Well, after reinstalling the whole system and doing the backlight service masking explained in the link W1sE provided, the result was the same and the two errors I listed were still showing:
[FAILED] Failed to start Load/Save ness of backlight:acpi_video0.
[FAILED] Failed to start Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
Then I realized that backlight:acpi_video0 and backlight:amdgpu_bl1 were the names of the actual services that weren’t working, so I masked them with the same commands:
sudo systemctl mask systemd-backlight@backlight:acpi_video0.service
sudo systemctl mask systemd-backlight@backlight:amdgpu_bl1.service
Now the errors are not displayed when the system is booting!
… But the system doesn’t boot either
I can continue to login and startx from TTY2. So the X server is not starting, but it actually can be started, because I’m not’t doing anything special after login from another TTY.
This is the output of my dmesg :
[ 0.000000] Linux version 5.13.19-2-MANJARO (builduser@fv-az39-393) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=493eff76-7e58-4ab4-ad16-04ea364812fd rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009eeffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009ef0000-0x000000000a000fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a001000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a20f000-0x00000000c72fdfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c72fe000-0x00000000c747bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c747c000-0x00000000c74effff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000c74f0000-0x00000000c76e5fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000c76e6000-0x00000000ccf83fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ccf84000-0x00000000ccffdfff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000ccffe000-0x00000000cdffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ce000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000fdffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe700000-0x00000000fe700fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedc4000-0x00000000fedc9fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedcc000-0x00000000fedcefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedd5000-0x00000000fedd5fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000040e2fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000040e300000-0x000000042fffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0xc74ef000 ACPI 2.0=0xc74ef014 SMBIOS=0xcce1f000 SMBIOS 3.0=0xcce1e000 MEMATTR=0xc44bf698 ESRT=0xc5d21518
[ 0.000000] SMBIOS 3.3.0 present.
[ 0.000000] DMI: HP HP Pavilion Gaming Laptop 15-ec2xxx/88DD, BIOS F.10 04/15/2021
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3193.961 MHz processor
[ 0.000131] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000133] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000137] last_pfn = 0x40e300 max_arch_pfn = 0x400000000
[ 0.000912] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001124] last_pfn = 0xce000 max_arch_pfn = 0x400000000
[ 0.003782] esrt: Reserving ESRT space from 0x00000000c5d21518 to 0x00000000c5d21550.
[ 0.003787] e820: update [mem 0xc5d21000-0xc5d21fff] usable ==> reserved
[ 0.003799] Using GB pages for direct mapping
[ 0.004111] Secure boot disabled
[ 0.004112] RAMDISK: [mem 0x36d55000-0x376a1fff]
[ 0.004116] ACPI: Early table checksum verification disabled
[ 0.004118] ACPI: RSDP 0x00000000C74EF014 000024 (v02 HPQOEM)
[ 0.004121] ACPI: XSDT 0x00000000C74EE728 0000F4 (v01 HPQOEM SLIC-MPC 01072009 AMI 01000013)
[ 0.004124] ACPI: FACP 0x00000000C74E0000 000114 (v06 HPQOEM SLIC-MPC 01072009 HP 00010013)
[ 0.004128] ACPI: DSDT 0x00000000C74CA000 015787 (v02 HPQOEM 88DD 01072009 ACPI 20190509)
[ 0.004129] ACPI: FACS 0x00000000C76C9000 000040
[ 0.004131] ACPI: SSDT 0x00000000C74E6000 007229 (v02 HPQOEM 88DD 00000002 ACPI 04000000)
[ 0.004133] ACPI: IVRS 0x00000000C74E5000 0001A4 (v02 HPQOEM 88DD 00000001 HP 00000000)
[ 0.004134] ACPI: SSDT 0x00000000C74E1000 003A21 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004135] ACPI: FIDT 0x00000000C74C9000 00009C (v01 HPQOEM 88DD 01072009 HP 00010013)
[ 0.004137] ACPI: MCFG 0x00000000C74C8000 00003C (v01 HPQOEM 88DD 01072009 HP 00010013)
[ 0.004138] ACPI: HPET 0x00000000C74C7000 000038 (v01 HPQOEM 88DD 01072009 HP 00000005)
[ 0.004140] ACPI: VFCT 0x00000000C74B9000 00D884 (v01 HPQOEM 88DD 00000001 HP 31504F47)
[ 0.004141] ACPI: SSDT 0x00000000C74B8000 000060 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004143] ACPI: SSDT 0x00000000C74B2000 005354 (v02 HPQOEM 88DD 00000001 ACPI 00000001)
[ 0.004144] ACPI: CRAT 0x00000000C74B1000 000EE8 (v01 HPQOEM 88DD 00000001 HP 00000001)
[ 0.004146] ACPI: CDIT 0x00000000C74B0000 000029 (v01 HPQOEM 88DD 00000001 HP 00000001)
[ 0.004147] ACPI: SSDT 0x00000000C74AE000 0019C4 (v01 HPQOEM 88DD 00001000 ACPI 20190509)
[ 0.004148] ACPI: SSDT 0x00000000C74AD000 000149 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004150] ACPI: SSDT 0x00000000C74AC000 00048C (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004151] ACPI: SSDT 0x00000000C74AB000 000647 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004153] ACPI: SSDT 0x00000000C74A9000 001486 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004154] ACPI: SSDT 0x00000000C74A7000 001517 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004156] ACPI: SSDT 0x00000000C74A6000 0005F6 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004157] ACPI: SSDT 0x00000000C74A2000 0036E3 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004158] ACPI: WSMT 0x00000000C74A1000 000028 (v01 HPQOEM 88DD 01072009 HP 00010013)
[ 0.004160] ACPI: APIC 0x00000000C74A0000 0000DE (v03 HPQOEM 88DD 01072009 HP 00010013)
[ 0.004161] ACPI: SSDT 0x00000000C749F000 00008D (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004163] ACPI: SSDT 0x00000000C749E000 000917 (v01 HPQOEM 88DD 00000001 ACPI 20190509)
[ 0.004164] ACPI: FPDT 0x00000000C749D000 000044 (v01 HPQOEM 88DD 01072009 HP 01000013)
[ 0.004166] ACPI: BGRT 0x00000000C749C000 000038 (v01 HPQOEM 88DD 01072009 HP 00010013)
[ 0.004167] ACPI: Reserving FACP table memory at [mem 0xc74e0000-0xc74e0113]
[ 0.004168] ACPI: Reserving DSDT table memory at [mem 0xc74ca000-0xc74df786]
[ 0.004168] ACPI: Reserving FACS table memory at [mem 0xc76c9000-0xc76c903f]
[ 0.004169] ACPI: Reserving SSDT table memory at [mem 0xc74e6000-0xc74ed228]
[ 0.004169] ACPI: Reserving IVRS table memory at [mem 0xc74e5000-0xc74e51a3]
[ 0.004170] ACPI: Reserving SSDT table memory at [mem 0xc74e1000-0xc74e4a20]
[ 0.004170] ACPI: Reserving FIDT table memory at [mem 0xc74c9000-0xc74c909b]
[ 0.004171] ACPI: Reserving MCFG table memory at [mem 0xc74c8000-0xc74c803b]
[ 0.004171] ACPI: Reserving HPET table memory at [mem 0xc74c7000-0xc74c7037]
[ 0.004171] ACPI: Reserving VFCT table memory at [mem 0xc74b9000-0xc74c6883]
[ 0.004172] ACPI: Reserving SSDT table memory at [mem 0xc74b8000-0xc74b805f]
[ 0.004172] ACPI: Reserving SSDT table memory at [mem 0xc74b2000-0xc74b7353]
[ 0.004173] ACPI: Reserving CRAT table memory at [mem 0xc74b1000-0xc74b1ee7]
[ 0.004173] ACPI: Reserving CDIT table memory at [mem 0xc74b0000-0xc74b0028]
[ 0.004174] ACPI: Reserving SSDT table memory at [mem 0xc74ae000-0xc74af9c3]
[ 0.004174] ACPI: Reserving SSDT table memory at [mem 0xc74ad000-0xc74ad148]
[ 0.004175] ACPI: Reserving SSDT table memory at [mem 0xc74ac000-0xc74ac48b]
[ 0.004175] ACPI: Reserving SSDT table memory at [mem 0xc74ab000-0xc74ab646]
[ 0.004176] ACPI: Reserving SSDT table memory at [mem 0xc74a9000-0xc74aa485]
[ 0.004176] ACPI: Reserving SSDT table memory at [mem 0xc74a7000-0xc74a8516]
[ 0.004177] ACPI: Reserving SSDT table memory at [mem 0xc74a6000-0xc74a65f5]
[ 0.004177] ACPI: Reserving SSDT table memory at [mem 0xc74a2000-0xc74a56e2]
[ 0.004177] ACPI: Reserving WSMT table memory at [mem 0xc74a1000-0xc74a1027]
[ 0.004178] ACPI: Reserving APIC table memory at [mem 0xc74a0000-0xc74a00dd]
[ 0.004178] ACPI: Reserving SSDT table memory at [mem 0xc749f000-0xc749f08c]
[ 0.004179] ACPI: Reserving SSDT table memory at [mem 0xc749e000-0xc749e916]
[ 0.004179] ACPI: Reserving FPDT table memory at [mem 0xc749d000-0xc749d043]
[ 0.004180] ACPI: Reserving BGRT table memory at [mem 0xc749c000-0xc749c037]
[ 0.004189] ACPI: Local APIC address 0xfee00000
[ 0.004229] No NUMA configuration found
[ 0.004230] Faking a node at [mem 0x0000000000000000-0x000000040e2fffff]
[ 0.004232] NODE_DATA(0) allocated [mem 0x40e2fc000-0x40e2fffff]
[ 0.004251] Zone ranges:
[ 0.004252] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.004253] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.004254] Normal [mem 0x0000000100000000-0x000000040e2fffff]
[ 0.004255] Device empty
[ 0.004255] Movable zone start for each node
[ 0.004256] Early memory node ranges
[ 0.004256] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.004257] node 0: [mem 0x0000000000100000-0x0000000009eeffff]
[ 0.004257] node 0: [mem 0x000000000a001000-0x000000000a1fffff]
[ 0.004258] node 0: [mem 0x000000000a20f000-0x00000000c72fdfff]
[ 0.004258] node 0: [mem 0x00000000ccffe000-0x00000000cdffffff]
[ 0.004259] node 0: [mem 0x0000000100000000-0x000000040e2fffff]
[ 0.004260] Initmem setup node 0 [mem 0x0000000000001000-0x000000040e2fffff]
[ 0.004261] On node 0 totalpages: 4023423
[ 0.004262] DMA zone: 64 pages used for memmap
[ 0.004263] DMA zone: 159 pages reserved
[ 0.004263] DMA zone: 3999 pages, LIFO batch:0
[ 0.004264] DMA32 zone: 12744 pages used for memmap
[ 0.004265] DMA32 zone: 815584 pages, LIFO batch:63
[ 0.004265] Normal zone: 50060 pages used for memmap
[ 0.004265] Normal zone: 3203840 pages, LIFO batch:63
[ 0.004267] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.004278] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.004378] On node 0, zone DMA32: 273 pages in unavailable ranges
[ 0.007859] On node 0, zone DMA32: 15 pages in unavailable ranges
[ 0.008016] On node 0, zone DMA32: 23808 pages in unavailable ranges
[ 0.024019] On node 0, zone Normal: 8192 pages in unavailable ranges
[ 0.024063] On node 0, zone Normal: 7424 pages in unavailable ranges
[ 0.024320] ACPI: PM-Timer IO Port: 0x808
[ 0.024323] ACPI: Local APIC address 0xfee00000
[ 0.024327] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.024339] IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
[ 0.024343] IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
[ 0.024344] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.024346] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.024347] ACPI: IRQ0 used by override.
