Manjaro on Macbook Pro 2012
I’m using Macbook Pro 2012 with dual GPU, intel + nvidia gt650m. I want to move from MacOS to Linux. Already tried some other Linux distros, and find out that only manjaro with nvidia 470 driver works. But I have one problem, when I connect external monitor with HDMI it’s not working. In nvidia configs it shows external monitor as connected, but there is no picture. Is it possible to resolve at all or I need to stay on low noevue driver?
Welcome to the Manjaro community @Srdjoni
It will be difficult to provide any advice without some detailed information about your system. Please read through the following pre-prepared instructions and ensure that you provide the output of inxi -zv8 in your reply.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Required reading
Resources
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=5bc0849a-2753-40fd-9b75-6de1f977e2de rw rootflags=subvol=@
    quiet apparmor=1 security=apparmor udev.log_priority=3
  Desktop: i3 v: 4.24 with: i3bar tools: avail: i3lock vt: 7 dm: LightDM
    v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Apple product: MacBookPro10,1 v: 1.0
    serial: <superuser required> Chassis: type: 10 v: Mac-C3EC7CD22292981F
  Mobo: Apple model: Mac-C3EC7CD22292981F v: MacBookPro10,1
    serial: <superuser required> uuid: <superuser required> UEFI: Apple
    v: 429.0.0.0.0 date: 03/18/2022
  ID-1: BAT0 charge: 54.1 Wh (97.1%) condition: 55.7/92.6 Wh (60.1%)
    temp: 34.3 C volts: 12.22 min: 10.95 model: SMP bq20z451 type: Li-ion
    serial: N/A charging: status: full cycles: 714
  Device-1: hid-F0T2096RK20JKR4AB-battery model: Apple Inc. Magic Keyboard
    with Numeric Keypad serial: N/A charge: N/A status: charging
  System RAM: total: 16 GiB available: 15.53 GiB used: 2.01 GiB (13.0%)
  Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width: N/A manufacturer: 0x80AD
    part-no: 0x484D5434314753364D465238432D50422020 serial: <filter>
  Device-2: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i7-3615QM bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1200 min/max: 1200/3300 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
    7: 1200 8: 1200 bogomips: 36728
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
    erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
    v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports: active: none
    empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
    driver: nouveau v: kernel non-free: series: 470.xx+
    status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1
    empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:0fd5 class-ID: 0300
    temp: 76.0 C
  Device-3: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.1:3
    chip-ID: 05ac:8510 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.18 compositor: Picom v: 12.5 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: nouveau,crocus
    gpu: nouveau display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4800x1800 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Sony TV
    serial: <filter> built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 69 gamma: 1.2 chroma: red: x: 0.627 y: 0.341 green: x: 0.278 y: 0.596
    blue: x: 0.153 y: 0.071 white: x: 0.282 y: 0.298
    size: 708x398mm (27.87x15.67") diag: 812mm (32") ratio: 16:9
    modes: 1920x1080, 1920x1080i, 1680x1050, 1600x900, 1280x1024, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  Monitor-2: eDP-1 pos: primary,left model: Apple Color LCD built: 2011 res:
    mode: 2880x1800 hz: 60 scale: 100% (1) dpi: 221 gamma: 1.2 chroma: red:
    x: 0.655 y: 0.333 green: x: 0.298 y: 0.620 blue: x: 0.145 y: 0.047 white:
    x: 0.314 y: 0.329 size: 331x207mm (13.03x8.15") diag: 390mm (15.4")
    ratio: 16:10 modes: 2880x1800, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1400x1050, 1280x1024, 1280x960, 1152x864, 1024x768, 800x600
  API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia nouveau platforms:
    device: 0 drv: crocus device: 1 drv: nouveau device: 2 drv: swrast gbm:
