Manjaro keeps freezing randomly every 10-15 minutes
Manjaro keeps freezing randomly every 15 minutes or so and when it does, I am unable to move my cursor and the screen freezes for 8-15 seconds.
Here is my current state of inxi -Fxz
  Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    Desktop: GNOME v: 43.2 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Micro-Star product: Thin GF63 12HW v: REV:1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MS-16R7 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E16R7IMS.10A date: 07/01/2022
  ID-1: BAT1 charge: 39.8 Wh (77.1%) condition: 51.6/51.3 Wh (100.7%)
    volts: 11.6 min: 11.4 model: MSI BIF0_9 status: discharging
  Info: 12-core (4-mt/8-st) model: 12th Gen Intel Core i5-12500H bits: 64
    type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.1 MiB L2: 9 MiB
    L3: 18 MiB
  Speed (MHz): avg: 2779 high: 3100 min/max: 400/4500:3300 cores: 1: 3100
    2: 572 3: 3100 4: 3100 5: 498 6: 3100 7: 3100 8: 3100 9: 3100 10: 3100
    11: 3100 12: 3100 13: 3100 14: 3100 15: 3100 16: 3100 bogomips: 99568
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen-12.2 bus-ID: 00:02.0
  Device-2: Intel DG2 [Arc A370M] vendor: Micro-Star MSI driver: i915
    v: kernel arch: Gen-12.7 bus-ID: 03:00.0
  Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
    compositor: gnome-shell driver: gpu: i915 resolution: 1920x1080~144Hz
  API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Graphics (ADL GT2)
    direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3
  Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.63 running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3
  IF: wlo1 state: down mac: <filter>
    vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 06:00.0
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    bus-ID: 3-10:2
  Local Storage: total: 476.94 GiB used: 17.46 GiB (3.7%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN540
    SDDPNPF-512G-1032 size: 476.94 GiB temp: 24.9 C
  ID-1: / size: 140.67 GiB used: 17.42 GiB (12.4%) fs: ext4
    dev: /dev/nvme0n1p8
  ID-2: /boot/efi size: 296 MiB used: 44.4 MiB (15.0%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p5
  System Temperatures: cpu: 46.0 C mobo: N/A
  Processes: 327 Uptime: 24m Memory: 7.47 GiB used: 2.8 GiB (37.5%)
  Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 999 Shell: fish
  v: 3.5.1 inxi: 3.3.24
Maybe not enough swap? 2 GB looks very small for a machine with only 8 GB RAM.
Thank you for the response, I increased swap to 8GB but the issue still persists.
grep SwapTotal /proc/meminfo
SwapTotal:       8388604 kB
see this , you may need also swap
Thank You for the response, but this did not help either.
you are on wayland so switch to xorg, and see if it helped