[ 0.024348] ACPI: IRQ9 used by override.
[ 0.024349] Using ACPI (MADT) for SMP configuration information
[ 0.024350] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.024357] e820: update [mem 0xc5d09000-0xc5d1cfff] usable ==> reserved
[ 0.024365] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.024383] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.024385] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.024386] PM: hibernation: Registered nosave memory: [mem 0x09ef0000-0x0a000fff]
[ 0.024387] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20efff]
[ 0.024388] PM: hibernation: Registered nosave memory: [mem 0xc5d09000-0xc5d1cfff]
[ 0.024389] PM: hibernation: Registered nosave memory: [mem 0xc5d21000-0xc5d21fff]
[ 0.024390] PM: hibernation: Registered nosave memory: [mem 0xc72fe000-0xc747bfff]
[ 0.024390] PM: hibernation: Registered nosave memory: [mem 0xc747c000-0xc74effff]
[ 0.024391] PM: hibernation: Registered nosave memory: [mem 0xc74f0000-0xc76e5fff]
[ 0.024391] PM: hibernation: Registered nosave memory: [mem 0xc76e6000-0xccf83fff]
[ 0.024391] PM: hibernation: Registered nosave memory: [mem 0xccf84000-0xccffdfff]
[ 0.024392] PM: hibernation: Registered nosave memory: [mem 0xce000000-0xcfffffff]
[ 0.024393] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xefffffff]
[ 0.024393] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[ 0.024393] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfcffffff]
[ 0.024394] PM: hibernation: Registered nosave memory: [mem 0xfd000000-0xfdffffff]
[ 0.024394] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe6fffff]
[ 0.024394] PM: hibernation: Registered nosave memory: [mem 0xfe700000-0xfe700fff]
[ 0.024395] PM: hibernation: Registered nosave memory: [mem 0xfe701000-0xfeb7ffff]
[ 0.024395] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[ 0.024395] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.024396] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.024396] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.024396] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.024397] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.024397] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.024397] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.024398] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.024398] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc3fff]
[ 0.024399] PM: hibernation: Registered nosave memory: [mem 0xfedc4000-0xfedc9fff]
[ 0.024399] PM: hibernation: Registered nosave memory: [mem 0xfedca000-0xfedcbfff]
[ 0.024399] PM: hibernation: Registered nosave memory: [mem 0xfedcc000-0xfedcefff]
[ 0.024400] PM: hibernation: Registered nosave memory: [mem 0xfedcf000-0xfedd4fff]
[ 0.024400] PM: hibernation: Registered nosave memory: [mem 0xfedd5000-0xfedd5fff]
[ 0.024400] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfeffffff]
[ 0.024401] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.024402] [mem 0xd0000000-0xefffffff] available for PCI devices
[ 0.024403] Booting paravirtualized kernel on bare hardware
[ 0.024405] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.026996] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[ 0.027394] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u262144
[ 0.027398] pcpu-alloc: s196608 r8192 d28672 u262144 alloc=1*2097152
[ 0.027400] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.027418] Built 1 zonelists, mobility grouping on. Total pages: 3960396
[ 0.027419] Policy zone: Normal
[ 0.027419] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=493eff76-7e58-4ab4-ad16-04ea364812fd rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.028653] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.029284] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.029317] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.053828] Memory: 15653820K/16093692K available (14344K kernel code, 2076K rwdata, 9444K rodata, 1792K init, 4080K bss, 439612K reserved, 0K cma-reserved)
[ 0.053835] random: get_random_u64 called from __kmem_cache_create+0x2a/0x580 with crng_init=0
[ 0.053898] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.053906] ftrace: allocating 42500 entries in 167 pages
[ 0.064196] ftrace: allocated 167 pages with 5 groups
[ 0.064278] rcu: Preemptible hierarchical RCU implementation.
[ 0.064279] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.064280] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.064281] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.064281] Trampoline variant of Tasks RCU enabled.
[ 0.064282] Rude variant of Tasks RCU enabled.
[ 0.064282] Tracing variant of Tasks RCU enabled.
[ 0.064283] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.064283] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.066513] NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
[ 0.066792] Console: colour dummy device 80x25
[ 0.066800] printk: console [tty0] enabled
[ 0.066813] ACPI: Core revision 20210331
[ 0.066965] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.066981] APIC: Switch to symmetric I/O mode setup
[ 0.067522] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR0, rdevid:160
[ 0.067523] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR1, rdevid:160
[ 0.067524] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR2, rdevid:160
[ 0.067524] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR3, rdevid:160
[ 0.067761] Switched APIC routing to physical flat.
[ 0.068356] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.083656] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2e0a011a876, max_idle_ns: 440795241200 ns
[ 0.083659] Calibrating delay loop (skipped), value calculated using timer frequency.. 6390.08 BogoMIPS (lpj=10646536)
[ 0.083661] pid_max: default: 32768 minimum: 301
[ 0.085141] LSM: Security Framework initializing
[ 0.085147] landlock: Up and running.
[ 0.085148] Yama: becoming mindful.
[ 0.085166] AppArmor: AppArmor initialized
[ 0.085227] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.085264] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.085458] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.085467] LVT offset 1 assigned for vector 0xf9
[ 0.085479] LVT offset 2 assigned for vector 0xf4
[ 0.085483] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.085484] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.085487] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.085489] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.085490] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.085491] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.085492] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.085493] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.085494] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.087976] Freeing SMP alternatives memory: 36K
[ 0.198464] smpboot: CPU0: AMD Ryzen 7 5800H with Radeon Graphics (family: 0x19, model: 0x50, stepping: 0x0)
[ 0.198563] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.198567] ... version: 0
[ 0.198568] ... bit width: 48
[ 0.198568] ... generic registers: 6
[ 0.198569] ... value mask: 0000ffffffffffff
[ 0.198569] ... max period: 00007fffffffffff
[ 0.198570] ... fixed-purpose events: 0
[ 0.198570] ... event mask: 000000000000003f
[ 0.198608] rcu: Hierarchical SRCU implementation.
[ 0.198922] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.199032] smp: Bringing up secondary CPUs ...
