Hi all.
I just installed Manjaro Minimal on my RPI 5.
I installed plasmamobile it seems to run pretty well on it.
Now i just need the system to run plasmamobile on boot. How do i do that?
Ive been googling for an hour or so i cant seem to find anything on this.
To have the GUI start at boot - install and enable the plasma display manager
sudo pacman -Syu sddm
systemctl enable sddm
Thats almost just to easy. Thank you very much. :).
Now i just need to get my DIY powerbank working with a solid 5A output and a RPI 5 diy tablet guide should be on its way.
