Hey there,
i tried to follow this tutorial ( https://youtu.be/DX_gQTQLUZc?si=gQHlBv1LoQKkar65 ) to get a macos bigspur look alike manjaro. sadly i couldn’t find every desktop effect which the video creator showed in his video.
For example he is showing the “Wobbly Windows”, “Magic Lamp” and so on which i can’t find.
mine:
What ISO did you use for installing? On my system, both of the effects you mention here are (and have always been) installed, but if you installed from one of the minimal ISOs, then those effects might not be included — I don’t really know, which is why I’m asking.
In that case, those effects should be available. What kind of graphics adapter and graphics driver are you using? Are you using Nvidia in combination with the nouveau driver by any chance?
OP is using the proprietary Nvidia driver. I think it rather depends on the settings and/or capabilities of the virtual machine monitor. virtualbox for instance requires guest add-ons for any kind of 3D functionality inside the virtual machine.
I think a VM isn’t a real GPU, so doesn’t really have the capabilities of one.So, I think those effects are hidden because the virtual GPU doesn’t have the capabilities that’s necessary for the effect.
However, an excellent game to follow and learn. I would definitely recommend you set up your snapshots and backups first…
Something else I discovered whilst using ‘konsave’ is that some of the theming stuff can get lost… when I tried to export one of my profiles, it generated 2GiB… and most of that was icons - icons which don’t show up in Plasma…
So get nicely familiar with the locations, add them to nicely labelled bookmarks in Dolphin (not places - that gets too crowded) and have fun.
It’s a good plan to export your colour schemes and other resources to a resource folder alongside your backups… I say this as I have tweaked a lot of colour schemes, and found custom icons… and then I have my own cursors which are no longer available in AUR, so I’m glad I kept them (not sure why the vanished…'.
In the end, you’ll be able to load up a vanilla desktop and have it themed easily.
I use the Lightly theme, so I’m not using Breeze… and I’d suggest you take a look at “Rounded SBE” Window Decorations which have some nice custom features (including different widget styles/colours).
There is also a way to save your own Global Theme too, and Konsave is a good way to save what you have now before applying new stuff.
I like Konsave, and hopefully on it’s next release the developer will make it even simpler to use (i.e. instead of having to List, then type the name of the profile as you saved it, you’ll be able to enter konsave -s and then choose an item to save, or type a fresh name).
pamac install konsave
konsave -s Comfort-Dark
konsave -l
cd ~/.config/konsave
Have fun and keep an eye on that folder for bloat.