[ 0.199101] x86: Booting SMP configuration:
[ 0.199102] .... node #0, CPUs: #1
[ 0.200421] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.200482] #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.233700] smp: Brought up 1 node, 16 CPUs
[ 0.233700] smpboot: Max logical packages: 1
[ 0.233701] smpboot: Total of 16 processors activated (102247.36 BogoMIPS)
[ 0.234732] devtmpfs: initialized
[ 0.234732] x86/mm: Memory block size: 128MB
[ 0.234732] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20efff] (61440 bytes)
[ 0.234732] PM: Registering ACPI NVS region [mem 0xc74f0000-0xc76e5fff] (2056192 bytes)
[ 0.234732] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.234732] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.234732] pinctrl core: initialized pinctrl subsystem
[ 0.234732] PM: RTC time: 07:16:29, date: 2021-10-28
[ 0.234732] NET: Registered protocol family 16
[ 0.234732] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.234732] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.234732] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.234732] audit: initializing netlink subsys (disabled)
[ 0.234732] audit: type=2000 audit(1635405389.166:1): state=initialized audit_enabled=0 res=1
[ 0.234732] thermal_sys: Registered thermal governor 'fair_share'
[ 0.234732] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.234732] thermal_sys: Registered thermal governor 'step_wise'
[ 0.234732] thermal_sys: Registered thermal governor 'user_space'
[ 0.234732] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.234732] cpuidle: using governor ladder
[ 0.234732] cpuidle: using governor menu
[ 0.237020] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.237021] ACPI: bus type PCI registered
[ 0.237022] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.237062] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.237066] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.237074] PCI: Using configuration type 1 for base access
[ 0.237802] Kprobes globally optimized
[ 0.237805] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.237805] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.237805] ACPI: Added _OSI(Module Device)
[ 0.237805] ACPI: Added _OSI(Processor Device)
[ 0.237805] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.237805] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.237805] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.237805] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.237805] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.251799] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP1.WLAN], AE_NOT_FOUND (20210331/dswload2-162)
[ 0.251804] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210331/psobject-220)
[ 0.251805] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[ 0.252171] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP0.VGA], AE_ALREADY_EXISTS (20210331/dswload2-326)
[ 0.252173] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
[ 0.252174] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.252175] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP0.HDAU], AE_ALREADY_EXISTS (20210331/dswload2-326)
[ 0.252177] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
[ 0.252178] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.253195] ACPI: 15 ACPI AML tables successfully acquired and loaded
[ 0.254348] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.255899] ACPI: EC: EC started
[ 0.255900] ACPI: EC: interrupt blocked
[ 0.435681] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.435683] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 0.435685] ACPI: Interpreter enabled
[ 0.435698] ACPI: (supports S0 S3 S4 S5)
[ 0.435699] ACPI: Using IOAPIC for interrupt routing
[ 0.435872] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.436118] ACPI: Enabled 5 GPEs in block 00 to 1F
[ 0.437804] ACPI: PM: Power Resource [PG00] (on)
[ 0.461945] ACPI: PM: Power Resource [PRWL] (on)
[ 0.463223] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.463233] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.463588] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[ 0.463944] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.463946] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.463972] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 0.464756] PCI host bridge to bus 0000:00
[ 0.464759] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.464762] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.464765] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.464766] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.464768] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.464770] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.464772] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfebfffff window]
[ 0.464774] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.464776] pci_bus 0000:00: root bus resource [mem 0x430000000-0xffffffffff window]
[ 0.464778] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.464798] pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
[ 0.465035] pci 0000:00:00.2: [1022:1631] type 00 class 0x080600
[ 0.465168] pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
[ 0.465255] pci 0000:00:01.1: [1022:1633] type 01 class 0x060400
[ 0.465316] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.465753] pci 0000:00:01.2: [1022:1634] type 01 class 0x060400
[ 0.465781] pci 0000:00:01.2: enabling Extended Tags
[ 0.465820] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.465921] pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
[ 0.466011] pci 0000:00:02.1: [1022:1634] type 01 class 0x060400
[ 0.466038] pci 0000:00:02.1: enabling Extended Tags
[ 0.466076] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 0.466172] pci 0000:00:02.4: [1022:1634] type 01 class 0x060400
[ 0.466198] pci 0000:00:02.4: enabling Extended Tags
[ 0.466236] pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
[ 0.466335] pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
[ 0.466424] pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
[ 0.466451] pci 0000:00:08.1: enabling Extended Tags
[ 0.466487] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.466579] pci 0000:00:08.2: [1022:1635] type 01 class 0x060400
[ 0.466605] pci 0000:00:08.2: enabling Extended Tags
[ 0.466640] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.466757] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.466893] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.467045] pci 0000:00:18.0: [1022:166a] type 00 class 0x060000
[ 0.467113] pci 0000:00:18.1: [1022:166b] type 00 class 0x060000
[ 0.467179] pci 0000:00:18.2: [1022:166c] type 00 class 0x060000
[ 0.467252] pci 0000:00:18.3: [1022:166d] type 00 class 0x060000
[ 0.467319] pci 0000:00:18.4: [1022:166e] type 00 class 0x060000
[ 0.467389] pci 0000:00:18.5: [1022:166f] type 00 class 0x060000
[ 0.467459] pci 0000:00:18.6: [1022:1670] type 00 class 0x060000
[ 0.467526] pci 0000:00:18.7: [1022:1671] type 00 class 0x060000
[ 0.467673] pci 0000:01:00.0: [10de:1f99] type 00 class 0x030000
[ 0.467685] pci 0000:01:00.0: reg 0x10: [mem 0xfb000000-0xfbffffff]
[ 0.467695] pci 0000:01:00.0: reg 0x14: [mem 0xffe0000000-0xffefffffff 64bit pref]
[ 0.467706] pci 0000:01:00.0: reg 0x1c: [mem 0xfff0000000-0xfff1ffffff 64bit pref]
[ 0.467712] pci 0000:01:00.0: reg 0x24: [io 0xf000-0xf07f]
[ 0.467718] pci 0000:01:00.0: reg 0x30: [mem 0xfc000000-0xfc07ffff pref]
[ 0.467783] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.467863] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.468115] pci 0000:01:00.1: [10de:10fa] type 00 class 0x040300
[ 0.468127] pci 0000:01:00.1: reg 0x10: [mem 0xfc080000-0xfc083fff]
[ 0.468261] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.468264] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 0.468267] pci 0000:00:01.1: bridge window [mem 0xfb000000-0xfc0fffff]
[ 0.468270] pci 0000:00:01.1: bridge window [mem 0xffe0000000-0xfff1ffffff 64bit pref]
[ 0.468333] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.468348] pci 0000:02:00.0: reg 0x10: [io 0xe000-0xe0ff]
[ 0.468367] pci 0000:02:00.0: reg 0x18: [mem 0xfc904000-0xfc904fff 64bit]
[ 0.468380] pci 0000:02:00.0: reg 0x20: [mem 0xfc900000-0xfc903fff 64bit]
[ 0.468474] pci 0000:02:00.0: supports D1 D2
[ 0.468475] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.468615] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.468619] pci 0000:00:01.2: bridge window [io 0xe000-0xefff]
[ 0.468621] pci 0000:00:01.2: bridge window [mem 0xfc900000-0xfc9fffff]
[ 0.468681] pci 0000:03:00.0: [10ec:8852] type 00 class 0x028000
[ 0.468700] pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.468725] pci 0000:03:00.0: reg 0x18: [mem 0xfc800000-0xfc8fffff 64bit]
[ 0.468850] pci 0000:03:00.0: supports D1 D2
[ 0.468850] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.468996] pci 0000:00:02.1: PCI bridge to [bus 03]
[ 0.469000] pci 0000:00:02.1: bridge window [io 0xd000-0xdfff]
[ 0.469002] pci 0000:00:02.1: bridge window [mem 0xfc800000-0xfc8fffff]
[ 0.469331] pci 0000:04:00.0: [2646:5010] type 00 class 0x010802
[ 0.469353] pci 0000:04:00.0: reg 0x10: [mem 0xfc700000-0xfc703fff 64bit]
[ 0.469565] pci 0000:00:02.4: PCI bridge to [bus 04]
[ 0.469569] pci 0000:00:02.4: bridge window [mem 0xfc700000-0xfc7fffff]
[ 0.469638] pci 0000:05:00.0: [1002:1638] type 00 class 0x030000
[ 0.469651] pci 0000:05:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.469659] pci 0000:05:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
[ 0.469665] pci 0000:05:00.0: reg 0x20: [io 0xc000-0xc0ff]
[ 0.469671] pci 0000:05:00.0: reg 0x24: [mem 0xfc500000-0xfc57ffff]
[ 0.469680] pci 0000:05:00.0: enabling Extended Tags
[ 0.469693] pci 0000:05:00.0: BAR 0: assigned to efifb
[ 0.469737] pci 0000:05:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.469779] pci 0000:05:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.469828] pci 0000:05:00.2: [1022:15df] type 00 class 0x108000
[ 0.469843] pci 0000:05:00.2: reg 0x18: [mem 0xfc400000-0xfc4fffff]
[ 0.469854] pci 0000:05:00.2: reg 0x24: [mem 0xfc5c8000-0xfc5c9fff]
[ 0.469862] pci 0000:05:00.2: enabling Extended Tags
[ 0.469951] pci 0000:05:00.3: [1022:1639] type 00 class 0x0c0330
