Manjaro machine freezes when qbittorrent runs
Was there anything in recent updates to explain a Manjaro machine’s crashing when qbittorrent is running?
The setup is as follows, and it has given me no problem for a couple years until recently (last couple of months).
  • Manjaro (Stable Branch, XFCE) runs in a virtual machine (VMWare Workstation).
  • It has LAN access to a physical Windows machine. I use a command such as follows for mounting the Windows location in Manjaro
sudo mount -t cifs -o username=user,password=pass,uid=1000,gid=1000 //10.200.17.11/dir /home/luna/mnt/daisy/dir
  • qbittorrent is directed to download to the mounted location. (Therefore, it generates quite a bit of LAN traffic.)
  • qbittorrent’s settings are mostly the default. (In any event, my settings were fine for a couple of years.)
  • When qbittorrent is running, the CPU and RAM usages are low (as low as those in similar Manjaro VM not running qbittorrent and not crashing).
The crash can happen as frequently as every five minutes and five times in a row. So there appears to be a “routine” process that leads to a freeze.
If I should upload any log excerpt, please let me know where/how to get it. Thanks.
Hi @jamjar,
Always provide the output for:
inxi --filter --verbosity=8
Then some system logs might help:
journalctl --priority=warning..crit --no-pager --boot=0
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • --no-pager formats the output nicely for use here, on the forum;
  • the --boot=0 argument limits the messages to be from the current boot.
More:
Note that the above text is partially pre-prepared as general information for new users. Please take the time to follow the given links and learn more.
Thanks.
Here are the output from the two commands.
inxi --filter --verbosity=8 gave:
[luna@jar-d ~]$ inxi --filter --verbosity=8
  Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=95a87c40-ba34-439f-9662-962ae4a653c0 rw apparmor=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver dm: LightDM v: 1.32.0
  Type: Vmware System: VMware product: VMware Virtual Platform v: N/A
    serial: <superuser required> Chassis: No Enclosure type: 1
  Mobo: Intel model: 440BX Desktop Reference Platform
    serial: <superuser required> uuid: <superuser required> BIOS: Phoenix
    v: 6.00 date: 11/12/2020
  System RAM: total: 5 GiB available: 4.76 GiB used: 911.2 MiB (18.7%)
  Array-1: capacity: 81 GiB note: check slots: 43 note: check modules: 2
    EC: None max-module-size: N/A
  Device-1: RAM slot #0 type: DRAM detail: edo size: 4 GiB speed: N/A
    volts: N/A width (bits): data: 32 total: 32 manufacturer: N/A part-no: N/A
    serial: N/A
  Device-2: RAM slot #1 type: DRAM detail: edo size: 1024 MiB speed: N/A
    serial: N/A
  Device-3: RAM slot #2 type: no module installed
  Device-4: RAM slot #3 type: no module installed
  Device-5: RAM slot #4 type: no module installed
  Device-6: RAM slot #5 type: no module installed
  Device-7: RAM slot #6 type: no module installed
  Device-8: RAM slot #7 type: no module installed
  Device-9: RAM slot #8 type: no module installed
  Device-10: RAM slot #9 type: no module installed
  Device-11: RAM slot #10 type: no module installed
  Device-12: RAM slot #11 type: no module installed
  Device-13: RAM slot #12 type: no module installed
  Device-14: RAM slot #13 type: no module installed
  Device-15: RAM slot #14 type: no module installed
  Device-16: RAM slot #15 type: no module installed
  Device-17: RAM slot #16 type: no module installed
  Device-18: RAM slot #17 type: no module installed
  Device-19: RAM slot #18 type: no module installed
  Device-20: RAM slot #19 type: no module installed
  Device-21: RAM slot #20 type: no module installed
  Device-22: RAM slot #21 type: no module installed
  Device-23: RAM slot #22 type: no module installed
  Device-24: RAM slot #23 type: no module installed
  Device-25: RAM slot #24 type: no module installed
  Device-26: RAM slot #25 type: no module installed
  Device-27: RAM slot #26 type: no module installed
  Device-28: RAM slot #27 type: no module installed
  Device-29: RAM slot #28 type: no module installed
  Device-30: RAM slot #29 type: no module installed
  Device-31: RAM slot #30 type: no module installed
  Device-32: RAM slot #31 type: no module installed
  Device-33: RAM slot #32 type: no module installed
  Device-34: RAM slot #33 type: no module installed
  Device-35: RAM slot #34 type: no module installed
  Device-36: RAM slot #35 type: no module installed
  Device-37: RAM slot #36 type: no module installed
  Device-38: RAM slot #37 type: no module installed
  Device-39: RAM slot #38 type: no module installed
  Device-40: RAM slot #39 type: no module installed
  Device-41: RAM slot #40 type: no module installed
  Device-42: RAM slot #41 type: no module installed
  Device-43: RAM slot #42 type: no module installed
  Info: model: 12th Gen Intel Core i5-12400 bits: 64 type: SMP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 5
    microcode: 0x26
  Topology: cpus: 2x dies: 1 clusters: 1 cores: 1 smt: <unsupported> cache:
    L1: 2x 80 KiB (160 KiB) desc: d-1x48 KiB; i-1x32 KiB
    L2: 2x 1.2 MiB (2.5 MiB) desc: 1x1.2 MiB L3: 2x 18 MiB (36 MiB)
    desc: 1x18 MiB
  Speed (MHz): avg: 2496 min/max: N/A cores: 1: 2496 2: 2496 bogomips: 9988
  Flags: 3dnowprefetch abm adx aes apic arat arch_capabilities arch_perfmon
    avx avx2 avx_vnni bmi1 bmi2 clflush clflushopt clwb cmov constant_tsc
    cpuid cx16 cx8 de erms f16c flush_l1d fma fpu fsgsbase fsrm fxsr gfni
    hypervisor ibpb ibrs ibrs_enhanced invpcid lahf_lm lm mca mce md_clear
    mmx movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
    pclmulqdq pdpe1gb pge pku pni popcnt pse pse36 rdpid rdrand rdseed rdtscp
    rep_good sep serialize sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tsc tsc_adjust tsc_deadline_timer tsc_known_freq
    tsc_reliable umip user_shstk vaes vme vpclmulqdq x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: reg_file_data_sampling status: Vulnerable: No microcode
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.20.0.0 ports:
    active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
    Virtual-6, Virtual-7, Virtual-8 bus-ID: 00:0f.0 chip-ID: 15ad:0405
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.15 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: vmware unloaded: modesetting alternate: fbdev,vesa gpu: vmwgfx
    display-ID: :1.0 screens: 1
  Screen-1: 0 s-res: 1400x959 s-dpi: 96 s-size: 370x253mm (14.57x9.96")
    s-diag: 448mm (17.65")
  Monitor-1: Virtual-1 mapped: VNC-0 res: mode: 1400x959 hz: 60
    scale: 100% (1) size: N/A modes: 843x547, 4096x2160, 2560x1600, 1920x1440,
    1856x1392, 1792x1344, 2048x1152, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900, 1280x960, 1366x768,
    1360x768, 1280x800, 1280x768, 1280x720, 1024x768, 800x600, 848x480,
    640x480
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: de: xfce4-display-settings x11: xdpyinfo, xprop, xrandr
  Device-1: Ensoniq ES1371/ES1373 / Creative Labs CT2518 driver: snd_ens1371
    v: kernel bus-ID: 02:02.0 chip-ID: 1274:1371 class-ID: 0401
  API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: VMware Virtual Machine
    type: network bridge driver: N/A modules: i2c_piix4 port: N/A
    bus-ID: 00:07.3 chip-ID: 8086:7113 class-ID: 0680
  Device-2: Intel 82545EM Gigabit Ethernet vendor: VMware PRO/1000 MT
    Single Port driver: e1000 v: kernel port: 2000 bus-ID: 02:01.0
    chip-ID: 8086:100f class-ID: 0200
  IF: ens33 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: dadfailed tentative noprefixroute scope: global
  IP v6: <filter> type: noprefixroute scope: global
  Info: services: NetworkManager,sshd
  Local Storage: total: 100 GiB used: 26.26 GiB (26.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: VMware model: Virtual S size: 100 GiB
    block-size: physical: 512 B logical: 512 B tech: N/A serial: N/A fw-rev: 1.0
    scheme: MBR
  Optical-1: /dev/sr0 vendor: NECVMWar model: VMware IDE CDR10 rev: 1.00
    dev-links: cdrom
  Features: speed: 1 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 26.26 GiB (26.8%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 95a87c40-ba34-439f-9662-962ae4a653c0
  ID-2: /home/<filter>/mnt/daisy/have raw-size: N/A size: 7.28 TiB
    used: 5.98 TiB (82.1%) fs: cifs dev: /dev/have
  ID-3: /home/<filter>/mnt/daisy/jane raw-size: N/A size: 7.28 TiB
    used: 6.03 TiB (82.9%) fs: cifs dev: /dev/jane
  ID-4: /home/<filter>/mnt/daisy/kaze raw-size: N/A size: 7.28 TiB
    used: 3.61 TiB (49.6%) fs: cifs dev: /dev/kaze
  ID-5: /home/<filter>/mnt/daisy/lady raw-size: N/A size: 7.28 TiB
    used: 4.7 TiB (64.6%) fs: cifs dev: /dev/lady
  ID-6: /home/<filter>/mnt/town raw-size: N/A size: 7.28 TiB
    used: 5.98 TiB (82.1%) fs: cifs dev: /dev/town
  ID-1: swap-1 type: file size: 5 GiB used: 239.3 MiB (4.7%) priority: -2
    file: /swapfile
  Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Device-1: 2-1:2 info: VMware Virtual Mouse type: mouse
    lanes: 1 mode: 1.1 chip-ID: 0e0f:0003 class-ID: 0301
  Hub-3: 2-2:3 info: VMware Virtual USB Hub ports: 7 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0e0f:0002
  Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
    or lm-sensors.
  Packages: pm: pacman pkgs: 1394 libs: 437 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    3: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 234
  1: cpu: 6.7% command: ibus-extension-gtk3 pid: 2507 mem: 38.2 MiB (0.7%)
  2: cpu: 2.9% command: qbittorrent pid: 2132 mem: 146.3 MiB (2.9%)
  3: cpu: 1.4% command: [ksoftirqd/1] pid: 28 mem: 0.00 MiB (0.0%)
  4: cpu: 1.4% command: xfce4-terminal pid: 2478 mem: 60.1 MiB (1.2%)
  5: cpu: 0.5% command: ibus-ui-gtk3 pid: 2506 mem: 55.5 MiB (1.1%)
  Memory top: 5 of 234
  1: mem: 146.3 MiB (2.9%) command: qbittorrent pid: 2132 cpu: 2.9%
  2: mem: 89.7 MiB (1.8%) command: Xvnc pid: 1302 cpu: 0.3%
  3: mem: 66.8 MiB (1.3%) command: Thunar pid: 1403 cpu: 0.1%
  4: mem: 65.1 MiB (1.3%) command: lightdm-gtk-greeter pid: 1151 cpu: 0.0%
  5: mem: 60.1 MiB (1.2%) command: xfce4-terminal pid: 2478 cpu: 1.4%
  Processes: 234 Power: uptime: 51m states: freeze,standby,mem,disk
    suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 1.9 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
[luna@jar-d ~]$
journalctl --priority=warning..crit --no-pager --boot=0 gave:
[luna@jar-d ~]$ journalctl --priority=warning..crit --no-pager --boot=0
Mar 28 21:06:35 jar-d kernel: core: CPUID marked event: 'cpu cycles' unavailable
Mar 28 21:06:35 jar-d kernel: core: CPUID marked event: 'instructions' unavailable
Mar 28 21:06:35 jar-d kernel: core: CPUID marked event: 'bus cycles' unavailable
Mar 28 21:06:35 jar-d kernel: core: CPUID marked event: 'cache references' unavailable
Mar 28 21:06:35 jar-d kernel: core: CPUID marked event: 'cache misses' unavailable
Mar 28 21:06:35 jar-d kernel: core: CPUID marked event: 'branch instructions' unavailable
Mar 28 21:06:35 jar-d kernel: core: CPUID marked event: 'branch misses' unavailable
Mar 28 21:06:35 jar-d kernel: sd 2:0:0:0: [sda] Assuming drive cache: write through
Mar 28 21:06:35 jar-d kernel: piix4_smbus 0000:00:07.3: SMBus Host Controller not enabled!
Mar 28 21:06:36 jar-d systemd-vconsole-setup[544]: /usr/bin/loadkeys failed with exit status 1.
Mar 28 21:06:36 jar-d systemd[1]: systemd-vconsole-setup.service: Failed with result 'exit-code'.
Mar 28 21:06:36 jar-d systemd[1]: Failed to start Virtual Console Setup.
Mar 28 21:06:36 jar-d (re-tools)[634]: vmwaretools.service: Failed at step EXEC spawning /etc/init.d/vmware-tools: No such file or directory
Mar 28 21:06:36 jar-d systemd[1]: vmwaretools.service: Failed with result 'exit-code'.
Mar 28 21:06:37 jar-d dbus-broker-launch[626]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Mar 28 21:06:55 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-2
Mar 28 21:06:55 jar-d NetworkManager[629]: <error> [1743163615.9264] dhcp6 (ens33): DAD failed for address: fd93:8f99:81c6::76a/128 lft forever pref forever lifetime 3-3[4294967295,4294967295] dev 2 src dhcp
Mar 28 21:06:56 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-3
Mar 28 21:06:57 jar-d dbus-broker-launch[626]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Mar 28 21:06:57 jar-d dbus-broker-launch[1154]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 28 21:06:57 jar-d dbus-broker-launch[1154]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Mar 28 21:06:57 jar-d dbus-broker-launch[1154]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Mar 28 21:06:57 jar-d dbus-broker-launch[1154]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Mar 28 21:06:57 jar-d dbus-broker-launch[1154]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mar 28 21:06:57 jar-d dbus-broker-launch[1154]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Mar 28 21:06:58 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-4
Mar 28 21:06:59 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-5
Mar 28 21:07:00 jar-d systemd-xdg-autostart-generator[1205]: Configuration file /home/luna/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Mar 28 21:07:00 jar-d systemd-xdg-autostart-generator[1205]: Configuration file /home/luna/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Mar 28 21:07:00 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-6
Mar 28 21:07:00 jar-d dbus-broker-launch[1234]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 28 21:07:00 jar-d dbus-broker-launch[1234]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Mar 28 21:07:00 jar-d dbus-broker-launch[1234]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Mar 28 21:07:00 jar-d dbus-broker-launch[1234]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Mar 28 21:07:00 jar-d dbus-broker-launch[1234]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mar 28 21:07:00 jar-d dbus-broker-launch[1234]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Mar 28 21:07:00 jar-d kernel: show_signal: 157 callbacks suppressed
Mar 28 21:07:01 jar-d systemd-coredump[1273]: [🡕] Process 1246 (ibus-ui-gtk3) of user 1000 dumped core.
                                              Module [dso] without build-id.
                                              Stack trace of thread 1246:
                                              #0  0x000078d13170aa48 n/a (n/a + 0x0)
                                              #1  0x000078d13170ad47 n/a (n/a + 0x0)
                                              #2  0x000078d13170afcc n/a (n/a + 0x0)
                                              #3  0x000078d13170b354 n/a (n/a + 0x0)
                                              #4  0x000061710a1e3fbc n/a (n/a + 0x0)
                                              #5  0x000061710a1e4596 n/a (n/a + 0x0)
                                              #6  0x000061710a1e785a n/a (n/a + 0x0)
                                              #7  0x000078d13157adb9 n/a (n/a + 0x0)
                                              #8  0x000078d131705919 n/a (n/a + 0x0)
                                              #9  0x000078d1317685d7 n/a (n/a + 0x0)
                                              #10 0x000078d131706647 n/a (n/a + 0x0)
                                              #11 0x000078d131e24dff n/a (n/a + 0x0)
                                              #12 0x000061710a1e4c76 n/a (n/a + 0x0)
                                              #13 0x000061710a1e00c4 n/a (n/a + 0x0)
                                              #14 0x000078d1312ae488 n/a (n/a + 0x0)
                                              #15 0x000078d1312ae54c n/a (n/a + 0x0)
                                              #16 0x000061710a1e00f5 n/a (n/a + 0x0)
Mar 28 21:07:01 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-7
Mar 28 21:07:02 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-8
Mar 28 21:07:03 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-9
Mar 28 21:07:04 jar-d vncsession[1297]: ~/.vnc is deprecated, please consult 'man vncsession' for paths to migrate to.