    drv: crocus surfaceless: drv: crocus x11: drv: nouveau inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.2 vendor: mesa v: 25.2.3-arch1.2 glx-v: 1.4
    direct-render: yes renderer: NVE7 device-ID: 10de:0fd5 memory: 964.8 MiB
    unified: no
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Device-1: Broadcom NetXtreme BCM57786 Gigabit Ethernet PCIe driver: N/A
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
    chip-ID: 14e4:16a3 class-ID: 0200
  Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
    driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 04:00.0 chip-ID: 14e4:4331 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.8.1.3:8
    chip-ID: 05ac:8286 class-ID: fe01
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
  Local Storage: total: 233.76 GiB used: 6.68 GiB (2.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM256E
    size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 9A1Q scheme: GPT
  ID-1: / raw-size: 116.78 GiB size: 116.78 GiB (100.00%)
    used: 6.68 GiB (5.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 5bc0849a-2753-40fd-9b75-6de1f977e2de
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
    used: 2.8 MiB (1.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
    uuid: 67E3-17ED
  ID-3: /home raw-size: 116.78 GiB size: 116.78 GiB (100.00%)
  ID-4: /var/cache raw-size: 116.78 GiB size: 116.78 GiB (100.00%)
  ID-5: /var/log raw-size: 116.78 GiB size: 116.78 GiB (100.00%)
  ID-1: /dev/sda2 maj-min: 8:2 size: 116.78 GiB fs: apfs label: N/A
    uuid: 2520980a-8e09-4c57-b92d-baedd5d33481
  Device-1: 1-1:2 info: Apple Magic Keyboard with Numeric Keypad
    type: HID,keyboard driver: apple,usbhid interfaces: 2 rev: 2.0
    chip-ID: 05ac:026c class-ID: 0301 serial: <filter>
  Device-2: 1-2:4 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-4: 2-1.8:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 2
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 0424:2512 class-ID: 0900
  Hub-5: 2-1.8.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
    Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
  Device-1: 2-1.8.1.3:8 info: Apple Bluetooth Host Controller
    type: bluetooth driver: btusb interfaces: 4 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 05ac:8286
    class-ID: fe01
  Device-2: 2-1.8.2:5 info: Apple Apple Internal Keyboard / Trackpad
    (MacBook Retina) type: keyboard,HID,mouse driver: apple,bcm5974,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 40mA chip-ID: 05ac:0263 class-ID: 0301
  Hub-6: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-7: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-8: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 4-1.1:3 info: Apple FaceTime HD Camera (Built-in) type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 05ac:8510 class-ID: 0e02
    serial: <filter>
  System Temperatures: cpu: 90.0 C mobo: 54.0 C gpu: nouveau temp: 76.0 C
  Fan Speeds (rpm): N/A
Processes:
  CPU top: 5 of 281
  1: cpu: 100% command: ps pid: 25888 mem: 3.89 MiB (0.0%)
  2: cpu: 39.2% command: chrome pid: 25544 mem: 436.7 MiB (2.7%)
  3: cpu: 21.8% command: chrome pid: 24011 mem: 348.2 MiB (2.1%)
  4: cpu: 20.4% command: chrome pid: 25799 mem: 285.4 MiB (1.7%)
  5: cpu: 14.8% command: chrome pid: 25864 mem: 97.2 MiB (0.6%)
  Memory top: 5 of 281
  1: mem: 436.7 MiB (2.7%) command: chrome pid: 25544 cpu: 39.2%
  2: mem: 348.2 MiB (2.1%) command: chrome pid: 24011 cpu: 21.8%
  3: mem: 341.1 MiB (2.1%) command: chrome pid: 24093 cpu: 11.9%
  4: mem: 285.4 MiB (1.7%) command: chrome pid: 25799 cpu: 20.4%
  5: mem: 251.0 MiB (1.5%) command: manjaro-hello started-by: python3
    pid: 926 cpu: 0.3%
  Processes: 281 Power: uptime: 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: upowerd,xfce4-power-manager
  Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.3 running-in: urxvtd
    inxi: 3.3.39
WOW. I am interested in this. I wonder how late of a Macbook Pro this would work with.
