Manjaro rebooting after a period of time, specifically after locking it
I’m having a nearly daily recurring issue after locking my PC for the night, or for long periods of time. It is either in a hung state (no video output, no keyboard backlight, etc etc), or at the post-boot sign-in prompt. In order to recover from the former situation, I hard reset the PC. I’m writing this post after the latter had just occurred. At this time, I’m unsure if one or the other happens the most.
In regards to today, I tried looking at journalctl to see if anything stuck out at me. The only thing that occurred before journalctl stopped logging was timeshift was running and appears to have completed successfully at around 4 am, as well as some things about Obsidian. Then, nothing until I hard reset my machine at around 12:46 PM. I’ve included these logs as attachments to the topic. It’s hard for me to pinpoint when exactly the system rebooted, or if it crashed, or something else.
Lastly, this has been going on throughout the time I’ve had Manjaro installed for better part of a year now. After updating Manjaro recently, it seemed the issue disappeared, but it has now returned to its normal frequency.
inxi output:
  Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=869e4728-b5ce-438c-999a-b67e42f28f5b rw quiet splash
    resume=UUID=3993a3f0-8eb9-4e25-9a73-b8de7a0a5645 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
  Type: Desktop System: Gigabyte product: X570 AORUS ULTRA v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ULTRA serial: <superuser required>
    uuid: <superuser required> BIOS: American Megatrends LLC. v: F36d
    date: 07/20/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 31.26 GiB used: 6.28 GiB (20.1%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-8GTZR serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
    desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3983 min/max: 550/4560 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3983 2: 3983 3: 3983
    4: 3983 5: 3983 6: 3983 7: 3983 8: 3983 9: 3983 10: 3983 11: 3983 12: 3983
    13: 3983 14: 3983 15: 3983 16: 3983 bogomips: 124568
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: eVga.com.
    driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
    off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0a:00.0 chip-ID: 10de:2216
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 192 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Samsung Q80A
    serial: <filter> built: 2021 res: N/A dpi: 81 gamma: 1.2 chroma: red:
    x: 0.671 y: 0.310 green: x: 0.275 y: 0.659 blue: x: 0.153 y: 0.043 white:
    x: 0.314 y: 0.329 size: 1210x680mm (47.64x26.77") diag: 1388mm (54.6")
    ratio: 16:9 modes: 3840x2160, 4096x2160, 2560x1440, 2560x1080, 1920x1080,
    1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 101 4: parse_edid:
    unhandled CEA mode 102 5: parse_edid: unhandled CEA mode 117 6: parse_edid:
    unhandled CEA mode 118 7: parse_edid: unhandled CEA mode 90 8: parse_edid:
    unhandled CEA mode 91 9: parse_edid: unhandled CEA mode 93 10: parse_edid:
    unhandled CEA mode 94 11: parse_edid: unhandled CEA mode 95 12: parse_edid:
    unhandled CEA mode 98 13: parse_edid: unhandled CEA mode 100
    14: parse_edid: unhandled CEA mode 90 15: parse_edid: unhandled CEA mode
    92
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
    memory: 9.77 GiB
  API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3080 driver: nvidia v: 570.144 device-ID: 10de:2216
    surfaces: N/A
  Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.14.6-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  Device-3: Broadcom NetXtreme II BCM57810 10 Gigabit Ethernet driver: bnx2x
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 port: N/A bus-ID: 0b:00.0
    chip-ID: 14e4:168e class-ID: 0200
  IF: enp11s0f0 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-4: Broadcom NetXtreme II BCM57810 10 Gigabit Ethernet driver: bnx2x
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 port: N/A bus-ID: 0b:00.1
  IF: enp11s0f1 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 3.7 TiB used: 312.01 GiB (8.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT303.2 temp: 32.9 C
    scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Sabrent model: N/A
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 32.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-1: / raw-size: 919.47 GiB size: 903.96 GiB (98.31%)
    used: 312.01 GiB (34.5%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:2
    label: N/A uuid: 869e4728-b5ce-438c-999a-b67e42f28f5b
  ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:3 label: swap
    uuid: 3993a3f0-8eb9-4e25-9a73-b8de7a0a5645
  ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A
    uuid: 402C-9851
  ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 1.86 TiB fs: ntfs label: N/A
    uuid: D8222D97222D7B9E
  ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 700 MiB fs: ntfs label: N/A
    uuid: 2AEC0754EC0719A9
  ID-5: /dev/sda1 maj-min: 8:1 size: 930.98 GiB fs: ntfs label: N/A
    uuid: 02C64A50C64A43DF
  ID-6: /dev/sda2 maj-min: 8:2 size: 545 MiB fs: ntfs label: N/A
    uuid: 782A1E242A1DDFC4
  Device-1: 1-1:2 info: Integrated Express IT8297 RGB LED Controller
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8297 class-ID: 0301
  Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-6.3:4 info: NZXT Kraken X type: HID
    driver: nzxt-kraken2,usbhid interfaces: 1 rev: 2.0
    chip-ID: 1e71:170e class-ID: 0300 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-1:2 info: Holtek USB-HID Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:0207 class-ID: 0300
  Device-2: 3-5:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-5: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-6.2:5 info: Future Devices FT232 Serial (UART) IC
    type: <vendor specific> driver: ftdi_sio,gpio_stub_drv interfaces: 1
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 90mA
    chip-ID: 0403:6001 class-ID: 0000 serial: <filter>
  Device-2: 3-6.4:6 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 44.9 C mobo: N/A gpu: nvidia temp: 53 C
  Fan Speeds (rpm): fan-1: 0 gpu: nvidia fan: 0%
  Packages: 1358 pm: pacman pkgs: 1338 libs: 376 tools: pamac pm: flatpak
    pkgs: 20
    1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    4: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 437
  1: cpu: 8.4% command: konsole pid: 11536 mem: 191.9 MiB (0.5%)
  2: cpu: 3.8% command: brave pid: 8364 mem: 415.1 MiB (1.2%)
  3: cpu: 3.5% command: zsh pid: 11550 mem: 10.0 MiB (0.0%)
  4: cpu: 3.1% command: brave pid: 11431 mem: 258.0 MiB (0.8%)
  5: cpu: 2.1% command: Xorg pid: 793 mem: 221.7 MiB (0.6%)
  Memory top: 5 of 437
  1: mem: 824.0 MiB (2.5%) command: thunderbird pid: 3950 cpu: 1.7%
  2: mem: 670.7 MiB (2.0%) command: plasmashell pid: 989 cpu: 0.3%
  3: mem: 431.1 MiB (1.3%) command: brave pid: 1776 cpu: 1.9%
  4: mem: 415.1 MiB (1.2%) command: brave pid: 8364 cpu: 3.8%
  5: mem: 398.9 MiB (1.2%) command: DiscoverNotifier pid: 1260 cpu: 0.0%
  Processes: 437 Power: uptime: 1h 9m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
Last journalctl logs before booting
Jun 20 04:00:00 Manjaro-Workstation CROND[50391]: (root) CMD (timeshift --check --scripted)
Jun 20 04:00:00 Manjaro-Workstation CROND[50390]: (root) CMDOUT (Mounted '/dev/nvme0n1p1' at '/run/timeshift/50391/backup')
Jun 20 04:00:00 Manjaro-Workstation CROND[50390]: (root) CMDOUT (Daily snapshots are enabled)
Jun 20 04:00:00 Manjaro-Workstation CROND[50390]: (root) CMDOUT (Last daily snapshot is 4 hours old)
Jun 20 04:00:00 Manjaro-Workstation CROND[50390]: (root) CMDOUT (------------------------------------------------------------------------------)
Jun 20 04:00:00 Manjaro-Workstation CROND[50390]: (root) CMDOUT (Maximum backups exceeded for backup level 'daily')
Jun 20 04:00:00 Manjaro-Workstation crontab[50419]: (root) LIST (root)
Jun 20 04:00:00 Manjaro-Workstation crontab[50420]: (root) LIST (root)
Jun 20 04:00:00 Manjaro-Workstation systemd[1]: run-timeshift-50391-backup.mount: Deactivated successfully.
Jun 20 04:00:00 Manjaro-Workstation CROND[50390]: (root) CMDEND (timeshift --check --scripted)
Jun 20 04:01:00 Manjaro-Workstation CROND[50511]: (root) CMD (run-parts /etc/cron.hourly)
Jun 20 04:01:00 Manjaro-Workstation CROND[50510]: (root) CMDEND (run-parts /etc/cron.hourly)
Jun 20 04:06:18 Manjaro-Workstation systemd[909]: Started app-flatpak-com.brave.Browser-2858292937.scope.
