Up until yesterday i didn’t have to do this I can simply change the boot order permanently by going to BIOS setup then it will automatically boot into Manjaro
But since yesterday, Manjaro not listed in Boot Order Menu (look at picture below), but efi file is listed in boot device options (look at first picture)
Everything was working fine till yesterday.
I’ve neither updated the system nor made any changes to any system file
I’ve done 3 things yesterday :
Installed transmission-gtk
Downloaded a torrent file (.mkv) form eztv
Downloaded tor browswer
I hope to get some answers
Can .mkv file downloaded from torrent be a cause for it ?
How can i list Manajro in UEFI boot order ?
Suppse i booted into Manjaro (SSD) and then restart my laptop, it’ll go into grub (installed with linux mint) and i’ve to select Manjaro by going into Boot Device Options again
these issue never arise with no interference, the ones listed by you has nothing got to do with EFI or the boot process. you will have to start with BIOS settings first, disable all setting that could lead to BIOS opting to boot the drive in CD-ROM bay(caddy), since it is the OSs in your HDD that is preventing manjaro’s GRUB from loading. from the ones visible i would start by disabling “CD_ROM Boot” and see.
from you bootloader list, BootCurrent: 0004 indicates that EFI Hard Drive 1 (CT500MX500SSD1) is set to boot if nothing else interferes
