18:03 stickman-pc systemd[1128]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[stickman] ruser=[<unknown>] rhost=[<unknown>]
mai 07 17:18:03 stickman-pc systemd[1]: user@1000.service: Deactivated successfully.
mai 07 17:18:03 stickman-pc systemd[1]: Stopped User Manager for UID 1000.
mai 07 17:18:03 stickman-pc systemd[1]: user@1000.service: Consumed 12.684s CPU time.
mai 07 17:18:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:03 stickman-pc systemd[1]: Stopping User Runtime Directory /run/user/1000...
mai 07 17:18:03 stickman-pc systemd[1]: run-user-1000.mount: Deactivated successfully.
mai 07 17:18:03 stickman-pc systemd[1]: Unmounted /run/user/1000.
mai 07 17:18:03 stickman-pc systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
mai 07 17:18:03 stickman-pc systemd[1]: Stopped User Runtime Directory /run/user/1000.
mai 07 17:18:03 stickman-pc systemd[1]: Removed slice User Slice of UID 1000.
mai 07 17:18:03 stickman-pc systemd[1]: user-1000.slice: Consumed 39.211s CPU time.
mai 07 17:18:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:03 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:03 stickman-pc sddm[928]: Setting default cursor
mai 07 17:18:03 stickman-pc sddm[928]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
mai 07 17:18:03 stickman-pc sddm[928]: Display server started.
mai 07 17:18:03 stickman-pc sddm[928]: Socket server starting...
mai 07 17:18:03 stickman-pc sddm[928]: Socket server started.
mai 07 17:18:03 stickman-pc sddm[928]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
mai 07 17:18:03 stickman-pc sddm[928]: Greeter starting...
mai 07 17:18:03 stickman-pc sddm[928]: Signal received: SIGTERM
mai 07 17:18:03 stickman-pc sddm[928]: Socket server stopping...
mai 07 17:18:03 stickman-pc sddm[928]: Socket server stopped.
mai 07 17:18:03 stickman-pc sddm[928]: Display server stopping...
mai 07 17:18:03 stickman-pc sddm-helper[2508]: [PAM] Starting...
mai 07 17:18:03 stickman-pc audit[2508]: USER_AUTH pid=2508 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
mai 07 17:18:03 stickman-pc audit[2508]: USER_ACCT pid=2508 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
mai 07 17:18:03 stickman-pc sddm-helper[2508]: [PAM] Authenticating...
mai 07 17:18:03 stickman-pc sddm-helper[2508]: [PAM] returning.
mai 07 17:18:04 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:04 stickman-pc sddm[928]: Display server stopped.
mai 07 17:18:04 stickman-pc sddm[928]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
mai 07 17:18:04 stickman-pc sddm[928]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
mai 07 17:18:04 stickman-pc systemd[1]: sddm.service: Deactivated successfully.
mai 07 17:18:04 stickman-pc systemd[1]: Stopped Simple Desktop Display Manager.
mai 07 17:18:04 stickman-pc systemd[1]: sddm.service: Consumed 5.117s CPU time.
mai 07 17:18:04 stickman-pc systemd[1]: Stopping User Login Management...
mai 07 17:18:04 stickman-pc systemd[1]: Stopping Permit User Sessions...
mai 07 17:18:04 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:04 stickman-pc systemd[1]: systemd-user-sessions.service: Deactivated successfully.
mai 07 17:18:04 stickman-pc systemd[1]: Stopped Permit User Sessions.
mai 07 17:18:04 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:04 stickman-pc systemd[1]: Stopped target Remote File Systems.
mai 07 17:18:04 stickman-pc systemd[1]: systemd-logind.service: Deactivated successfully.
mai 07 17:18:04 stickman-pc systemd[1]: Stopped User Login Management.