Mar 28 21:07:04 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-10
Mar 28 21:07:05 jar-d pulseaudio[1378]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.bluez': unit failed
Mar 28 21:07:05 jar-d colord[1557]: failed to get edid data: EDID length is too small
Mar 28 21:07:06 jar-d tumblerd[1527]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Mar 28 21:07:06 jar-d udisksd[1617]: Error probing device: Error sending ATA command IDENTIFY PACKET DEVICE to '/dev/sr0': ATA command failed: error=0x01 count=0x02 status=0x50 (g-io-error-quark, 0)
Mar 28 21:07:06 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-11
Mar 28 21:07:07 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-12
Mar 28 21:07:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-13
Mar 28 21:07:22 jar-d kernel: CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
Mar 28 21:07:22 jar-d baloo_file[1523]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkRequested(QString)
Mar 28 21:07:22 jar-d baloo_file[1523]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkDone(Solid::ErrorType, QVariant, QString)
Mar 28 21:07:22 jar-d kernel: CIFS: VFS:  BAD_NETWORK_NAME: \\10.200.17.11\may
Mar 28 21:07:22 jar-d kernel: CIFS: VFS: cifs_mount failed w/return code = -2
Mar 28 21:07:22 jar-d kernel: CIFS: VFS:  BAD_NETWORK_NAME: \\10.200.17.11\nap
Mar 28 21:07:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-14
Mar 28 21:07:40 jar-d qbittorrent[1914]: QFSFileEngine::open: No file name specified
Mar 28 21:07:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-15
Mar 28 21:08:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-16
Mar 28 21:08:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-17
Mar 28 21:08:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-18
Mar 28 21:09:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-19
Mar 28 21:09:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-20
Mar 28 21:09:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-21
Mar 28 21:10:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-22
Mar 28 21:10:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-23
Mar 28 21:10:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-24
Mar 28 21:11:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-25
Mar 28 21:11:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-26
Mar 28 21:11:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-27
Mar 28 21:12:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-28
Mar 28 21:12:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-29
Mar 28 21:12:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-30
Mar 28 21:13:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-31
Mar 28 21:13:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-32
Mar 28 21:13:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-33
Mar 28 21:14:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-34
Mar 28 21:14:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-35
Mar 28 21:14:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-36
Mar 28 21:15:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-37
Mar 28 21:15:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-38
Mar 28 21:15:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-39
Mar 28 21:16:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-40
Mar 28 21:16:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-41
Mar 28 21:16:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-42
Mar 28 21:17:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-43
Mar 28 21:17:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-44
Mar 28 21:17:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-45
Mar 28 21:18:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-46
Mar 28 21:18:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-47
Mar 28 21:18:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-48
Mar 28 21:19:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-49
Mar 28 21:19:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-50
Mar 28 21:19:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-51
Mar 28 21:20:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-52
Mar 28 21:20:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-53
Mar 28 21:20:32 jar-d tumblerd[2027]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Mar 28 21:20:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-54
Mar 28 21:21:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-55
Mar 28 21:21:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-56
Mar 28 21:21:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-57
Mar 28 21:22:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-58
Mar 28 21:22:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-59
Mar 28 21:22:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-60
Mar 28 21:23:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-61
Mar 28 21:23:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-62
Mar 28 21:23:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-63
Mar 28 21:24:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-64
Mar 28 21:24:12 jar-d qbittorrent[2094]: edit: editing failed
Mar 28 21:24:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-65
Mar 28 21:24:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-66
Mar 28 21:25:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-67
Mar 28 21:25:24 jar-d baloo_file_extractor[2238]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkRequested(QString)
Mar 28 21:25:24 jar-d baloo_file_extractor[2238]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkDone(Solid::ErrorType, QVariant, QString)
Mar 28 21:25:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-68
Mar 28 21:25:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-69
Mar 28 21:26:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-70
Mar 28 21:26:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-71
Mar 28 21:26:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-72
Mar 28 21:27:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-73
Mar 28 21:27:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-74
Mar 28 21:27:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-75
Mar 28 21:28:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-76
Mar 28 21:28:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-77
Mar 28 21:28:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-78
Mar 28 21:29:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-79
Mar 28 21:29:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-80
Mar 28 21:29:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-81
Mar 28 21:30:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-82
Mar 28 21:30:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-83
Mar 28 21:30:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-84
Mar 28 21:31:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-85
Mar 28 21:31:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-86
Mar 28 21:31:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-87
Mar 28 21:32:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-88
Mar 28 21:32:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-89
Mar 28 21:32:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-90
Mar 28 21:33:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-91
Mar 28 21:33:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-92
Mar 28 21:33:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-93
Mar 28 21:34:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-94
Mar 28 21:34:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-95
Mar 28 21:34:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-96
Mar 28 21:35:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-97
Mar 28 21:35:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-98
Mar 28 21:35:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-99
Mar 28 21:36:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-100
Mar 28 21:36:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-101
Mar 28 21:36:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-102
Mar 28 21:37:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-103
Mar 28 21:37:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-104
Mar 28 21:37:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-105
Mar 28 21:38:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-106
Mar 28 21:38:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-107
Mar 28 21:38:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-108
Mar 28 21:39:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-109
Mar 28 21:39:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-110
Mar 28 21:39:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-111
Mar 28 21:40:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-112
Mar 28 21:40:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-113
Mar 28 21:40:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-114
Mar 28 21:41:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-115
Mar 28 21:41:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-116
Mar 28 21:41:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-117
Mar 28 21:42:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-118
Mar 28 21:42:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-119
Mar 28 21:42:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-120
Mar 28 21:43:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-121
Mar 28 21:43:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-122
Mar 28 21:43:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-123
Mar 28 21:43:49 jar-d tumblerd[2351]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Mar 28 21:44:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-124
Mar 28 21:44:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-125
Mar 28 21:44:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-126
Mar 28 21:45:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-127
Mar 28 21:45:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-128
Mar 28 21:45:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-129
Mar 28 21:46:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-130
Mar 28 21:46:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-131
Mar 28 21:46:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-132
Mar 28 21:47:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-133
Mar 28 21:47:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-134
Mar 28 21:47:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-135
Mar 28 21:48:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-136
Mar 28 21:48:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-137
Mar 28 21:48:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-138
Mar 28 21:49:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-139
Mar 28 21:49:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-140
Mar 28 21:49:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-141
Mar 28 21:50:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-142
Mar 28 21:50:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-143
Mar 28 21:50:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-144
Mar 28 21:51:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-145
Mar 28 21:51:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-146
Mar 28 21:51:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-147
Mar 28 21:52:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-148
Mar 28 21:52:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-149
Mar 28 21:52:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-150
Mar 28 21:53:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-151
Mar 28 21:53:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-152
Mar 28 21:53:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-153
Mar 28 21:54:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-154
Mar 28 21:54:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-155
Mar 28 21:54:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-156
Mar 28 21:55:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-157
Mar 28 21:55:29 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-158
Mar 28 21:55:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-159
Mar 28 21:56:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-160
Mar 28 21:56:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-161
Mar 28 21:56:48 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-162
Mar 28 21:57:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-163
Mar 28 21:57:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-164
Mar 28 21:57:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-165
Mar 28 21:58:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-166
Mar 28 21:58:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-167
Mar 28 21:58:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-168
Mar 28 21:59:08 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-169
Mar 28 21:59:28 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-170
Mar 28 21:59:34 jar-d tumblerd[2708]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Mar 28 21:59:49 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-171
Mar 28 22:00:09 jar-d avahi-daemon[630]: Host name conflict, retrying with jar-d-172
[luna@jar-d ~]$
In the latter, I see a lot of Host name conflict, retrying with jar-d-165 or similar.
My /etc/hosts have (relevantly):
::1        localhost ip6-localhost ip6-loopback
ff02::1    ip6-allnodes
ff02::2    ip6-allrouters
# This host address
127.0.1.1  jar-d
10.200.17.51    jar-d
–where 10.200.17.51 jar-d are the I.P. address and computer name of the VM in question.
I don’t have any other machine in LAN shaing that I.P. address or computer name.
I see that my other Manjaro machines do not have a line like 10.200.17.51 jar-d in their /etc/hosts. I am removing it from the affected machine and will see whether that fixes the problem.
ADDED LATER. That might have done it! The use of qbittorrent has now gone on longer than it would have taken for the system to crash–on a bad day.
Of course, now I wonder why there were also good days, i.e. those on which the system did not crash even though qbittorrent was running (in the sense of having torrents to download, not just in the sense of being open).
I am going to observe for a few days before accepting an answer and closing the post.
I see you use Xfce, which uses the GTK engine. And in the log I see
So I don’t know if they’re related, but they might be.
Yes, those are from Akonadi:
As far as I know, someone might know better than me, but as far as I know, Avahi doesn’t really seem necessary for you, so disable it:
sudo systemctl disable --nnow avahi-daemon
But, according to:
Hostname changes with appending incrementing numbers
This is a known bug that is caused by a hostname race condition. One possible workaround is disabling IPv6 to attempt to prevent the race condition. If multiple interfaces are present use allow-interfaces to limit Avahi to a single interface. Another possible workaround is to disable the cache to prevent Avahi from checking for host name conflicts altogether, but this prevents Avahi from performing lookups.
Which version of qBittorrent (qBT) are you using?
And the RAM and CPU usage of your qBT?
Did you use RSS in qBT?
Did you enable “recheck torrents on completion” in settings?
What is the read/write speed of the target HDD in qBT?
On
–and other questions.
Version is 5.0.4 (it is updated with Manjaro update).
Right now with nothing up or downloading, total (not just qbittorrent) CPU usage is less than 10% and total RAM is less than 25%. Even when up and downloading is at my max ISP bandwidth, that usage does not go up much.
Never consciously used RSS. On Preferences > RSS, all boxes are unticked, except for “Download REPACK/PROPER episodes” (which is ticked). Those must be the default settings. I never touched them.
I never checked “recheck torrents on completion.” I could not find it in Preferences. It would be in its default condition.
Target HDDs are from within the past five years if you are asking about their hardware specs (above my 1 gigabit LAN). In qbittorrent Preferences, I’ve limited “global rate limits” to 15,000 KiB/s for both up and down (even that is above my ISP/WAN speed).
This is in qBT’s Preference > Advanced > Recheck torrents on completion.
Regarding your freezes, does the system become responsive after a while?
Or it has to be hard rebooted?
Does that happen when new torrents are loaded to qBT?
Or when completed torrents are being checked?
On
–and other questions:
“Recheck torrents on completion" is not ticked on my system.
After a freeze, the system does not become response again.
If I reboot the system, shutting down takes a long time (5 to 10 minutes) while the system repeatedly does the same thing (from what I can tell by the screen output). Resetting (there is a button for that in my VM app, an equivalent of the physical reset button I believe) is much faster.
I have seen the crash happen in two situations. 1. When new torrents are loaded and are being downloaded. 2. When I have left the system unattended for some time (e.g. hours). This latter might have included a new torrent having completed. However, it presumably did not include a completed torrent’s being rechecked if I correctly understand what it means to tick or not tick “Recheck torrents on completion" (and mine is not ticked as above).
When your qBT is downloading, what is the RAM and CPU usage of your qBT?
You previously mentioned that with no downloading / uploading activity, your CPU is 10% usage, and RAM is 25%.
How about during downloading / uploading activity, which leads to system crash?
When qbittorrent is idle, its usage (by Htop) is:
  • CPU 4 to 6%
  • RAM 3 to 4%
When it is downloading a single torrent near ISP’s full bandwith (11 Mbyte/s):
  • CPU 6 to 12%
  • RAM rises steadily to 32%
After download ends and idle again: Reverts to above idle figures.
When I have 6 or 7 torrents uploading (total upload bandwidth of 1 Mbyte/s or less):
  • CPU 5 to 10%
  • RAM 12 to 16%
The total I gave to VM is “total processor cores 2” and RAM 5 GB.
As mentioned in another reply below, one crash happened after the resolution of the computer name conflict. Still watching with 6 or 7 torrents uploading.
Try adjusting your qbittorrent configuration;
for example, reducing the amount of peers per torrent can be beneficial, as can reducing the overall bandwidth used (also configurable).
Spending 20 minutes carefully reviewing Qbit settings can potentially make all the difference.
Thanks. I tried peers from 500 (default) to 100 and bandwidth from unlimited to 10000 KiB/s. Also there were couple of years when default numbers worked fine. I’ll try again.
I was able to reproduce the crash even after the resolution of the computer name conflict.
Only, the crash was not so “routine” anymore (i.e. took longer than 5 min to happen).
So it is possible that there were multiple causes (computer name being only one).
While the system was shutting down, I captured the screenshots at the bottom.
I can run the two commands again if that would be worthwhile (i.e.,inxi --filter --verbosity=8 and journalctl --priority=warning..crit --no-pager --boot=0 )
And posting the output as text will also be more helpful; searchable; less resource intensive (be kind to the server); and all that jazz. :wink:
Okay.
But if you are referring to the two jpg shots, they aren’t the result of running any commands. They capture I saw on the VM’s window (as it struggled to shut down), and I did not know whether such screen content is the same as (would also be included in) the output of the the two commands you gave me.
I am waiting for the system to crash again so that the commands’ output might contain a couple of incidents. I will update this reply with command output when that happens or in the best scenario won’t be able to do that because the system did not crash.
When/if it crashes, use the following command immediately after the next boot;
journalctl --boot=-1 --no-pager
If you forget to, change the -1 to -2 and run it on the very next boot. As you will have guessed the negative number refers to the number of boots ago to reference.
Note that possible uses are finite; using -5 for example might return nothing.
p2p app can be quite resource demanding when initiating torrent and checking downloaded content.
And especially when you’re downloading onto a network drive.
Having said that, from what you posted, your qBT doesn’t seem to be the cause - unless the system freezes due to non-responsiveness of your target network drive.
To verify this (and also as a best practice): do connect the p2p drive to this machine locally, and see if the issue persists.
Also, I would recommend you to run a full sector scan of your p2p drive (the drive should have no other process running when running this scan) to verify its integrity.
At the very least, these 2 steps would rule out 2 variables in the troubleshooting of your issue.
I was rash to think the problem first reported in Manjaro machine freezes when qbittorrent runs was fixed and choose a “solution” (thus letting it close).
The crash happened again.
As before, the setup is qbittorrent running in a Manjaro VM (in VMWare Workstation) saving contents to a Windows computer in LAN.
This time, it happened when qbittorrent was not downloading anything but only uploading, probably at 1 Mbit/s or less (which is the usual bandwidth usage on upload only, though it could have peaked just before crash).
I shut down the VM (rather than “reset” it) and ran this command immediately on reboot: journalctl --boot=-1 --no-pager
The output is as at the bottom. Output was beyond upload limit, and so I cut out some repetitive stuff and marked the places with, “[Many similar lines deleted.]”
One thing I notice, there are thousands of lines similar to: Apr 02 13:07:27 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-3248
Possibly, I have already been told what to try in a reply to the other post, as below:
Any other insight would be appreciated.
[XXXXX@jar-d ~]$ journalctl --boot=-1 --no-pager
Mar 31 23:21:50 jar-d kernel: Linux version 6.12.20-2-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20250207, GNU ld (GNU Binutils) 2.44) #1 SMP PREEMPT_DYNAMIC Mon, 24 Mar 2025 06:33:36 +0000
Mar 31 23:21:50 jar-d kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=95a87c40-ba34-439f-9662-962ae4a653c0 rw apparmor=1 security=apparmor udev.log_priority=3
Mar 31 23:21:50 jar-d kernel: BIOS-provided physical RAM map:
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ebff] usable
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x000000000009ec00-0x000000000009ffff] reserved
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000000dc000-0x00000000000fffff] reserved
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000bfecffff] usable
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000bfed0000-0x00000000bfefefff] ACPI data
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000bfeff000-0x00000000bfefffff] ACPI NVS
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000bff00000-0x00000000bfffffff] usable
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec0ffff] reserved
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x00000000fffe0000-0x00000000ffffffff] reserved
Mar 31 23:21:50 jar-d kernel: BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
Mar 31 23:21:50 jar-d kernel: NX (Execute Disable) protection: active
Mar 31 23:21:50 jar-d kernel: APIC: Static calls initialized
Mar 31 23:21:50 jar-d kernel: SMBIOS 2.7 present.
Mar 31 23:21:50 jar-d kernel: DMI: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 11/12/2020
Mar 31 23:21:50 jar-d kernel: DMI: Memory slots populated: 2/128
Mar 31 23:21:50 jar-d kernel: vmware: hypercall mode: 0x02
Mar 31 23:21:50 jar-d kernel: Hypervisor detected: VMware
Mar 31 23:21:50 jar-d kernel: vmware: TSC freq read from hypervisor : 2496.003 MHz
Mar 31 23:21:50 jar-d kernel: vmware: Host bus clock speed read from hypervisor : 66000000 Hz
Mar 31 23:21:50 jar-d kernel: vmware: using clock offset of 7014994950 ns
Mar 31 23:21:50 jar-d kernel: tsc: Detected 2496.003 MHz processor
Mar 31 23:21:50 jar-d kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Mar 31 23:21:50 jar-d kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Mar 31 23:21:50 jar-d kernel: last_pfn = 0x180000 max_arch_pfn = 0x400000000
Mar 31 23:21:50 jar-d kernel: total RAM covered: 130048M
Mar 31 23:21:50 jar-d kernel: Found optimal setting for mtrr clean up
Mar 31 23:21:50 jar-d kernel:  gran_size: 64K         chunk_size: 64K         num_reg: 7          lose cover RAM: 0G
Mar 31 23:21:50 jar-d kernel: MTRR map: 7 entries (5 fixed + 2 variable; max 21), built from 8 variable MTRRs
Mar 31 23:21:50 jar-d kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Mar 31 23:21:50 jar-d kernel: e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
Mar 31 23:21:50 jar-d kernel: last_pfn = 0xc0000 max_arch_pfn = 0x400000000
Mar 31 23:21:50 jar-d kernel: found SMP MP-table at [mem 0x000f6a70-0x000f6a7f]
Mar 31 23:21:50 jar-d kernel: Using GB pages for direct mapping
Mar 31 23:21:50 jar-d kernel: Incomplete global flushes, disabling PCID
Mar 31 23:21:50 jar-d kernel: RAMDISK: [mem 0x35aef000-0x36d6efff]
Mar 31 23:21:50 jar-d kernel: ACPI: Early table checksum verification disabled
Mar 31 23:21:50 jar-d kernel: ACPI: RSDP 0x00000000000F6A00 000024 (v02 PTLTD )
Mar 31 23:21:50 jar-d kernel: ACPI: XSDT 0x00000000BFEDB633 00005C (v01 INTEL  440BX    06040000 VMW  01324272)
Mar 31 23:21:50 jar-d kernel: ACPI: FACP 0x00000000BFEFEE73 0000F4 (v04 INTEL  440BX    06040000 PTL  000F4240)
Mar 31 23:21:50 jar-d kernel: ACPI: DSDT 0x00000000BFEDD001 021E72 (v01 PTLTD  Custom   06040000 MSFT 03000001)
Mar 31 23:21:50 jar-d kernel: ACPI: FACS 0x00000000BFEFFFC0 000040
Mar 31 23:21:50 jar-d kernel: ACPI: BOOT 0x00000000BFEDCFB4 000028 (v01 PTLTD  $SBFTBL$ 06040000  LTP 00000001)
Mar 31 23:21:50 jar-d kernel: ACPI: APIC 0x00000000BFEDC872 000742 (v01 PTLTD  ? APIC   06040000  LTP 00000000)
Mar 31 23:21:50 jar-d kernel: ACPI: MCFG 0x00000000BFEDC836 00003C (v01 PTLTD  $PCITBL$ 06040000  LTP 00000001)
Mar 31 23:21:50 jar-d kernel: ACPI: SRAT 0x00000000BFEDB72F 0008D0 (v02 VMWARE MEMPLUG  06040000 VMW  00000001)
Mar 31 23:21:50 jar-d kernel: ACPI: HPET 0x00000000BFEDB6F7 000038 (v01 VMWARE VMW HPET 06040000 VMW  00000001)
Mar 31 23:21:50 jar-d kernel: ACPI: WAET 0x00000000BFEDB6CF 000028 (v01 VMWARE VMW WAET 06040000 VMW  00000001)
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving FACP table memory at [mem 0xbfefee73-0xbfefef66]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving DSDT table memory at [mem 0xbfedd001-0xbfefee72]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving FACS table memory at [mem 0xbfefffc0-0xbfefffff]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving BOOT table memory at [mem 0xbfedcfb4-0xbfedcfdb]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving APIC table memory at [mem 0xbfedc872-0xbfedcfb3]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving MCFG table memory at [mem 0xbfedc836-0xbfedc871]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving SRAT table memory at [mem 0xbfedb72f-0xbfedbffe]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving HPET table memory at [mem 0xbfedb6f7-0xbfedb72e]
Mar 31 23:21:50 jar-d kernel: ACPI: Reserving WAET table memory at [mem 0xbfedb6cf-0xbfedb6f6]
Mar 31 23:21:50 jar-d kernel: ACPI: SRAT: Node 0 PXM 0 [mem 0x00000000-0x0009ffff]
Mar 31 23:21:50 jar-d kernel: ACPI: SRAT: Node 0 PXM 0 [mem 0x00100000-0xbfffffff]
Mar 31 23:21:50 jar-d kernel: ACPI: SRAT: Node 0 PXM 0 [mem 0x100000000-0x17fffffff]
Mar 31 23:21:50 jar-d kernel: ACPI: SRAT: Node 0 PXM 0 [mem 0x180000000-0x143fffffff] hotplug
Mar 31 23:21:50 jar-d kernel: NUMA: Node 0 [mem 0x00001000-0x0009ffff] + [mem 0x00100000-0xbfffffff] -> [mem 0x00001000-0xbfffffff]
Mar 31 23:21:50 jar-d kernel: NUMA: Node 0 [mem 0x00001000-0xbfffffff] + [mem 0x100000000-0x17fffffff] -> [mem 0x00001000-0x17fffffff]
Mar 31 23:21:50 jar-d kernel: NODE_DATA(0) allocated [mem 0x17ffd52c0-0x17fffffff]
Mar 31 23:21:50 jar-d kernel: Zone ranges:
Mar 31 23:21:50 jar-d kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Mar 31 23:21:50 jar-d kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Mar 31 23:21:50 jar-d kernel:   Normal   [mem 0x0000000100000000-0x000000017fffffff]
Mar 31 23:21:50 jar-d kernel:   Device   empty
Mar 31 23:21:50 jar-d kernel: Movable zone start for each node
Mar 31 23:21:50 jar-d kernel: Early memory node ranges
Mar 31 23:21:50 jar-d kernel:   node   0: [mem 0x0000000000001000-0x000000000009dfff]
Mar 31 23:21:50 jar-d kernel:   node   0: [mem 0x0000000000100000-0x00000000bfecffff]
Mar 31 23:21:50 jar-d kernel:   node   0: [mem 0x00000000bff00000-0x00000000bfffffff]
Mar 31 23:21:50 jar-d kernel:   node   0: [mem 0x0000000100000000-0x000000017fffffff]
Mar 31 23:21:50 jar-d kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000017fffffff]
Mar 31 23:21:50 jar-d kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Mar 31 23:21:50 jar-d kernel: On node 0, zone DMA: 98 pages in unavailable ranges
Mar 31 23:21:50 jar-d kernel: On node 0, zone DMA32: 48 pages in unavailable ranges
Mar 31 23:21:50 jar-d kernel: ACPI: PM-Timer IO Port: 0x1008
Mar 31 23:21:50 jar-d kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Mar 31 23:21:50 jar-d kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Mar 31 23:21:50 jar-d kernel: ACPI: LAPIC_NMI (acpi_id[0x7f] high edge lint[0x1])
Mar 31 23:21:50 jar-d kernel: IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
Mar 31 23:21:50 jar-d kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
Mar 31 23:21:50 jar-d kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Mar 31 23:21:50 jar-d kernel: ACPI: HPET id: 0x8086af01 base: 0xfed00000
Mar 31 23:21:50 jar-d kernel: TSC deadline timer available
Mar 31 23:21:50 jar-d kernel: CPU topo: Max. logical packages: 128
Mar 31 23:21:50 jar-d kernel: CPU topo: Max. logical dies:     128
Mar 31 23:21:50 jar-d kernel: CPU topo: Max. dies per package:   1
Mar 31 23:21:50 jar-d kernel: CPU topo: Max. threads per core:   1
Mar 31 23:21:50 jar-d kernel: CPU topo: Num. cores per package:     1
Mar 31 23:21:50 jar-d kernel: CPU topo: Num. threads per package:   1
Mar 31 23:21:50 jar-d kernel: CPU topo: Allowing 2 present CPUs plus 126 hotplug CPUs
Mar 31 23:21:50 jar-d kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Mar 31 23:21:50 jar-d kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
Mar 31 23:21:50 jar-d kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfffdffff]
Mar 31 23:21:50 jar-d kernel: PM: hibernation: Registered nosave memory: [mem 0xfffe0000-0xffffffff]
Mar 31 23:21:50 jar-d kernel: [mem 0xc0000000-0xefffffff] available for PCI devices
Mar 31 23:21:50 jar-d kernel: Booting paravirtualized kernel on VMware hypervisor
Mar 31 23:21:50 jar-d kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Mar 31 23:21:50 jar-d kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:128 nr_cpu_ids:128 nr_node_ids:1
Mar 31 23:21:50 jar-d kernel: percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
Mar 31 23:21:50 jar-d kernel: pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
Mar 31 23:21:50 jar-d kernel: pcpu-alloc: [0] 000 001 002 003 [0] 004 005 006 007
Mar 31 23:21:50 jar-d kernel: pcpu-alloc: [0] 008 009 010 011 [0] 012 013 014 015
Mar 31 23:21:50 jar-d kernel: pcpu-alloc: [0] 016 017 018 019 [0] 020 021 022 023
Mar 31 23:21:50 jar-d kernel: pcpu-alloc: [0] 112 113 114 115 [0] 116 117 118 119
Mar 31 23:21:50 jar-d kernel: pcpu-alloc: [0] 120 121 122 123 [0] 124 125 126 127
Mar 31 23:21:50 jar-d kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=95a87c40-ba34-439f-9662-962ae4a653c0 rw apparmor=1 security=apparmor udev.log_priority=3
Mar 31 23:21:50 jar-d kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64", will be passed to user space.