[ 0.469963] pci 0000:05:00.3: reg 0x10: [mem 0xfc300000-0xfc3fffff 64bit]
[ 0.469993] pci 0000:05:00.3: enabling Extended Tags
[ 0.470029] pci 0000:05:00.3: PME# supported from D0 D3hot D3cold
[ 0.470086] pci 0000:05:00.4: [1022:1639] type 00 class 0x0c0330
[ 0.470098] pci 0000:05:00.4: reg 0x10: [mem 0xfc200000-0xfc2fffff 64bit]
[ 0.470127] pci 0000:05:00.4: enabling Extended Tags
[ 0.470161] pci 0000:05:00.4: PME# supported from D0 D3hot D3cold
[ 0.470218] pci 0000:05:00.5: [1022:15e2] type 00 class 0x048000
[ 0.470226] pci 0000:05:00.5: reg 0x10: [mem 0xfc580000-0xfc5bffff]
[ 0.470251] pci 0000:05:00.5: enabling Extended Tags
[ 0.470283] pci 0000:05:00.5: PME# supported from D0 D3hot D3cold
[ 0.470340] pci 0000:05:00.6: [1022:15e3] type 00 class 0x040300
[ 0.470348] pci 0000:05:00.6: reg 0x10: [mem 0xfc5c0000-0xfc5c7fff]
[ 0.470373] pci 0000:05:00.6: enabling Extended Tags
[ 0.470405] pci 0000:05:00.6: PME# supported from D0 D3hot D3cold
[ 0.470470] pci 0000:00:08.1: PCI bridge to [bus 05]
[ 0.470473] pci 0000:00:08.1: bridge window [io 0xc000-0xcfff]
[ 0.470475] pci 0000:00:08.1: bridge window [mem 0xfc200000-0xfc5fffff]
[ 0.470478] pci 0000:00:08.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.470524] pci 0000:06:00.0: [1022:7901] type 00 class 0x010601
[ 0.470557] pci 0000:06:00.0: reg 0x24: [mem 0xfc601000-0xfc6017ff]
[ 0.470567] pci 0000:06:00.0: enabling Extended Tags
[ 0.470640] pci 0000:06:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.470680] pci 0000:06:00.1: [1022:7901] type 00 class 0x010601
[ 0.470714] pci 0000:06:00.1: reg 0x24: [mem 0xfc600000-0xfc6007ff]
[ 0.470723] pci 0000:06:00.1: enabling Extended Tags
[ 0.470807] pci 0000:00:08.2: PCI bridge to [bus 06]
[ 0.470811] pci 0000:00:08.2: bridge window [mem 0xfc600000-0xfc6fffff]
[ 0.471362] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.471405] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.471441] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.471485] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.471525] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.471558] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.471591] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.471624] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.472563] acpi LNXPOWER:01: Turning OFF
[ 0.472599] ACPI: EC: interrupt unblocked
[ 0.472600] ACPI: EC: event unblocked
[ 0.472608] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.472609] ACPI: EC: GPE=0x3
[ 0.472610] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 0.472611] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.472635] iommu: Default domain type: Translated
[ 0.472635] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.472635] pci 0000:05:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.472635] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.472635] pci 0000:05:00.0: vgaarb: bridge control possible
[ 0.472635] pci 0000:05:00.0: vgaarb: setting as boot device
[ 0.472635] vgaarb: loaded
[ 0.472635] SCSI subsystem initialized
[ 0.472635] libata version 3.00 loaded.
[ 0.472635] ACPI: bus type USB registered
[ 0.472635] usbcore: registered new interface driver usbfs
[ 0.472635] usbcore: registered new interface driver hub
[ 0.472635] usbcore: registered new device driver usb
[ 0.477751] pps_core: LinuxPPS API ver. 1 registered
[ 0.477753] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.477756] PTP clock support registered
[ 0.477763] EDAC MC: Ver: 3.0.0
[ 0.477876] Registered efivars operations
[ 0.477876] NetLabel: Initializing
[ 0.477876] NetLabel: domain hash size = 128
[ 0.477876] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.477876] NetLabel: unlabeled traffic allowed by default
[ 0.477876] PCI: Using ACPI for IRQ routing
[ 0.479908] PCI: pci_cache_line_size set to 64 bytes
[ 0.480024] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.480026] e820: reserve RAM buffer [mem 0x09ef0000-0x0bffffff]
[ 0.480027] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.480027] e820: reserve RAM buffer [mem 0xc5d09000-0xc7ffffff]
[ 0.480028] e820: reserve RAM buffer [mem 0xc5d21000-0xc7ffffff]
[ 0.480029] e820: reserve RAM buffer [mem 0xc72fe000-0xc7ffffff]
[ 0.480029] e820: reserve RAM buffer [mem 0xce000000-0xcfffffff]
[ 0.480030] e820: reserve RAM buffer [mem 0x40e300000-0x40fffffff]
[ 0.480347] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.480350] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.484708] clocksource: Switched to clocksource tsc-early
[ 0.488033] VFS: Disk quotas dquot_6.6.0
[ 0.488041] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.488102] AppArmor: AppArmor Filesystem Enabled
[ 0.488123] pnp: PnP ACPI init
[ 0.488178] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.488182] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.488233] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.488246] pnp 00:02: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
[ 0.488383] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.488384] system 00:03: [io 0x040b] has been reserved
[ 0.488385] system 00:03: [io 0x04d6] has been reserved
[ 0.488386] system 00:03: [io 0x0c00-0x0c01] has been reserved
[ 0.488386] system 00:03: [io 0x0c14] has been reserved
[ 0.488387] system 00:03: [io 0x0c50-0x0c51] has been reserved
[ 0.488388] system 00:03: [io 0x0c52] has been reserved
[ 0.488388] system 00:03: [io 0x0c6c] has been reserved
[ 0.488389] system 00:03: [io 0x0c6f] has been reserved
[ 0.488389] system 00:03: [io 0x0cd8-0x0cdf] has been reserved
[ 0.488390] system 00:03: [io 0x0800-0x089f] has been reserved
[ 0.488391] system 00:03: [io 0x0b00-0x0b0f] has been reserved
[ 0.488392] system 00:03: [io 0x0b20-0x0b3f] has been reserved
[ 0.488393] system 00:03: [io 0x0900-0x090f] has been reserved
[ 0.488393] system 00:03: [io 0x0910-0x091f] has been reserved
[ 0.488394] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.488395] system 00:03: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.488396] system 00:03: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.488398] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.488399] system 00:03: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.488400] system 00:03: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.488401] system 00:03: [mem 0xff000000-0xffffffff] has been reserved
[ 0.488403] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.489293] pnp: PnP ACPI: found 4 devices
[ 0.494554] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.494604] NET: Registered protocol family 2
[ 0.494796] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.495951] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.496042] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.496184] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.496255] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.496314] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.496357] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.496390] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.496430] NET: Registered protocol family 1
[ 0.496433] NET: Registered protocol family 44
[ 0.496439] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.496441] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 0.496444] pci 0000:00:01.1: bridge window [mem 0xfb000000-0xfc0fffff]
[ 0.496446] pci 0000:00:01.1: bridge window [mem 0xffe0000000-0xfff1ffffff 64bit pref]
[ 0.496448] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.496449] pci 0000:00:01.2: bridge window [io 0xe000-0xefff]
[ 0.496451] pci 0000:00:01.2: bridge window [mem 0xfc900000-0xfc9fffff]
[ 0.496455] pci 0000:00:02.1: PCI bridge to [bus 03]
[ 0.496456] pci 0000:00:02.1: bridge window [io 0xd000-0xdfff]
[ 0.496458] pci 0000:00:02.1: bridge window [mem 0xfc800000-0xfc8fffff]
[ 0.496462] pci 0000:00:02.4: PCI bridge to [bus 04]
[ 0.496465] pci 0000:00:02.4: bridge window [mem 0xfc700000-0xfc7fffff]
[ 0.496468] pci 0000:00:08.1: PCI bridge to [bus 05]
[ 0.496470] pci 0000:00:08.1: bridge window [io 0xc000-0xcfff]
[ 0.496471] pci 0000:00:08.1: bridge window [mem 0xfc200000-0xfc5fffff]
[ 0.496473] pci 0000:00:08.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.496475] pci 0000:00:08.2: PCI bridge to [bus 06]
[ 0.496477] pci 0000:00:08.2: bridge window [mem 0xfc600000-0xfc6fffff]
[ 0.496481] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.496482] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.496482] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.496483] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.496484] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.496484] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.496485] pci_bus 0000:00: resource 10 [mem 0xd0000000-0xfebfffff window]
[ 0.496486] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[ 0.496486] pci_bus 0000:00: resource 12 [mem 0x430000000-0xffffffffff window]
[ 0.496487] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 0.496487] pci_bus 0000:01: resource 1 [mem 0xfb000000-0xfc0fffff]
[ 0.496488] pci_bus 0000:01: resource 2 [mem 0xffe0000000-0xfff1ffffff 64bit pref]
[ 0.496489] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.496490] pci_bus 0000:02: resource 1 [mem 0xfc900000-0xfc9fffff]
[ 0.496490] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.496491] pci_bus 0000:03: resource 1 [mem 0xfc800000-0xfc8fffff]
[ 0.496491] pci_bus 0000:04: resource 1 [mem 0xfc700000-0xfc7fffff]
[ 0.496492] pci_bus 0000:05: resource 0 [io 0xc000-0xcfff]
[ 0.496492] pci_bus 0000:05: resource 1 [mem 0xfc200000-0xfc5fffff]
[ 0.496493] pci_bus 0000:05: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.496494] pci_bus 0000:06: resource 1 [mem 0xfc600000-0xfc6fffff]
[ 0.496570] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.496644] pci 0000:05:00.3: extending delay after power-on from D3hot to 20 msec
[ 0.496738] pci 0000:05:00.4: extending delay after power-on from D3hot to 20 msec
[ 0.496788] PCI: CLS 64 bytes, default 64
[ 0.496796] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.496821] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.496822] pci 0000:00:00.2: PCI INT A: not connected
[ 0.496824] AMD-Vi: Lazy IO/TLB flushing enabled
[ 0.496832] Trying to unpack rootfs image as initramfs...
