I have been running Manjaro as my main OS for about 14 days now and enjoy the experience a lot. I have a Thinkpad P50 which comes with a Nvidia Quadro M1000M GPU. I’m on the 5.9 kernel and installed the proprietary drivers. Everything works just fine and I’ve really been enjoying using a Linux distro as my main OS. The only issue is the laptop sometimes doesn’t go to sleep when I put it to sleep. It goes into the login screen and I can log in if I want. If I do, I can use it for a couple of seconds, then the everything just freezes, a black screen appears with only the mouse pointer. I’ve actually waited a few minutes to see if it will eventually go to sleep but it doesn’t. My only solution at this point is to force a manual reboot (by holding down the power button). This happens about once every two days and would really be happy if I can know what’s causing it and hopefully solve the issue. I’m ready to provide logs in case someone is willing to help resolve this issue.
For additional information: I’m using chrome instead of firefox, if that matters. Also, I have no fancy software installed.