Mar 31 23:21:50 jar-d kernel: random: crng init done
Mar 31 23:21:50 jar-d kernel: printk: log_buf_len individual max cpu contribution: 4096 bytes
Mar 31 23:21:50 jar-d kernel: printk: log_buf_len total cpu_extra contributions: 520192 bytes
Mar 31 23:21:50 jar-d kernel: printk: log_buf_len min size: 131072 bytes
Mar 31 23:21:50 jar-d kernel: printk: log_buf_len: 1048576 bytes
Mar 31 23:21:50 jar-d kernel: printk: early log buf free: 113096(86%)
Mar 31 23:21:50 jar-d kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Mar 31 23:21:50 jar-d kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Mar 31 23:21:50 jar-d kernel: Fallback order for Node 0: 0
Mar 31 23:21:50 jar-d kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1310573
Mar 31 23:21:50 jar-d kernel: Policy zone: Normal
Mar 31 23:21:50 jar-d kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Mar 31 23:21:50 jar-d kernel: software IO TLB: area num 128.
Mar 31 23:21:50 jar-d kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=128, Nodes=1
Mar 31 23:21:50 jar-d kernel: ftrace: allocating 51381 entries in 201 pages
Mar 31 23:21:50 jar-d kernel: ftrace: allocated 201 pages with 4 groups
Mar 31 23:21:50 jar-d kernel: Dynamic Preempt: full
Mar 31 23:21:50 jar-d kernel: rcu: Preemptible hierarchical RCU implementation.
Mar 31 23:21:50 jar-d kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=128.
Mar 31 23:21:50 jar-d kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Mar 31 23:21:50 jar-d kernel:         Trampoline variant of Tasks RCU enabled.
Mar 31 23:21:50 jar-d kernel:         Rude variant of Tasks RCU enabled.
Mar 31 23:21:50 jar-d kernel:         Tracing variant of Tasks RCU enabled.
Mar 31 23:21:50 jar-d kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Mar 31 23:21:50 jar-d kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=128
Mar 31 23:21:50 jar-d kernel: RCU Tasks: Setting shift to 7 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=128.
Mar 31 23:21:50 jar-d kernel: RCU Tasks Rude: Setting shift to 7 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=128.
Mar 31 23:21:50 jar-d kernel: RCU Tasks Trace: Setting shift to 7 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=128.
Mar 31 23:21:50 jar-d kernel: NR_IRQS: 524544, nr_irqs: 1448, preallocated irqs: 16
Mar 31 23:21:50 jar-d kernel: rcu: srcu_init: Setting srcu_struct sizes to big.
Mar 31 23:21:50 jar-d kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Mar 31 23:21:50 jar-d kernel: Console: colour dummy device 80x25
Mar 31 23:21:50 jar-d kernel: printk: legacy console [tty0] enabled
Mar 31 23:21:50 jar-d kernel: ACPI: Core revision 20240827
Mar 31 23:21:50 jar-d kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
Mar 31 23:21:50 jar-d kernel: APIC: Switch to symmetric I/O mode setup
Mar 31 23:21:50 jar-d kernel: x2apic enabled
Mar 31 23:21:50 jar-d kernel: APIC: Switched APIC routing to: physical x2apic
Mar 31 23:21:50 jar-d kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Mar 31 23:21:50 jar-d kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23fa7a05128, max_idle_ns: 440795285767 ns
Mar 31 23:21:50 jar-d kernel: Calibrating delay loop (skipped) preset value.. 4994.00 BogoMIPS (lpj=8320010)
Mar 31 23:21:50 jar-d kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Mar 31 23:21:50 jar-d kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Mar 31 23:21:50 jar-d kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
Mar 31 23:21:50 jar-d kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Mar 31 23:21:50 jar-d kernel: Spectre V2 : Spectre BHI mitigation: SW BHB clearing on syscall and VM exit
Mar 31 23:21:50 jar-d kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
Mar 31 23:21:50 jar-d kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Mar 31 23:21:50 jar-d kernel: Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
Mar 31 23:21:50 jar-d kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Mar 31 23:21:50 jar-d kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Mar 31 23:21:50 jar-d kernel: Register File Data Sampling: Vulnerable: No microcode
Mar 31 23:21:50 jar-d kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Mar 31 23:21:50 jar-d kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Mar 31 23:21:50 jar-d kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Mar 31 23:21:50 jar-d kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Mar 31 23:21:50 jar-d kernel: x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
Mar 31 23:21:50 jar-d kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Mar 31 23:21:50 jar-d kernel: x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
Mar 31 23:21:50 jar-d kernel: x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
Mar 31 23:21:50 jar-d kernel: x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
Mar 31 23:21:50 jar-d kernel: Freeing SMP alternatives memory: 40K
Mar 31 23:21:50 jar-d kernel: pid_max: default: 131072 minimum: 1024
Mar 31 23:21:50 jar-d kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
Mar 31 23:21:50 jar-d kernel: landlock: Up and running.
Mar 31 23:21:50 jar-d kernel: Yama: becoming mindful.
Mar 31 23:21:50 jar-d kernel: LSM support for eBPF active
Mar 31 23:21:50 jar-d kernel: AppArmor: AppArmor initialized
Mar 31 23:21:50 jar-d kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Mar 31 23:21:50 jar-d kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Mar 31 23:21:50 jar-d kernel: smpboot: CPU0: 12th Gen Intel(R) Core(TM) i5-12400 (family: 0x6, model: 0x97, stepping: 0x5)
Mar 31 23:21:50 jar-d kernel: Performance Events: Alderlake Hybrid events, core PMU driver.
Mar 31 23:21:50 jar-d kernel: core: CPUID marked event: 'cpu cycles' unavailable
Mar 31 23:21:50 jar-d kernel: core: CPUID marked event: 'instructions' unavailable
Mar 31 23:21:50 jar-d kernel: core: CPUID marked event: 'bus cycles' unavailable
Mar 31 23:21:50 jar-d kernel: core: CPUID marked event: 'cache references' unavailable
Mar 31 23:21:50 jar-d kernel: core: CPUID marked event: 'cache misses' unavailable
Mar 31 23:21:50 jar-d kernel: core: CPUID marked event: 'branch instructions' unavailable
Mar 31 23:21:50 jar-d kernel: core: CPUID marked event: 'branch misses' unavailable
Mar 31 23:21:50 jar-d kernel: core: cpu_core PMU driver:
Mar 31 23:21:50 jar-d kernel: ... version:                1
Mar 31 23:21:50 jar-d kernel: ... bit width:              48
Mar 31 23:21:50 jar-d kernel: ... generic registers:      8
Mar 31 23:21:50 jar-d kernel: ... value mask:             0000ffffffffffff
Mar 31 23:21:50 jar-d kernel: ... max period:             000000007fffffff
Mar 31 23:21:50 jar-d kernel: ... fixed-purpose events:   0
Mar 31 23:21:50 jar-d kernel: ... event mask:             00010000000000ff
Mar 31 23:21:50 jar-d kernel: signal: max sigframe size: 3632
Mar 31 23:21:50 jar-d kernel: rcu: Hierarchical SRCU implementation.
Mar 31 23:21:50 jar-d kernel: rcu:         Max phase no-delay instances is 1000.
Mar 31 23:21:50 jar-d kernel: Timer migration: 3 hierarchy levels; 8 children per group; 3 crossnode level
Mar 31 23:21:50 jar-d kernel: NMI watchdog: Perf NMI watchdog permanently disabled
Mar 31 23:21:50 jar-d kernel: smp: Bringing up secondary CPUs ...
Mar 31 23:21:50 jar-d kernel: smpboot: x86: Booting SMP configuration:
Mar 31 23:21:50 jar-d kernel: .... node  #0, CPUs:          #1
Mar 31 23:21:50 jar-d kernel: smp: Brought up 1 node, 2 CPUs
Mar 31 23:21:50 jar-d kernel: smpboot: Total of 2 processors activated (9988.01 BogoMIPS)
Mar 31 23:21:50 jar-d kernel: Memory: 4958236K/5242292K available (18432K kernel code, 2672K rwdata, 14324K rodata, 4280K init, 4008K bss, 271752K reserved, 0K cma-reserved)
Mar 31 23:21:50 jar-d kernel: devtmpfs: initialized
Mar 31 23:21:50 jar-d kernel: x86/mm: Memory block size: 128MB
Mar 31 23:21:50 jar-d kernel: ACPI: PM: Registering ACPI NVS region [mem 0xbfeff000-0xbfefffff] (4096 bytes)
Mar 31 23:21:50 jar-d kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Mar 31 23:21:50 jar-d kernel: futex hash table entries: 32768 (order: 9, 2097152 bytes, linear)
Mar 31 23:21:50 jar-d kernel: pinctrl core: initialized pinctrl subsystem
Mar 31 23:21:50 jar-d kernel: PM: RTC time: 14:21:48, date: 2025-03-31
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Mar 31 23:21:50 jar-d kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
Mar 31 23:21:50 jar-d kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Mar 31 23:21:50 jar-d kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Mar 31 23:21:50 jar-d kernel: audit: initializing netlink subsys (disabled)
Mar 31 23:21:50 jar-d kernel: thermal_sys: Registered thermal governor 'fair_share'
Mar 31 23:21:50 jar-d kernel: thermal_sys: Registered thermal governor 'bang_bang'
Mar 31 23:21:50 jar-d kernel: thermal_sys: Registered thermal governor 'step_wise'
Mar 31 23:21:50 jar-d kernel: thermal_sys: Registered thermal governor 'user_space'
Mar 31 23:21:50 jar-d kernel: thermal_sys: Registered thermal governor 'power_allocator'
Mar 31 23:21:50 jar-d kernel: audit: type=2000 audit(1743430908.049:1): state=initialized audit_enabled=0 res=1
Mar 31 23:21:50 jar-d kernel: cpuidle: using governor ladder
Mar 31 23:21:50 jar-d kernel: cpuidle: using governor menu
Mar 31 23:21:50 jar-d kernel: Simple Boot Flag at 0x36 set to 0x80
Mar 31 23:21:50 jar-d kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Mar 31 23:21:50 jar-d kernel: PCI: ECAM [mem 0xf0000000-0xf7ffffff] (base 0xf0000000) for domain 0000 [bus 00-7f]
Mar 31 23:21:50 jar-d kernel: PCI: Using configuration type 1 for base access
Mar 31 23:21:50 jar-d kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Mar 31 23:21:50 jar-d kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Mar 31 23:21:50 jar-d kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Mar 31 23:21:50 jar-d kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Mar 31 23:21:50 jar-d kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Mar 31 23:21:50 jar-d kernel: ACPI: Added _OSI(Module Device)
Mar 31 23:21:50 jar-d kernel: ACPI: Added _OSI(Processor Device)
Mar 31 23:21:50 jar-d kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Mar 31 23:21:50 jar-d kernel: ACPI: Added _OSI(Processor Aggregator Device)
Mar 31 23:21:50 jar-d kernel: ACPI: 1 ACPI AML tables successfully acquired and loaded
Mar 31 23:21:50 jar-d kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Mar 31 23:21:50 jar-d kernel: ACPI: Interpreter enabled
Mar 31 23:21:50 jar-d kernel: ACPI: PM: (supports S0 S1 S4 S5)
Mar 31 23:21:50 jar-d kernel: ACPI: Using IOAPIC for interrupt routing
Mar 31 23:21:50 jar-d kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Mar 31 23:21:50 jar-d kernel: PCI: Using E820 reservations for host bridge windows
Mar 31 23:21:50 jar-d kernel: ACPI: Enabled 4 GPEs in block 00 to 0F
Mar 31 23:21:50 jar-d kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7f])
Mar 31 23:21:50 jar-d kernel: acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Mar 31 23:21:50 jar-d kernel: acpi PNP0A03:00: _OSC: platform does not support [AER LTR DPC]
Mar 31 23:21:50 jar-d kernel: acpi PNP0A03:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability]
Mar 31 23:21:50 jar-d kernel: PCI host bridge to bus 0000:00
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000dbfff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xfeff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: root bus resource [bus 00-7f]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:00.0: [8086:7190] type 00 class 0x060000 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:00:01.0: [8086:7191] type 01 class 0x060400 conventional PCI bridge
Mar 31 23:21:50 jar-d kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.0: [8086:7110] type 00 class 0x060100 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.1: [8086:7111] type 00 class 0x01018a conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.1: BAR 4 [io  0x1060-0x106f]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.1: BAR 0 [io  0x01f0-0x01f7]: legacy IDE quirk
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.1: BAR 1 [io  0x03f6]: legacy IDE quirk
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.1: BAR 2 [io  0x0170-0x0177]: legacy IDE quirk
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.1: BAR 3 [io  0x0376]: legacy IDE quirk
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.3: [8086:7113] type 00 class 0x068000 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.3: quirk: [io  0x1000-0x103f] claimed by PIIX4 ACPI
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.3: quirk: [io  0x1040-0x104f] claimed by PIIX4 SMB
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.7: [15ad:0740] type 00 class 0x088000 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.7: BAR 0 [io  0x1080-0x10bf]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:07.7: BAR 1 [mem 0xfebc0000-0xfebfffff 64bit]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: [15ad:0405] type 00 class 0x030000 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: BAR 0 [io  0x1070-0x107f]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: BAR 1 [mem 0xe8000000-0xefffffff pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: BAR 2 [mem 0xfe000000-0xfe7fffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: ROM [mem 0x00000000-0x00007fff pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:10.0: [1000:0030] type 00 class 0x010000 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:00:10.0: BAR 0 [io  0x1400-0x14ff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:10.0: BAR 1 [mem 0xfeb80000-0xfeb9ffff 64bit]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:10.0: BAR 3 [mem 0xfeba0000-0xfebbffff 64bit]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:10.0: ROM [mem 0x00000000-0x00003fff pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0: [15ad:0790] type 01 class 0x060401 conventional PCI bridge
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0: PCI bridge to [bus 02] (subtractive decode)
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [io  0x2000-0x3fff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [mem 0xfd500000-0xfdffffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [mem 0xe7b00000-0xe7ffffff 64bit pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.0: [15ad:07a0] type 01 class 0x060400 PCIe Root Port
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.6: PME# supported from D0 D3hot D3cold
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.7: [15ad:07a0] type 01 class 0x060400 PCIe Root Port
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.7: PCI bridge to [bus 22]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.7:   bridge window [mem 0xfb500000-0xfb5fffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.7:   bridge window [mem 0xe5b00000-0xe5bfffff 64bit pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.7: PME# supported from D0 D3hot D3cold
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:01: extended config space not accessible
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:02: extended config space not accessible
Mar 31 23:21:50 jar-d kernel: acpiphp: Slot [32] registered
Mar 31 23:21:50 jar-d kernel: acpiphp: Slot [33] registered
Mar 31 23:21:50 jar-d kernel: acpiphp: Slot [34] registered
Mar 31 23:21:50 jar-d kernel: acpiphp: Slot [35] registered
Mar 31 23:21:50 jar-d kernel: acpiphp: Slot [61] registered
Mar 31 23:21:50 jar-d kernel: acpiphp: Slot [62] registered
Mar 31 23:21:50 jar-d kernel: acpiphp: Slot [63] registered
Mar 31 23:21:50 jar-d kernel: pci 0000:02:00.0: [15ad:0774] type 00 class 0x0c0300 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:02:00.0: BAR 4 [io  0x2080-0x209f]
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: [8086:100f] type 00 class 0x020000 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: BAR 0 [mem 0xfd5c0000-0xfd5dffff 64bit]
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: BAR 2 [mem 0xfdff0000-0xfdffffff 64bit]
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: BAR 4 [io  0x2000-0x203f]
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: ROM [mem 0x00000000-0x0000ffff pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: PME# supported from D0 D3hot D3cold
Mar 31 23:21:50 jar-d kernel: pci 0000:02:02.0: [1274:1371] type 00 class 0x040100 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:02:02.0: BAR 0 [io  0x2040-0x207f]
Mar 31 23:21:50 jar-d kernel: pci 0000:02:03.0: [15ad:0770] type 00 class 0x0c0320 conventional PCI endpoint
Mar 31 23:21:50 jar-d kernel: pci 0000:02:03.0: BAR 0 [mem 0xfd5ef000-0xfd5effff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [mem 0x000cc000-0x000dbfff window] (subtractive decode)
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [mem 0xc0000000-0xfebfffff window] (subtractive decode)
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
Mar 31 23:21:50 jar-d kernel: pci 0000:00:11.0:   bridge window [io  0x0d00-0xfeff window] (subtractive decode)
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.0: PCI bridge to [bus 03]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.1: PCI bridge to [bus 04]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.2: PCI bridge to [bus 05]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.6: PCI bridge to [bus 21]
Mar 31 23:21:50 jar-d kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 9
Mar 31 23:21:50 jar-d kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 11
Mar 31 23:21:50 jar-d kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 10
Mar 31 23:21:50 jar-d kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 7
Mar 31 23:21:50 jar-d kernel: iommu: Default domain type: Translated
Mar 31 23:21:50 jar-d kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Mar 31 23:21:50 jar-d kernel: SCSI subsystem initialized
Mar 31 23:21:50 jar-d kernel: libata version 3.00 loaded.