[ 0.496834] pci 0000:00:01.0: Adding to iommu group 0
[ 0.496840] pci 0000:00:01.1: Adding to iommu group 1
[ 0.496844] pci 0000:00:01.2: Adding to iommu group 2
[ 0.496853] pci 0000:00:02.0: Adding to iommu group 3
[ 0.496857] pci 0000:00:02.1: Adding to iommu group 4
[ 0.496862] pci 0000:00:02.4: Adding to iommu group 5
[ 0.496872] pci 0000:00:08.0: Adding to iommu group 6
[ 0.496876] pci 0000:00:08.1: Adding to iommu group 6
[ 0.496880] pci 0000:00:08.2: Adding to iommu group 6
[ 0.496887] pci 0000:00:14.0: Adding to iommu group 7
[ 0.496891] pci 0000:00:14.3: Adding to iommu group 7
[ 0.496908] pci 0000:00:18.0: Adding to iommu group 8
[ 0.496912] pci 0000:00:18.1: Adding to iommu group 8
[ 0.496916] pci 0000:00:18.2: Adding to iommu group 8
[ 0.496920] pci 0000:00:18.3: Adding to iommu group 8
[ 0.496924] pci 0000:00:18.4: Adding to iommu group 8
[ 0.496928] pci 0000:00:18.5: Adding to iommu group 8
[ 0.496932] pci 0000:00:18.6: Adding to iommu group 8
[ 0.496936] pci 0000:00:18.7: Adding to iommu group 8
[ 0.496944] pci 0000:01:00.0: Adding to iommu group 9
[ 0.496949] pci 0000:01:00.1: Adding to iommu group 9
[ 0.496954] pci 0000:02:00.0: Adding to iommu group 10
[ 0.496959] pci 0000:03:00.0: Adding to iommu group 11
[ 0.496964] pci 0000:04:00.0: Adding to iommu group 12
[ 0.496974] pci 0000:05:00.0: Adding to iommu group 6
[ 0.496976] pci 0000:05:00.2: Adding to iommu group 6
[ 0.496978] pci 0000:05:00.3: Adding to iommu group 6
[ 0.496981] pci 0000:05:00.4: Adding to iommu group 6
[ 0.496983] pci 0000:05:00.5: Adding to iommu group 6
[ 0.496986] pci 0000:05:00.6: Adding to iommu group 6
[ 0.496988] pci 0000:06:00.0: Adding to iommu group 6
[ 0.496990] pci 0000:06:00.1: Adding to iommu group 6
[ 0.498155] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.498156] AMD-Vi: Extended features (0x206d73ef22254ade): PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.498160] AMD-Vi: Interrupt remapping enabled
[ 0.498160] AMD-Vi: Virtual APIC enabled
[ 0.498161] AMD-Vi: X2APIC enabled
[ 0.533060] amd_uncore: 4 amd_df counters detected
[ 0.533063] amd_uncore: 6 amd_l3 counters detected
[ 0.533485] LVT offset 0 assigned for vector 0x400
[ 0.533648] perf: AMD IBS detected (0x000003ff)
[ 0.533653] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.534942] Initialise system trusted keyrings
[ 0.534948] Key type blacklist registered
[ 0.534972] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.535457] zbud: loaded
[ 0.538303] Key type asymmetric registered
[ 0.538304] Asymmetric key parser 'x509' registered
[ 0.538308] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.538330] io scheduler mq-deadline registered
[ 0.538331] io scheduler kyber registered
[ 0.538348] io scheduler bfq registered
[ 0.538537] pcieport 0000:00:01.1: PME: Signaling with IRQ 26
[ 0.538621] pcieport 0000:00:01.2: PME: Signaling with IRQ 27
[ 0.538695] pcieport 0000:00:02.1: PME: Signaling with IRQ 28
[ 0.538771] pcieport 0000:00:02.4: PME: Signaling with IRQ 29
[ 0.538848] pcieport 0000:00:08.1: PME: Signaling with IRQ 30
[ 0.538989] pcieport 0000:00:08.2: PME: Signaling with IRQ 31
[ 0.539047] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.539061] efifb: probing for efifb
[ 0.539074] efifb: showing boot graphics
[ 0.540495] efifb: framebuffer at 0xd0000000, using 8128k, total 8128k
[ 0.540496] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.540497] efifb: scrolling: redraw
[ 0.540497] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.540525] fbcon: Deferring console take-over
[ 0.540525] fb0: EFI VGA frame buffer device
[ 0.569509] Freeing initrd memory: 9524K
[ 0.598985] ACPI: AC: AC Adapter [ACAD] (on-line)
[ 0.599084] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.599120] ACPI: button: Power Button [PWRB]
[ 0.599176] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.599195] ACPI: button: Lid Switch [LID]
[ 0.599229] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.604197] ACPI: button: Power Button [PWRF]
[ 0.604482] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1226
[ 0.604527] Monitor-Mwait will be used to enter C-1 state
[ 0.604542] ACPI: \_SB_.PLTF.P000: Found 3 idle states
[ 0.604806] ACPI: \_SB_.PLTF.P001: Found 3 idle states
[ 0.604958] ACPI: \_SB_.PLTF.P002: Found 3 idle states
[ 0.605168] ACPI: \_SB_.PLTF.P003: Found 3 idle states
[ 0.605358] ACPI: \_SB_.PLTF.P004: Found 3 idle states
[ 0.605625] ACPI: \_SB_.PLTF.P005: Found 3 idle states
[ 0.606764] ACPI: \_SB_.PLTF.P006: Found 3 idle states
[ 0.607171] ACPI: \_SB_.PLTF.P007: Found 3 idle states
[ 0.607545] ACPI: \_SB_.PLTF.P008: Found 3 idle states
[ 0.607916] ACPI: \_SB_.PLTF.P009: Found 3 idle states
[ 0.608206] ACPI: \_SB_.PLTF.P00A: Found 3 idle states
[ 0.608643] ACPI: \_SB_.PLTF.P00B: Found 3 idle states
[ 0.608925] ACPI: \_SB_.PLTF.P00C: Found 3 idle states
[ 0.609396] ACPI: \_SB_.PLTF.P00D: Found 3 idle states
[ 0.609838] ACPI: \_SB_.PLTF.P00E: Found 3 idle states
[ 0.610278] ACPI: \_SB_.PLTF.P00F: Found 3 idle states
[ 0.613160] ACPI: \_TZ_.THRM: Invalid passive threshold
[ 0.614429] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.614432] ACPI: thermal: Thermal Zone [THRM] (47 C)
[ 0.614629] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.615662] Non-volatile memory driver v1.3
[ 0.615664] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.616957] nvme nvme0: pci function 0000:04:00.0
[ 0.616995] ahci 0000:06:00.0: version 3.0
[ 0.617437] ahci 0000:06:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.617440] ahci 0000:06:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.617638] scsi host0: ahci
[ 0.617683] ata1: SATA max UDMA/133 abar m2048@0xfc601000 port 0xfc601100 irq 33
[ 0.617888] ahci 0000:06:00.1: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.617891] ahci 0000:06:00.1: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.618046] scsi host1: ahci
[ 0.618078] ata2: SATA max UDMA/133 abar m2048@0xfc600000 port 0xfc600100 irq 37
[ 0.618106] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.618112] ehci-pci: EHCI PCI platform driver
[ 0.618133] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.618134] ohci-pci: OHCI PCI platform driver
[ 0.618139] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.618168] usbcore: registered new interface driver usbserial_generic
[ 0.618170] usbserial: USB Serial support registered for generic
[ 0.618308] rtc_cmos 00:01: RTC can wake from S4
[ 0.618589] rtc_cmos 00:01: registered as rtc0
[ 0.618716] rtc_cmos 00:01: setting system clock to 2021-10-28T07:16:29 UTC (1635405389)
[ 0.618737] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.619061] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.619154] hid: raw HID events driver (C) Jiri Kosina
[ 0.619223] ashmem: initialized
[ 0.619309] drop_monitor: Initializing network drop monitor service
[ 0.619346] Initializing XFRM netlink socket
[ 0.619391] NET: Registered protocol family 10
[ 0.624528] Segment Routing with IPv6
[ 0.624531] RPL Segment Routing with IPv6
[ 0.624554] NET: Registered protocol family 17
[ 0.625326] microcode: CPU0: patch_level=0x0a50000c
[ 0.625330] microcode: CPU1: patch_level=0x0a50000c
[ 0.625362] microcode: CPU2: patch_level=0x0a50000c
[ 0.625376] microcode: CPU3: patch_level=0x0a50000c
[ 0.625385] microcode: CPU4: patch_level=0x0a50000c
[ 0.625399] microcode: CPU5: patch_level=0x0a50000c
[ 0.625410] microcode: CPU6: patch_level=0x0a50000c
[ 0.625427] microcode: CPU7: patch_level=0x0a50000c
[ 0.625437] microcode: CPU8: patch_level=0x0a50000c
[ 0.625451] microcode: CPU9: patch_level=0x0a50000c
[ 0.625461] microcode: CPU10: patch_level=0x0a50000c
[ 0.625476] microcode: CPU11: patch_level=0x0a50000c
[ 0.625486] microcode: CPU12: patch_level=0x0a50000c
[ 0.625500] microcode: CPU13: patch_level=0x0a50000c
[ 0.625509] microcode: CPU14: patch_level=0x0a50000c
[ 0.625524] microcode: CPU15: patch_level=0x0a50000c
[ 0.625530] microcode: Microcode Update Driver: v2.2.
