Hi,
Recently, I have updated the manjaro installation along with its KDE. Everything is upgraded. The problem: I cannot login again, since my keyboards are not working (I tried with two different).
At least I have another computer with ssh to connect to it, and I did many tests:
acpi=off (grub)
pci=noacpi (grub)
downgrading libinput and xf86-input…
downgrading the kernel version (5.9 and 5.12 or so)
switching to a kernel 4.19
disabling acpid.service
disabling sddm
The keyboards does not work in any place (neither sddm login nor the virtual console)
Any idea what is going on?
Any idea? Still not working.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f3352e98-3b2b-44db-8a55-2547ed0de67e rw quiet udev.log_priority=3
Console: tty pts/0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: 990FXA-UD3 v: x.x serial: <filter>
UEFI: American Megatrends v: FC date: 02/05/2013
RAM: total: 23.51 GiB used: 623.7 MiB (2.6%)
RAM Report:
missing: Required tool dmidecode not installed. Check --recommends
Info: 6-Core model: AMD FX-6350 bits: 64 type: MCP arch: Bulldozer
family: 15 (21) model-id: 2 stepping: 0 microcode: 6000852 cache: L2: 2 MiB
bogomips: 47029
Speed: 1406 MHz min/max: 1400/3900 MHz boost: enabled Core speeds (MHz):
1: 1406 2: 1406 3: 1406 4: 1406 5: 1406 6: 1406
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht hw_pstate
ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor msr mtrr
nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean vme vmmcall wdt
xop xsave
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: server: X.org 1.20.11 driver: loaded: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa tty: 106x51
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: Gigabyte driver: r8169 v: kernel port: b000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
vendor: TP-LINK TG-3468 driver: r8169 v: kernel port: a000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: up speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: vethd23060b state: up speed: 10000 Mbps duplex: full mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 2.05 TiB used: 104.03 GiB (5.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EZRX-00D8PB0
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: <unknown>
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
ID-1: / raw-size: 116.88 GiB size: 114.93 GiB (98.33%) used: 104 GiB (90.5%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: f3352e98-3b2b-44db-8a55-2547ed0de67e
used: 26.6 MiB (27.7%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: A441-1939
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
ID-3: /dev/sda4 maj-min: 8:4 size: 114.89 GiB fs: ntfs label: N/A
uuid: A04C5DC34C5D94BE
ID-4: /dev/sda5 maj-min: 8:5 size: 517 MiB fs: ntfs label: N/A
uuid: 96C2FAA9C2FA8CAD
ID-5: /dev/sdb1 maj-min: 8:17 size: 1.56 TiB fs: ext4 label: data
uuid: f63f85d2-0ae2-42dc-a7c2-48bbb03914d2
ID-6: /dev/sdb2 maj-min: 8:18 size: 263.01 GiB fs: ntfs label: N/A
uuid: 4B4275A81C17F739
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-2:2 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-9: 9-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-10: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Hub-11: 11-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1
System Temperatures: cpu: 15.5 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 735
Processes: 169 Uptime: 6m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1278 lib: 288
Shell: Zsh v: 5.8 running-in: tty pts/0 (SSH) inxi: 3.3.05
So, the USB Keyboard is not recognized. Using that USB keyboard in another manjaro machine, I can get listed like this:
Device-1: 2-5.2:3 info: Alcor Micro Keyboard type: Keyboard,HID
driver: maltron,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 50mA
chip-ID: 058f:9410 class-ID: 0300
In the original machine, when connecting to two different USB ports:
[ 1609.600354] usb 9-4: new low-speed USB device number 14 using ohci-pci
[ 1609.753690] usb 9-4: device descriptor read/64, error -32
[ 1610.013695] usb 9-4: device descriptor read/64, error -32
[ 1610.270366] usb 9-4: new low-speed USB device number 15 using ohci-pci
[ 1610.423699] usb 9-4: device descriptor read/64, error -32
[ 1610.683704] usb 9-4: device descriptor read/64, error -32
[ 1610.790419] usb usb9-port4: attempt power cycle
[ 1611.243715] usb 9-4: new low-speed USB device number 16 using ohci-pci
[ 1611.657052] usb 9-4: device not accepting address 16, error -32
[ 1611.807056] usb 9-4: new low-speed USB device number 17 using ohci-pci
[ 1612.220395] usb 9-4: device not accepting address 17, error -32
[ 1612.220448] usb usb9-port4: unable to enumerate USB device
[ 1624.600590] usb 9-5: new low-speed USB device number 18 using ohci-pci
[ 1624.753925] usb 9-5: device descriptor read/64, error -32
[ 1625.013930] usb 9-5: device descriptor read/64, error -32
[ 1625.270601] usb 9-5: new low-speed USB device number 19 using ohci-pci
[ 1625.423947] usb 9-5: device descriptor read/64, error -32
[ 1625.683940] usb 9-5: device descriptor read/64, error -32
[ 1625.790653] usb usb9-port5: attempt power cycle
[ 1626.243949] usb 9-5: new low-speed USB device number 20 using ohci-pci
[ 1626.657373] usb 9-5: device not accepting address 20, error -32
[ 1626.807294] usb 9-5: new low-speed USB device number 21 using ohci-pci
[ 1627.220628] usb 9-5: device not accepting address 21, error -32
[ 1627.220681] usb usb9-port5: unable to enumerate USB device
Solved by doing iommu=soft
in grub.
system
Closed
27 July 2021 18:20
4
