Hey all,
I am a newbie more or less. But have been having lots of fun with manjaro, which I managed to dual boot on a windows 10 asus laptop many months ago.
The thing is, I can’t boot into manjaro after installing the latest kernel update.
I’ve tried a few commands to see what’s up, but seeing as I am a mindless newbie, I don’t see what to do based on that. I can’t post images nor links, so I cant really share what it all looks like.
I’ve also tried to use manjaro-chroot -a from a boot usb, but that didn’t go well at all.
Now - when you are back in your now up and running system
it’s time to take some measures to keep this from happening again:
run: sudo tune2fs -c 20 /dev/sdaX
on every partition that is a Linux ext4 filesystem, where X denominates your partition number.
It will have the filesystem force-checked after it has been mounted 20 times without a check.
This check is quick, as you noticed - just a few seconds every 20 boots …
they can be quite arcane, especially if none of what they (very accurately) try to explain bears no context whatsoever to you as the reader
… experience / time - and context and understanding will build, the dot’s will start to connect
as is the case with every skill, with everything new
