After the last update when I try to startup my system on linux66 i get black screen but when I tried to start on linux54 it’s working preety well with some issues, but I’d like to work on Linux66. Haw can I repair it?
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Hi @Adaamek, welcome at the forum ![]()
Have you cleaned your cache before updating? If not, please enter
sudo pacman -Sc
and confirm all queries.
Then update by
sudo pacman -Syu
and show us the log list.
how to show the log list?
I mean the output you see on the screen when you enter the update command, sorry for the confusion.
Also, please provide
inxi -Fza
I have linux in Polish so here is log:
:: Synchronizowanie baz danych z pakietami…
core jest aktualne
extra jest aktualne
multilib jest aktualne
:: Rozpoczynanie pełnej aktualizacji systemu…
nie ma nic do zrobienia
it means that there is no packages to update
Welcome to the forum! ![]()
Please read what @soundofthunder posted above ![]()
when I use the command inxi -zv8 this is what it shows:
Kernel: 5.4.291-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d4a9fac6-d6ff-4cdb-a80f-55ee89de1889 rw intel_iommu=on iommu=pt
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Mobo: ASUSTeK model: PRIME B660M-K D4 v: Rev 1.xx
UEFI: American Megatrends v: 3601 date: 10/12/2024
System RAM: total: 16 GiB available: 15.51 GiB used: 4.24 GiB (27.3%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 8 GiB speed: 2666 MT/s volts: curr: 1 min: 1 max: 1.35 width (bits):
data: 64 total: 64 manufacturer: A-DATA Technology
part-no: AX4U32008G16A-SBKD35 serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
Info: model: 12th Gen Intel Core i3-12100F bits: 64 type: MT MCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 5
microcode: 0x38
Topology: cpus: 1x dies: 1 cores: 4 threads: 8 tpc: 2 smt: enabled cache:
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3701 min/max: 800/5500 scaling: driver: intel_pstate
governor: powersave cores: 1: 3701 2: 3701 3: 3701 4: 3701 5: 3701 6: 3701
7: 3701 8: 3701 bogomips: 52856
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic
prctl and seccomp
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, RSB filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 570.133.07 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 ports: active: none off: DVI-D-1,HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: wayland server: X. org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch d-rect: 3200x1080 display-ID: 0
Monitor-1: DVI-D-1 pos: primary,left model: Dell E176FP serial: <filter>
built: 2005 res: mode: 1280x1024 hz: 75 scale: 100% (1) dpi: 96 gamma: 1.2
chroma: red: x: 0.639 y: 0.341 green: x: 0.278 y: 0.620 blue: x: 0.137
y: 0.067 white: x: 0.310 y: 0.329 size: 338x270mm (13.31x10.63")
diag: 433mm (17") ratio: 5:4 modes: 1280x1024, 1920x1080, 1152x864,
1280x720, 1024x768, 800x600, 720x480, 640x480
Monitor-2: HDMI-A-1 pos: right model: MSI MP252 serial: <filter>
built: 2024 res: mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 90 gamma: 1.2
chroma: red: x: 0.659 y: 0.333 green: x: 0.302 y: 0.627 blue: x: 0.141
y: 0.063 white: x: 0.314 y: 0.329 size: 544x303mm (21.42x11.93")
diag: 623mm (24.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 8 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: N/A device-ID: 10de:1b81
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu
de: kscreen-console,kscreen-doctor gpu: corectrl, nvidia-settings,
nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:9
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k5.4.291-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
chip-ID: 10ec:8179 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v6: <filter> virtual: stable-privacy scope: link
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: N/A
v: N/A port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 2.06 TiB used: 450.7 GiB (21.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: P400L 1000GB
lanes: 4 tech: SSD serial: <filter> fw-rev: VF001C4E scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500514NS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AV23 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 model: P3-256 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 910 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MK5065GSXF