Mar 31 23:21:50 jar-d kernel: ACPI: bus type USB registered
Mar 31 23:21:50 jar-d kernel: usbcore: registered new interface driver usbfs
Mar 31 23:21:50 jar-d kernel: usbcore: registered new interface driver hub
Mar 31 23:21:50 jar-d kernel: usbcore: registered new device driver usb
Mar 31 23:21:50 jar-d kernel: EDAC MC: Ver: 3.0.0
Mar 31 23:21:50 jar-d kernel: NetLabel: Initializing
Mar 31 23:21:50 jar-d kernel: NetLabel:  domain hash size = 128
Mar 31 23:21:50 jar-d kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Mar 31 23:21:50 jar-d kernel: NetLabel:  unlabeled traffic allowed by default
Mar 31 23:21:50 jar-d kernel: mctp: management component transport protocol core
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_MCTP protocol family
Mar 31 23:21:50 jar-d kernel: PCI: Using ACPI for IRQ routing
Mar 31 23:21:50 jar-d kernel: PCI: pci_cache_line_size set to 64 bytes
Mar 31 23:21:50 jar-d kernel: e820: reserve RAM buffer [mem 0x0009ec00-0x0009ffff]
Mar 31 23:21:50 jar-d kernel: e820: reserve RAM buffer [mem 0xbfed0000-0xbfffffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: vgaarb: setting as boot VGA device
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: vgaarb: bridge control possible
Mar 31 23:21:50 jar-d kernel: pci 0000:00:0f.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Mar 31 23:21:50 jar-d kernel: vgaarb: loaded
Mar 31 23:21:50 jar-d kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
Mar 31 23:21:50 jar-d kernel: hpet0: 16 comparators, 64-bit 14.318180 MHz counter
Mar 31 23:21:50 jar-d kernel: clocksource: Switched to clocksource tsc-early
Mar 31 23:21:50 jar-d kernel: VFS: Disk quotas dquot_6.6.0
Mar 31 23:21:50 jar-d kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Mar 31 23:21:50 jar-d kernel: AppArmor: AppArmor Filesystem Enabled
Mar 31 23:21:50 jar-d kernel: pnp: PnP ACPI init
Mar 31 23:21:50 jar-d kernel: system 00:00: [io  0x1000-0x103f] has been reserved
Mar 31 23:21:50 jar-d kernel: system 00:00: [io  0x1040-0x104f] has been reserved
Mar 31 23:21:50 jar-d kernel: system 00:00: [io  0x0cf0-0x0cf1] has been reserved
Mar 31 23:21:50 jar-d kernel: system 00:04: [mem 0xfed00000-0xfed003ff] has been reserved
Mar 31 23:21:50 jar-d kernel: system 00:06: [io  0xfce0-0xfcff] has been reserved
Mar 31 23:21:50 jar-d kernel: system 00:06: [mem 0xf0000000-0xf7ffffff] has been reserved
Mar 31 23:21:50 jar-d kernel: system 00:06: [mem 0xfe800000-0xfe9fffff] has been reserved
Mar 31 23:21:50 jar-d kernel: pnp: PnP ACPI: found 7 devices
Mar 31 23:21:50 jar-d kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_INET protocol family
Mar 31 23:21:50 jar-d kernel: IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Mar 31 23:21:50 jar-d kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
Mar 31 23:21:50 jar-d kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Mar 31 23:21:50 jar-d kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
Mar 31 23:21:50 jar-d kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Mar 31 23:21:50 jar-d kernel: TCP: Hash tables configured (established 65536 bind 65536)
Mar 31 23:21:50 jar-d kernel: MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
Mar 31 23:21:50 jar-d kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
Mar 31 23:21:50 jar-d kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_XDP protocol family
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.3: bridge window [io  0x1000-0x0fff] to [bus 06] add_size 1000
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.4: bridge window [io  0x1000-0x0fff] to [bus 07] add_size 1000
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.5: bridge window [io  0x1000-0x0fff] to [bus 08] add_size 1000
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.6: bridge window [io  0x1000-0x0fff] to [bus 09] add_size 1000
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.6: bridge window [io  0x1000-0x0fff] to [bus 21] add_size 1000
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.7: bridge window [io  0x1000-0x0fff] to [bus 22] add_size 1000
Mar 31 23:21:50 jar-d kernel: pci 0000:00:10.0: ROM [mem 0xc0000000-0xc0003fff pref]: assigned
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.3: bridge window [io  size 0x1000]: can't assign; no space
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.3: bridge window [io  size 0x1000]: failed to assign
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.4: bridge window [io  size 0x1000]: can't assign; no space
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.4: bridge window [io  size 0x1000]: failed to assign
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.5: bridge window [io  size 0x1000]: can't assign; no space
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.5: bridge window [io  size 0x1000]: failed to assign
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: ROM [mem 0xfd500000-0xfd50ffff pref]: assigned
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.0:   bridge window [io  0x4000-0x4fff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.0:   bridge window [mem 0xfd400000-0xfd4fffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.0:   bridge window [mem 0xe7a00000-0xe7afffff 64bit pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.1:   bridge window [io  0x8000-0x8fff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.1:   bridge window [mem 0xfd000000-0xfd0fffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:15.1:   bridge window [mem 0xe7600000-0xe76fffff 64bit pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.6:   bridge window [mem 0xfb900000-0xfb9fffff]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:18.6:   bridge window [mem 0xe5f00000-0xe5ffffff 64bit pref]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: resource 4 [mem 0x000a0000-0x000bffff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: resource 5 [mem 0x000cc000-0x000dbfff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: resource 6 [mem 0xc0000000-0xfebfffff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: resource 7 [io  0x0000-0x0cf7 window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:00: resource 8 [io  0x0d00-0xfeff window]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:02: resource 0 [io  0x2000-0x3fff]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:02: resource 1 [mem 0xfd500000-0xfdffffff]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:21: resource 2 [mem 0xe5f00000-0xe5ffffff 64bit pref]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:22: resource 1 [mem 0xfb500000-0xfb5fffff]
Mar 31 23:21:50 jar-d kernel: pci_bus 0000:22: resource 2 [mem 0xe5b00000-0xe5bfffff 64bit pref]
Mar 31 23:21:50 jar-d kernel: pci 0000:00:00.0: Limiting direct PCI/PCI transfers
Mar 31 23:21:50 jar-d kernel: pci 0000:02:01.0: CLS mismatch (32 != 64), using 64 bytes
Mar 31 23:21:50 jar-d kernel: Trying to unpack rootfs image as initramfs...
Mar 31 23:21:50 jar-d kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Mar 31 23:21:50 jar-d kernel: software IO TLB: mapped [mem 0x00000000bbed0000-0x00000000bfed0000] (64MB)
Mar 31 23:21:50 jar-d kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa7a05128, max_idle_ns: 440795285767 ns
Mar 31 23:21:50 jar-d kernel: Initialise system trusted keyrings
Mar 31 23:21:50 jar-d kernel: Key type blacklist registered
Mar 31 23:21:50 jar-d kernel: workingset: timestamp_bits=36 max_order=21 bucket_order=0
Mar 31 23:21:50 jar-d kernel: fuse: init (API version 7.41)
Mar 31 23:21:50 jar-d kernel: integrity: Platform Keyring initialized
Mar 31 23:21:50 jar-d kernel: integrity: Machine keyring initialized
Mar 31 23:21:50 jar-d kernel: Key type asymmetric registered
Mar 31 23:21:50 jar-d kernel: Asymmetric key parser 'x509' registered
Mar 31 23:21:50 jar-d kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Mar 31 23:21:50 jar-d kernel: io scheduler mq-deadline registered
Mar 31 23:21:50 jar-d kernel: io scheduler kyber registered
Mar 31 23:21:50 jar-d kernel: io scheduler bfq registered
Mar 31 23:21:50 jar-d kernel: ledtrig-cpu: registered to indicate activity on CPUs
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:15.0: PME: Signaling with IRQ 24
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:15.0: pciehp: Slot #160 AttnBtn+ PwrCtrl+ MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:15.1: PME: Signaling with IRQ 25
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:15.1: pciehp: Slot #161 AttnBtn+ PwrCtrl+ MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:18.6: PME: Signaling with IRQ 54
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:18.6: pciehp: Slot #262 AttnBtn+ PwrCtrl+ MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:18.7: PME: Signaling with IRQ 55
Mar 31 23:21:50 jar-d kernel: pcieport 0000:00:18.7: pciehp: Slot #263 AttnBtn+ PwrCtrl+ MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Mar 31 23:21:50 jar-d kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Mar 31 23:21:50 jar-d kernel: ACPI: AC: AC Adapter [ACAD] (on-line)
Mar 31 23:21:50 jar-d kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
Mar 31 23:21:50 jar-d kernel: ACPI: button: Power Button [PWRF]
Mar 31 23:21:50 jar-d kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Mar 31 23:21:50 jar-d kernel: 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
Mar 31 23:21:50 jar-d kernel: Non-volatile memory driver v1.3
Mar 31 23:21:50 jar-d kernel: Linux agpgart interface v0.103
Mar 31 23:21:50 jar-d kernel: ACPI: bus type drm_connector registered
Mar 31 23:21:50 jar-d kernel: ehci-pci 0000:02:03.0: EHCI Host Controller
Mar 31 23:21:50 jar-d kernel: ehci-pci 0000:02:03.0: new USB bus registered, assigned bus number 1
Mar 31 23:21:50 jar-d kernel: ehci-pci 0000:02:03.0: irq 17, io mem 0xfd5ef000
Mar 31 23:21:50 jar-d kernel: ehci-pci 0000:02:03.0: USB 2.0 started, EHCI 1.00
Mar 31 23:21:50 jar-d kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
Mar 31 23:21:50 jar-d kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 31 23:21:50 jar-d kernel: usb usb1: Product: EHCI Host Controller
Mar 31 23:21:50 jar-d kernel: usb usb1: Manufacturer: Linux 6.12.20-2-MANJARO ehci_hcd
Mar 31 23:21:50 jar-d kernel: usb usb1: SerialNumber: 0000:02:03.0
Mar 31 23:21:50 jar-d kernel: hub 1-0:1.0: USB hub found
Mar 31 23:21:50 jar-d kernel: hub 1-0:1.0: 6 ports detected
Mar 31 23:21:50 jar-d kernel: uhci_hcd 0000:02:00.0: UHCI Host Controller
Mar 31 23:21:50 jar-d kernel: uhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 2
Mar 31 23:21:50 jar-d kernel: uhci_hcd 0000:02:00.0: detected 2 ports
Mar 31 23:21:50 jar-d kernel: uhci_hcd 0000:02:00.0: irq 18, io port 0x00002080
Mar 31 23:21:50 jar-d kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12
Mar 31 23:21:50 jar-d kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 31 23:21:50 jar-d kernel: usb usb2: Product: UHCI Host Controller
Mar 31 23:21:50 jar-d kernel: usb usb2: Manufacturer: Linux 6.12.20-2-MANJARO uhci_hcd
Mar 31 23:21:50 jar-d kernel: usb usb2: SerialNumber: 0000:02:00.0
Mar 31 23:21:50 jar-d kernel: hub 2-0:1.0: USB hub found
Mar 31 23:21:50 jar-d kernel: hub 2-0:1.0: 2 ports detected
Mar 31 23:21:50 jar-d kernel: usbcore: registered new interface driver usbserial_generic
Mar 31 23:21:50 jar-d kernel: usbserial: USB Serial support registered for generic
Mar 31 23:21:50 jar-d kernel: rtc_cmos 00:01: registered as rtc0
Mar 31 23:21:50 jar-d kernel: rtc_cmos 00:01: setting system clock to 2025-03-31T14:21:48 UTC (1743430908)
Mar 31 23:21:50 jar-d kernel: rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram
Mar 31 23:21:50 jar-d kernel: intel_pstate: CPU model not supported
Mar 31 23:21:50 jar-d kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
Mar 31 23:21:50 jar-d kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Mar 31 23:21:50 jar-d kernel: fbcon: Deferring console take-over
Mar 31 23:21:50 jar-d kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Mar 31 23:21:50 jar-d kernel: hid: raw HID events driver (C) Jiri Kosina
Mar 31 23:21:50 jar-d kernel: drop_monitor: Initializing network drop monitor service
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_INET6 protocol family
Mar 31 23:21:50 jar-d kernel: Freeing initrd memory: 18944K
Mar 31 23:21:50 jar-d kernel: Segment Routing with IPv6
Mar 31 23:21:50 jar-d kernel: RPL Segment Routing with IPv6
Mar 31 23:21:50 jar-d kernel: In-situ OAM (IOAM) with IPv6
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_PACKET protocol family
Mar 31 23:21:50 jar-d kernel: IPI shorthand broadcast: enabled
Mar 31 23:21:50 jar-d kernel: sched_clock: Marking stable (1053338263, 2031452)->(1113339883, -57970168)
Mar 31 23:21:50 jar-d kernel: registered taskstats version 1
Mar 31 23:21:50 jar-d kernel: Loading compiled-in X.509 certificates
Mar 31 23:21:50 jar-d kernel: Loaded X.509 cert 'Build time autogenerated kernel key: aa99f33d6b8a9c729859acc52f59347840c73b6a'
Mar 31 23:21:50 jar-d kernel: Demotion targets for Node 0: null
Mar 31 23:21:50 jar-d kernel: Key type .fscrypt registered
Mar 31 23:21:50 jar-d kernel: Key type fscrypt-provisioning registered
Mar 31 23:21:50 jar-d kernel: AppArmor: AppArmor sha256 policy hashing enabled
Mar 31 23:21:50 jar-d kernel: PM:   Magic number: 1:619:385
Mar 31 23:21:50 jar-d kernel: thermal cooling_device0: hash matches
Mar 31 23:21:50 jar-d kernel: clockevents clockevent102: hash matches
Mar 31 23:21:50 jar-d kernel: RAS: Correctable Errors collector initialized.
Mar 31 23:21:50 jar-d kernel: clk: Disabling unused clocks
Mar 31 23:21:50 jar-d kernel: PM: genpd: Disabling unused power domains
Mar 31 23:21:50 jar-d kernel: Freeing unused decrypted memory: 2028K
Mar 31 23:21:50 jar-d kernel: Freeing unused kernel image (initmem) memory: 4280K
Mar 31 23:21:50 jar-d kernel: Write protecting the kernel read-only data: 32768k
Mar 31 23:21:50 jar-d kernel: Freeing unused kernel image (rodata/data gap) memory: 12K
Mar 31 23:21:50 jar-d kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Mar 31 23:21:50 jar-d kernel: rodata_test: all tests were successful
Mar 31 23:21:50 jar-d kernel: Run /init as init process
Mar 31 23:21:50 jar-d kernel:   with arguments:
Mar 31 23:21:50 jar-d kernel:     /init
Mar 31 23:21:50 jar-d kernel:   with environment:
Mar 31 23:21:50 jar-d kernel:     HOME=/
Mar 31 23:21:50 jar-d kernel:     TERM=linux
Mar 31 23:21:50 jar-d kernel:     BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
Mar 31 23:21:50 jar-d kernel: fbcon: Taking over console
Mar 31 23:21:50 jar-d kernel: Console: switching to colour frame buffer device 80x30
Mar 31 23:21:50 jar-d kernel: i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOUS] at 0x60,0x64 irq 1,12
Mar 31 23:21:50 jar-d kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Mar 31 23:21:50 jar-d kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Mar 31 23:21:50 jar-d kernel: usb 2-1: new full-speed USB device number 2 using uhci_hcd
Mar 31 23:21:50 jar-d kernel: agpgart-intel 0000:00:00.0: Intel 440BX Chipset
Mar 31 23:21:50 jar-d kernel: agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0x0
Mar 31 23:21:50 jar-d kernel: ata_piix 0000:00:07.1: version 2.13
Mar 31 23:21:50 jar-d kernel: scsi host0: ata_piix
Mar 31 23:21:50 jar-d kernel: scsi host1: ata_piix
Mar 31 23:21:50 jar-d kernel: ata1: PATA max UDMA/33 cmd 0x1f0 ctl 0x3f6 bmdma 0x1060 irq 14 lpm-pol 0
Mar 31 23:21:50 jar-d kernel: ata2: PATA max UDMA/33 cmd 0x170 ctl 0x376 bmdma 0x1068 irq 15 lpm-pol 0
Mar 31 23:21:50 jar-d kernel: Fusion MPT base driver 3.04.20
Mar 31 23:21:50 jar-d kernel: Copyright (c) 1999-2008 LSI Corporation
Mar 31 23:21:50 jar-d kernel: usb 2-1: New USB device found, idVendor=0e0f, idProduct=0003, bcdDevice= 1.03
Mar 31 23:21:50 jar-d kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Mar 31 23:21:50 jar-d kernel: usb 2-1: Product: VMware Virtual USB Mouse
Mar 31 23:21:50 jar-d kernel: usb 2-1: Manufacturer: VMware
Mar 31 23:21:50 jar-d kernel: ata2.00: ATAPI: VMware Virtual IDE CDROM Drive, 00000001, max UDMA/33
Mar 31 23:21:50 jar-d kernel: scsi 1:0:0:0: CD-ROM            NECVMWar VMware IDE CDR10 1.00 PQ: 0 ANSI: 5
Mar 31 23:21:50 jar-d kernel: Fusion MPT SPI Host driver 3.04.20
Mar 31 23:21:50 jar-d kernel: mptbase: ioc0: Initiating bringup
Mar 31 23:21:50 jar-d kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
Mar 31 23:21:50 jar-d kernel: sr 1:0:0:0: [sr0] scsi3-mmc drive: 1x/1x writer dvd-ram cd/rw xa/form2 cdda tray
Mar 31 23:21:50 jar-d kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Mar 31 23:21:50 jar-d kernel: Console: switching to colour dummy device 80x25
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: vgaarb: deactivate vga console
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] FIFO at 0x00000000fe000000 size is 8192 KiB
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] VRAM at 0x00000000e8000000 size is 131072 KiB
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Running on SVGA version 2.
