Hello,
I have installed Manjaro and VLC for playing.
But the play is not good.
Manjaro is made for RPI3 ?
It seems the RPI3 is not enough powerfull for playing with VLC.
Hello,
With out HW decoding within a DE playing videos can be problematic on the pi3 with a 64bit OS. Using kodi-rpi outside of a DE should be able to play h264/265 streams with HW decoding if they are not too stout.
sudo pacman -S kodi-rpi-git kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker
Make some changes in /boot/config.txt:
Add some memory to this line:
dtoverlay=vc4-kms-v3d,cma-256
Uncomment this line to look like this:
disable_fw_kms_setup=1
Reboot the pi3 and at the login screen switch to a TTY and login with CTRL-ALT F2
After you log in in the terminal run kodi-standalone
When done with kodi exit out then do a CTRL-ALT F7
to get back to the Graphical login screen.
