I increased the volume on alsamixer but it didn’t change the volume. I did a bit of googling as it is a common issue but didn’t find any solutions. I’m using an MSI GE75 Raider 9SF.
Nothing I have done has increased the volume but I can hear sounds in the headphone but very faint.
Pipewire may be trying to take control of audio devices from PulseAudio
But Pipewire cannot work unless PulseAudio packages are replaced with Pipewire dependencies
You can either disable the pipewire systemd socket and service to continue using PulseAudio
I disabled pipewire via your command, rebooted and somehow pipewire was still running while the issue was not solved. I will unmask and enable pipewire and replace it with pulse and see if it solves my issue.
EDIT: pipewire is running and pulseaudio is gone but the problem persists. I went back to alsamixer and nothing helped. I’m not sure where to go from here.
