Manjaro not booting after interrupted update and attempted reinstallation of grub
So my incredibly adorable menace of a cat managed to turn off my surge protector during an update to my computer, and I am now not able to get back into my main machine. I have tried the standard fixes listed at
and at
and none of these solutions seem to work. I have loaded into a bootable medium and used
manjaro-chroot - a
to get into my system, and I made sure to finish all of the installations that got interrupted. Everything seems to be fine, but then when I go to reboot the system, I can’t even get in. I put my GRUB bootloader to the top of the boot priority, and it just black-screens and kicks me back to UEFI/BIOS. For reference, here is what I am seeing in my chroot:
[manjaro /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=GRUB
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
done
[manjaro /]# update-grub
done
I also made sure to check my efibootmgr to see that the proper boot order was loaded, and everything seems to be in order. For some context, here is my grub.cfg file:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root e8776534-c4e1-4691-baab-b172cbc83ce2
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod ext2
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=hidden
  set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
  set timeout=0
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/15_ostree ###
### END /etc/grub.d/15_ostree ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/25_bli ###
if [ "$grub_platform" = "efi" ]; then
  insmod bli
fi
### END /etc/grub.d/25_bli ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
        menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
                fwsetup
fi
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/35_fwupd ###
### END /etc/grub.d/35_fwupd ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
    menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
        search --fs-uuid --no-floppy --set=root  e8776534-c4e1-4691-baab-b172cbc83ce2
        linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
If someone could help me out, I would greatly appreciate it. Thank you!
It’s not grub that is/was your problem.
You have no kernel installed.
in chroot, use pacman to install one
(not mhwd-kernel -i - it won’t work in chroot),
then mkinitcpio -P and update-grub
Thank you for the response! I am showing
[manjaro /]# mhwd-kernel -li
Currently running: 6.10.11-2-MANJARO (linux610)
   * linux61
   * linux66
so I thought that they were installed, but I’ll try reinstalling see if that fixes it
yes - simply reinstall one of them
but not via mhwd-kernel
That worked! Thank you so much!! This has been driving me nuts for the past 6 hours
