Manjaro messing up VirtualBox audio output
Hi everyone!
On my Manjaro install, I have a VirtualBox Windows 10 VM. The audio it outputs sounds like this. The thing is is that if I choose a different output device, the problem goes away. All other applications also don’t have this problem. It is just VirtualBox with this specific output device. When monitoring the output device with Audacity, it sounds fine too.
Could anyone shed some light on what may be causing this?
Thanks!
Hey @freggel.doe, thanks! That worked!