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Capabilities: rect copy, cursor, cursor bypass, cursor bypass 2, 8bit emulation, alpha cursor, extended fifo, multimon, pitchlock, irq mask, display topology, gmr, traces, gmr2, screen object 2, command buffers, command buffers 2, gbobject, dx, hp cmd queue, no bb restriction, cap2 register,
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Capabilities2: grow otable, intra surface copy, dx2, gb memsize 2, screendma reg, otable ptdepth2, non ms to ms stretchblt, cursor mob, mshint, cb max size 4mb, dx3, frame type, trace full fb, extra regs, lo staging,
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] DMA map mode: Caching DMA mappings.
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Legacy memory limits: VRAM = 4096 KiB, FIFO = 256 KiB, surface = 0 KiB
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] MOB limits: max mob size = 262144 KiB, max mob pages = 65536
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Max GMR ids is 64
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Max number of GMR pages is 65536
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Maximum display memory size is 262144 KiB
Mar 31 23:21:50 jar-d kernel: usb 2-2: new full-speed USB device number 3 using uhci_hcd
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Screen Target display unit initialized
Mar 31 23:21:50 jar-d kernel: ioc0: LSI53C1030 B0: Capabilities={Initiator}
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Fifo max 0x00040000 min 0x00001000 cap 0x0000077f
Mar 31 23:21:50 jar-d kernel: sr 1:0:0:0: Attached scsi CD-ROM sr0
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Using command buffers with DMA pool.
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] Available shader model: Legacy.
Mar 31 23:21:50 jar-d kernel: [drm] Initialized vmwgfx 2.20.0 for 0000:00:0f.0 on minor 0
Mar 31 23:21:50 jar-d kernel: fbcon: vmwgfxdrmfb (fb0) is primary device
Mar 31 23:21:50 jar-d kernel: Console: switching to colour frame buffer device 160x50
Mar 31 23:21:50 jar-d kernel: vmwgfx 0000:00:0f.0: [drm] fb0: vmwgfxdrmfb frame buffer device
Mar 31 23:21:50 jar-d kernel: usb 2-2: New USB device found, idVendor=0e0f, idProduct=0002, bcdDevice= 1.00
Mar 31 23:21:50 jar-d kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Mar 31 23:21:50 jar-d kernel: usb 2-2: Product: VMware Virtual USB Hub
Mar 31 23:21:50 jar-d kernel: usb 2-2: Manufacturer: VMware, Inc.
Mar 31 23:21:50 jar-d kernel: hub 2-2:1.0: USB hub found
Mar 31 23:21:50 jar-d kernel: scsi host2: ioc0: LSI53C1030 B0, FwRev=01032920h, Ports=1, MaxQ=128, IRQ=17
Mar 31 23:21:50 jar-d kernel: hub 2-2:1.0: 7 ports detected
Mar 31 23:21:50 jar-d kernel: usbcore: registered new interface driver usbhid
Mar 31 23:21:50 jar-d kernel: usbhid: USB HID core driver
Mar 31 23:21:50 jar-d kernel: input: VMware VMware Virtual USB Mouse as /devices/pci0000:00/0000:00:11.0/0000:02:00.0/usb2/2-1/2-1:1.0/0003:0E0F:0003.0001/input/input3
Mar 31 23:21:50 jar-d kernel: hid-generic 0003:0E0F:0003.0001: input,hidraw0: USB HID v1.10 Mouse [VMware VMware Virtual USB Mouse] on usb-0000:02:00.0-1/input0
Mar 31 23:21:50 jar-d kernel: scsi 2:0:0:0: Direct-Access     VMware,  VMware Virtual S 1.0  PQ: 0 ANSI: 2
Mar 31 23:21:50 jar-d kernel: scsi target2:0:0: Beginning Domain Validation
Mar 31 23:21:50 jar-d kernel: scsi target2:0:0: Domain Validation skipping write tests
Mar 31 23:21:50 jar-d kernel: scsi target2:0:0: Ending Domain Validation
Mar 31 23:21:50 jar-d kernel: scsi target2:0:0: FAST-40 WIDE SCSI 80.0 MB/s ST (25 ns, offset 127)
Mar 31 23:21:50 jar-d kernel: sd 2:0:0:0: [sda] 209715200 512-byte logical blocks: (107 GB/100 GiB)
Mar 31 23:21:50 jar-d kernel: sd 2:0:0:0: [sda] Write Protect is off
Mar 31 23:21:50 jar-d kernel: sd 2:0:0:0: [sda] Mode Sense: 61 00 00 00
Mar 31 23:21:50 jar-d kernel: sd 2:0:0:0: [sda] Cache data unavailable
Mar 31 23:21:50 jar-d kernel: sd 2:0:0:0: [sda] Assuming drive cache: write through
Mar 31 23:21:50 jar-d kernel:  sda: sda1
Mar 31 23:21:50 jar-d kernel: sd 2:0:0:0: [sda] Attached SCSI disk
Mar 31 23:21:50 jar-d kernel: EXT4-fs (sda1): mounted filesystem 95a87c40-ba34-439f-9662-962ae4a653c0 r/w with ordered data mode. Quota mode: none.
Mar 31 23:21:50 jar-d systemd[1]: systemd 257.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
Mar 31 23:21:50 jar-d systemd[1]: Detected virtualization vmware.
Mar 31 23:21:50 jar-d systemd[1]: Detected architecture x86-64.
Mar 31 23:21:50 jar-d systemd[1]: Hostname set to <jar-d>.
Mar 31 23:21:50 jar-d systemd[1]: bpf-restrict-fs: LSM BPF program attached
Mar 31 23:21:50 jar-d kernel: vmw_vmci 0000:00:07.7: MMIO register access is available
Mar 31 23:21:50 jar-d kernel: vmw_vmci 0000:00:07.7: Using capabilities 0x3c
Mar 31 23:21:50 jar-d kernel: Guest personality initialized and is active
Mar 31 23:21:50 jar-d kernel: VMCI host device registered (name=vmci, major=10, minor=123)
Mar 31 23:21:50 jar-d kernel: Initialized host personality
Mar 31 23:21:50 jar-d kernel: NET: Registered PF_VSOCK protocol family
Mar 31 23:21:50 jar-d systemd[1]: Queued start job for default target Graphical Interface.
Mar 31 23:21:50 jar-d systemd[1]: Created slice CUPS Slice.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/dirmngr.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/getty.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/gpg-agent.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/gpg-agent-browser.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/gpg-agent-extra.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/keyboxd.
Mar 31 23:21:50 jar-d systemd[1]: Created slice Slice /system/modprobe.
Mar 31 23:21:50 jar-d systemd[1]: Created slice User and Session Slice.
Mar 31 23:21:50 jar-d systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Mar 31 23:21:50 jar-d systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Mar 31 23:21:50 jar-d systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Local Encrypted Volumes.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Login Prompts.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Local Integrity Protected Volumes.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Remote File Systems.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Slice Units.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Mounting snaps.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Mounted snaps.
Mar 31 23:21:50 jar-d systemd[1]: Reached target System Time Set.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Local Verity Protected Volumes.
Mar 31 23:21:50 jar-d systemd[1]: Listening on Device-mapper event daemon FIFOs.
Mar 31 23:21:50 jar-d systemd[1]: Listening on LVM2 poll daemon socket.
Mar 31 23:21:50 jar-d systemd[1]: Listening on Process Core Dump Socket.
Mar 31 23:21:50 jar-d systemd[1]: Listening on Credential Encryption/Decryption.
Mar 31 23:21:50 jar-d systemd[1]: Listening on Journal Socket (/dev/log).
Mar 31 23:21:50 jar-d systemd[1]: Listening on Journal Sockets.
Mar 31 23:21:50 jar-d systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Mar 31 23:21:50 jar-d systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Mar 31 23:21:50 jar-d systemd[1]: Listening on udev Control Socket.
Mar 31 23:21:50 jar-d systemd[1]: Listening on udev Kernel Socket.
Mar 31 23:21:50 jar-d systemd[1]: Mounting Huge Pages File System...
Mar 31 23:21:50 jar-d systemd[1]: Mounting POSIX Message Queue File System...
Mar 31 23:21:50 jar-d systemd[1]: Mounting Kernel Debug File System...
Mar 31 23:21:50 jar-d systemd[1]: Mounting Kernel Trace File System...
Mar 31 23:21:50 jar-d systemd[1]: Starting Load AppArmor profiles...
Mar 31 23:21:50 jar-d systemd[1]: Starting Create List of Static Device Nodes...
Mar 31 23:21:50 jar-d systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Mar 31 23:21:50 jar-d systemd[1]: Starting Load Kernel Module configfs...
Mar 31 23:21:50 jar-d systemd[1]: Starting Load Kernel Module dm_mod...
Mar 31 23:21:50 jar-d systemd[1]: Starting Load Kernel Module drm...
Mar 31 23:21:50 jar-d systemd[1]: Starting Load Kernel Module fuse...
Mar 31 23:21:50 jar-d systemd[1]: Starting Load Kernel Module loop...
Mar 31 23:21:50 jar-d systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Mar 31 23:21:50 jar-d systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Mar 31 23:21:50 jar-d systemd[1]: Starting Load Kernel Modules...
Mar 31 23:21:50 jar-d systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Mar 31 23:21:50 jar-d kernel: device-mapper: uevent: version 1.0.3
Mar 31 23:21:50 jar-d kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.949:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=289 comm="apparmor_parser"
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.949:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=290 comm="apparmor_parser"
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.953:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=293 comm="apparmor_parser"
Mar 31 23:21:50 jar-d systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 31 23:21:50 jar-d systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Mar 31 23:21:50 jar-d kernel: loop: module loaded
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.956:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=292 comm="apparmor_parser"
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.956:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=295 comm="apparmor_parser"
Mar 31 23:21:50 jar-d systemd[1]: Starting Load udev Rules from Credentials...
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.963:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=297 comm="apparmor_parser"
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.966:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=299 comm="apparmor_parser"
Mar 31 23:21:50 jar-d systemd[1]: Starting Coldplug All udev Devices...
Mar 31 23:21:50 jar-d systemd[1]: Mounted Huge Pages File System.
Mar 31 23:21:50 jar-d systemd[1]: Mounted POSIX Message Queue File System.
Mar 31 23:21:50 jar-d systemd[1]: Mounted Kernel Debug File System.
Mar 31 23:21:50 jar-d systemd[1]: Mounted Kernel Trace File System.
Mar 31 23:21:50 jar-d systemd[1]: Finished Create List of Static Device Nodes.
Mar 31 23:21:50 jar-d kernel: EXT4-fs (sda1): re-mounted 95a87c40-ba34-439f-9662-962ae4a653c0 r/w. Quota mode: none.
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.979:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=302 comm="apparmor_parser"
Mar 31 23:21:50 jar-d systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Mar 31 23:21:50 jar-d systemd[1]: modprobe@configfs.service: Deactivated successfully.
Mar 31 23:21:50 jar-d systemd[1]: Finished Load Kernel Module configfs.
Mar 31 23:21:50 jar-d systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Mar 31 23:21:50 jar-d systemd[1]: Finished Load Kernel Module dm_mod.
Mar 31 23:21:50 jar-d systemd[1]: modprobe@drm.service: Deactivated successfully.
Mar 31 23:21:50 jar-d systemd[1]: Finished Load Kernel Module drm.
Mar 31 23:21:50 jar-d systemd[1]: modprobe@fuse.service: Deactivated successfully.
Mar 31 23:21:50 jar-d systemd[1]: Finished Load Kernel Module fuse.
Mar 31 23:21:50 jar-d systemd[1]: modprobe@loop.service: Deactivated successfully.
Mar 31 23:21:50 jar-d systemd[1]: Finished Load Kernel Module loop.
Mar 31 23:21:50 jar-d kernel: audit: type=1400 audit(1743430909.983:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=304 comm="apparmor_parser"
Mar 31 23:21:50 jar-d systemd[1]: Finished Load Kernel Modules.
Mar 31 23:21:50 jar-d systemd[1]: Finished Remount Root and Kernel File Systems.
Mar 31 23:21:50 jar-d systemd[1]: Activating swap /swapfile...
Mar 31 23:21:50 jar-d systemd[1]: Mounting FUSE Control File System...
Mar 31 23:21:50 jar-d systemd[1]: Mounting Kernel Configuration File System...
Mar 31 23:21:50 jar-d systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Mar 31 23:21:50 jar-d systemd[1]: Starting Load/Save OS Random Seed...
Mar 31 23:21:50 jar-d systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Mar 31 23:21:50 jar-d systemd[1]: Starting Apply Kernel Variables...
Mar 31 23:21:50 jar-d systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Mar 31 23:21:50 jar-d kernel: Adding 5242876k swap on /swapfile.  Priority:-2 extents:28 across:45539324k
Mar 31 23:21:50 jar-d systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Mar 31 23:21:50 jar-d systemd[1]: Activated swap /swapfile.
Mar 31 23:21:50 jar-d systemd[1]: Finished Load udev Rules from Credentials.
Mar 31 23:21:50 jar-d systemd[1]: Mounted FUSE Control File System.
Mar 31 23:21:50 jar-d systemd[1]: Mounted Kernel Configuration File System.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Swaps.
Mar 31 23:21:50 jar-d systemd[1]: Mounting Temporary Directory /tmp...
Mar 31 23:21:50 jar-d systemd[1]: Finished Load/Save OS Random Seed.
Mar 31 23:21:50 jar-d systemd[1]: Finished Apply Kernel Variables.
Mar 31 23:21:50 jar-d systemd[1]: Starting CLI Netfilter Manager...
Mar 31 23:21:50 jar-d systemd[1]: Mounted Temporary Directory /tmp.
Mar 31 23:21:50 jar-d systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
Mar 31 23:21:50 jar-d systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Mar 31 23:21:50 jar-d systemd[1]: Starting Create Static Device Nodes in /dev...
Mar 31 23:21:50 jar-d systemd[1]: Finished CLI Netfilter Manager.
Mar 31 23:21:50 jar-d systemd[1]: Finished Create Static Device Nodes in /dev.
Mar 31 23:21:50 jar-d systemd[1]: Reached target Preparation for Local File Systems.
Mar 31 23:21:50 jar-d systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Mar 31 23:21:50 jar-d systemd[1]: Starting Journal Service...
Mar 31 23:21:50 jar-d systemd[1]: Starting Rule-based Manager for Device Events and Files...
Mar 31 23:21:50 jar-d systemd[1]: Finished Coldplug All udev Devices.
Mar 31 23:21:50 jar-d systemd-journald[361]: Collecting audit messages is disabled.
Mar 31 23:21:50 jar-d systemd[1]: Started Rule-based Manager for Device Events and Files.
Mar 31 23:21:50 jar-d systemd-journald[361]: Journal started
Mar 31 23:21:50 jar-d systemd-journald[361]: Runtime Journal (/run/log/journal/e0068f4c5910446384c0ae3bc0665c5e) is 8M, max 243.9M, 235.9M free.
Mar 31 23:21:49 jar-d systemd-modules-load[288]: Inserted module 'crypto_user'
Mar 31 23:21:50 jar-d apparmor.systemd[275]: Restarting AppArmor
Mar 31 23:21:50 jar-d apparmor.systemd[275]: Reloading AppArmor profiles
Mar 31 23:21:50 jar-d ufw-init[344]: Skip starting firewall: ufw (not enabled)
Mar 31 23:21:50 jar-d systemd[1]: Started Journal Service.
Mar 31 23:21:50 jar-d systemd[1]: Starting Flush Journal to Persistent Storage...
Mar 31 23:21:50 jar-d systemd-journald[361]: Time spent on flushing to /var/log/journal/e0068f4c5910446384c0ae3bc0665c5e is 54.045ms for 1435 entries.
Mar 31 23:21:50 jar-d systemd-journald[361]: System Journal (/var/log/journal/e0068f4c5910446384c0ae3bc0665c5e) is 49.9M, max 4G, 3.9G free.
Mar 31 23:21:50 jar-d systemd-journald[361]: Received client request to flush runtime journal.
Mar 31 23:21:50 jar-d systemd[1]: Finished Flush Journal to Persistent Storage.
Mar 31 23:21:50 jar-d systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
Mar 31 23:21:50 jar-d systemd[1]: Reached target Local File Systems.
Mar 31 23:21:50 jar-d systemd[1]: Listening on Boot Entries Service Socket.
Mar 31 23:21:50 jar-d systemd[1]: Listening on Disk Image Download Service Socket.
Mar 31 23:21:50 jar-d systemd[1]: Listening on System Extension Image Management.
Mar 31 23:21:50 jar-d systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
Mar 31 23:21:50 jar-d systemd[1]: Update Boot Loader Random Seed was skipped because no trigger condition checks were met.
Mar 31 23:21:50 jar-d systemd[1]: Starting Create System Files and Directories...
Mar 31 23:21:51 jar-d kernel: piix4_smbus 0000:00:07.3: SMBus Host Controller not enabled!
Mar 31 23:21:51 jar-d kernel: e1000: Intel(R) PRO/1000 Network Driver
Mar 31 23:21:51 jar-d kernel: e1000: Copyright (c) 1999-2006 Intel Corporation.
Mar 31 23:21:51 jar-d systemd[1]: Finished Create System Files and Directories.
Mar 31 23:21:51 jar-d systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
Mar 31 23:21:51 jar-d systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 31 23:21:51 jar-d systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 31 23:21:51 jar-d systemd[1]: Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
Mar 31 23:21:51 jar-d systemd[1]: Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
Mar 31 23:21:51 jar-d systemd[1]: Update is Completed was skipped because no trigger condition checks were met.
Mar 31 23:21:51 jar-d systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Mar 31 23:21:51 jar-d systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Mar 31 23:21:51 jar-d kernel: input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input5
Mar 31 23:21:51 jar-d kernel: input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input4
Mar 31 23:21:51 jar-d systemd[1]: Starting Virtual Console Setup...
