about a week ago i ran the command sudo pacman -Syu to update my system, however i ctrl-C since it took too long (or i turned the computer off, can’t remember which one), later i tried turning on my laptop and it gave the error file /boot/vmlinuz not found, i googled the error and found a way to fix it, i followed the steps:
1.get an usb with manjaro on it.
2.open terminal after booting using the usb and run the following commands
sudo su -
manjaro-chroot -a
pacman-mirrors -f 5 && pacman -Syyu
update-grub
exit
after that i turned the laptop off, removed the usb, turned the laptop on and this time it didnt load manjaro at all, it simply loaded memtest, which was odd, i googled some more and found that u can press ESC key to show the grub boot menu, i did that and all the menu showed was memtest, no manjaro(manjaro was an option before running the commands i ran)
do note that when i ran the command manjaro-chroot -a the following errors were shown in terminal
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
How can i fix this? is there any additional information i need to provide ? if so please tell me can i get access to such info. Thank you.
I didn’t write that. You replied to a post, correcting it, and I replied to yours and wrote “as well as blabla…” adding to the correction. This works but is not correct:
sudo manjaro-chroot -a
sudo update-grub
I see that often copy/pasted, and despite telling it every time, people continue the same copy/paste of the same erroneous commands.
