I have just installed manjaro from the iso and got an \etc\sddm.conf file.
However this is problematic: it is legacy and takes precedence over anything in \etc\sddm.conf.d making it impossible to install local changes.
I think the sddm developers say “If anyone is still installing a /etc/sddm.conf they should stop”.
Strange. I always understood that the .d items would take precedence. Of course, having the same option in both uncommented would be less than desirable, regardless.
However, the documentation does indeed spell it out differently:
Configuration loads all files in the configuration directories followed by the configuration file in the order listed below with the latter having highest precedence. Changes should be made to the local configurations.
/usr/lib/sddm/sddm.conf.d
System configuration directory
/etc/sddm.conf.d
Local configuration directory
/etc/sddm.conf
Local configuration file for compatibility
This might simply be poor wording, but it does indicate that sddm.conf has the highest priority.
That’s not the way it is on my system. I set up autologin a few weeks ago and this file was created:
/etc/sddm.conf.d/kde_settings.conf
[Autologin]
Relogin=false
Session=plasmawayland
User=scotty
[General]
HaltCommand=/usr/bin/systemctl poweroff
Numlock=on
RebootCommand=/usr/bin/systemctl reboot
[Theme]
Current=breath
CursorSize=28
CursorTheme=Bibata-Rainbow-Modern
Font=Noto Sans,10,-1,0,400,0,0,0,0,0,0,0,0,0,0,1
[Users]
MaximumUid=60513
MinimumUid=1000
So, the drop-in configuration in /etc/sddm.conf.d/ definitely takes precedence over the default /etc/sddm.conf file (at least it does on my system).
Hi @callegar ,
If this is true, it seems to have been installed from a future, so far yet unreleased version of Manjaro.
However, considering time travel is yet to be invented, I suspect you’ve got your paths confused, which is a much simpler, more likely explanation.
I both /etc/sddm.conf and /etc/sddm.conf.d with the following files:
drwxr-xr-x root root 4.0 KB Wed Oct 16 12:36:31 2024 .
drwxr-xr-x root root 12 KB Sat Nov 16 11:21:53 2024 ..
.rw-r--r-- root root 23 B Wed May 1 23:09:53 2024 00_manjaro_settings.conf
.rw-r--r-- root root 278 B Wed Oct 16 12:36:31 2024 kde_settings.conf
.rw-r--r-- root root 35 B Sat Jul 20 08:30:11 2024 rootless-x11.conf
.rw-r--r-- root root 31 B Wed May 1 23:09:53 2024 virtualkeyboard.conf
The iso-profiles repo for kde installs the file via the desktop-overlay folder.
I created a question at the repo
May be, this is only the case if there are contradictory values in both files.
In the event of a contradiction, the values in sddm.conf overwrite the other value in sddm.conf.d/*.conf
If all values in sddm.conf are commented out, there is no contradiction. Then what is in sddm.conf.d/*.conf applies
andreas85:
May be, this is only case if there are contradictory values in both files.
I understand now. So, if for example I created the file /etc/sddm.conf.d/no-session-remember.conf with the following line:
RememberLastSession=false
to override the default /etc/sddm.conf file’s value:
RememberLastSession=true
then the next time I booted up SDDM (if I wasn’t using autologin) would still remember that my PC’s last session was Plasma Wayland, because the default value of “true” would override my drop-in config file’s value of “false”?
callegar:
\etc\sddm.conf
\etc\sddm.conf.d
Please don’t use Microsoft-style notations for UNIX-style paths. In UNIX, the backslash is an escape character, not a directory separator.
You are definitely right, too used to
You are right! Either I am too used to type the backslash from LaTeX or I have copied and pasted from someone making the mistake!
andreas85:
This is exactly what is going on. The problem is that the sddm.conf file installed in Manjaro sets almost everythinig, including a nasty HideUsers= that makes setting HideUsers from files in sddm.conf.d impossible.
My suggestion is that either Manjaro does not ship sddm.conf or it ships it with just a comment noticing that it is a legacy file and that the configuration entries can be found in files in sddm.conf.d.
Please post contents of /etc/sddm.conf to confirm source of issue
If you can demonstrate that commenting out configuration works as expected, it may get better attention from Manjaro
philm
19 November 2024 06:40
12
Calamares still ships /etc/sddm.conf as its config file: [displaymanager] Add SDDM config-file setting · calamares/calamares@25ab3f7 · GitHub . I can look into other distros on how they manage SDDM.
philm
19 November 2024 12:02
13