Mar 31 23:21:51 jar-d kernel: mousedev: PS/2 mouse device common for all mice
Mar 31 23:21:51 jar-d systemd-vconsole-setup[543]: loadkeys: Unable to open file: ko: No such file or directory
Mar 31 23:21:51 jar-d systemd-vconsole-setup[540]: /usr/bin/loadkeys failed with exit status 1.
Mar 31 23:21:51 jar-d systemd[1]: systemd-vconsole-setup.service: Main process exited, code=exited, status=1/FAILURE
Mar 31 23:21:51 jar-d systemd[1]: systemd-vconsole-setup.service: Failed with result 'exit-code'.
Mar 31 23:21:51 jar-d systemd[1]: Failed to start Virtual Console Setup.
Mar 31 23:21:51 jar-d kernel: RAPL PMU: API unit is 2^-32 Joules, 0 fixed counters, 10737418240 ms ovfl timer
Mar 31 23:21:51 jar-d kernel: cryptd: max_cpu_qlen set to 1000
Mar 31 23:21:51 jar-d kernel: AES CTR mode by8 optimization enabled
Mar 31 23:21:51 jar-d mtp-probe[563]: checking bus 2, device 2: "/sys/devices/pci0000:00/0000:00:11.0/0000:02:00.0/usb2/2-1"
Mar 31 23:21:51 jar-d mtp-probe[563]: bus: 2, device: 2 was not an MTP device
Mar 31 23:21:51 jar-d systemd[1]: Finished Load AppArmor profiles.
Mar 31 23:21:51 jar-d systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
Mar 31 23:21:51 jar-d kernel: intel_rapl_msr: PL4 support detected.
Mar 31 23:21:51 jar-d systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 607 (snapd-apparmor)
Mar 31 23:21:51 jar-d systemd[1]: Mounting Arbitrary Executable File Formats File System...
Mar 31 23:21:51 jar-d systemd[1]: Mounted Arbitrary Executable File Formats File System.
Mar 31 23:21:51 jar-d snapd-apparmor[607]: main.go:143: No profiles to load
Mar 31 23:21:51 jar-d systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
Mar 31 23:21:51 jar-d systemd[1]: Reached target System Initialization.
Mar 31 23:21:51 jar-d systemd[1]: Started CUPS Scheduler.
Mar 31 23:21:51 jar-d systemd[1]: Started Refresh existing PGP keys of archlinux-keyring regularly.
Mar 31 23:21:51 jar-d systemd[1]: Started Discard unused filesystem blocks once a week.
Mar 31 23:21:51 jar-d systemd[1]: Started Daily rotation of log files.
Mar 31 23:21:51 jar-d systemd[1]: Started Daily man-db regeneration.
Mar 31 23:21:51 jar-d systemd[1]: Started Monthly clean packages cache.
Mar 31 23:21:51 jar-d systemd[1]: Started pkgfile database update timer.
Mar 31 23:21:51 jar-d systemd[1]: Started Update the plocate database daily.
Mar 31 23:21:51 jar-d systemd[1]: Started Daily verification of password and group files.
Mar 31 23:21:51 jar-d systemd[1]: Started Daily Cleanup of Temporary Directories.
Mar 31 23:21:51 jar-d systemd[1]: Reached target Path Units.
Mar 31 23:21:51 jar-d systemd[1]: Reached target Timer Units.
Mar 31 23:21:51 jar-d systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Mar 31 23:21:51 jar-d systemd[1]: Listening on CUPS Scheduler.
Mar 31 23:21:51 jar-d systemd[1]: Listening on D-Bus System Message Bus Socket.
Mar 31 23:21:51 jar-d systemd[1]: Listening on GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Mar 31 23:21:51 jar-d systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Mar 31 23:21:51 jar-d systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Mar 31 23:21:51 jar-d systemd[1]: Listening on GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Mar 31 23:21:51 jar-d systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Mar 31 23:21:51 jar-d systemd[1]: Listening on GnuPG public key management service for /etc/pacman.d/gnupg.
Mar 31 23:21:51 jar-d systemd[1]: Starting Socket activation for snappy daemon...
Mar 31 23:21:51 jar-d systemd[1]: Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Mar 31 23:21:51 jar-d systemd[1]: Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_VSOCK).
Mar 31 23:21:51 jar-d systemd[1]: Reached target SSH Access Available.
Mar 31 23:21:51 jar-d systemd[1]: Listening on Hostname Service Socket.
Mar 31 23:21:51 jar-d systemd[1]: Starting D-Bus System Message Bus...
Mar 31 23:21:51 jar-d systemd[1]: TPM PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Mar 31 23:21:51 jar-d systemd[1]: Listening on Socket activation for snappy daemon.
Mar 31 23:21:51 jar-d systemd[1]: Reached target Socket Units.
Mar 31 23:21:51 jar-d dbus-broker-launch[625]: Looking up NSS user entry for 'pulse'...
Mar 31 23:21:51 jar-d dbus-broker-launch[625]: NSS returned no entry for 'pulse'
Mar 31 23:21:51 jar-d dbus-broker-launch[625]: Invalid user-name in /usr/share/dbus-1/system.d/pulseaudio-system.conf +27: user="pulse"
Mar 31 23:21:51 jar-d systemd[1]: Started D-Bus System Message Bus.
Mar 31 23:21:51 jar-d systemd[1]: Reached target Basic System.
Mar 31 23:21:51 jar-d systemd[1]: Starting Network Manager...
Mar 31 23:21:51 jar-d systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Mar 31 23:21:51 jar-d dbus-broker-launch[625]: Ready
Mar 31 23:21:51 jar-d systemd[1]: Starting Authorization Manager...
Mar 31 23:21:51 jar-d systemd[1]: Starting Snap Daemon...
Mar 31 23:21:51 jar-d systemd[1]: SSH Key Generation was skipped because no trigger condition checks were met.
Mar 31 23:21:51 jar-d systemd[1]: Starting User Login Management...
Mar 31 23:21:51 jar-d systemd[1]: TPM PCR Barrier (User) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Mar 31 23:21:51 jar-d systemd[1]: Started VMWare Tools daemon.
Mar 31 23:21:51 jar-d (re-tools)[632]: vmwaretools.service: Unable to locate executable '/etc/init.d/vmware-tools': No such file or directory
Mar 31 23:21:51 jar-d (re-tools)[632]: vmwaretools.service: Failed at step EXEC spawning /etc/init.d/vmware-tools: No such file or directory
Mar 31 23:21:51 jar-d avahi-daemon[628]: Found user 'avahi' (UID 971) and group 'avahi' (GID 971).
Mar 31 23:21:51 jar-d systemd[1]: vmwaretools.service: Main process exited, code=exited, status=203/EXEC
Mar 31 23:21:51 jar-d systemd[1]: vmwaretools.service: Failed with result 'exit-code'.
Mar 31 23:21:51 jar-d avahi-daemon[628]: Successfully dropped root privileges.
Mar 31 23:21:51 jar-d avahi-daemon[628]: avahi-daemon 0.8 starting up.
Mar 31 23:21:51 jar-d avahi-daemon[628]: Successfully called chroot().
Mar 31 23:21:51 jar-d avahi-daemon[628]: Successfully dropped remaining capabilities.
Mar 31 23:21:51 jar-d systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Mar 31 23:21:51 jar-d avahi-daemon[628]: No service file found in /etc/avahi/services.
Mar 31 23:21:51 jar-d avahi-daemon[628]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Mar 31 23:21:51 jar-d avahi-daemon[628]: New relevant interface lo.IPv6 for mDNS.
Mar 31 23:21:51 jar-d avahi-daemon[628]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Mar 31 23:21:51 jar-d avahi-daemon[628]: New relevant interface lo.IPv4 for mDNS.
Mar 31 23:21:51 jar-d avahi-daemon[628]: Network interface enumeration completed.
Mar 31 23:21:51 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:21:51 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.7949] NetworkManager (version 1.52.0-1) is starting... (boot:bac8eb46-8795-4661-924e-965caecc9309)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.7950] Read config: /etc/NetworkManager/NetworkManager.conf, /usr/lib/NetworkManager/conf.d/20-connectivity.conf
Mar 31 23:21:51 jar-d kernel: e1000 0000:02:01.0 eth0: (PCI:66MHz:32-bit) 00:0c:29:27:26:f0
Mar 31 23:21:51 jar-d kernel: e1000 0000:02:01.0 eth0: Intel(R) PRO/1000 Network Connection
Mar 31 23:21:51 jar-d kernel: e1000 0000:02:01.0 ens33: renamed from eth0
Mar 31 23:21:51 jar-d systemd-logind[631]: New seat seat0.
Mar 31 23:21:51 jar-d systemd-logind[631]: Watching system buttons on /dev/input/event0 (Power Button)
Mar 31 23:21:51 jar-d systemd-logind[631]: Watching system buttons on /dev/input/event1 (AT Translated Set 2 keyboard)
Mar 31 23:21:51 jar-d systemd[1]: Started User Login Management.
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.8332] manager[0x5b67aa040fc0]: monitoring kernel firmware directory '/lib/firmware'.
Mar 31 23:21:51 jar-d polkitd[629]: Started polkitd version 126
Mar 31 23:21:51 jar-d systemd[1]: Starting Hostname Service...
Mar 31 23:21:51 jar-d polkitd[629]: Loading rules from directory /etc/polkit-1/rules.d
Mar 31 23:21:51 jar-d polkitd[629]: Loading rules from directory /run/polkit-1/rules.d
Mar 31 23:21:51 jar-d polkitd[629]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Mar 31 23:21:51 jar-d polkitd[629]: Loading rules from directory /usr/local/share/polkit-1/rules.d
Mar 31 23:21:51 jar-d polkitd[629]: Error opening rules directory: Error opening directory “/usr/local/share/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Mar 31 23:21:51 jar-d polkitd[629]: Loading rules from directory /usr/share/polkit-1/rules.d
Mar 31 23:21:51 jar-d polkitd[629]: Finished loading, compiling and executing 6 rules
Mar 31 23:21:51 jar-d systemd[1]: Started Authorization Manager.
Mar 31 23:21:51 jar-d polkitd[629]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Mar 31 23:21:51 jar-d systemd[1]: Starting Modem Manager...
Mar 31 23:21:51 jar-d systemd[1]: Started Hostname Service.
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9066] hostname: hostname: using hostnamed
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9067] hostname: static hostname changed from (none) to "jar-d"
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9069] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9183] manager[0x5b67aa040fc0]: rfkill: Wi-Fi hardware radio set enabled
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9183] manager[0x5b67aa040fc0]: rfkill: WWAN hardware radio set enabled
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9438] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.52.0-1/libnm-device-plugin-wwan.so)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9454] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.52.0-1/libnm-device-plugin-adsl.so)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9464] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.52.0-1/libnm-device-plugin-wifi.so)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9471] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.52.0-1/libnm-device-plugin-ovs.so)
Mar 31 23:21:51 jar-d ModemManager[663]: <msg> ModemManager (version 1.22.0-1) starting in system bus...
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9807] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.52.0-1/libnm-device-plugin-team.so)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9815] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.52.0-1/libnm-device-plugin-bluetooth.so)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9818] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9820] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9821] manager: Networking is enabled by state file
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9829] settings: Loaded settings plugin: keyfile (internal)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9844] dhcp: init: Using DHCP client 'internal'
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9852] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
Mar 31 23:21:51 jar-d systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9893] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', managed-type: 'external')
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9905] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', managed-type: 'external')
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9912] device (lo): Activation: starting connection 'lo' (8e1b30c5-c16d-46ee-8fa3-6d14a4cc4723)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9924] manager: (ens33): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9960] settings: (ens33): created default wired connection 'Wired connection 1'
Mar 31 23:21:51 jar-d NetworkManager[627]: <info>  [1743430911.9960] device (ens33): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Mar 31 23:21:52 jar-d snapd[630]: overlord.go:284: Acquiring state lock file
Mar 31 23:21:52 jar-d snapd[630]: overlord.go:289: Acquired state lock file
Mar 31 23:21:52 jar-d kernel: NET: Registered PF_QIPCRTR protocol family
Mar 31 23:21:52 jar-d systemd[1]: Started Modem Manager.
Mar 31 23:21:52 jar-d kernel: e1000: ens33 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Mar 31 23:21:52 jar-d snapd[630]: daemon.go:250: started snapd/2.68-1 (series 16; classic; devmode) manjaro/ (amd64) linux/6.12.20-2-MANJARO.
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0167] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0174] ovsdb: disconnected from ovsdb
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0175] device (lo): state change: disconnected -> prepare (reason 'none', managed-type: 'external')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0176] device (lo): state change: prepare -> config (reason 'none', managed-type: 'external')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0178] device (lo): state change: config -> ip-config (reason 'none', managed-type: 'external')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0179] device (ens33): carrier: link connected
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0183] device (lo): state change: ip-config -> ip-check (reason 'none', managed-type: 'external')
Mar 31 23:21:52 jar-d systemd[1]: Started Network Manager.
Mar 31 23:21:52 jar-d systemd[1]: Reached target Network.
Mar 31 23:21:52 jar-d systemd[1]: Starting CUPS Scheduler...
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0244] device (ens33): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0270] policy: auto-activating connection 'Wired connection 1' (8a3985b9-fd8f-38eb-9230-3653eae51547)
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0272] device (ens33): Activation: starting connection 'Wired connection 1' (8a3985b9-fd8f-38eb-9230-3653eae51547)
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0272] device (ens33): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0273] manager: NetworkManager state is now CONNECTING
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0274] device (ens33): state change: prepare -> config (reason 'none', managed-type: 'full')
Mar 31 23:21:52 jar-d systemd[1]: Starting OpenSSH Daemon...
Mar 31 23:21:52 jar-d kernel: loop0: detected capacity change from 0 to 8
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0390] device (ens33): state change: config -> ip-config (reason 'none', managed-type: 'full')
Mar 31 23:21:52 jar-d systemd[1]: Starting Permit User Sessions...
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0486] dhcp4 (ens33): activation: beginning transaction (timeout in 45 seconds)
Mar 31 23:21:52 jar-d avahi-daemon[628]: Joining mDNS multicast group on interface ens33.IPv6 with address fe80::5ef:8c6e:3e18:aa66.
Mar 31 23:21:52 jar-d avahi-daemon[628]: New relevant interface ens33.IPv6 for mDNS.
Mar 31 23:21:52 jar-d avahi-daemon[628]: Registering new address record for fe80::5ef:8c6e:3e18:aa66 on ens33.*.
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0539] modem-manager: ModemManager available
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0542] dhcp4 (ens33): state changed new lease, address=10.200.17.51, acd pending
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0662] device (lo): state change: ip-check -> secondaries (reason 'none', managed-type: 'external')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0663] device (lo): state change: secondaries -> activated (reason 'none', managed-type: 'external')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.0666] device (lo): Activation: successful, device activated.
Mar 31 23:21:52 jar-d systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 31 23:21:52 jar-d kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mar 31 23:21:52 jar-d systemd[1]: tmp-syscheck\x2dmountpoint\x2d567964581.mount: Deactivated successfully.
Mar 31 23:21:52 jar-d snapd[630]: daemon.go:353: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Mar 31 23:21:52 jar-d snapd[630]: backends.go:91: AppArmor status: apparmor is enabled but some kernel features are missing: dbus, network
Mar 31 23:21:52 jar-d systemd[1]: Finished Permit User Sessions.
Mar 31 23:21:52 jar-d systemd[1]: Started Command Scheduler.
Mar 31 23:21:52 jar-d sshd[703]: Server listening on 0.0.0.0 port 22.
Mar 31 23:21:52 jar-d sshd[703]: Server listening on :: port 22.
Mar 31 23:21:52 jar-d systemd[1]: Starting Light Display Manager...
Mar 31 23:21:52 jar-d systemd[1]: Started OpenSSH Daemon.
Mar 31 23:21:52 jar-d crond[722]: (CRON) STARTUP (1.7.2)
Mar 31 23:21:52 jar-d systemd[1]: Started CUPS Scheduler.
Mar 31 23:21:52 jar-d crond[722]: (CRON) INFO (Syslog will be used instead of sendmail.)
Mar 31 23:21:52 jar-d crond[722]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 45% if used.)
Mar 31 23:21:52 jar-d crond[722]: (CRON) INFO (running with inotify support)
Mar 31 23:21:52 jar-d systemd[1]: Started Light Display Manager.
Mar 31 23:21:52 jar-d systemd[1]: Started Open Virtual Machine Tools (VMware Tools).
Mar 31 23:21:52 jar-d systemd[1]: Reached target User and Group Name Lookups.
Mar 31 23:21:52 jar-d systemd[1]: Starting Accounts Service...
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2093] dhcp4 (ens33): state changed new lease, address=10.200.17.51
Mar 31 23:21:52 jar-d avahi-daemon[628]: Joining mDNS multicast group on interface ens33.IPv4 with address 10.200.17.51.
Mar 31 23:21:52 jar-d avahi-daemon[628]: New relevant interface ens33.IPv4 for mDNS.
Mar 31 23:21:52 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2110] policy: set 'Wired connection 1' (ens33) as default for IPv4 routing and DNS
Mar 31 23:21:52 jar-d systemd[1]: Starting Save/Restore Sound Card State...
Mar 31 23:21:52 jar-d systemd[1]: Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
Mar 31 23:21:52 jar-d dbus-broker-launch[625]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2252] device (ens33): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2345] device (ens33): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2346] device (ens33): state change: secondaries -> activated (reason 'none', managed-type: 'full')
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2348] manager: NetworkManager state is now CONNECTED_SITE
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2349] device (ens33): Activation: successful, device activated.
Mar 31 23:21:52 jar-d NetworkManager[627]: <info>  [1743430912.2420] manager: startup complete
Mar 31 23:21:52 jar-d alsactl[750]: alsa-lib main.c:1554:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
Mar 31 23:21:52 jar-d systemd[1]: Finished Save/Restore Sound Card State.
Mar 31 23:21:52 jar-d systemd[1]: Reached target Sound Card.
Mar 31 23:21:52 jar-d accounts-daemon[745]: started daemon version 23.13.0
Mar 31 23:21:52 jar-d systemd[1]: Started Accounts Service.
Mar 31 23:21:52 jar-d systemd[1]: Started Snap Daemon.
Mar 31 23:21:52 jar-d systemd[1]: Reached target Multi-User System.
Mar 31 23:21:52 jar-d systemd[1]: Reached target Graphical Interface.
Mar 31 23:21:52 jar-d systemd[1]: Starting TLP system startup/shutdown...
Mar 31 23:21:52 jar-d systemd[1]: Starting Time & Date Service...
Mar 31 23:22:09 jar-d systemd[1]: Started Time & Date Service.
Mar 31 23:22:10 jar-d tlp[799]: Applying power save settings...done.
Mar 31 23:22:10 jar-d tlp[799]: Setting battery charge thresholds...done.
Mar 31 23:22:10 jar-d systemd[1]: Finished TLP system startup/shutdown.
Mar 31 23:22:10 jar-d systemd[1]: Startup finished in 1.979s (kernel) + 3.313s (userspace) = 5.293s.
