Manjaro no recononce el monitor externo con driver nvidia
Hola,
utilizo manjaro en mi laptop mas un monitor externo, funciona bien con el driver nouveau, pero al instalar el driver hibrido de nvidia, no reconoce el monitor externo.
esta es mi configuración
OS: Manjaro Linux x86_64
Host: OMEN by HP Laptop 16-c0xxx
Kernel: 6.5.13-4-MANJARO
Uptime: 2 mins
Packages: 1193 (pacman)
Shell: bash 5.2.21
Resolution: 1920x1080
DE: Plasma 5.27.10
WM: KWin
WM Theme: Oxígeno
Theme: [Plasma], Breeze [GTK2/3]
Icons: [Plasma], breeze [GTK2/3]
Terminal: konsole
CPU: AMD Ryzen 7 5800H with Radeon Graphics (16) @ 4.463GHz
GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
GPU: NVIDIA GeForce RTX 3050 Mobile
Memory: 2395MiB / 31436MiB
mhwd -li
> Installed PCI configs:
video-hybrid-amd-nvidia-prime     2023.03.23               false            PCI
           video-linux            2018.05.04                true            PCI
xrandr
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 355mm x 199mm
   1920x1080     60.00*+  40.00
   1680x1050     60.00
   1280x1024     60.00
   1440x900      60.00
   1280x800      60.00
   1280x720      60.00
   1024x768      60.00
   800x600       60.00
   640x480       60.00
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected (normal left inverted right x axis y axis)
   1920x1080     60.00 +  59.94    50.00
   1680x1050     59.95
   1600x900      60.00
   1440x900      59.89
   1280x1024     60.02
   1280x800      59.81
   1280x720      60.00    59.94    50.00
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       59.94
   640x480       59.94    59.93
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
(con nouveau driver)
xrandr --listmonitors
Monitors: 2
 0: +*eDP 1920/355x1080/199+0+0  eDP
 1: +HDMI-1-1 1920/527x1080/296+1920+0  HDMI-1-1
(con nvidia driver)
Monitors: 1
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x54 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 2 associated providers: 1 name:AMD Radeon Graphics @ pci:0000:06:00.0
Provider 1: id: 0x1f6 cap: 0x2, Sink Output crtcs: 4 outputs: 3 associated providers: 1 name:NVIDIA-G0
agradesco mucho su pronta ayuda.