mai 07 17:18:04 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:18:04 stickman-pc audit: BPF prog-id=0 op=UNLOAD
mai 07 17:18:05 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:06 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:07 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:08 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:09 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:10 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:11 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:12 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:13 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:14 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:15 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:16 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:17 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:18 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:19 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:20 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:21 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:22 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:23 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:24 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:25 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:26 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:27 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:28 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:29 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:30 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:31 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:32 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:33 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:34 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:35 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:36 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:37 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:38 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:39 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:40 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:41 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:42 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:43 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:44 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:45 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:46 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:47 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:48 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:49 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:50 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:51 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:52 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:53 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:54 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:55 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:56 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:57 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:58 stickman-pc audit[2760]: USER_AUTH pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2760]: USER_ACCT pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc su[2760]: (to nxpgsql) root on none
mai 07 17:18:58 stickman-pc kernel: kauditd_printk_skb: 18 callbacks suppressed
mai 07 17:18:58 stickman-pc kernel: audit: type=1100 audit(1651936738.889:144): pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? r
es=success'
mai 07 17:18:58 stickman-pc kernel: audit: type=1101 audit(1651936738.889:145): pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=suc
cess'
mai 07 17:18:58 stickman-pc kernel: audit: type=1103 audit(1651936738.892:146): pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=succ
ess'
mai 07 17:18:58 stickman-pc kernel: audit: type=1105 audit(1651936738.892:147): pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=s
uccess'
mai 07 17:18:58 stickman-pc audit[2760]: CRED_ACQ pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2760]: USER_START pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc su[2760]: pam_unix(su:session): session opened for user nxpgsql(uid=1001) by (uid=0)
mai 07 17:18:58 stickman-pc su[2760]: pam_unix(su:session): session closed for user nxpgsql
mai 07 17:18:58 stickman-pc audit[2760]: USER_END pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc kernel: audit: type=1106 audit(1651936738.895:148): pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=
success'
mai 07 17:18:58 stickman-pc kernel: audit: type=1104 audit(1651936738.895:149): pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=succ
ess'
mai 07 17:18:58 stickman-pc audit[2760]: CRED_DISP pid=2760 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2766]: USER_AUTH pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2766]: USER_ACCT pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc su[2766]: (to nxpgsql) root on none
mai 07 17:18:58 stickman-pc audit[2766]: CRED_ACQ pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2766]: USER_START pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc su[2766]: pam_unix(su:session): session opened for user nxpgsql(uid=1001) by (uid=0)
mai 07 17:18:58 stickman-pc kernel: audit: type=1100 audit(1651936738.915:150): pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? r
es=success'
mai 07 17:18:58 stickman-pc kernel: audit: type=1101 audit(1651936738.915:151): pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=suc
cess'
mai 07 17:18:58 stickman-pc kernel: audit: type=1103 audit(1651936738.915:152): pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=succ
ess'
mai 07 17:18:58 stickman-pc kernel: audit: type=1105 audit(1651936738.915:153): pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=s
uccess'
mai 07 17:18:58 stickman-pc su[2766]: pam_unix(su:session): session closed for user nxpgsql
mai 07 17:18:58 stickman-pc audit[2766]: USER_END pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2766]: CRED_DISP pid=2766 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2772]: USER_AUTH pid=2772 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2772]: USER_ACCT pid=2772 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc su[2772]: (to nxpgsql) root on none
mai 07 17:18:58 stickman-pc audit[2772]: CRED_ACQ pid=2772 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2772]: USER_START pid=2772 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc su[2772]: pam_unix(su:session): session opened for user nxpgsql(uid=1001) by (uid=0)
mai 07 17:18:58 stickman-pc su[2772]: pam_unix(su:session): session closed for user nxpgsql
mai 07 17:18:58 stickman-pc audit[2772]: USER_END pid=2772 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc audit[2772]: CRED_DISP pid=2772 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:58 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:59 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:18:59 stickman-pc audit[2792]: USER_AUTH pid=2792 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:59 stickman-pc audit[2792]: USER_ACCT pid=2792 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:59 stickman-pc su[2792]: (to nxpgsql) root on none
mai 07 17:18:59 stickman-pc audit[2792]: CRED_ACQ pid=2792 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:59 stickman-pc audit[2792]: USER_START pid=2792 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:59 stickman-pc su[2792]: pam_unix(su:session): session opened for user nxpgsql(uid=1001) by (uid=0)
mai 07 17:18:59 stickman-pc su[2792]: pam_unix(su:session): session closed for user nxpgsql
