Manjaro Linux Samsung SSD 970 Evo Plus not showing up in Boot Menu
I currently have installed Manjaro Gnome on a Samsung SSD 970 Evo Plus. Everything was working properly until I went to restart the system. I am not able to see my my m.2 drive in the boot menu. I have been searching this issue but have not found a direct solution. I have disabled “fast boot” and made sure to be in “AHCI” mode. I can see my m.2 drive under storage information so I know that is recognized by the system. I’m new to this forum and to Manjaro so any help is appreciated. I have run Ubuntu Linux for many years and have recently switched over.
Asus B550M Plus
Ryzen 7 3700x
EVGA 1650 Geforce GTX Super
UEFI ↔ BIOS issue?
Please post the output of:
sudo parted -l
Model: ATA WDC WD10EZEX-08W (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 1000GB 1000GB fat32 msftdata
Model: Sandisk USB Ultra (scsi)
Disk /dev/sdb: 8054MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2954MB 2958MB 4194kB primary esp
Model: Samsung SSD 970 EVO Plus 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Disk Flags:
1 1049kB 1000GB 1000GB ext4
Hello @nrb523 :wink:
GPT is correct.
If you boot with UEFI, don’t you forget the efi partition, which have to be fat32 formatted :wink:
If you use a BIOS to boot a disk with GPT, there is a 8MB bios-grub partition needed, so that grub write to this partition, since GPT don’t support MBR like MS-DOS.
So it should look like this (it is my SSD), if it is uefi boot:
Model: ATA Apacer AS350 240 (scsi)
Disk /dev/sdd: 240GB
Disk Flags:
 1      2097kB  317MB  315MB  fat32        boot  boot, esp
 2      317MB   240GB  240GB  ext4         root
I assume this only for exchange? Or is that a 1TB efi partition? (you need only max. 500MB xD)
