Manjaro not boot when usb3 device connected
I have latest stable Manjaro Gnome on my HP 360 laptop. System is fully updated. If I connect an usb mouse or usb keyboard and power on laptop, there is only blank (black) screen without any logo, progressbar or nothing. In this state is laptop stucked until I disconnect usb device and do “hard restart” :slight_smile:
I also try to modify /etc/mkinitcpio.confand add
MODULES=(ohci-pci ehci-pci xhci_pci ohci_hcd ehci_hcd xhci_hcd hid_generic hid usbhid evdev)
but this modofication not resolve anything. What I can do please to boot with usb device connected?
open your bios and disable the option to boot from external devices. undo the changes in mkinitcpio and run
sudo mkinitcpio -P
to take effect.
ok I disable whole boot functionallity in bios and also revert changes in mkinit but nothing changes.
There are many ‘HP 360 laptops’, we need more information. Please post the output of:
inxi -Fazy
here is output of inxi:
  Kernel: 6.6.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=fcad83dc-ef4f-4106-b1ec-703734d1fd55 rw quiet splash
    resume=UUID=013be4dc-f11e-458e-848b-4793546d8984 udev.log_priority=3
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Convertible System: HP product: HP Pavilion x360 Convertible 14-dw0xxx
    v: N/A serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 8775 v: 16.31 serial: <superuser required> UEFI: AMI
    v: F.17 date: 08/06/2020
  ID-1: BAT0 charge: 36.5 Wh (100.0%) condition: 36.5/36.5 Wh (100.0%)
    volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: not charging
  Device-1: hid-0018:04F3:2B50.0002-battery model: ELAN2513:00 04F3:2B50
    serial: N/A charge: N/A status: N/A
  Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBC
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 486 high: 1089 min/max: 400/3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 1089 6: 400 7: 400 8: 400 bogomips: 19048
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
    active: DP-3,DP-4 off: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:8a56 class-ID: 0300
  Device-2: Luxvisions Innotech HP Wide Vision HD Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2
    chip-ID: 30c9:000e class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: DP-3 model: Dell 1908WFP serial: <filter> built: 2008
    res: 1440x900 dpi: 90 gamma: 1.2 size: 408x255mm (16.06x10.04")
    diag: 481mm (18.9") ratio: 16:10 modes: max: 1440x900 min: 720x400
  Monitor-2: DP-4 model: EIZO NANAO S2402W serial: <filter> built: 2010
    res: 1920x1200 dpi: 94 gamma: 1.2 size: 519x324mm (20.43x12.76")
    diag: 616mm (24.2") ratio: 16:10 modes: max: 1920x1200 min: 720x400
  Monitor-3: eDP-1 model: BOE Display 0x0868 built: 2019 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
    device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
    device-ID: 8086:8a56 memory: 14.96 GiB unified: yes display-ID: :0.0
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-icl
    alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
    chip-ID: 8086:34c8 class-ID: 0401
  Device-2: HP USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6.2:5
    chip-ID: 03f0:056b class-ID: 0300 serial: <filter>
  API: ALSA v: k6.6.0-1-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.4:4
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s13f0u4u4 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: wwan0 state: down mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 3060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 953.87 GiB used: 52.79 GiB (5.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S1024G
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 29.9 C
    scheme: GPT
  ID-1: / raw-size: 936.72 GiB size: 920.94 GiB (98.32%) used: 52.79 GiB (5.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 338 Uptime: 4m wakeups: 301 Memory: total: 16 GiB note: est.
  available: 15.32 GiB used: 3.24 GiB (21.2%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1094 libs: 352 tools: gnome-software,pamac
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.30
Two things that hit me immediately:
  • switch from the experimental 6.6 kernel to the regular 6.5 or the 6.1LTS
  • update your bios, your F.17 is 3 years out of date, latest is F.32 from August 25 2023
So I updated bios to the last one and switch kernel to 6.5 but behavior is same :frowning:
please plug in the devices and post the output of these 2 commands with plugged devices.
lsusb
ok, here is output of inxi:
  Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
  Mobo: HP model: 8775 v: 16.35 serial: <superuser required> UEFI: AMI
    v: F.32 date: 08/09/2023
  ID-1: BAT0 charge: 36.9 Wh (100.0%) condition: 36.9/36.9 Wh (100.0%)
    volts: 12.8 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
  System RAM: total: 16 GiB note: est. available: 15.32 GiB
    used: 3.87 GiB (25.3%)
    desc: 1x6 MiB
  Speed (MHz): avg: 737 high: 1301 min/max: 400/3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1300 2: 400 3: 400 4: 400
    5: 1301 6: 1300 7: 400 8: 400 bogomips: 19048
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
    avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
    est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    drv: iris x11: drv: iris
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6.2:12
  API: ALSA v: k6.1.55-1-MANJARO status: kernel-api tools: N/A
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.4:7
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 59.7 GiB (6.3%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 26.9 C
    scheme: GPT
  ID-1: / raw-size: 936.72 GiB size: 920.94 GiB (98.32%) used: 59.7 GiB (6.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: fcad83dc-ef4f-4106-b1ec-703734d1fd55
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 1A56-922B
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 013be4dc-f11e-458e-848b-4793546d8984
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 2-4:5 info: HP HP USB-C Dock G5 ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 03f0:066b
  Hub-4: 2-4.3:6 info: HP USB5734 ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 03f0:076b
  Device-1: 2-4.4:7 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 256mA
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-4:2 info: Luxvisions Innotech HP Wide Vision HD Camera
    type: video driver: uvcvideo interfaces: 2 rev: 2.0
  Hub-6: 3-6:11 info: HP HP USB-C Dock G5 ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 03f0:036b
  Device-1: 3-6.2:12 info: HP USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Hub-7: 3-6.3:13 info: HP USB2734 ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 03f0:086b
  Device-1: 3-6.3.3:15 info: China Resource Semico USB Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1a2c:2c27 class-ID: 0300
  Device-2: 3-6.3.4:16 info: A4Tech OpticalMouse type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 09da:3519 class-ID: 0300
  Device-3: 3-6.5:14 info: HP HP USB-C Dock G5 type: billboard,HID
    lanes: 1 mode: 1.1 chip-ID: 03f0:046b class-ID: 0300 serial: <filter>
  Device-4: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-8: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 57.0 C mobo: N/A
  Processes: 308 Uptime: 3h 10m wakeups: 293 Init: systemd v: 254
  Packages: pm: pacman pkgs: 1106 libs: 353 tools: gnome-software,pamac
and lsusb:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 014: ID 03f0:046b HP, Inc HP USB-C Dock G5
Bus 003 Device 016: ID 09da:3519 A4Tech Co., Ltd. A4Tech OpticalMouse
Bus 003 Device 015: ID 1a2c:2c27 China Resource Semico Co., Ltd USB Keyboard
Bus 003 Device 013: ID 03f0:086b HP, Inc USB2734
Bus 003 Device 012: ID 03f0:056b HP, Inc USB Audio
Bus 003 Device 011: ID 03f0:036b HP, Inc HP USB-C Dock G5
Bus 003 Device 002: ID 30c9:000e Luxvisions Innotech Limited HP Wide Vision HD Camera
Bus 003 Device 003: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 007: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 002 Device 006: ID 03f0:076b HP, Inc USB5734
Bus 002 Device 005: ID 03f0:066b HP, Inc HP USB-C Dock G5
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
edit: mouse and keyboard are connected via usb-c HP dock. If mouse or keyboard are connected directly to the laptop’s usb ports, boot issue is still present.