-- Boot ef1cb23a37a941ec82a9ab48130d913f --
Jun 20 12:46:51 Manjaro-Workstation kernel: Linux version 6.14.6-2-MANJARO (linux614@manjaro) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Wed, 14 May 2025 14:56:34 +0000
-- Boot e6e303f7fa0242c7979c5a95e0235ad6 --
Jun 20 04:12:48 Manjaro-Workstation obsidian[13955]: 2025-06-20 09:12:48 Checking for update using Github
Jun 20 12:46:51 Manjaro-Workstation kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64 root=UUID=869e4728-b5ce-438c-999a-b67e42f28f5b rw quiet splash resume=UUID=3993a3f0-8eb9-4e25-9a73-b8de7a0a5645 udev.log_priority=3
Jun 20 04:12:48 Manjaro-Workstation obsidian[13955]: 2025-06-20 09:12:48 Success.
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-provided physical RAM map:
Jun 20 04:12:48 Manjaro-Workstation obsidian[13955]: 2025-06-20 09:12:48 Latest version is 1.8.10
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
Jun 20 04:12:48 Manjaro-Workstation obsidian[13955]: 2025-06-20 09:12:48 App is up to date.
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009c3efff] usable
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x0000000009c3f000-0x0000000009ffffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a210fff] ACPI NVS
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x000000000a211000-0x00000000bb097fff] usable
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000bb098000-0x00000000bc804fff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000bc805000-0x00000000bc843fff] ACPI data
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000bc844000-0x00000000bcf2dfff] ACPI NVS
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000bcf2e000-0x00000000bdbfefff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000bdbff000-0x00000000beffffff] usable
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000bf000000-0x00000000bfffffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fd400000-0x00000000fd5fffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
Jun 20 12:46:51 Manjaro-Workstation kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Let me know if I need to provide any more logs. Any tips on looking in the right place would be helpful.
Thank you for your time.
Welcome to the Manjaro community @sirbuster
The first thing I usually recommend nowadays to members experiencing issues with Plasma on X11 is that they try switching to a Plasma Wayland session (which is now the default for Plasma). Most issues which came about with KDE’s change from X11 to Wayland last year (mainly associated with Nvidia) have now been resolved.
You can change your Plasma session from X11 to Wayland by selecting the session type at the login screen (Wayland is the default for Plasma).
If you have set up autologin to skip the password screen, you can change to a Wayland session by opening System Settings → Colors & Themes → Login Screen (SDDM) → Behavior.
If this could be the cause of what I’m experiencing, I’ll give it a shot. I rebooted and selected Wayland (switching to it without a reboot resulted in a black screen after signing in).
I’ll run with this for now - hopefully its that easy. Thank you.
When using the proprietary driver - it will probably be better to use Plasma X11 session.
If you want to use Wayland switch the driver to be the open source driver.
You can run nvidia-recommended-driver to verify what nvidia recommends.
As for your recurring issues - my bet is on the nvidia proprietary driver. It is a known that the combination of using Nvidia with hibernation or sleep can cause issues on wake-up.
The simplest method is to shutdown the system instead of locking it. Savings on the hardware life and on the power bill.
I double checked my power settings to make sure there was no hibernation or sleep going active after locking the PC:
I’ll see about switching to the open source driver. So far, after switching to Wayland while on the proprietary driver, I did not get a reboot/hang last night. I’ll need to keep an eye on it, though. I appreciate the suggestion.
For the sake of the issue: if I wanted to catch this issue in the act again, are there any changes I need to make to the available log sources (such as logging level for systemd, persistent dmesg logs after reboot, etc?) to capture something? Is there a log that I haven’t looked at yet, perhaps?
And basically right after I posted my last reply, my PC completely froze, then rebooted again without me locking it.
I’ve been trying to uninstall the nvidia drivers following this guide, but I am running into a dependency issue with the existing nvidia packages:
sudo mhwd -r pci video-nvidia         ✔
> Removing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies...
:: removing nvidia-utils breaks dependency 'nvidia-utils=570.144' required by linux614-nvidia
Error: pacman failed!
Error: script failed!
Something tells me that going down the dependency list here isn’t the right move. What would be the correct action to take here?
I don’t have a system with Nvidia but to manually change drivers you would
  • either use the kernel specific package
  • or use the generic dkms package
In any case you need to know your running kernel - better the installed kernels
 $ mhwd-kernel -li
Currently running: 6.15.3-1-MANJARO (linux615)
   * linux612
   * linux615
The following is examples drawn from the example kernel listing above
sudo pacman -Syu linux615-nvidia-open linux612-nvidia-open
using generic package
sudo pacman -Syu linux615-headers linux612-headers nvidia-open-dkms
After two months without further comment from the OP this topic is deemed abandoned and therefore closed. If there is valid reason to re-open it please contact a Moderation staff member (via PM).
