I have been using Manjaro off and on for a few years now but just last month decided to dual boot with a third HDD and use Manjaro more than Windows for awhile. I have everything I need to play games and drivers are installed for my system but at random times my second display blacks out then comes back, I see it black out but the monitor still has power when this happens. First display uses DisplayPort and never gets affected, second display using HDMI, was DVI-D to HDMI but cables are not at fault at this time as the DVI-D to HDMI cable did the same.
inxi -v 8 output
Host: [don't want my name and hostname shown] Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.0 Distro: Manjaro Linux
Type: Desktop System: Hewlett-Packard product: HP ProDesk 400 G1 SFF v: N/A
serial: <superuser required>
Mobo: Hewlett-Packard model: 18E9 serial: <superuser required>
UEFI: Hewlett-Packard v: L02 v02.56 date: 04/24/2019
Info: quad core Intel Core i5-4590 [MCP] speed (MHz): avg: 2431
min/max: 800/3700
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
driver: i915 v: kernel
Device-2: NVIDIA GP107 [GeForce GTX 1050] driver: nvidia v: 525.60.11
Device-3: Quanta RGB-IR Camera type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7 driver: N/A
resolution: 1: 2560x1080~60Hz 2: 1920x1080~60Hz
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
1050/PCIe/SSE2
driver: r8169
Device-2: Intel Wireless 8260 driver: iwlwifi
Device-3: Intel Bluetooth wireless interface type: USB driver: btusb
Device-4: Microsoft Xbox 360 Wireless Adapter type: USB driver: usbfs
Local Storage: total: 4.53 TiB used: 3.6 TiB (79.4%)
Processes: 262 Uptime: 25m Memory: 15.55 GiB used: 4.5 GiB (29.0%)
Shell: Bash
inxi: 3.3.24
compiler: gcc v: 12.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=7cf75a0a-4602-4d1e-987a-d66b13ac9986 rw nouveau.modeset=0 quiet
apparmor=1 security=apparmor
resume=UUID=dd4c6f28-0e35-4cdd-a0fb-03561efda310 udev.log_priority=3
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 2 dm: 1: GDM v: 43.0 2: LightDM v: 1.32.0 note: stopped
serial: <superuser required> Chassis: type: 4 serial: <superuser required>
RAM: total: 15.55 GiB used: 4.46 GiB (28.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1249 high: 1290 min/max: 800/3700 scaling:
driver: intel_cpufreq governor: ondemand cores: 1: 1268 2: 1290 3: 1222
4: 1216 bogomips: 26348
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
disabled
prctl and seccomp
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-5.75
process: Intel 45nm built: 2010 ports: active: none empty: HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0380
Device-2: NVIDIA GP107 [GeForce GTX 1050] vendor: Gigabyte driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
Device-3: Quanta RGB-IR Camera type: USB driver: uvcvideo bus-ID: 3-2:3
chip-ID: 0408:7020 class-ID: 0e02 serial: 0001
compositor: xfwm v: 4.18.0 driver: N/A display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1185x286mm (46.65x11.26")
s-diag: 1219mm (47.99")
Monitor-1: DP-0.8 pos: primary,left res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.18") diag: 730mm (28.76") modes: N/A
Monitor-2: HDMI-1 pos: right res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.74x10.55") diag: 546mm (21.51") modes: N/A
1050/PCIe/SSE2 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 3-1:2
bus-ID: 00:1b.0 chip-ID: 046d:0a5c chip-ID: 8086:8c20 class-ID: 0300
serial: 00000000 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: Logitech Logitech G633 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2.3:6 chip-ID: 0d8c:0005
class-ID: 0300 serial: 201306
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: ec:b1:d7:41:5b:d7
IP v4: 192.168.12.227/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.12.255
IP v6: 2607:fb90:db03:89cb:b48f:463a:50d0:f734/128
IP v6: 2607:fb90:db03:89cb:6681:6113:74fa:ef6c/64
IP v6: fe80::1f4a:8cef:f531:cbc1/64 type: noprefixroute scope: link
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp4s0 state: down mac: 56:20:cb:35:22:44
Device-3: Microsoft Xbox 360 Wireless Adapter type: USB driver: usbfs
bus-ID: 5-2.4:7 chip-ID: 045e:0719 class-ID: ff00 serial: E1A4A600
WAN IP: 172.58.184.83
bus-ID: 3-10:6 chip-ID: 8087:0a2b class-ID: e001
ID-1: /dev/sda maj-min: 8:0 vendor: Apacer model: APS-SL3N-480
