The manjaro settings manager in the system tray is not opening. It opend for some time after fresh install. Now when I click it nothing happens.
Does it still open when you launch it from the launcher or the terminal?
yes .
Terminal output:
manjaro-settings-manager ✔ Shutting down Manjaro Settings Manager...
It’s opening from terminal without any issue
Do you still have the right-click menu from the tray icon? Do the entries still work?
Yes.
Three right click menu items are popping up and clicking on any menu item it opens the window
That’s the usual behavior as far as i remember.
