Manjaro Rescue 3.1.0 porting to python
Hello everyone, seeing some system recovery problems I gave a double check to the manjaro-rescue app that I created some time ago. A few months ago I brought it to version 3.0.0 which was rewritten in Python, but I only now noticed some bugs; for example it didn’t work properly with non-standard “custom” partitions so by correcting it I decided to expand some functions. If you want to test it, I think I will include it in all Manjaro editions to have it available in all future ISOs. Note that the optional tool on the interactive terminal part only appears if you install the optional dependencies of course at timeshift only if there are snapshots for btrfs in the system to be recovered. Another note, the application tries to recognize which terminal is installed depending on the edition or at least it tries. For now, I have only tested Plasma on a Plasma VM with custom partitioning.
You already did three years ago. :winking_face_with_tongue:
It’s also been integrated into Manjaro Hello for a couple years.
EDIT: Oh, perhaps adding those would help as well.
Yes, years ago I modified manjaro-hello to include a “Manjaro Rescue” button, with the condition that it would only appear if it was installed on the live system. At the time, I only added it to the GNOME edition; I should check on it, as it doesn’t seem to be showing up anymore—perhaps a Python update broke it. I had included it by default in GNOME but not in the other editions; I left the decision up to Philip and Artem, though I don’t think they ever added it. So, now I would include it in the settings shared across all editions.
Do you intend to include optional apps by default in the ISO, so that they are already present upon installation?
Since it’s in shared/Packages-Live as I linked above, it’s present in all editions. :wink:
I just checked live ISOs, it doesn’t appear. I had completely forgotten about it.
Since Rescue is only for use on the live ISO, it should already depend on anything it needs without any optional dependencies at all.
Yep need to investigate why this happen
Ok all needed will be installed
Edit: Aha.. i only check if we are in a livesystem with this path /run/miso/bootmnt/manjaro but now this not work :sweat_smile: … i need to change this and adapt at the new builds
@Yochanan
seem i have lost the ability of merge myself :joy:.. someone removed my rights to modify manjaro applications :innocent:
Someone never gave you the rights in the applications repo to begin with.
Your fork is not up to date, I can’t merge it.
Yep, not now when Philip move to forgejo but before yes i have access to some applications repo like hello, manjaro-tools, chrootbuild and others i don’ t remember.. This comment is not direct to you of course..
Forgeyo say is possible merge this request or at last say this to me.. from my fork i can see all of your commit before my
Yes, I noticed it wasn’t reporting any conflicts. Maybe it’s on my end as I only tried to apply the PR as a patch in the PKGBUILD. I’ll merge it and see what happens.
Looking good! Just tested 0.8.3 on a live GNOME ISO.
Users can test with manjaro-hello 0.8.3-1 and manjaro-rescue 3.1.0-2 which are now available in the Unstable branch. They will be included in the next scheduled daily ISO (Plasma, GNOME, XFCE).
