I have triple monitors, 2 are connected to the nVidia GPU and they work flawlessly now, but my igpu monitor won’t work.
At the fresh installation, the intel gpu worked and the nvidia didn’t but i kept missing around with mhwd and tried to install a couple of drivers to get my nvidia gpu to work until it finally did, but now my intel gpu display won’t work.
here are some specs:
[hegz@hegzaro ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-450xx 2019.10.25 false PCI
hegz@hegzaro ~]$ inxi -G
Graphics: Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 450.66
Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 1: 1600x900~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
[hegz@hegzaro ~]$ xrandr
Screen 0: minimum 8 x 8, current 3520 x 1080, maximum 32767 x 32767
DVI-D-0 connected primary 1600x900+1920+180 (normal left inverted right x axis y axis) 443mm x 249mm
1600x900 60.00*+
1440x900 74.98 59.89
1280x800 74.93 59.81
1280x720 60.00 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 70.07 60.00
800x600 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 72.81 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
i’m using i3 community image