[ 0.625736] resctrl: L3 allocation detected
[ 0.625738] resctrl: L3DATA allocation detected
[ 0.625738] resctrl: L3CODE allocation detected
[ 0.625739] resctrl: MB allocation detected
[ 0.625739] resctrl: L3 monitoring detected
[ 0.625742] IPI shorthand broadcast: enabled
[ 0.625753] sched_clock: Marking stable (625431376, 292008)->(628441477, -2718093)
[ 0.626080] registered taskstats version 1
[ 0.626091] Loading compiled-in X.509 certificates
[ 0.626317] ACPI: battery: Slot [BAT0] (battery present)
[ 0.628072] Loaded X.509 cert 'Build time autogenerated kernel key: e702c64672c19636695ff1312cc12d56f2639519'
[ 0.630210] zswap: loaded using pool zstd/z3fold
[ 0.630638] Key type ._fscrypt registered
[ 0.630640] Key type .fscrypt registered
[ 0.630641] Key type fscrypt-provisioning registered
[ 0.630669] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.630872] PM: Magic number: 9:589:269
[ 0.631061] RAS: Correctable Errors collector initialized.
[ 0.643356] nvme nvme0: allocated 64 MiB host memory buffer.
[ 0.672368] nvme nvme0: 15/0/0 default/read/poll queues
[ 0.679558] nvme0n1: p1 p2 p3
[ 0.943190] ata2: SATA link down (SStatus 0 SControl 300)
[ 0.943264] ata1: SATA link down (SStatus 0 SControl 300)
[ 0.944628] Freeing unused decrypted memory: 2036K
[ 0.944911] Freeing unused kernel image (initmem) memory: 1792K
[ 0.944915] Write protecting the kernel read-only data: 26624k
[ 0.945391] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.945552] Freeing unused kernel image (rodata/data gap) memory: 796K
[ 0.969043] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.969048] rodata_test: all tests were successful
[ 0.969052] Run /init as init process
[ 0.969053] with arguments:
[ 0.969054] /init
[ 0.969054] splash
[ 0.969055] with environment:
[ 0.969055] HOME=/
[ 0.969055] TERM=linux
[ 0.969056] BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64
[ 1.346286] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 1.346296] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 1
[ 1.346383] xhci_hcd 0000:05:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 1.346688] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[ 1.346690] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.346692] usb usb1: Product: xHCI Host Controller
[ 1.346693] usb usb1: Manufacturer: Linux 5.13.19-2-MANJARO xhci-hcd
[ 1.346694] usb usb1: SerialNumber: 0000:05:00.3
[ 1.346780] hub 1-0:1.0: USB hub found
[ 1.346785] hub 1-0:1.0: 4 ports detected
[ 1.346917] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 1.346919] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 2
[ 1.346921] xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.346930] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.346941] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[ 1.346943] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.346944] usb usb2: Product: xHCI Host Controller
[ 1.346945] usb usb2: Manufacturer: Linux 5.13.19-2-MANJARO xhci-hcd
[ 1.346946] usb usb2: SerialNumber: 0000:05:00.3
[ 1.347114] hub 2-0:1.0: USB hub found
[ 1.347120] hub 2-0:1.0: 2 ports detected
[ 1.347603] xhci_hcd 0000:05:00.4: xHCI Host Controller
[ 1.347610] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 3
[ 1.347614] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.347616] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.347695] xhci_hcd 0000:05:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 1.347998] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[ 1.348001] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.348003] usb usb3: Product: xHCI Host Controller
[ 1.348004] usb usb3: Manufacturer: Linux 5.13.19-2-MANJARO xhci-hcd
[ 1.348005] usb usb3: SerialNumber: 0000:05:00.4
[ 1.348084] hub 3-0:1.0: USB hub found
[ 1.348091] hub 3-0:1.0: 4 ports detected
[ 1.348261] xhci_hcd 0000:05:00.4: xHCI Host Controller
[ 1.348264] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 4
[ 1.348266] xhci_hcd 0000:05:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.348277] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.348293] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[ 1.348295] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.348297] usb usb4: Product: xHCI Host Controller
[ 1.348298] usb usb4: Manufacturer: Linux 5.13.19-2-MANJARO xhci-hcd
[ 1.348299] usb usb4: SerialNumber: 0000:05:00.4
[ 1.348381] hub 4-0:1.0: USB hub found
[ 1.348385] hub 4-0:1.0: 2 ports detected
[ 1.348426] usb: port power management may be unreliable
[ 1.348774] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.448130] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 1.506047] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.542691] random: fast init done
[ 1.557578] tsc: Refined TSC clocksource calibration: 3218.325 MHz
[ 1.557585] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2e63e96becd, max_idle_ns: 440795368175 ns
[ 1.557651] clocksource: Switched to clocksource tsc
[ 1.583340] systemd[1]: systemd 249.4-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.593709] usb 1-4: new full-speed USB device number 2 using xhci_hcd
[ 1.597120] systemd[1]: Detected architecture x86-64.
[ 1.597684] systemd[1]: Hostname set to <emilio-hp-pavilion>.
[ 1.600348] usb 3-3: new high-speed USB device number 2 using xhci_hcd
[ 1.690734] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 1.729684] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.731079] systemd[1]: Created slice Slice /system/getty.
[ 1.731279] systemd[1]: Created slice Slice /system/modprobe.
[ 1.731443] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.731531] systemd[1]: Created slice User and Session Slice.
[ 1.731570] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.731665] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.731695] systemd[1]: Reached target Login Prompts.
[ 1.731713] systemd[1]: Reached target Remote File Systems.
[ 1.731719] systemd[1]: Reached target Slice Units.
[ 1.731729] systemd[1]: Reached target Swaps.
[ 1.731738] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[ 1.731772] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.731829] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.732412] systemd[1]: Listening on Process Core Dump Socket.
[ 1.732483] systemd[1]: Listening on Journal Audit Socket.
[ 1.732522] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.732566] systemd[1]: Listening on Journal Socket.
[ 1.733237] systemd[1]: Listening on udev Control Socket.
[ 1.733279] systemd[1]: Listening on udev Kernel Socket.
[ 1.733668] systemd[1]: Mounting Huge Pages File System...
[ 1.734190] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.734735] systemd[1]: Mounting Kernel Debug File System...
[ 1.735238] systemd[1]: Mounting Kernel Trace File System...
[ 1.736427] systemd[1]: Mounting Temporary Directory /tmp...
[ 1.736909] systemd[1]: Starting Load AppArmor profiles...
[ 1.737644] systemd[1]: Starting Create List of Static Device Nodes...
[ 1.738205] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 1.738766] systemd[1]: Starting Load Kernel Module configfs...
[ 1.739343] systemd[1]: Starting Load Kernel Module drm...
[ 1.739723] systemd[1]: Starting Load Kernel Module fuse...
[ 1.740168] random: lvm: uninitialized urandom read (4 bytes read)
[ 1.740199] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 1.740239] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 1.741437] systemd[1]: Starting Load Kernel Modules...
[ 1.742119] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.742163] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 1.742911] systemd[1]: Starting Coldplug All udev Devices...
[ 1.744156] usb 3-3: New USB device found, idVendor=30c9, idProduct=0035, bcdDevice= 0.03
[ 1.744163] usb 3-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.744164] usb 3-3: Product: HP TrueVision HD Camera
[ 1.744165] usb 3-3: Manufacturer: DLEQNA1UIF7E6J
[ 1.744166] usb 3-3: SerialNumber: 0001
[ 1.744180] systemd[1]: Mounted Huge Pages File System.
[ 1.744394] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.744491] systemd[1]: Mounted Kernel Debug File System.
[ 1.744595] systemd[1]: Mounted Kernel Trace File System.
[ 1.744682] systemd[1]: Mounted Temporary Directory /tmp.
[ 1.744843] systemd[1]: Finished Create List of Static Device Nodes.
[ 1.745074] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 1.745231] systemd[1]: Finished Load Kernel Module configfs.
[ 1.745380] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 1.745465] systemd[1]: Finished Load Kernel Module drm.
[ 1.746051] systemd[1]: Mounting Kernel Configuration File System...
[ 1.746764] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null). Quota mode: none.
[ 1.747676] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 1.748091] systemd[1]: Mounted Kernel Configuration File System.
