Manjaro-printer invalid corrupted package (PGP signature)
Hi Team,
I am trying to install the manjaro-printer package (and dependencies) but I am finding the following error with pacman:
error: manjaro-printer: signature from “Mark Wagie mark@manjaro.org” is unknown trust
:: File /var/cache/pacman/pkg/manjaro-printer-20220314-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
I tried the software center app and also having the same issue.
Can anyone else try to duplicate this issue, and can we verify the current package integrity?
Same problem with system update. It shows following error:
grub: signature from “Mark Wagie mark@manjaro.org” is unknown trust
$ sudo pacman-key --refresh-keys
Thanks guys, it did indeed solve the issue. Just for my better understanding, I have been keeping my system up to date and using Manjaro for quite a while, never ran into this issue before. Is this something I need to add to a regular maintenance plan, or did I do something wrong that might give me this issue?
Was just bad timing, nothing to worry much from your end.
