[alex@main-desktop ~]$ nvidia-settings
Segmentation fault (core dumped)
[alex@main-desktop ~]$ haruna
unknown() : qrc:/qml/main.qml:180:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
unknown() : qrc:/qml/Actions.qml:39:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
unknown() : qrc:/qml/HProgressBar.qml:227:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
unknown() : qrc:/qml/PlayList.qml:327:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
unknown() : file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Floating point exception (core dumped)
It happens on a fresh installed system from manjaro-kde-21.2.5-minimal-220314-linux515.iso
[alex@main-desktop ~]$ pamac info nvidia-utils
Version : 525.85.05-1
Description : NVIDIA drivers utilities
URL : http://www.nvidia.com/
Licenses : custom
Repository : extra
Installed Size : 685.7 MB
Groups : --
Depends On : xorg-server libglvnd egl-wayland jansson gtk3 libxv libvdpau libxnvctrl
Optional Dependencies : xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support
Required By : lib32-nvidia-utils libglvnd linux61-nvidia
Optional For : ffmpeg ffmpeg4.4 vulkan-icd-loader
Provides : vulkan-driver opengl-driver nvidia-libgl nvidia-utils=525.85.05
Replaces : nvidia-libgl
Conflicts With : nvidia-libgl
Packager : Mark Wagie <mark@manjaro.org>
Build Date : Fri Jan 20 00:55:48 2023
Install Date : Sun Jan 29 16:12:31 2023
Install Reason : Explicitly installed
Validated By : Signature
Backup files : --
[alex@main-desktop ~]$ pamac info haruna
Version : 0.10.3-1
Description : Video player built with Qt/QML on top of libmpv
URL : https://apps.kde.org/haruna/
Licenses : GPL3
Repository : community
Installed Size : 1.1 MB
Groups : --
Depends On : kfilemetadata kio mpv kirigami2
Optional Dependencies : yt-dlp: YouTube support [Installed]
Required By : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Sun Jan 29 23:28:03 2023
Install Date : Wed Feb 1 14:41:21 2023
Backup files : --
What could it be?