tech: HDD rpm: 5400 serial: <filter> fw-rev: 5B scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Generic model: Flash Disk
size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 8.07
scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 450.68 GiB (49.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: d4a9fac6-d6ff-4cdb-a80f-55ee89de1889
used: 428 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8421-FB79
ID-3: /run/media/adama/TAK raw-size: 7.5 GiB size: 7.48 GiB (99.79%)
used: 16 MiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: TAK
uuid: F606-53C1
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda2 maj-min: 8:2 size: 465.21 GiB fs: ntfs label: gry
uuid: 964EDF974EDF6E8D
ID-2: /dev/sdb1 maj-min: 8:17 size: 50 MiB fs: ntfs
label: Zastrze\xc5\xbcone przez system uuid: 3A9E8F1E9E8ED235
ID-3: /dev/sdb2 maj-min: 8:18 size: 237.89 GiB fs: ntfs label: N/A
uuid: 349E9CA89E9C63E0
ID-4: /dev/sdb3 maj-min: 8:19 size: 540 MiB fs: ntfs label: N/A
uuid: 22D446CBD446A0C1
ID-5: /dev/sdc1 maj-min: 8:33 size: 200 MiB fs: vfat label: EFI
uuid: 2860-11F4
ID-6: /dev/sdc2 maj-min: 8:34 size: 465.56 GiB fs: ntfs label: gry 2
uuid: 625295015294DADD
Device-1: 1-1:2 info: 8BitDo IDLE type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 2dc8:301c class-ID: 0300 serial: <filter>
Device-2: 1-3:3 info: China Resource Semico USB Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1a2c:8b03 class-ID: 0301
Device-3: 1-4:4 info: E-Signal USB Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 331a:5001 class-ID: 0300
Device-4: 1-5:5 info: Alcor Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 058f:6387 class-ID: 0806
serial: <filter>
Device-5: 1-6:6 info: SayoDevice O3C v1 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 8089:0009 class-ID: 0300 serial: <filter>
Device-6: 1-7:7 info: Wacom CTH-461 [Bamboo Fun/Craft/Comic Pen & Touch
(S)] type: mouse,HID driver: usbhid,wacom interfaces: 2 rev: 2.0
chip-ID: 056a:00d2 class-ID: 0300
Device-7: 1-9:8 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-8: 1-10:9 info: C-Media Blue Snowball type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
speed: 10 Gb/s (1.16 GiB/s) lanes: 2 mode: 3.2 gen-1x2 chip-ID: 1d6b:0003
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes:
CPU top: 5 of 321
1: cpu: 99.7% command: pipewire pid: 1138 mem: 16.2 MiB (0.1%)
2: cpu: 5.3% command: Xwayland pid: 1161 mem: 125.5 MiB (0.7%)
3: cpu: 4.9% command: kwin_wayland pid: 1066 mem: 264.2 MiB (1.6%)
4: cpu: 4.2% command: brave pid: 4459 mem: 251.0 MiB (1.5%)
5: cpu: 2.9% command: brave pid: 1960 mem: 267.1 MiB (1.6%)
Memory top: 5 of 321
1: mem: 498.0 MiB (3.1%) command: plasmashell pid: 1223 cpu: 0.5%
2: mem: 466.1 MiB (2.9%) command: brave pid: 1492 cpu: 2.2%
3: mem: 425.4 MiB (2.6%) command: steamwebhelper pid: 2666 cpu: 0.3%
4: mem: 366.1 MiB (2.3%) command: brave pid: 2098 cpu: 2.3%
5: mem: 325.7 MiB (2.0%) command: ./steamwebhelper pid: 2566 cpu: 0.3%
Processes: 321 Power: uptime: 32m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
mod. edited for legibility
mod. edited for spelling
Content of both commands is very similar, if you want you can delete the second post.
Next time, please format the output as I did this time for you. ![]()
Ok thank you for helping
As far as I understood the combination of Nvidia and wayland sometimes could form an issue (I have Intel, so no personal experience). In your case I would try to login to X11, to verify if this could help. Maybe someone from the forum with Nvidia experience can assists.
The second detail I saw is that you connect one of your monitors via DVI-D, maybe the older kernel better suports this ancient technology. ![]()
If I change to x11 on Linux54 will it change on Linux66?
I think so. But not 100% sure, to be honest.
I tried it and nothing changed
Have you tried other kernels?
I tried only on 54 and 66 because they are only kernels I had preinstalled
Why not installing another one then in addition?
Ok I’ll try with Linux614 kernel
Better start with 6.12 or 6.13.
System now works preety fine on 612 kernel. Thank you for your help!
