I wanted to run the manjaro minimal xfce live to install manjaro but itll show the error below
ln: /dev/disk/by-label/MANJARO_XFCEM_2021: File exist
mount: /run/msio/sfs/rootfs: missing codepage or helper program, or other error
ERROR: Failed to mount '/dev/loop3'
Falling back to interactive prompt
You can try to fix the problem manually, log out whene you are finished
sh: can't access tty; job control turned off
for record ive tried to do the ln and mount manually but itll say the same thing
and im using ventoy to run the iso