mai 07 17:18:59 stickman-pc audit[2792]: USER_END pid=2792 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:18:59 stickman-pc audit[2792]: CRED_DISP pid=2792 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:00 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:00 stickman-pc audit[2803]: USER_AUTH pid=2803 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:00 stickman-pc audit[2803]: USER_ACCT pid=2803 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:00 stickman-pc su[2803]: (to nxpgsql) root on none
mai 07 17:19:00 stickman-pc audit[2803]: CRED_ACQ pid=2803 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:00 stickman-pc audit[2803]: USER_START pid=2803 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:00 stickman-pc su[2803]: pam_unix(su:session): session opened for user nxpgsql(uid=1001) by (uid=0)
mai 07 17:19:00 stickman-pc su[2803]: pam_unix(su:session): session closed for user nxpgsql
mai 07 17:19:00 stickman-pc audit[2803]: USER_END pid=2803 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:00 stickman-pc audit[2803]: CRED_DISP pid=2803 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2812]: USER_AUTH pid=2812 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2812]: USER_ACCT pid=2812 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc su[2812]: (to nxpgsql) root on none
mai 07 17:19:01 stickman-pc audit[2812]: CRED_ACQ pid=2812 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2812]: USER_START pid=2812 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc su[2812]: pam_unix(su:session): session opened for user nxpgsql(uid=1001) by (uid=0)
mai 07 17:19:01 stickman-pc su[2812]: pam_unix(su:session): session closed for user nxpgsql
mai 07 17:19:01 stickman-pc audit[2812]: USER_END pid=2812 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2812]: CRED_DISP pid=2812 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2818]: USER_AUTH pid=2818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2818]: USER_ACCT pid=2818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc su[2818]: (to nxpgsql) root on none
mai 07 17:19:01 stickman-pc audit[2818]: CRED_ACQ pid=2818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2818]: USER_START pid=2818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc su[2818]: pam_unix(su:session): session opened for user nxpgsql(uid=1001) by (uid=0)
mai 07 17:19:01 stickman-pc su[2818]: pam_unix(su:session): session closed for user nxpgsql
mai 07 17:19:01 stickman-pc audit[2818]: USER_END pid=2818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc audit[2818]: CRED_DISP pid=2818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_rootok acct="nxpgsql" exe="/usr/bin/su" hostname=? addr=? terminal=? res=success'
mai 07 17:19:01 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:03 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:04 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:05 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:06 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:07 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:08 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:09 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:10 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:11 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:12 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:13 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:14 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:15 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:16 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:17 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:18 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:19 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:20 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:21 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:22 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:23 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:24 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:25 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:26 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:27 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:28 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:29 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:30 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:31 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:32 stickman-pc nexposeconsole.rc[2426]: Waiting for Nexpose console to exit
mai 07 17:19:32 stickman-pc systemd[1]: nexposeconsole.service: Stopping timed out. Terminating.
mai 07 17:19:32 stickman-pc systemd[1]: nexposeconsole.service: Control process exited, code=killed, status=15/TERM
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: State 'final-sigterm' timed out. Killing.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1901 (nexserv) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1902 (Security Consol) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1903 (GC Thread#0) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1904 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1905 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1907 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1908 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1909 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1910 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1911 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1913 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1915 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1916 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1917 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1919 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1921 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1923 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1924 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1925 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 1926 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2250 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2598 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2607 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2636 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2661 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2662 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2663 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2676 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2677 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2682 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2743 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2744 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2745 (http-nio-3780-C) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2747 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2748 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2749 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2750 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2751 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2752 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2753 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2754 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2823 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2833 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2834 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2835 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2840 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2954 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Killing process 2955 (n/a) with signal SIGKILL.