[ 1.748242] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 1.748957] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 1.750803] Linux agpgart interface v0.103
[ 1.750883] fuse: init (API version 7.34)
[ 1.751289] systemd[1]: Starting Load/Save Random Seed...
[ 1.751348] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 1.752144] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 1.752776] systemd[1]: Starting Setup Virtual Console...
[ 1.753002] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 1.753115] systemd[1]: Finished Load Kernel Module fuse.
[ 1.753756] usb 1-4: New USB device found, idVendor=0bda, idProduct=2852, bcdDevice= 0.00
[ 1.753765] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.753768] usb 1-4: Product: Bluetooth Radio
[ 1.753769] usb 1-4: Manufacturer: Realtek
[ 1.753770] usb 1-4: SerialNumber: 00e04c000001
[ 1.753815] systemd[1]: Mounting FUSE Control File System...
[ 1.755373] systemd[1]: Mounted FUSE Control File System.
[ 1.764739] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 1.764925] systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being skipped.
[ 1.766802] systemd[1]: Starting Journal Service...
[ 1.768611] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 1.772611] systemd[1]: Finished Setup Virtual Console.
[ 1.795443] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 1.795531] audit: type=1130 audit(1635405390.672:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.795633] systemd[1]: Reached target Preparation for Local File Systems.
[ 1.795657] systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
[ 1.795803] audit: type=1400 audit(1635405390.672:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=348 comm="apparmor_parser"
[ 1.797660] systemd[1]: Started Journal Service.
[ 1.797727] audit: type=1130 audit(1635405390.675:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.799188] audit: type=1130 audit(1635405390.675:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.801434] audit: type=1400 audit(1635405390.679:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=349 comm="apparmor_parser"
[ 1.802257] audit: type=1400 audit(1635405390.679:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=349 comm="apparmor_parser"
[ 1.803610] systemd-journald[355]: Received client request to flush runtime journal.
[ 1.834667] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[ 1.858063] audit: type=1400 audit(1635405390.735:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=352 comm="apparmor_parser"
[ 1.869384] audit: type=1400 audit(1635405390.745:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=350 comm="apparmor_parser"
[ 1.895845] audit: type=1130 audit(1635405390.772:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.947573] nvidia: loading out-of-tree module taints kernel.
[ 1.947595] nvidia: module license 'NVIDIA' taints kernel.
[ 1.947597] Disabling lock debugging due to kernel taint
[ 1.958874] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 1.973977] nvidia-nvlink: Nvlink Core is being initialized, major device number 236
[ 1.974781] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 1.974909] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 1.974995] input: HP Wireless hotkeys as /devices/virtual/input/input4
[ 1.977862] hp_accel: laptop model unknown, using default axes configuration
[ 1.979855] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.980355] acpi device:08: registered as cooling_device16
[ 1.980469] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:07/LNXVIDEO:00/input/input5
[ 1.980698] ACPI: video: [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 1.987960] lis3lv02d: 8 bits 3DC sensor found
[ 1.988744] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.013747] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input6
[ 2.018069] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
[ 2.049086] EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 2.057681] input: ELAN0718:00 04F3:30FD Mouse as /devices/platform/AMDI0010:03/i2c-1/i2c-ELAN0718:00/0018:04F3:30FD.0001/input/input7
[ 2.057745] input: ELAN0718:00 04F3:30FD Touchpad as /devices/platform/AMDI0010:03/i2c-1/i2c-ELAN0718:00/0018:04F3:30FD.0001/input/input9
[ 2.057830] hid-generic 0018:04F3:30FD.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN0718:00 04F3:30FD] on i2c-ELAN0718:00
[ 2.064970] input: PC Speaker as /devices/platform/pcspkr/input/input10
[ 2.065376] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xff00, revision 15
[ 2.065383] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 2.065454] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xff20
[ 2.068982] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 2.069074] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 2.069082] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 2.069407] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 2.069409] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 2.071494] cryptd: max_cpu_qlen set to 1000
[ 2.080440] AVX2 version of gcm_enc/dec engaged.
[ 2.080470] AES CTR mode by8 optimization enabled
[ 2.081176] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 2.081184] r8169 0000:02:00.0: enabling device (0000 -> 0003)
[ 2.095715] libphy: r8169: probed
[ 2.095856] r8169 0000:02:00.0 eth0: RTL8168h/8111h, 48:9e:bd:28:ee:58, XID 541, IRQ 74
[ 2.095860] r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 2.270962] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.63.01 Tue Aug 3 20:30:55 UTC 2021
[ 2.285449] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 2.289814] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.289818] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 2.291064] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.291077] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.291083] input: HP WMI hotkeys as /devices/virtual/input/input11
[ 2.291536] snd_hda_intel 0000:05:00.6: enabling device (0000 -> 0002)
[ 2.366338] r8169 0000:02:00.0 eno1: renamed from eth0
[ 2.380812] input: ELAN0718:00 04F3:30FD Mouse as /devices/platform/AMDI0010:03/i2c-1/i2c-ELAN0718:00/0018:04F3:30FD.0001/input/input12
[ 2.380873] input: ELAN0718:00 04F3:30FD Touchpad as /devices/platform/AMDI0010:03/i2c-1/i2c-ELAN0718:00/0018:04F3:30FD.0001/input/input14
[ 2.380938] hid-multitouch 0018:04F3:30FD.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN0718:00 04F3:30FD] on i2c-ELAN0718:00
[ 2.412915] mc: Linux media interface: v0.10
[ 2.416212] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input15
[ 2.416281] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input16
[ 2.416314] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input17
[ 2.416343] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input18
[ 2.418962] mousedev: PS/2 mouse device common for all mice
[ 2.442271] videodev: Linux video capture interface: v2.00
[ 2.449632] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC285: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 2.449638] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.449640] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 2.449641] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 2.449642] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 2.449643] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 2.449644] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 2.450968] ccp 0000:05:00.2: enabling device (0000 -> 0002)
[ 2.451164] ccp 0000:05:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[ 2.461300] ccp 0000:05:00.2: tee enabled
[ 2.461305] ccp 0000:05:00.2: psp enabled
[ 2.516698] Bluetooth: Core ver 2.22
[ 2.516724] NET: Registered protocol family 31
[ 2.516726] Bluetooth: HCI device and connection manager initialized
[ 2.516731] Bluetooth: HCI socket layer initialized
[ 2.516733] Bluetooth: L2CAP socket layer initialized
[ 2.516737] Bluetooth: SCO socket layer initialized
[ 2.524372] kvm: Nested Virtualization enabled
[ 2.524377] SVM: kvm: Nested Paging enabled
[ 2.524398] SVM: Virtual VMLOAD VMSAVE supported
[ 2.524399] SVM: Virtual GIF supported
[ 2.527426] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input19
[ 2.527474] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input20
[ 2.527857] usb 3-3: Found UVC 1.10 device HP TrueVision HD Camera (30c9:0035)
[ 2.532741] usbcore: registered new interface driver btusb
[ 2.533685] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=000a lmp_ver=0b lmp_subver=8852
[ 2.535146] input: HP TrueVision HD Camera: HP Tru as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-3/3-3:1.0/input/input21
[ 2.535329] usbcore: registered new interface driver uvcvideo
[ 2.535609] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 2.535615] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852au_fw.bin
[ 2.536232] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852au_config.bin
[ 2.536589] Bluetooth: hci0: RTL: cfg_sz 6, total sz 46195
[ 2.538915] MCE: In-kernel MCE decoding enabled.
[ 2.539210] NET: Registered protocol family 42
[ 2.570410] Generic FE-GE Realtek PHY r8169-0-200:00: attached PHY driver (mii_bus:phy_addr=r8169-0-200:00, irq=MAC)
[ 2.609969] snd_rn_pci_acp3x 0000:05:00.5: enabling device (0000 -> 0002)
[ 2.612083] intel_rapl_common: Found RAPL domain package
[ 2.612086] intel_rapl_common: Found RAPL domain core
[ 2.767129] r8169 0000:02:00.0 eno1: Link is Down
[ 2.923627] Bluetooth: hci0: RTL: fw version 0xd9a91d69
[ 3.032216] [drm] amdgpu kernel modesetting enabled.
[ 3.032238] vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
[ 3.032611] ATPX version 1, functions 0x00000201
[ 3.032654] ATPX Hybrid Graphics
[ 3.032791] amdgpu: Virtual CRAT table created for CPU
[ 3.032808] amdgpu: Topology: Add CPU node
[ 3.032897] checking generic (d0000000 7f0000) vs hw (d0000000 10000000)
[ 3.032899] fb0: switching to amdgpudrmfb from EFI VGA
[ 3.032986] amdgpu 0000:05:00.0: vgaarb: deactivate vga console
[ 3.033016] amdgpu 0000:05:00.0: enabling device (0006 -> 0007)
[ 3.033087] [drm] initializing kernel modesetting (RENOIR 0x1002:0x1638 0x103C:0x88DD 0xC5).
