Hi, i have a problem in manjaro where occasionally after my latest update today i can not login sometimes after the automatic lock screen it will say my password is incorrect (it is correct typed it 5 times, and checked it without hide) this persists on both my main pc and my laptop, and i need to reboot to log back in after this, here are the inxi -Fxxzzaa of my PC
Anyone got any idea how to fix this, thanks.
pastebin.com/wrRqivHM this includes the inxi -Fxxzzaa
Wollie
9 September 2020 18:16
2
Welcome, here @HmonsterG ,
your issue bmight be linked to PAM issue.
So this was pretty straightforward.
But just to elaborate for others
On my system I needed to edit /etc/pam.d/system-login
From this
#%PAM-1.0
auth required pam_tally2.so
auth required pam_shells.so
auth requisite pam_nologin.so
auth include system-auth
account required pam_tally2.so
account required pam_access.so
account required pam_nologin.so
account include system-auth
password include system-auth
session optional pam_lo…
Ok it appears that a file named .pam_environment was present under my home directory.
I deleted this file and login is now successful.
Here are my own copies of the three files. I have not made any modifications to them, and I have not had any login problems since the update.
#%PAM-1.0
session optional pam_loginuid.so
session optional pam_keyini…
This is maybe the most helpful link:
Known issues and solutions
PAM and PAMBASE got updated, which might prevent you from login
Due to updates from pambase and pam you might take care about any .pacnew files in /etc/pam.d as for example pam_tally, pam_tally2 and pam_cracklib got deprecated . Read in the ArchWiki about managing those files.
Typical issue:
For recovery, it is enough to boot with kernel opti…
You probably have to look for the mentioned .pacnew files.
Oh hi, thanks for that i will follow that also what is a PAM issue?