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Failed with result 'timeout'.
mai 07 17:21:02 stickman-pc systemd[1]: Stopped Security Console Service.
mai 07 17:21:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nexposeconsole comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
mai 07 17:21:02 stickman-pc systemd[1]: nexposeconsole.service: Consumed 8min 4.431s CPU time.
mai 07 17:21:02 stickman-pc systemd[1]: Stopped target Network.
mai 07 17:21:02 stickman-pc systemd[1]: Stopping Network Manager...
mai 07 17:21:02 stickman-pc wpa_supplicant[1025]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.8805] caught SIGTERM, shutting down normally.
mai 07 17:21:02 stickman-pc systemd[1]: Stopping WPA supplicant...
mai 07 17:21:02 stickman-pc kernel: kauditd_printk_skb: 32 callbacks suppressed
mai 07 17:21:02 stickman-pc kernel: audit: type=1131 audit(1651936862.875:186): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nexposeconsole comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9191] dhcp4 (enp5s0): canceled DHCP transaction
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9192] dhcp4 (enp5s0): activation: beginning transaction (timeout in 45 seconds)
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9192] dhcp4 (enp5s0): state changed no lease
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9194] dhcp6 (enp5s0): canceled DHCP transaction
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9195] dhcp6 (enp5s0): activation: beginning transaction (timeout in 45 seconds)
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9195] dhcp6 (enp5s0): state changed no lease
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9198] manager: NetworkManager state is now CONNECTED_SITE
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9201] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
mai 07 17:21:02 stickman-pc dbus-daemon[821]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=912 comm="/usr/bin/NetworkManag
er --no-daemon")
mai 07 17:21:02 stickman-pc dbus-daemon[821]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9208] device (wlp2s0): set-hw-addr: reset MAC address to 1C:87:2C:B7:D1:AA (unmanage)
er --no-daemon")
mai 07 17:21:02 stickman-pc NetworkManager[912]: <info>  [1651936862.9362] exiting (success)
mai 07 17:21:02 stickman-pc wpa_supplicant[1025]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
mai 07 17:21:02 stickman-pc audit: BPF prog-id=0 op=UNLOAD
mai 07 17:21:02 stickman-pc kernel: audit: type=1334 audit(1651936862.969:187): prog-id=0 op=UNLOAD
mai 07 17:21:02 stickman-pc systemd[1]: NetworkManager.service: Deactivated successfully.
mai 07 17:21:02 stickman-pc systemd[1]: Stopped Network Manager.
mai 07 17:21:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:02 stickman-pc kernel: audit: type=1131 audit(1651936862.972:188): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:02 stickman-pc wpa_supplicant[1025]: wlp2s0: CTRL-EVENT-TERMINATING
mai 07 17:21:02 stickman-pc systemd[1]: wpa_supplicant.service: Deactivated successfully.
mai 07 17:21:02 stickman-pc systemd[1]: Stopped WPA supplicant.
mai 07 17:21:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:02 stickman-pc kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
mai 07 17:21:02 stickman-pc kernel: audit: type=1131 audit(1651936862.979:189): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:02 stickman-pc systemd[1]: Stopping D-Bus System Message Bus...
mai 07 17:21:02 stickman-pc systemd[1]: dbus.service: Deactivated successfully.
mai 07 17:21:02 stickman-pc systemd[1]: Stopped D-Bus System Message Bus.
mai 07 17:21:02 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Basic System.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Path Units.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Slice Units.
mai 07 17:21:03 stickman-pc systemd[1]: Removed slice Virtual Machine and Container Slice.
mai 07 17:21:03 stickman-pc systemd[1]: Removed slice User and Session Slice.
mai 07 17:21:03 stickman-pc systemd[1]: user.slice: Consumed 39.211s CPU time.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Socket Units.
mai 07 17:21:03 stickman-pc systemd[1]: avahi-daemon.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
mai 07 17:21:03 stickman-pc systemd[1]: dbus.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Closed D-Bus System Message Bus Socket.
mai 07 17:21:03 stickman-pc systemd[1]: libvirtd-admin.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Closed Libvirt admin socket.
