Manjaro Keeps in "x.55 No irq handler for vector"
[ Where X goes from 1 to 3 ]
It just doesn’t load, it boots and keep in No irq handler… ,I don’t know what could be the problem, the last thing I did is to successfully build and make WINE 5.19 and when installing, my laptop (Lenovo z50, 8GB, APU AMD A10) ran out of battery.
See here
and here
FWIW I had a similar problem with manjaro and also this kind of messages, boot time was very, very slow.
In my case it turned out to be a addon card, a usb 3.0 card, to be the problem. Removed it and problems where gone.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
