So I’m running on the unstable branch, and today, my input devices were unresponsive on the login screen (sddm), could not even get to a TTY.
Booting into cli mode and starting Xorg manually exhibited the same unresponsiveness.
Wayland would not start due to a libwacom version mismatch, so it turns out that the latest libwacom version was the culprit.
Solution : Boot into CLI mode. Downgrade libwacom to 1.12, and reboot. Input devices should now work again.
I’m not sure if this is the best fix, but at least it works, so I just wanted to leave it somewhere in case in can help someone.
EDIT: more info about my system :
Manjaro KDE Plasma Edition, unstable branch
Kernel: 5.16.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=c7efd223-eb35-452c-8ab3-e71d6d2baa2a rw apparmor=1
security=apparmor resume=UUID=44be34b4-fd1b-40dc-a8f7-21afefa86901
udev.log_priority=3 3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: X570 AORUS ULTRA v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS ULTRA v: x.x serial: <superuser required>
UEFI: American Megatrends v: F31j date: 11/20/2020
RAM: total: 31.35 GiB used: 4.04 GiB (12.9%)
RAM Report:
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3423 high: 4339 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4128 2: 4318
3: 2077 4: 2153 5: 4339 6: 3470 7: 3676 8: 2155 9: 4273 10: 3823 11: 4255
12: 4090 13: 3457 14: 4291 15: 2100 16: 2171 bogomips: 115028
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 0c:00.0 chip-ID: 1002:731f
class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-6.2:4 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 92
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.44.0
5.16.1-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.4 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0c:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0e:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 5-3.4:3
chip-ID: 0d8c:0014 class-ID: 0300
Sound Server-1: ALSA v: k5.16.1-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel port: f000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-5:2
Device-1: luks-8e4618e5-1025-420c-ba28-9b661b4e55de maj-min: 254:0
type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: sdb1 maj-min: 8:17 size: 1.82 TiB
Local Storage: total: 5.91 TiB used: 1.03 TiB (17.3%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung
rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 896.71 GiB size: 881.64 GiB (98.32%)
used: 180.01 GiB (20.4%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
label: arch uuid: c7efd223-eb35-452c-8ab3-e71d6d2baa2a
used: 1.7 MiB (0.6%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
uuid: 525B-F639
ID-3: /media/gamedisk raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 335.48 GiB (72.0%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Shared
uuid: DC56C9A556C9812E
ID-4: /run/timeshift/backup raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
used: 534.74 GiB (29.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-8e4618e5-1025-420c-ba28-9b661b4e55de label: backup
uuid: d6ed5888-fb5c-4f49-b4df-49a473cce5c9
ID-1: swap-1 type: partition size: 34.5 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8 label: N/A
uuid: 44be34b4-fd1b-40dc-a8f7-21afefa86901
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: B223-A72E
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.9 GiB fs: ntfs label: N/A
uuid: 00D424A5D4249EC2
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 511 MiB fs: ntfs label: N/A
uuid: 48D0A848D0A83DD6
ID-5: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ntfs label: backup
uuid: 12E471326822BEDD
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-5: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-6.2:4 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-2: 3-6.3:5
info: Corsair CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b49 class-ID: 0300
serial: <filter>
Device-3: 3-6.4:6 info: Razer USA Naga Trinity type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0067 class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 5-3:2 info: Super Top 4-Port hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 14cd:8601 class-ID: 0900
Device-1: 5-3.4:3 info: C-Media Audio Adapter (Unitek Y-247A)
type: Audio,HID driver: cmedia_hs100b,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0014 class-ID: 0300
Hub-9: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
mem: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 424 Uptime: 26m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1792 pacman: 1780 lib: 467
flatpak: 12 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.1