mai 07 17:21:03 stickman-pc systemd[1]: libvirtd-ro.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Closed Libvirt local read-only socket.
mai 07 17:21:03 stickman-pc systemd[1]: libvirtd.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Closed Libvirt local socket.
mai 07 17:21:03 stickman-pc systemd[1]: snapd.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Closed Socket activation for snappy daemon.
mai 07 17:21:03 stickman-pc systemd[1]: virtlockd.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc kernel: audit: type=1131 audit(1651936862.995:190): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc systemd[1]: Closed Virtual machine lock manager socket.
mai 07 17:21:03 stickman-pc systemd[1]: virtlogd.socket: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Closed Virtual machine log manager socket.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target System Initialization.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Local Encrypted Volumes.
mai 07 17:21:03 stickman-pc systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
mai 07 17:21:03 stickman-pc systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Local Integrity Protected Volumes.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Local Verity Protected Volumes.
mai 07 17:21:03 stickman-pc systemd[1]: Stopping Set Up Additional Binary Formats...
mai 07 17:21:03 stickman-pc systemd[1]: systemd-sysctl.service: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped Apply Kernel Variables.
mai 07 17:21:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc systemd[1]: systemd-modules-load.service: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped Load Kernel Modules.
mai 07 17:21:03 stickman-pc kernel: audit: type=1131 audit(1651936863.022:191): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc kernel: audit: type=1131 audit(1651936863.022:192): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc
cess'
mai 07 17:21:03 stickman-pc systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
mai 07 17:21:03 stickman-pc systemd[1]: systemd-binfmt.service: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped Set Up Additional Binary Formats.
mai 07 17:21:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
mai 07 17:21:03 stickman-pc audit[2957]: SYSTEM_SHUTDOWN pid=2957 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc kernel: audit: type=1131 audit(1651936863.029:193): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc kernel: audit: type=1128 audit(1651936863.029:194): pid=2957 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=s
uccess'
mai 07 17:21:03 stickman-pc systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
mai 07 17:21:03 stickman-pc systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: systemd-update-utmp.service: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
mai 07 17:21:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
mai 07 17:21:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 07 17:21:03 stickman-pc systemd[1]: Stopped Create Volatile Files and Directories.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped target Local File Systems.
mai 07 17:21:03 stickman-pc systemd[1]: Unmounting /boot/efi...
mai 07 17:21:03 stickman-pc kernel: audit: type=1131 audit(1651936863.095:195): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succ
ess'
mai 07 17:21:03 stickman-pc systemd[1]: Unmounting /home...
mai 07 17:21:03 stickman-pc systemd[1]: Unmounting /run/media/stickman...
mai 07 17:21:03 stickman-pc systemd[1]: Unmounting /tmp...
mai 07 17:21:03 stickman-pc systemd[1]: Unmounting /var/cache...
mai 07 17:21:03 stickman-pc systemd[1]: Unmounting Mount unit for ao, revision 20...
mai 07 17:21:03 stickman-pc systemd[1]: Unmounting Mount unit for core, revision 11993...
mai 07 17:21:03 stickman-pc systemd[1]: Stopping Flush Journal to Persistent Storage...
mai 07 17:21:03 stickman-pc systemd[1]: boot-efi.mount: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Unmounted /boot/efi.
mai 07 17:21:03 stickman-pc systemd[1]: home.mount: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Unmounted /home.
mai 07 17:21:03 stickman-pc systemd[1]: var-cache.mount: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Unmounted /var/cache.
mai 07 17:21:03 stickman-pc systemd[1]: systemd-fsck@dev-disk-by\x2duuid-3E9E\x2d6597.service: Deactivated successfully.
mai 07 17:21:03 stickman-pc systemd[1]: Stopped File System Check on /dev/disk/by-uuid/3E9E-6597.
mai 07 17:21:03 stickman-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-3E9E\x2d6597 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success
I think it’s netexpose thing that didn’t end up correctly.
yes its the nexpose that wont shut down, but i dont know what that even is…
It was that, i uninstall it and it works :slight_smile:
Thks :slight_smile:
