Hello, my Manjaro installation used to work perfectly fine before I tried logging out and logging back in one time because I added my user to the uucp
group and I was greeted by a black screen with a few messages saying
[ OK ] Finished Hold until boot process finishes up.
[ OK ] Started CUPS Scheduler.
[ OK ] Finished Terminate Plymouth Boot Screen.
instead of the login screen. I sat for minutes and nothing else happened.
there were the same messages after rebooting, sometimes the messages never show up and It’s just the boot splash screen.
here’s what I found in journalctl -p 3 -b
May 09 16:28:25 proto-travelmatep653m kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [ABOD] at bit offset/length 48/8192 exceeds size of target Buffer (4160 bits) (20220331/dsopcode-198)
May 09 16:28:25 proto-travelmatep653m kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [ABOR] at bit offset/length 8240/16 exceeds size of target Buffer (4160 bits) (20220331/dsopcode-198)
May 09 16:28:25 proto-travelmatep653m kernel: ACPI Error: AE_TYPE, Opcode is not deferred [ABOD] (BufferField) (20220331/nsinit-411)
May 09 16:28:25 proto-travelmatep653m kernel: ACPI Error: AE_TYPE, Could not execute arguments for [ABOD] (BufferField) (20220331/nsinit-419)
May 09 16:28:25 proto-travelmatep653m kernel: ACPI Error: AE_TYPE, Opcode is not deferred [ABOR] (BufferField) (20220331/nsinit-411)
May 09 16:28:25 proto-travelmatep653m kernel: ACPI Error: AE_TYPE, Could not execute arguments for [ABOR] (BufferField) (20220331/nsinit-419)
May 09 16:28:26 proto-travelmatep653m bluetoothd[384]: src/plugin.c:plugin_init() Failed to init vcp plugin
May 09 16:28:26 proto-travelmatep653m bluetoothd[384]: src/plugin.c:plugin_init() Failed to init mcp plugin
May 09 16:28:26 proto-travelmatep653m bluetoothd[384]: src/plugin.c:plugin_init() Failed to init bap plugin
May 09 16:28:26 proto-travelmatep653m bluetoothd[384]: Failed to set mode: Failed (0x03)
May 09 16:28:32 proto-travelmatep653m sddm[461]: Failed to read display number from pipe
May 09 16:28:34 proto-travelmatep653m sddm[461]: Failed to read display number from pipe
May 09 16:28:35 proto-travelmatep653m sddm[461]: Failed to read display number from pipe
May 09 16:28:35 proto-travelmatep653m sddm[461]: Could not start Display server on vt 1
systemctl --failed
reported no failures.
here’s my inxi report If that helps. (inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=2cde4d65-1f94-4c3a-bfd5-b14b6a622991 rw quiet splash
resume=UUID=a9309d54-1056-453d-b804-c5df2b44f531 udev.log_priority=3
Console: tty 2 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: TravelMate P653-M v: V2.15
serial: <filter>
Mobo: Acer model: TravelMate P653-M v: V2.15 serial: <filter> UEFI: Phoenix
v: 2.15 date: 10/21/2013
ID-1: BAT0 charge: 50.3 Wh (100.0%) condition: 50.3/66.6 Wh (75.5%)
volts: 12.2 min: 11.1 model: SONYCorp AS10D3E type: Li-ion serial: <filter>
status: full
System RAM: available: 3.61 GiB used: 445.8 MiB (12.0%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Kingston part-no: ACR16D3LS1KFG/4G serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i5-3230M socket: rPGA988B (U3E1) note: check bits: 64
type: MT MCP arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15
process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9
microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1800 high: 3200 min/max: 1200/3200 base/boost: 2600/2600
scaling: driver: intel_cpufreq governor: schedutil volts: 0.9 V
ext-clock: 100 MHz cores: 1: 1200 2: 1600 3: 3200 4: 1200 bogomips: 20760
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Suyin HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:4 chip-ID: 064e:c400
class-ID: 0e02
Display: server: X.org v: 1.21.1.8 driver: X: loaded: vesa gpu: i915
tty: 170x48
Monitor-1: LVDS-1 model: AU Optronics 0x46ec serial: <filter> built: 2010
res: 1366x768 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
API: OpenGL Message: GL data unavailable in console for root.
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
API: ALSA v: k6.1.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: off
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl
Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:088e
class-ID: 0280
IP v6: <filter> scope: link
Device-2: Broadcom NetXtreme BCM57761 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 14e4:16b0
class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:3
chip-ID: 8087:07da class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 447.13 GiB used: 201.39 GiB (45.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
family: Micron Client SSDs size: 447.13 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 041 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 147d 16h cycles: 779
written: 7.41 TiB
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM UJ8C2 rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 438.88 GiB size: 430.92 GiB (98.19%)
used: 201.39 GiB (46.7%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 2cde4d65-1f94-4c3a-bfd5-b14b6a622991
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: D5E8-AD06
ID-1: swap-1 type: partition size: 7.95 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: a9309d54-1056-453d-b804-c5df2b44f531
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.4:3 info: Intel Centrino Bluetooth Wireless Transceiver
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 8087:07da
class-ID: e001
Device-2: 1-1.5:4 info: Suyin HD WebCam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 064e:c400 class-ID: 0e02
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: LighTuning ES603 Swipe Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
chip-ID: 1c7a:0603 class-ID: 0000
Device-2: 2-1.7:4 info: Gemalto (was Gemplus) GemPC Twin SmartCard Reader
type: smart card driver: N/A interfaces: 1 rev: 1.1
chip-ID: 08e6:3437 class-ID: 0b00
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:4 info: Samsung Galaxy series misc. (MTP mode) type: still
imaging,abstract (modem),CDC-data driver: cdc_acm interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 96mA
chip-ID: 04e8:6860 class-ID: 0a00 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 128 Uptime: 23m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1337 libs: 379 tools: pamac pm: flatpak pkgs: 0 Shell: Bash (sudo)
v: 5.1.16 running-in: tty 2 inxi: 3.3.27
Any help will be greatly appreciated.