Mar 31 23:22:10 jar-d NetworkManager[627]: <info>  [1743430930.1765] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 31 23:22:10 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d.local. Local service cookie is 3702138598.
Mar 31 23:22:11 jar-d NetworkManager[627]: <info>  [1743430931.0647] dhcp6 (ens33): activation: beginning transaction (timeout in 45 seconds)
Mar 31 23:22:11 jar-d avahi-daemon[628]: Leaving mDNS multicast group on interface ens33.IPv6 with address fe80::5ef:8c6e:3e18:aa66.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Joining mDNS multicast group on interface ens33.IPv6 with address fd93:8f99:81c6:0:38e8:f99e:777:62a1.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Withdrawing address record for fe80::5ef:8c6e:3e18:aa66 on ens33.
Mar 31 23:22:11 jar-d NetworkManager[627]: <info>  [1743430931.0781] dhcp6 (ens33): state changed new lease, address=fd93:8f99:81c6::76a
Mar 31 23:22:11 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-2
Mar 31 23:22:11 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:22:11 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:22:11 jar-d NetworkManager[627]: <error> [1743430931.7587] dhcp6 (ens33): DAD failed for address: fd93:8f99:81c6::76a/128 lft forever pref forever lifetime 3-3[4294967295,4294967295] dev 2 src dhcp
Mar 31 23:22:11 jar-d kernel: IPv6: ens33: IPv6 duplicate address fd93:8f99:81c6::76a used by 00:0c:29:ee:14:57 detected!
Mar 31 23:22:12 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-2.local. Local service cookie is 3702138598.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6::76a on ens33.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-3
Mar 31 23:22:12 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:22:12 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:22:12 jar-d lightdm[1130]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Mar 31 23:22:12 jar-d systemd[1]: Created slice User Slice of UID 966.
Mar 31 23:22:12 jar-d systemd[1]: Starting User Runtime Directory /run/user/966...
Mar 31 23:22:12 jar-d systemd-logind[631]: New session c1 of user lightdm.
Mar 31 23:22:12 jar-d systemd[1]: Finished User Runtime Directory /run/user/966.
Mar 31 23:22:12 jar-d systemd[1]: Starting User Manager for UID 966...
Mar 31 23:22:12 jar-d dbus-broker-launch[625]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Mar 31 23:22:12 jar-d (systemd)[1137]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Mar 31 23:22:12 jar-d (systemd)[1137]: pam_unix(systemd-user:session): session opened for user lightdm(uid=966) by lightdm(uid=0)
Mar 31 23:22:12 jar-d systemd-logind[631]: New session 1 of user lightdm.
Mar 31 23:22:12 jar-d systemd[1137]: Queued start job for default target Main User Target.
Mar 31 23:22:12 jar-d systemd[1137]: Created slice User Application Slice.
Mar 31 23:22:12 jar-d systemd[1137]: Reached target Paths.
Mar 31 23:22:12 jar-d systemd[1137]: Reached target Timers.
Mar 31 23:22:12 jar-d systemd[1137]: Starting D-Bus User Message Bus Socket...
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GnuPG network certificate management daemon.
Mar 31 23:22:12 jar-d systemd[1137]: Starting GCR ssh-agent wrapper...
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GNOME Keyring daemon.
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GnuPG cryptographic agent and passphrase cache.
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GnuPG public key management service.
Mar 31 23:22:12 jar-d systemd[1137]: Listening on p11-kit server.
Mar 31 23:22:12 jar-d systemd[1137]: Listening on PipeWire Multimedia System Sockets.
Mar 31 23:22:12 jar-d systemd[1137]: Listening on Sound System.
Mar 31 23:22:12 jar-d systemd[1137]: Listening on D-Bus User Message Bus Socket.
Mar 31 23:22:12 jar-d systemd[1137]: Listening on GCR ssh-agent wrapper.
Mar 31 23:22:12 jar-d systemd[1137]: Reached target Sockets.
Mar 31 23:22:12 jar-d systemd[1137]: Reached target Basic System.
Mar 31 23:22:12 jar-d systemd[1]: Started User Manager for UID 966.
Mar 31 23:22:12 jar-d systemd[1]: Started Session c1 of User lightdm.
Mar 31 23:22:12 jar-d systemd[1137]: Starting Update XDG user dir configuration...
Mar 31 23:22:12 jar-d systemd[1137]: Finished Update XDG user dir configuration.
Mar 31 23:22:12 jar-d systemd[1137]: Reached target Main User Target.
Mar 31 23:22:12 jar-d systemd[1137]: Startup finished in 135ms.
Mar 31 23:22:13 jar-d systemd[1137]: Created slice User Core Session Slice.
Mar 31 23:22:13 jar-d systemd[1137]: Starting D-Bus User Message Bus...
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
Mar 31 23:22:13 jar-d systemd[1137]: Started D-Bus User Message Bus.
Mar 31 23:22:13 jar-d dbus-broker-launch[1153]: Ready
Mar 31 23:22:13 jar-d systemd[1137]: Starting Accessibility services bus...
Mar 31 23:22:13 jar-d systemd[1137]: Started Accessibility services bus.
Mar 31 23:22:13 jar-d dbus-broker-launch[1161]: Ready
Mar 31 23:22:13 jar-d systemd[1137]: Starting Virtual filesystem service...
Mar 31 23:22:13 jar-d systemd[1137]: Started Virtual filesystem service.
Mar 31 23:22:13 jar-d systemd[1137]: Created slice Slice /app/dbus-:1.4-org.a11y.atspi.Registry.
Mar 31 23:22:13 jar-d systemd[1137]: Started dbus-:1.4-org.a11y.atspi.Registry@0.service.
Mar 31 23:22:13 jar-d ModemManager[663]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:11.0/0000:02:01.0': not supported by any plugin
Mar 31 23:22:13 jar-d at-spi2-registryd[1187]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Mar 31 23:22:14 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-3.local. Local service cookie is 3702138598.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-4
Mar 31 23:22:14 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:22:14 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:22:14 jar-d snapd[630]: daemon.go:548: gracefully waiting for running hooks
Mar 31 23:22:14 jar-d snapd[630]: daemon.go:550: done waiting for running hooks
Mar 31 23:22:15 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:22:15 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:22:15 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:22:15 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:22:15 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-4.local. Local service cookie is 3702138598.
Mar 31 23:22:15 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:22:15 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:22:15 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6::76a on ens33.
[Many similar lines deleted.]
Mar 31 23:22:17 jar-d snapd[630]: overlord.go:528: Released state lock file
Mar 31 23:22:17 jar-d snapd[630]: daemon stop requested to wait for socket activation
Mar 31 23:22:17 jar-d systemd[1]: snapd.service: Deactivated successfully.
Mar 31 23:22:18 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-6.local. Local service cookie is 3702138598.
Mar 31 23:22:18 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:22:18 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:22:18 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:22:18 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:22:24 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-12
Mar 31 23:22:24 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:22:24 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:22:24 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:22:24 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:22:24 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:22:39 jar-d systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Mar 31 23:22:39 jar-d systemd[1]: systemd-timedated.service: Deactivated successfully.
Mar 31 23:22:44 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-12.local. Local service cookie is 3702138598.
Mar 31 23:22:44 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:22:44 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:22:44 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:22:44 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:33:44 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-46
Mar 31 23:33:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:33:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:33:44 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:33:44 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:33:44 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:33:59 jar-d sshd-session[1211]: [redacted]
Mar 31 23:33:59 jar-d sshd-session[1211]: pam_unix(sshd:session): session opened for user XXXXX(uid=1000) by XXXXX(uid=0)
Mar 31 23:33:59 jar-d systemd-logind[631]: New session 2 of user XXXXX.
Mar 31 23:33:59 jar-d systemd[1]: Created slice User Slice of UID 1000.
Mar 31 23:33:59 jar-d systemd[1]: Starting User Runtime Directory /run/user/1000...
Mar 31 23:33:59 jar-d systemd[1]: Finished User Runtime Directory /run/user/1000.
Mar 31 23:33:59 jar-d systemd[1]: Starting User Manager for UID 1000...
Mar 31 23:33:59 jar-d (systemd)[1216]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[XXXXX] ruser=[<unknown>] rhost=[<unknown>]
Mar 31 23:33:59 jar-d (systemd)[1216]: pam_unix(systemd-user:session): session opened for user XXXXX(uid=1000) by XXXXX(uid=0)
Mar 31 23:33:59 jar-d systemd-logind[631]: New session 3 of user XXXXX.
Mar 31 23:33:59 jar-d systemd-xdg-autostart-generator[1223]: Configuration file /home/XXXXX/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Mar 31 23:33:59 jar-d systemd-xdg-autostart-generator[1223]: Configuration file /home/XXXXX/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Mar 31 23:33:59 jar-d systemd[1216]: Queued start job for default target Main User Target.
Mar 31 23:33:59 jar-d systemd[1216]: Created slice User Application Slice.
Mar 31 23:33:59 jar-d systemd[1216]: Reached target Paths.
Mar 31 23:33:59 jar-d systemd[1216]: Reached target Timers.
Mar 31 23:33:59 jar-d systemd[1216]: Starting D-Bus User Message Bus Socket...
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GnuPG network certificate management daemon.
Mar 31 23:33:59 jar-d systemd[1216]: Starting GCR ssh-agent wrapper...
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GNOME Keyring daemon.
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GnuPG cryptographic agent and passphrase cache.
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GnuPG public key management service.
Mar 31 23:33:59 jar-d systemd[1216]: Listening on p11-kit server.
Mar 31 23:33:59 jar-d systemd[1216]: Listening on PipeWire Multimedia System Sockets.
Mar 31 23:33:59 jar-d systemd[1216]: Listening on Sound System.
Mar 31 23:33:59 jar-d systemd[1216]: Listening on D-Bus User Message Bus Socket.
Mar 31 23:33:59 jar-d systemd[1216]: Listening on GCR ssh-agent wrapper.
Mar 31 23:33:59 jar-d systemd[1216]: Reached target Sockets.
Mar 31 23:33:59 jar-d systemd[1216]: Reached target Basic System.
Mar 31 23:33:59 jar-d systemd[1]: Started User Manager for UID 1000.
Mar 31 23:33:59 jar-d systemd[1216]: Starting Update XDG user dir configuration...
Mar 31 23:33:59 jar-d systemd[1]: Started Session 2 of User XXXXX.
Mar 31 23:33:59 jar-d systemd[1216]: Finished Update XDG user dir configuration.
Mar 31 23:33:59 jar-d systemd[1216]: Reached target Main User Target.
Mar 31 23:33:59 jar-d systemd[1216]: Startup finished in 104ms.
Mar 31 23:33:59 jar-d systemd[1216]: Created slice User Core Session Slice.
Mar 31 23:33:59 jar-d systemd[1216]: Starting D-Bus User Message Bus...
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Mar 31 23:33:59 jar-d systemd[1216]: Started D-Bus User Message Bus.
Mar 31 23:33:59 jar-d dbus-broker-launch[1252]: Ready
Mar 31 23:33:59 jar-d systemd[1216]: Starting Virtual filesystem service...
Mar 31 23:33:59 jar-d systemd[1216]: Started Virtual filesystem service.
Mar 31 23:33:59 jar-d systemd[1216]: Created slice Slice /app/dbus-:1.2-org.freedesktop.portal.IBus.
Mar 31 23:33:59 jar-d systemd[1216]: Started dbus-:1.2-org.freedesktop.portal.IBus@0.service.
Mar 31 23:33:59 jar-d kernel: show_signal: 157 callbacks suppressed
Mar 31 23:33:59 jar-d kernel: traps: ibus-ui-gtk3[1272] trap int3 ip:72109fb68248 sp:7ffec9067230 error:0 in libglib-2.0.so.0.8400.0[63248,72109fb23000+a7000]
Mar 31 23:33:59 jar-d systemd-coredump[1286]: Process 1272 (ibus-ui-gtk3) of user 1000 terminated abnormally with signal 5/TRAP, processing...
Mar 31 23:33:59 jar-d systemd[1]: Created slice Slice /system/systemd-coredump.
Mar 31 23:33:59 jar-d systemd[1]: Started Process Core Dump (PID 1286/UID 0).
Mar 31 23:33:59 jar-d systemd-coredump[1287]: [🡕] Process 1272 (ibus-ui-gtk3) of user 1000 dumped core.
                                              Stack trace of thread 1272:
                                              #0  0x000072109fb68248 g_log_structured_array (libglib-2.0.so.0 + 0x63248)
                                              #1  0x000072109fb68547 g_log_default_handler (libglib-2.0.so.0 + 0x63547)
                                              #2  0x000072109fb687cc g_logv (libglib-2.0.so.0 + 0x637cc)
                                              #3  0x000072109fb68b54 g_log (libglib-2.0.so.0 + 0x63b54)
                                              #4  0x00005d4ffd5cffbc n/a (/usr/lib/ibus/ibus-ui-gtk3 + 0xffbc)
                                              #5  0x00005d4ffd5d0596 n/a (/usr/lib/ibus/ibus-ui-gtk3 + 0x10596)
                                              #6  0x00005d4ffd5d385a n/a (/usr/lib/ibus/ibus-ui-gtk3 + 0x1385a)
                                              #7  0x000072109f9d8479 n/a (libgio-2.0.so.0 + 0x102479)
                                              #8  0x000072109fb63104 n/a (libglib-2.0.so.0 + 0x5e104)
                                              #9  0x000072109fbc6d57 n/a (libglib-2.0.so.0 + 0xc1d57)
                                              #10 0x000072109fb63de7 g_main_loop_run (libglib-2.0.so.0 + 0x5ede7)
                                              #11 0x00007210a0224dff gtk_main (libgtk-3.so.0 + 0x424dff)
                                              #12 0x00005d4ffd5d0c76 n/a (/usr/lib/ibus/ibus-ui-gtk3 + 0x10c76)
                                              #13 0x00005d4ffd5cc0c4 n/a (/usr/lib/ibus/ibus-ui-gtk3 + 0xc0c4)
                                              #14 0x000072109f70b488 n/a (libc.so.6 + 0x27488)
                                              #15 0x000072109f70b54c __libc_start_main (libc.so.6 + 0x2754c)
                                              #16 0x00005d4ffd5cc0f5 n/a (/usr/lib/ibus/ibus-ui-gtk3 + 0xc0f5)
                                              Stack trace of thread 1284:
                                              #0  0x000072109f781be2 n/a (libc.so.6 + 0x9dbe2)
                                              #1  0x000072109f775e33 n/a (libc.so.6 + 0x91e33)
                                              #2  0x000072109f775e74 n/a (libc.so.6 + 0x91e74)
                                              #3  0x000072109f7f0a06 ppoll (libc.so.6 + 0x10ca06)
                                              #4  0x000072109fbc6e27 n/a (libglib-2.0.so.0 + 0xc1e27)
                                              #5  0x000072109fb62535 g_main_context_iteration (libglib-2.0.so.0 + 0x5d535)
                                              #6  0x000072109fb62592 n/a (libglib-2.0.so.0 + 0x5d592)
                                              #7  0x000072109fb9aa3e n/a (libglib-2.0.so.0 + 0x95a3e)
                                              #8  0x000072109f77970a n/a (libc.so.6 + 0x9570a)
                                              #9  0x000072109f7fdaac n/a (libc.so.6 + 0x119aac)
Mar 31 23:33:59 jar-d systemd[1]: systemd-coredump@0-1286-0.service: Deactivated successfully.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-46.local. Local service cookie is 3702138598.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-47
Mar 31 23:34:04 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:34:04 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:34:05 jar-d sudo[1299]:     XXXXX : TTY=pts/0 ; PWD=/home/XXXXX ; USER=root ; COMMAND=/usr/bin/systemctl start vncserver@:1
Mar 31 23:34:05 jar-d sudo[1299]: pam_unix(sudo:session): session opened for user root(uid=0) by XXXXX(uid=1000)
Mar 31 23:34:05 jar-d systemd[1]: Created slice Slice /system/vncserver.
Mar 31 23:34:05 jar-d systemd[1]: Starting Remote desktop service (VNC)...
Mar 31 23:34:05 jar-d systemd-logind[631]: New session 4 of user XXXXX.
Mar 31 23:34:05 jar-d systemd[1]: Started Session 4 of User XXXXX.
Mar 31 23:34:05 jar-d vncsession[1313]: pam_unix(tigervnc:session): session opened for user XXXXX(uid=1000) by XXXXX(uid=0)
Mar 31 23:34:05 jar-d systemd[1]: Started Remote desktop service (VNC).
Mar 31 23:34:05 jar-d sudo[1299]: pam_unix(sudo:session): session closed for user root
Mar 31 23:34:05 jar-d vncsession[1314]: ~/.vnc is deprecated, please consult 'man vncsession' for paths to migrate to.
Mar 31 23:34:06 jar-d systemd[1216]: Starting Accessibility services bus...
Mar 31 23:34:06 jar-d systemd[1216]: Started Accessibility services bus.
Mar 31 23:34:06 jar-d dbus-broker-launch[1356]: Ready
Mar 31 23:34:06 jar-d systemd[1216]: Starting Xfce configuration service...
Mar 31 23:34:06 jar-d systemd[1216]: Started Xfce configuration service.
Mar 31 23:34:06 jar-d systemd[1216]: Created slice Slice /app/dbus-:1.14-org.a11y.atspi.Registry.
Mar 31 23:34:06 jar-d systemd[1216]: Started dbus-:1.14-org.a11y.atspi.Registry@0.service.
Mar 31 23:34:06 jar-d at-spi2-registryd[1364]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Mar 31 23:34:06 jar-d systemd[1216]: Started GnuPG cryptographic agent and passphrase cache.
Mar 31 23:34:06 jar-d gpg-agent[1374]: gpg-agent (GnuPG) 2.4.7 starting in supervised mode.
Mar 31 23:34:06 jar-d gpg-agent[1374]: using fd 3 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
Mar 31 23:34:06 jar-d gpg-agent[1374]: using fd 4 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
Mar 31 23:34:06 jar-d gpg-agent[1374]: using fd 5 for std socket (/run/user/1000/gnupg/S.gpg-agent)
Mar 31 23:34:06 jar-d gpg-agent[1374]: using fd 6 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
Mar 31 23:34:06 jar-d gpg-agent[1374]: listening on: std=5 extra=3 browser=4 ssh=6
Mar 31 23:34:06 jar-d gpg-agent[1378]: gpg-agent (GnuPG) 2.4.7 starting in supervised mode.
Mar 31 23:34:06 jar-d gpg-agent[1378]: using fd 3 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
Mar 31 23:34:06 jar-d gpg-agent[1378]: using fd 4 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
Mar 31 23:34:06 jar-d gpg-agent[1378]: using fd 5 for std socket (/run/user/1000/gnupg/S.gpg-agent)
Mar 31 23:34:06 jar-d gpg-agent[1378]: using fd 6 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
Mar 31 23:34:06 jar-d gpg-agent[1378]: listening on: std=5 extra=3 browser=4 ssh=6
Mar 31 23:34:06 jar-d systemd[1216]: Starting Sound Service...
Mar 31 23:34:06 jar-d systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Mar 31 23:34:06 jar-d systemd[1]: Started RealtimeKit Scheduling Policy Service.