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: SC20C25826WL rev: 61.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM000-1F2168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5900 serial: Z305P214 rev: CC54 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD5000LPVT-00G33T0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: WD-WX61C62U6275
rev: 1A01 scheme: GPT
ID-1: / raw-size: 448.36 GiB size: 440.25 GiB (98.19%)
used: 105.85 GiB (24.0%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 7cf75a0a-4602-4d1e-987a-d66b13ac9986
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
uuid: F88C-A775
ID-3: /mnt/48D6A240D6A22E5E raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 3.49 TiB (96.0%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: Storage
uuid: 48D6A240D6A22E5E
ID-4: /mnt/EE2614C026148C29 raw-size: 549 MiB size: 549 MiB (100.00%)
used: 10.4 MiB (1.9%) fs: ntfs dev: /dev/sda1 maj-min: 8:1
label: System Reserved uuid: EE2614C026148C29
ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: swap
uuid: dd4c6f28-0e35-4cdd-a0fb-03561efda310
ID-1: /dev/sda2 maj-min: 8:2 size: 445.13 GiB fs: ntfs label: Windows 11
uuid: 643A15E33A15B352
ID-2: /dev/sda3 maj-min: 8:3 size: 836 MiB fs: ntfs label: N/A
uuid: CE9AEAB79AEA9AEB
ID-3: /dev/sda4 maj-min: 8:4 size: 100 MiB fs: vfat label: N/A
uuid: 522A-C96C
ID-4: /dev/sda5 maj-min: 8:5 size: 555 MiB fs: ntfs label: N/A
uuid: 12E8D627E8D608BD
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-1:2 info: Logitech Logitech G633 Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 046d:0a5c class-ID: 0300
serial: 00000000
Device-2: 3-2:3 info: Quanta RGB-IR Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:7020
Device-3: 3-3:4 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: 118238583732
Device-4: 3-4:5 info: Logitech Gaming Keyboard G810 type: Keyboard,HID
power: 500mA chip-ID: 046d:c337 class-ID: 0300 serial: 0F6036643233
Device-5: 3-10:6 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Valve Wireless Steam Controller type: Keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 28de:1142 class-ID: 0300
Hub-8: 5-2:3 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Hub-9: 5-2.1:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-2.2:5 info: American Power Conversion Uninterruptible Supply
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 2mA chip-ID: 051d:0002 class-ID: 0300 serial: 0B2211N08897
Device-2: 5-2.3:6 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: 201306
Device-3: 5-2.4:7 info: Microsoft Xbox 360 Wireless Adapter type: WiFi
driver: usbfs interfaces: 8 rev: 2.0 speed: 12 Mb/s power: 260mA
Hub-10: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-11: 6-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-12: 6-2.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Packages: pm: pacman pkgs: 2147 libs: 513 tools: octopi,pamac,trizen
pm: flatpak pkgs: 0
1: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
3: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
4: https://manjaro.kyberorg.fi/stable/$repo/$arch
5: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
6: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
7: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
8: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 262
1: cpu: 18.0% command: steamwebhelper pid: 3311 mem: 409.7 MiB (2.5%)
2: cpu: 6.1% command: opera pid: 2714 mem: 362.6 MiB (2.2%)
3: cpu: 5.3% command: opera pid: 4489 mem: 273.8 MiB (1.7%)
4: cpu: 4.7% command: opera pid: 4693 mem: 354.5 MiB (2.2%)
5: cpu: 4.5% command: steam pid: 2384 mem: 236.8 MiB (1.4%)
Memory top: 5 of 262
1: mem: 409.7 MiB (2.5%) command: steamwebhelper pid: 3311 cpu: 18.0%
2: mem: 362.6 MiB (2.2%) command: opera pid: 2714 cpu: 6.1%
3: mem: 354.5 MiB (2.2%) command: opera pid: 4693 cpu: 4.7%
4: mem: 303.9 MiB (1.9%) command: opera pid: 4622 cpu: 3.7%
5: mem: 273.8 MiB (1.7%) command: opera pid: 4489 cpu: 5.3%
Processes: 262 Uptime: 25m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11
clang: 14.0.6 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
mhwd -l && mhwd -li
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1c81) Display controller nVidia Corporation:
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0380:8086:0412) Display controller Intel Corporation:
> Installed PCI configs:
