I use the latest manjaro version, just run pacman -Syu
to update to latest, doesn’t install any other packages.
this problem happened in youtube web and local mp4 file.
inxi output:
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=85f22cc6-1088-4823-995c-88b1529005bf rw quiet apparmor=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 21CY v: ThinkBook 16 G4+ IAP
serial: <superuser required> Chassis: type: 10 v: ThinkBook 16 G4+ IAP
Mobo: LENOVO model: LNVNB161216 v: SDK0T76479 WIN
serial: <superuser required> UEFI: LENOVO v: HYCN40WW date: 09/15/2022
ID-1: BAT0 charge: 70.5 Wh (100.0%) condition: 70.5/71.0 Wh (99.3%)
volts: 17.4 min: 15.4 model: SMP L21M4PD8 type: Li-ion serial: <filter>
status: full cycles: 6
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: discharging
RAM: total: 15.36 GiB used: 3.12 GiB (20.3%)
Info: model: 12th Gen Intel Core i5-12500H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 454 high: 635 min/max: 400/4500:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 608 2: 443 3: 413 4: 464
5: 418 6: 411 7: 431 8: 427 9: 400 10: 400 11: 400 12: 400 13: 400 14: 635
15: 535 16: 490 bogomips: 99568
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 2050] vendor: Lenovo driver: nouveau
v: kernel non-free: 520.xx+ status: current (as of 2022-10) arch: Turing
code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 4 speed: 16 GT/s
lanes: 4 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a9
class-ID: 0302
Device-3: Acer Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 5986:2146 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: BOE Display 0x0ac1 built: 2021 res: 2560x1600
hz: 120 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 2560x1600
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 491.53 GiB used: 143.84 GiB (29.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL2512HCJQ-00BL2
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CL1QGXA7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.59 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 11.28 GiB (11.8%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 85f22cc6-1088-4823-995c-88b1529005bf
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 38.9 MiB (15.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 0C86-02AF
ID-3: /run/media/liyang/Windows-SSD raw-size: 377.06 GiB
size: 377.06 GiB (100.00%) used: 132.52 GiB (35.1%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows-SSD
uuid: 8ED48678D4866277
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
label: WINRE_DRV uuid: 8A9687109686FC47
ID-3: /dev/sda1 maj-min: 8:1 size: 3.29 GiB fs: iso9660
ID-4: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: D007-DD0F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Device-2: 3-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 3-6:4 info: Acer Integrated RGB Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 327 Uptime: 8h 19m wakeups: 24505 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1119 libs: 332 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: xfce4-terminal inxi: 3.3.23
and hwinfo --sound
7: PCI 1f.3: 0401 Multimedia audio controller
[Created at pci.386]
Unique ID: nS1_.8S26+YQrW16
SysFS ID: /devices/pci0000:00/0000:00:1f.3
SysFS BusID: 0000:00:1f.3
Hardware Class: sound
Model: "Intel Multimedia audio controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x51c8
SubVendor: pci 0x17aa "Lenovo"
SubDevice: pci 0x3806
Revision: 0x01
Driver: "sof-audio-pci-intel-tgl"
Driver Modules: "snd_sof_pci_intel_tgl"
Memory Range: 0x6103188000-0x610318bfff (rw,non-prefetchable)
Memory Range: 0x6103000000-0x61030fffff (rw,non-prefetchable)
IRQ: 183 (13893 events)
Module Alias: "pci:v00008086d000051C8sv000017AAsd00003806bc04sc01i00"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Driver Info #1:
Driver Status: snd_sof_pci_intel_tgl is active
Driver Activation Cmd: "modprobe snd_sof_pci_intel_tgl"
Config Status: cfg=new, avail=yes, need=no, active=unknown
so far as i know:
the sudo dmesg|grep audio
output:
[ 3.123491] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 3.123512] sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 3.123538] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 3.123732] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 3.952763] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.970781] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 5.264914] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[ 5.264920] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 5.264929] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[ 5.265799] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 5.265803] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 5.265806] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 5.265810] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 5.364384] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 5.364395] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 5.364401] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 11.347551] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:18:0
[ 11.347554] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: topology ABI is more recent than kernel
[ 11.372397] sof-audio-pci-intel-tgl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[ 11.398940] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 11.398943] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 11.398944] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 11.398945] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 11.398945] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 11.398946] snd_hda_codec_realtek ehdaudio0D0: Mic=0x19
[ 11.442914] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[ 11.442923] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
output of sudo dmesg --level emerg,alert,crit,err,warn
[ 0.098587] Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
[ 0.122412] #9 #10 #11 #12 #13 #14 #15
[ 0.142604] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.856784] pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
[ 1.356612] pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 1.400143] hpet_acpi_add: no address or irqs in _CRS
[ 1.832851] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 2.439005] resource sanity check: requesting [mem 0xfedc0000-0xfedcffff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
[ 2.439011] caller igen6_probe+0x199/0x7d0 [igen6_edac] mapping multiple BARs
[ 2.513365] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.513409] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.513442] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.513488] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.513547] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.513639] acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.514953] i2c i2c-0: Systems with more than 4 memory slots not supported yet, not instantiating SPD
[ 2.523157] mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x800000
[ 2.617652] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-66.ucode failed with error -2
[ 2.617670] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-65.ucode failed with error -2
[ 2.618706] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 2.625089] ACPI Warning: \_SB.PC00.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 2.625122] ACPI Warning: \_SB.PC00.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 2.817098] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 8.540866] kauditd_printk_skb: 155 callbacks suppressed
[ 9.536480] perf uncore: Cannot find matched IMC device.
[ 9.536496] perf uncore: Cannot find matched IMC device.
[ 11.443108] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
[ 11.443115] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
[ 11.443120] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
[ 11.443126] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
[ 11.443131] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
[ 11.443139] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
[ 11.443147] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
[ 11.443154] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
[ 11.443163] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
[ 11.443171] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
[ 11.443179] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
[ 11.443193] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 12.518940] intel_ish_ipc 0000:00:12.0: [ishtp-ish]: Timed out waiting for FW-initiated reset
[ 12.518956] intel_ish_ipc 0000:00:12.0: ISH: hw start failed.
[ 13.616405] kauditd_printk_skb: 18 callbacks suppressed
[ 27.747747] kauditd_printk_skb: 2 callbacks suppressed
[ 124.254871] ntfs3: Unknown parameter 'windows_names'
[ 2266.083966] kauditd_printk_skb: 7 callbacks suppressed
[ 5917.254289] kauditd_printk_skb: 4 callbacks suppressed
[14102.178510] kauditd_printk_skb: 4 callbacks suppressed
[27244.299946] kauditd_printk_skb: 5 callbacks suppressed
[27250.386011] kauditd_printk_skb: 4 callbacks suppressed
[27762.306226] Bluetooth: hci0: Ignoring error of Inquiry Cancel command
[28992.643434] kauditd_printk_skb: 4 callbacks suppressed
output of journalctl --catalog --priority=3 --boot=-1
Dec 12 16:53:49 ang-manjaro kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Dec 12 16:53:49 ang-manjaro kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Dec 12 16:53:58 ang-manjaro lightdm[988]: gkr-pam: couldn't unlock the login keyring.
Dec 12 16:53:58 ang-manjaro bluetoothd[1035]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 12 16:53:58 ang-manjaro bluetoothd[1035]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 12 16:53:58 ang-manjaro bluetoothd[1035]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 12 16:53:59 ang-manjaro kernel: intel_ish_ipc 0000:00:12.0: [ishtp-ish]: Timed out waiting for FW-initiated reset
Dec 12 16:53:59 ang-manjaro kernel: intel_ish_ipc 0000:00:12.0: ISH: hw start failed.
Dec 12 16:55:09 ang-manjaro ss-qt5[2034]: Remote: Invalid authentication tag: ChaCha20Poly1305 tag check failed
Dec 12 16:55:20 ang-manjaro kernel: ntfs3: Unknown parameter 'windows_names'
Dec 12 17:00:54 ang-manjaro ss-qt5[2034]: Remote: Invalid authentication tag: ChaCha20Poly1305 tag check failed
Dec 12 17:01:00 ang-manjaro ss-qt5[2034]: Remote: Invalid authentication tag: ChaCha20Poly1305 tag check failed
Dec 12 17:02:45 ang-manjaro systemd-coredump[4287]: Failed to connect to coredump service: Connection refused
Dec 12 17:02:45 ang-manjaro pulseaudio[1149]: Error opening PCM device _ucm0001.hw:sofhdadsp,4: No such device
Dec 12 17:02:45 ang-manjaro pulseaudio[1149]: Error opening PCM device _ucm0001.hw:sofhdadsp,3: No such device
Dec 12 17:02:45 ang-manjaro pulseaudio[1149]: Error opening PCM device _ucm0001.hw:sofhdadsp: No such device
Dec 12 17:02:45 ang-manjaro pulseaudio[1149]: Error opening PCM device _ucm0001.hw:sofhdadsp,6: No such device
Dec 12 17:02:47 ang-manjaro kernel: watchdog: watchdog0: watchdog did not stop!
i hope above info is enough, there are some audio info there, but i can not understand.