Mar 31 23:34:06 jar-d rtkit-daemon[1396]: Successfully called chroot.
Mar 31 23:34:06 jar-d rtkit-daemon[1396]: Successfully dropped privileges.
Mar 31 23:34:06 jar-d rtkit-daemon[1396]: Successfully limited resources.
Mar 31 23:34:06 jar-d rtkit-daemon[1396]: Canary thread running.
Mar 31 23:34:06 jar-d rtkit-daemon[1396]: Running.
Mar 31 23:34:06 jar-d rtkit-daemon[1396]: Watchdog thread running.
Mar 31 23:34:06 jar-d systemd[1216]: Starting User preferences database...
Mar 31 23:34:06 jar-d systemd[1216]: Started User preferences database.
Mar 31 23:34:07 jar-d systemd[1216]: Starting XFCE notifications service...
Mar 31 23:34:07 jar-d systemd[1216]: Started XFCE notifications service.
Mar 31 23:34:07 jar-d spice-vdagent[1486]: vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0 does not exist, exiting
Mar 31 23:34:07 jar-d systemd[1216]: Starting Thumbnailing service...
Mar 31 23:34:07 jar-d systemd[1]: Starting Manage, Install and Generate Color Profiles...
Mar 31 23:34:07 jar-d colord[1542]: failed to get edid data: EDID length is too small
Mar 31 23:34:07 jar-d systemd[1]: Started Manage, Install and Generate Color Profiles.
Mar 31 23:34:07 jar-d sshd-session[1229]: Received disconnect from 10.200.17.53 port 53192:11: disconnected by user
Mar 31 23:34:07 jar-d sshd-session[1229]: Disconnected from user XXXXX 10.200.17.53 port 53192
Mar 31 23:34:07 jar-d sshd-session[1211]: pam_unix(sshd:session): session closed for user XXXXX
Mar 31 23:34:07 jar-d systemd-logind[631]: Session 2 logged out. Waiting for processes to exit.
Mar 31 23:34:08 jar-d systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Mar 31 23:34:08 jar-d tumblerd[1528]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Mar 31 23:34:08 jar-d rtkit-daemon[1396]: Supervising 0 threads of 0 processes of 1 users.
Mar 31 23:34:08 jar-d pulseaudio[1392]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.bluez': unit failed
Mar 31 23:34:08 jar-d systemd[1216]: Started Sound Service.
Mar 31 23:34:08 jar-d systemd[1216]: Starting Virtual filesystem service - disk device monitor...
Mar 31 23:34:08 jar-d systemd[1]: Starting Disk Manager...
Mar 31 23:34:08 jar-d udisksd[1633]: udisks daemon version 2.10.1 starting
Mar 31 23:34:08 jar-d udisksd[1633]: Error probing device: Error sending ATA command IDENTIFY PACKET DEVICE to '/dev/sr0': ATA command failed: error=0x01 count=0x02 status=0x50 (g-io-error-quark, 0)
Mar 31 23:34:08 jar-d systemd[1]: Started Disk Manager.
Mar 31 23:34:08 jar-d udisksd[1633]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Mar 31 23:34:08 jar-d systemd[1216]: Started Virtual filesystem service - disk device monitor.
Mar 31 23:34:08 jar-d systemd[1216]: Starting Virtual filesystem service - Apple File Conduit monitor...
Mar 31 23:34:08 jar-d systemd[1216]: Starting Portal service...
Mar 31 23:34:08 jar-d systemd[1216]: Started Virtual filesystem service - Apple File Conduit monitor.
Mar 31 23:34:08 jar-d systemd[1216]: Starting Virtual filesystem service - digital camera monitor...
Mar 31 23:34:08 jar-d systemd[1216]: Starting sandboxed app permission store...
Mar 31 23:34:08 jar-d systemd[1216]: Started Virtual filesystem service - digital camera monitor.
Mar 31 23:34:08 jar-d systemd[1216]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Mar 31 23:34:08 jar-d systemd[1216]: Started sandboxed app permission store.
Mar 31 23:34:08 jar-d systemd[1216]: Starting flatpak document portal service...
Mar 31 23:34:08 jar-d NetworkManager[627]: <info>  [1743431648.4947] agent-manager: agent[11baf2b9cd371307,:1.60/org.freedesktop.nm-applet/1000]: agent registered
Mar 31 23:34:08 jar-d systemd[1216]: Started flatpak document portal service.
Mar 31 23:34:08 jar-d systemd[1216]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Mar 31 23:34:08 jar-d systemd[1216]: Starting Portal service (GTK/GNOME implementation)...
Mar 31 23:34:08 jar-d systemd[1216]: Started Thumbnailing service.
Mar 31 23:34:08 jar-d systemd[1216]: Starting Virtual filesystem metadata service...
Mar 31 23:34:08 jar-d systemd[1216]: Started Virtual filesystem metadata service.
Mar 31 23:34:08 jar-d systemd[1216]: Started Portal service (GTK/GNOME implementation).
Mar 31 23:34:08 jar-d polkitd[629]: Registered Authentication Agent for unix-session:4 (system bus name :1.63 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Mar 31 23:34:08 jar-d systemd[1216]: Started PipeWire Multimedia Service.
Mar 31 23:34:08 jar-d systemd[1]: Starting Daemon for power management...
Mar 31 23:34:08 jar-d systemd[1216]: Started Portal service.
Mar 31 23:34:08 jar-d systemd[1]: Started Daemon for power management.
Mar 31 23:34:09 jar-d systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Mar 31 23:34:24 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-47.local. Local service cookie is 3702138598.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-48
Mar 31 23:34:24 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:34:24 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:34:38 jar-d sudo[1829]:     XXXXX : TTY=pts/0 ; PWD=/home/XXXXX/mntsw ; USER=root ; COMMAND=/usr/bin/mount -t cifs -o username=xxxx,password=xxxx,uid=1000,gid=1000 //10.200.17.11/have /home/XXXXX/mnt/daisy/have
Mar 31 23:34:38 jar-d sudo[1829]: pam_unix(sudo:session): session opened for user root(uid=0) by XXXXX(uid=1000)
Mar 31 23:34:38 jar-d kernel: netfs: FS-Cache loaded
Mar 31 23:34:38 jar-d kernel: Key type dns_resolver registered
Mar 31 23:34:38 jar-d kernel: Key type cifs.spnego registered
Mar 31 23:34:38 jar-d kernel: Key type cifs.idmap registered
Mar 31 23:34:38 jar-d kernel: CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
Mar 31 23:34:38 jar-d kernel: CIFS: enabling forceuid mount option implicitly because uid= option is specified
Mar 31 23:34:38 jar-d kernel: CIFS: enabling forcegid mount option implicitly because gid= option is specified
Mar 31 23:34:38 jar-d kernel: CIFS: Attempting to mount //10.200.17.11/have
Mar 31 23:34:38 jar-d baloo_file[1521]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkRequested(QString)
Mar 31 23:34:38 jar-d baloo_file[1521]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkDone(Solid::ErrorType, QVariant, QString)
Mar 31 23:34:38 jar-d sudo[1829]: pam_unix(sudo:session): session closed for user root
Mar 31 23:34:38 jar-d sudo[1871]:     XXXXX : TTY=pts/0 ; PWD=/home/XXXXX/mntsw ; USER=root ; COMMAND=/usr/bin/mount -t cifs -o username=xxxx,password=xxxx,uid=1000,gid=1000 //10.200.17.11/jane /home/XXXXX/mnt/daisy/jane
Mar 31 23:34:38 jar-d sudo[1871]: pam_unix(sudo:session): session opened for user root(uid=0) by XXXXX(uid=1000)
Mar 31 23:34:38 jar-d kernel: CIFS: Attempting to mount //10.200.17.11/jane
Mar 31 23:34:38 jar-d sudo[1871]: pam_unix(sudo:session): session closed for user root
Mar 31 23:34:38 jar-d sudo[1904]: pam_unix(sudo:session): session closed for user root
Mar 31 23:34:44 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-48.local. Local service cookie is 3702138598.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-49
Mar 31 23:34:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:34:44 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:35:04 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-49.local. Local service cookie is 3702138598.
Mar 31 23:35:04 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:35:04 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:35:04 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:35:04 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:35:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:35:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:35:44 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:35:44 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:35:44 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:35:47 jar-d baloo_file_extractor[2097]: kf.filemetadata: Found plugin with metadata: "/usr/lib/qt6/plugins/kf6/kfilemetadata/kfilemetadata_plaintextextractor.so"
Mar 31 23:35:47 jar-d baloo_file_extractor[2097]: kf.filemetadata: Found plugin with metadata: "/usr/lib/qt6/plugins/kf6/kfilemetadata/kfilemetadata_postscriptdscextractor.so"
Mar 31 23:35:47 jar-d baloo_file_extractor[2097]: kf.filemetadata: Found plugin with metadata: "/usr/lib/qt6/plugins/kf6/kfilemetadata/kfilemetadata_appimageextractor.so"
Mar 31 23:35:47 jar-d baloo_file_extractor[2097]: kf.filemetadata: Found plugin with metadata: "/usr/lib/qt6/plugins/kf6/kfilemetadata/kfilemetadata_mobiextractor.so"
Mar 31 23:35:47 jar-d baloo_file_extractor[2097]: kf.filemetadata: Found plugin with metadata: "/usr/lib/qt6/plugins/kf6/kfilemetadata/kfilemetadata_taglibextractor.so"
Mar 31 23:35:47 jar-d baloo_file_extractor[2097]: kf.filemetadata: Found plugin with metadata: "/usr/lib/qt6/plugins/kf6/kfilemetadata/kfilemetadata_poextractor.so"
Mar 31 23:35:48 jar-d baloo_file_extractor[2097]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkRequested(QString)
Mar 31 23:35:48 jar-d baloo_file_extractor[2097]: qt.core.qobject.connect: QObject::connect: No such signal Solid::Backends::Fstab::FstabStorageAccess::checkDone(Solid::ErrorType, QVariant, QString)
Mar 31 23:36:04 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-52.local. Local service cookie is 3702138598.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-53
Mar 31 23:36:04 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:36:04 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:36:16 jar-d gvfsd-trash[1729]: GFileInfo created without standard::name
Mar 31 23:36:16 jar-d gvfsd-trash[1729]: file ../glib/gio/gfileinfo.c: line 1698 (g_file_info_get_name): should not be reached
Mar 31 23:36:24 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-53.local. Local service cookie is 3702138598.
Mar 31 23:36:24 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:36:24 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:36:24 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:36:24 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:37:24 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:37:24 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:37:24 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:37:24 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:37:24 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:37:24 jar-d systemd[1]: Starting Cleanup of Temporary Directories...
Mar 31 23:37:24 jar-d systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Mar 31 23:37:24 jar-d systemd[1]: Finished Cleanup of Temporary Directories.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-57.local. Local service cookie is 3702138598.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-58
Mar 31 23:37:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Mar 31 23:37:44 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 31 23:38:04 jar-d avahi-daemon[628]: Server startup complete. Host name is jar-d-58.local. Local service cookie is 3702138598.
Mar 31 23:38:04 jar-d avahi-daemon[628]: Withdrawing address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.
Mar 31 23:38:04 jar-d avahi-daemon[628]: Withdrawing address record for 10.200.17.51 on ens33.
Mar 31 23:38:04 jar-d avahi-daemon[628]: Withdrawing address record for ::1 on lo.
Mar 31 23:38:04 jar-d avahi-daemon[628]: Withdrawing address record for 127.0.0.1 on lo.
[Many similar lines deleted:  As you can see from jar-d-58 and jar-d-3248, a staggering number of similar entries here]
Apr 02 13:07:27 jar-d avahi-daemon[628]: Host name conflict, retrying with jar-d-3248
Apr 02 13:07:27 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6::76a on ens33.*.
Apr 02 13:07:27 jar-d avahi-daemon[628]: Registering new address record for fd93:8f99:81c6:0:38e8:f99e:777:62a1 on ens33.*.
Apr 02 13:07:27 jar-d avahi-daemon[628]: Registering new address record for 10.200.17.51 on ens33.IPv4.
Apr 02 13:07:27 jar-d avahi-daemon[628]: Registering new address record for ::1 on lo.*.
Apr 02 13:07:27 jar-d avahi-daemon[628]: Registering new address record for 127.0.0.1 on lo.IPv4.
Apr 02 13:07:39 jar-d kernel: e1000 0000:02:01.0 ens33: Detected Tx Unit Hang
                                Tx Queue             <0>
                                TDH                  <fa>
                                TDT                  <ff>
                                next_to_use          <ff>
                                next_to_clean        <fa>
                              buffer_info[next_to_clean]
                                time_stamp           <1012709bb>
                                next_to_watch        <fe>
                                jiffies              <101270b41>
                                next_to_watch.status <0>
Apr 02 15:44:46 jar-d kernel: e1000 0000:02:01.0 ens33: Detected Tx Unit Hang
                                Tx Queue             <0>
                                TDH                  <fa>
                                TDT                  <ff>
                                next_to_use          <ff>
                                next_to_clean        <fa>
                                next_to_watch        <fe>
                                jiffies              <1015232c2>
Apr 02 15:44:48 jar-d systemd[1]: avahi-daemon.service: State 'stop-sigterm' timed out. Killing.
Apr 02 15:44:48 jar-d systemd[1]: avahi-daemon.service: Killing process 628 (avahi-daemon) with signal SIGKILL.
Apr 02 15:44:48 jar-d systemd[1]: avahi-daemon.service: Main process exited, code=killed, status=9/KILL
Apr 02 15:44:48 jar-d systemd[1]: avahi-daemon.service: Failed with result 'timeout'.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Apr 02 15:44:48 jar-d systemd[1]: avahi-daemon.service: Consumed 1min 8.739s CPU time, 1.7M memory peak, 400K memory swap peak.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Basic System.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Path Units.
Apr 02 15:44:48 jar-d systemd[1]: cups.path: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped CUPS Scheduler.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Slice Units.
Apr 02 15:44:48 jar-d systemd[1]: Removed slice User and Session Slice.
Apr 02 15:44:48 jar-d systemd[1]: user.slice: Consumed 2h 3min 7.873s CPU time, 4.4G memory peak, 342.1M memory swap peak.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Socket Units.
Apr 02 15:44:48 jar-d systemd[1]: avahi-daemon.socket: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Apr 02 15:44:48 jar-d systemd[1]: cups.socket: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Closed CUPS Scheduler.
Apr 02 15:44:48 jar-d systemd[1]: dirmngr@etc-pacman.d-gnupg.socket: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Closed GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Apr 02 15:44:48 jar-d systemd[1]: Removed slice Slice /system/dirmngr.
Apr 02 15:44:48 jar-d systemd[1]: systemd-importd.socket: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Closed Disk Image Download Service Socket.
Apr 02 15:44:48 jar-d dbus-broker[626]: Dispatched 18789 messages @ 5(±28)μs / message.
Apr 02 15:44:48 jar-d systemd[1]: Stopping D-Bus System Message Bus...
Apr 02 15:44:48 jar-d systemd[1]: dbus-broker.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped D-Bus System Message Bus.
Apr 02 15:44:48 jar-d systemd[1]: dbus.socket: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Closed D-Bus System Message Bus Socket.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target System Initialization.
Apr 02 15:44:48 jar-d systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Local Encrypted Volumes.
Apr 02 15:44:48 jar-d systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Apr 02 15:44:48 jar-d systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Local Integrity Protected Volumes.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Local Verity Protected Volumes.
Apr 02 15:44:48 jar-d systemd[1]: systemd-sysctl.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Apply Kernel Variables.
Apr 02 15:44:48 jar-d systemd[1]: systemd-coredump.socket: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Closed Process Core Dump Socket.
Apr 02 15:44:48 jar-d systemd[1]: systemd-modules-load.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Load Kernel Modules.
Apr 02 15:44:48 jar-d systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Apr 02 15:44:48 jar-d systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Apr 02 15:44:48 jar-d systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Create System Files and Directories.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Local File Systems.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Preparation for Local File Systems.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Mounted snaps.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Mounting snaps.
Apr 02 15:44:48 jar-d systemd[1]: Unmounting Temporary Directory /tmp...
Apr 02 15:44:48 jar-d systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Apr 02 15:44:48 jar-d systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Create Static Device Nodes in /dev.
Apr 02 15:44:48 jar-d systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
Apr 02 15:44:48 jar-d systemd[1]: tmp.mount: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Unmounted Temporary Directory /tmp.
Apr 02 15:44:48 jar-d systemd[1]: Stopped target Swaps.
Apr 02 15:44:48 jar-d systemd[1]: Deactivating swap /swapfile...
Apr 02 15:44:48 jar-d systemd[1]: lvm2-monitor.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Apr 02 15:44:48 jar-d systemd[1]: swapfile.swap: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Deactivated swap /swapfile.
Apr 02 15:44:48 jar-d systemd[1]: Reached target Unmount All Filesystems.
Apr 02 15:44:48 jar-d systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Stopped Remount Root and Kernel File Systems.
Apr 02 15:44:48 jar-d systemd[1]: Reached target System Shutdown.
Apr 02 15:44:48 jar-d systemd[1]: Reached target Late Shutdown Services.
Apr 02 15:44:48 jar-d systemd[1]: systemd-poweroff.service: Deactivated successfully.
Apr 02 15:44:48 jar-d systemd[1]: Finished System Power Off.
Apr 02 15:44:48 jar-d systemd[1]: Reached target System Power Off.
Apr 02 15:44:48 jar-d systemd[1]: Shutting down.
Apr 02 15:44:48 jar-d systemd-shutdown[1]: Syncing filesystems and block devices.
Apr 02 15:44:48 jar-d systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Apr 02 15:44:48 jar-d systemd-journald[361]: Received SIGTERM from PID 1 (systemd-shutdow).
Apr 02 15:44:48 jar-d systemd-journald[361]: Journal stopped
[XXXXX@jar-d ~]$
That command, if you have used it as written here, would not have worked.
It would have given you an error message (syntax error - there is a typo in it)
If you thought you did disable avahi with this: you didn’t
It’s still active.
no sudo needed - you will be prompted
systemctl disable --now avahi-daemon
or
systemctl disable --now avahi-daemon.service
Thank you. I tried with --now, got the expected result, rebooted for good measure, and did:
[luna@jar-d ~]$ systemctl status avahi-daemon
○ avahi-daemon.service - Avahi mDNS/DNS-SD Stack
     Loaded: loaded (/usr/lib/systemd/system/avahi-daemon.service; disabled; preset: disa>
     Active: inactive (dead)
TriggeredBy: ○ avahi-daemon.socket
lines 1-4/4 (END)
If this is the fix, I will only know when the system has not crashed by the time it should have (say, a week’s time).
Thanks. I will update here with outcome one way or the other.
… you might want to revise/shorten your log output above - there is several cifs mounts in there with username and password …
I think the reason is here:
                                Tx Queue             <0>
                                TDH                  <fa>
                                TDT                  <ff>
                                next_to_use          <ff>
                                next_to_clean        <fa>
                                next_to_watch        <fe>
                                jiffies              <101270b41>
But I don’t know what to do about it.
