Hello,
Is this a correct information: GPU: AMD RX Vega 56 - from your user profile?
The free drivers are not creating any config file, but that status report is just a warning, not an error. What was your expected change? Do you have any issues with the display, monitors layout, acceleration … ?
You had to uninstall some package that integrates it with Plasma. Look around your pacman history and see if you can find some Plasma-manjaro package removed.
Or, some configs changed.
Some users on this forum will know exactly what packages and what configs made the Manjaro settings integrate with Plasma settings. @anon89812132, any idea who should we call?
Yes. This is correct and I am using free drivers.
Ok. Thanks. So the warning is unrelated.
I expected to see manjaro tools in system settings : the one which display which kernel you use and let you install a new one, the one which let you know which allow you to auto-install gpu-drivers and change from free/non free, the one which let you install language packs etc…
Although I launched sudo pacman -S manjaro-kde-settings sddm-breath-theme manjaro-settings-manager-knotifier manjaro-settings-manager-kcm command as specified on wiki (I already did weeks ago) with output :