[ 3.033090] amdgpu 0000:05:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
[ 3.087573] [drm] register mmio base: 0xFC500000
[ 3.087583] [drm] register mmio size: 524288
[ 3.087592] [drm] PCIE atomic ops is not supported
[ 3.088749] [drm] add ip block number 0 <soc15_common>
[ 3.088751] [drm] add ip block number 1 <gmc_v9_0>
[ 3.088751] [drm] add ip block number 2 <vega10_ih>
[ 3.088752] [drm] add ip block number 3 <psp>
[ 3.088752] [drm] add ip block number 4 <smu>
[ 3.088753] [drm] add ip block number 5 <gfx_v9_0>
[ 3.088754] [drm] add ip block number 6 <sdma_v4_0>
[ 3.088755] [drm] add ip block number 7 <dm>
[ 3.088756] [drm] add ip block number 8 <vcn_v2_0>
[ 3.088756] [drm] add ip block number 9 <jpeg_v2_0>
[ 3.088768] amdgpu 0000:05:00.0: amdgpu: Fetched VBIOS from VFCT
[ 3.088771] amdgpu: ATOM BIOS: 113-CEZANNE-018
[ 3.089676] [drm] VCN decode is enabled in VM mode
[ 3.089678] [drm] VCN encode is enabled in VM mode
[ 3.089679] [drm] JPEG decode is enabled in VM mode
[ 3.089711] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 3.089717] amdgpu 0000:05:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
[ 3.089719] amdgpu 0000:05:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 3.089721] amdgpu 0000:05:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 3.089726] [drm] Detected VRAM RAM=512M, BAR=512M
[ 3.089727] [drm] RAM width 128bits DDR4
[ 3.089765] [drm] amdgpu: 512M of VRAM memory ready
[ 3.089767] [drm] amdgpu: 3072M of GTT memory ready.
[ 3.089768] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 3.089884] [drm] PCIE GART of 1024M enabled.
[ 3.089886] [drm] PTB located at 0x000000F400900000
[ 3.094204] [drm] Loading DMUB firmware via PSP: version=0x01010019
[ 3.094802] [drm] Found VCN firmware Version ENC: 1.14 DEC: 5 VEP: 0 Revision: 20
[ 3.094813] amdgpu 0000:05:00.0: amdgpu: Will use PSP to load VCN firmware
[ 3.137069] loop: module loaded
[ 3.198531] loop0: detected capacity change from 0 to 8
[ 3.204996] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.300342] random: crng init done
[ 3.300344] random: 6 urandom warning(s) missed due to ratelimiting
[ 3.705185] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.705188] Bluetooth: BNEP filters: protocol multicast
[ 3.705191] Bluetooth: BNEP socket layer initialized
[ 3.709174] NET: Registered protocol family 38
[ 3.822499] [drm] reserve 0x400000 from 0xf41f800000 for PSP TMR
[ 3.904878] amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 3.913409] amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 3.913412] amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 3.915835] amdgpu 0000:05:00.0: amdgpu: SMU is initialized successfully!
[ 3.917147] [drm] kiq ring mec 2 pipe 1 q 0
[ 3.919889] [drm] Display Core initialized with v3.2.132!
[ 3.920337] [drm] DMUB hardware initialized: version=0x01010019
[ 4.132637] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 4.132656] [drm] JPEG decode initialized successfully.
[ 4.134165] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 4.134301] amdgpu: Virtual CRAT table created for GPU
[ 4.135612] amdgpu: Topology: Add dGPU node [0x1638:0x1002]
[ 4.135614] kfd kfd: amdgpu: added device 1002:1638
[ 4.135616] amdgpu 0000:05:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 18, active_cu_number 28
[ 4.138339] [drm] fb mappable at 0x410CD2000
[ 4.138345] [drm] vram apper at 0x410000000
[ 4.138345] [drm] size 8294400
[ 4.138346] [drm] fb depth is 24
[ 4.138347] [drm] pitch is 7680
[ 4.138490] fbcon: amdgpudrmfb (fb0) is primary device
[ 4.138492] fbcon: Deferring console take-over
[ 4.138495] amdgpu 0000:05:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 4.170749] amdgpu 0000:05:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 4.170759] amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 4.170763] amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 4.170766] amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 4.170768] amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 4.170770] amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 4.170772] amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 4.170774] amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 4.170776] amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 4.170779] amdgpu 0000:05:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 4.170781] amdgpu 0000:05:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 4.170784] amdgpu 0000:05:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 4.170786] amdgpu 0000:05:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 4.170788] amdgpu 0000:05:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 4.170791] amdgpu 0000:05:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 4.176109] [drm] Initialized amdgpu 3.41.0 20150101 for 0000:05:00.0 on minor 1
[ 8.261767] kauditd_printk_skb: 107 callbacks suppressed
[ 8.261775] audit: type=1131 audit(1635405397.139:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8.633641] audit: type=1131 audit(1635405397.509:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9.133969] Generic FE-GE Realtek PHY r8169-0-200:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
[ 9.133996] r8169 0000:02:00.0 eno1: Link is Up - 100Mbps/Full (downshifted) - flow control rx/tx
[ 9.134023] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[ 13.009595] audit: type=1131 audit(1635405401.885:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.667074] audit: type=1130 audit(1635405402.545:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.672209] fbcon: Taking over console
[ 13.675406] audit: type=1131 audit(1635405402.552:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.681149] audit: type=1131 audit(1635405402.559:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.730320] Console: switching to colour frame buffer device 240x67
[ 20.879528] audit: type=1100 audit(1635405409.755:108): pid=1476 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="emilio" exe="/usr/bin/login" hostname=emilio-hp-pavilion addr=? terminal=/dev/tty2 res=success'
[ 20.883022] audit: type=1101 audit(1635405409.759:109): pid=1476 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="emilio" exe="/usr/bin/login" hostname=emilio-hp-pavilion addr=? terminal=/dev/tty2 res=success'
[ 20.885167] audit: type=1103 audit(1635405409.762:110): pid=1476 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="emilio" exe="/usr/bin/login" hostname=emilio-hp-pavilion addr=? terminal=/dev/tty2 res=success'
[ 20.885307] audit: type=1006 audit(1635405409.762:111): pid=1476 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=8 res=1
[ 20.885318] audit: type=1300 audit(1635405409.762:111): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffec7e865a0 a2=4 a3=3e8 items=0 ppid=1 pid=1476 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=8 comm="login" exe="/usr/bin/login" subj==unconfined key=(null)
[ 20.885323] audit: type=1327 audit(1635405409.762:111): proctitle=2F62696E2F6C6F67696E002D70002D2D
[ 20.902781] audit: type=1130 audit(1635405409.779:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.908661] audit: type=1101 audit(1635405409.785:113): pid=1701 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="emilio" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.908666] audit: type=1103 audit(1635405409.785:114): pid=1701 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="emilio" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 20.908730] audit: type=1006 audit(1635405409.785:115): pid=1701 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=9 res=1
[ 24.968309] ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210331/nsarguments-61)
[ 26.952034] kauditd_printk_skb: 10 callbacks suppressed
[ 26.952037] audit: type=1334 audit(1635405415.829:122): prog-id=17 op=LOAD
[ 26.952189] audit: type=1334 audit(1635405415.829:123): prog-id=18 op=LOAD
[ 26.993003] audit: type=1130 audit(1635405415.869:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.051693] audit: type=1130 audit(1635405415.929:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.054547] audit: type=1130 audit(1635405415.932:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.093136] audit: type=1130 audit(1635405415.969:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.162451] audit: type=1130 audit(1635405416.039:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.290845] Bluetooth: RFCOMM TTY layer initialized
[ 27.290856] Bluetooth: RFCOMM socket layer initialized
[ 27.290862] Bluetooth: RFCOMM ver 1.11
[ 27.566643] rfkill: input handler disabled
[ 27.626169] audit: type=1130 audit(1635405416.502:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.626803] audit: type=1334 audit(1635405416.502:130): prog-id=19 op=LOAD
[ 27.626900] audit: type=1334 audit(1635405416.502:131): prog-id=20 op=LOAD
[ 57.628878] kauditd_printk_skb: 2 callbacks suppressed
[ 57.628891] audit: type=1131 audit(1635405446.505:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.709058] audit: type=1131 audit(1635405446.585:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.783965] audit: type=1334 audit(1635405446.662:136): prog-id=14 op=UNLOAD
[ 57.783977] audit: type=1334 audit(1635405446.662:137): prog-id=13 op=UNLOAD
[ 57.783982] audit: type=1334 audit(1635405446.662:138): prog-id=12 op=UNLOAD
[ 57.930412] audit: type=1334 audit(1635405446.809:139): prog-id=21 op=UNLOAD
[ 57.930429] audit: type=1334 audit(1635405446.809:140): prog-id=20 op=UNLOAD
[ 57.930436] audit: type=1334 audit(1635405446.809:141): prog-id=19 op=UNLOAD
[ 60.536951] audit: type=1334 audit(1635405449.412:142): prog-id=22 op=LOAD
[ 60.584390] audit: type=1130 audit(1635405449.462:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 64.772842] audit: type=1100 audit(1635405453.649:144): pid=3778 uid=1000 auid=1000 ses=8 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="emilio" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 64.774889] audit: type=1101 audit(1635405453.652:145): pid=3778 uid=1000 auid=1000 ses=8 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="emilio" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 64.775038] audit: type=1110 audit(1635405453.652:146): pid=3778 uid=1000 auid=1000 ses=8 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 64.776009] audit: type=1105 audit(1635405453.652:147): pid=3778 uid=1000 auid=1000 ses=8 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
