The Problem
Hi, I recently re-installed Manjaro on my system (on an NVME SSD). I’ve been facing an issue for a few days now that whenever I put my PC to sleep and turn it back on, it takes a really long time to wake up (around 20-40seconds).
My Guess
I recently bought a realtek wifi adapter (rtl8821au) and installed its drivers from the AUR (rtl8821au-dkms-git). I have tried 4 different kernels: (linux510, linux515, linux54 and linux517). The kernels which didn’t have the driver installed didn’t have this issue (I mean after installing a kernel, I had to run sudo dkms autoinstall to install the driver module on that kernel, so before running this command, this issue was not present in the kernel).
If this issue is occurring because of that realtek driver, is there a way I can fix it? I have provided the output of jounalctl -f and inxi -Fazy.
Please help!!
journalctl -f
I put the computer to sleep/suspend at exactly 16:51:03 and then turned it on again at 16:52:40.
Jul 08 16:50:16 prayag-linux kwin_x11[783]: org.kde.bismuth: Client added: KWin::X11Client(0x558a3493d780)
Jul 08 16:50:16 prayag-linux kwin_x11[783]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 08 16:50:16 prayag-linux kwin_x11[783]: org.kde.bismuth: arrange
Jul 08 16:50:16 prayag-linux kwin_x11[783]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 08 16:50:16 prayag-linux kwin_x11[783]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x558a3493d780)
Jul 08 16:50:58 prayag-linux kwin_x11[783]: org.kde.bismuth: Client added: KWin::X11Client(0x558a34c58ec0)
Jul 08 16:50:58 prayag-linux kwin_x11[783]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 08 16:50:58 prayag-linux kwin_x11[783]: org.kde.bismuth: arrange
Jul 08 16:50:58 prayag-linux kwin_x11[783]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 08 16:50:58 prayag-linux kwin_x11[783]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x558a34c58ec0)
Jul 08 16:51:02 prayag-linux kwin_x11[783]: org.kde.bismuth: Client added: KWin::X11Client(0x558a34c58ec0)
Jul 08 16:51:02 prayag-linux kwin_x11[783]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 08 16:51:02 prayag-linux kwin_x11[783]: org.kde.bismuth: arrange
Jul 08 16:51:02 prayag-linux kwin_x11[783]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 08 16:51:02 prayag-linux kwin_x11[783]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x558a34c58ec0)
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.7458] manager: sleep: sleep requested (sleeping: no enabled: yes)
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.7460] device (enp27s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jul 08 16:51:03 prayag-linux ModemManager[521]: <info> [sleep-monitor] system is about to suspend
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.7548] device (p2p-dev-wlp21s0f0u2): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.7550] manager: NetworkManager state is now ASLEEP
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.7554] device (wlp21s0f0u2): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Jul 08 16:51:03 prayag-linux dbus-daemon[453]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=500 comm="/usr/bin/NetworkManager --no-daemon")
Jul 08 16:51:03 prayag-linux kded5[780]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Jul 08 16:51:03 prayag-linux systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 08 16:51:03 prayag-linux dbus-daemon[453]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 08 16:51:03 prayag-linux systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 08 16:51:03 prayag-linux kernel: audit: type=1130 audit(1657279263.767:237): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:51:03 prayag-linux audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:51:03 prayag-linux kscreenlocker_greet[171030]: Qt: Session management error: networkIdsList argument is NULL
Jul 08 16:51:03 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-DISCONNECTED bssid=24:0b:88:53:97:fd reason=3 locally_generated=1
Jul 08 16:51:03 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-DSCP-POLICY clear_all
Jul 08 16:51:03 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9080] device (wlp21s0f0u2): supplicant interface state: completed -> disconnected
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9082] device (wlp21s0f0u2): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Withdrawing address record for 2401:4900:1c64:12f1:505e:c0ad:60c5:8a4 on wlp21s0f0u2.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Leaving mDNS multicast group on interface wlp21s0f0u2.IPv6 with address 2401:4900:1c64:12f1:505e:c0ad:60c5:8a4.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Joining mDNS multicast group on interface wlp21s0f0u2.IPv6 with address fe80::1685:a568:989e:92dc.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Registering new address record for fe80::1685:a568:989e:92dc on wlp21s0f0u2.*.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Withdrawing address record for fe80::1685:a568:989e:92dc on wlp21s0f0u2.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Leaving mDNS multicast group on interface wlp21s0f0u2.IPv6 with address fe80::1685:a568:989e:92dc.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Interface wlp21s0f0u2.IPv6 no longer relevant for mDNS.
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9249] dhcp4 (wlp21s0f0u2): canceled DHCP transaction
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9250] dhcp4 (wlp21s0f0u2): activation: beginning transaction (timeout in 45 seconds)
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9250] dhcp4 (wlp21s0f0u2): state changed no lease
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9252] dhcp6 (wlp21s0f0u2): canceled DHCP transaction
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9252] dhcp6 (wlp21s0f0u2): activation: beginning transaction (timeout in 45 seconds)
Jul 08 16:51:03 prayag-linux NetworkManager[500]: <info> [1657279263.9252] dhcp6 (wlp21s0f0u2): state changed no lease
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Interface wlp21s0f0u2.IPv4 no longer relevant for mDNS.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Leaving mDNS multicast group on interface wlp21s0f0u2.IPv4 with address 192.168.1.28.
Jul 08 16:51:03 prayag-linux avahi-daemon[451]: Withdrawing address record for 192.168.1.28 on wlp21s0f0u2.
Jul 08 16:51:04 prayag-linux NetworkManager[500]: <info> [1657279264.0239] device (wlp21s0f0u2): set-hw-addr: set MAC address to BE:4F:3F:2E:C8:3C (scanning)
Jul 08 16:51:04 prayag-linux avahi-daemon[451]: Joining mDNS multicast group on interface wlp21s0f0u2.IPv4 with address 192.168.1.28.
Jul 08 16:51:04 prayag-linux avahi-daemon[451]: New relevant interface wlp21s0f0u2.IPv4 for mDNS.
Jul 08 16:51:04 prayag-linux avahi-daemon[451]: Registering new address record for 192.168.1.28 on wlp21s0f0u2.IPv4.
Jul 08 16:51:04 prayag-linux avahi-daemon[451]: Withdrawing address record for 192.168.1.28 on wlp21s0f0u2.
Jul 08 16:51:04 prayag-linux avahi-daemon[451]: Leaving mDNS multicast group on interface wlp21s0f0u2.IPv4 with address 192.168.1.28.
Jul 08 16:51:04 prayag-linux avahi-daemon[451]: Interface wlp21s0f0u2.IPv4 no longer relevant for mDNS.
Jul 08 16:51:04 prayag-linux NetworkManager[500]: <info> [1657279264.0488] device (wlp21s0f0u2): supplicant interface state: disconnected -> interface_disabled
Jul 08 16:51:04 prayag-linux NetworkManager[500]: <info> [1657279264.0492] device (wlp21s0f0u2): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jul 08 16:51:04 prayag-linux audit: BPF prog-id=47 op=UNLOAD
Jul 08 16:51:04 prayag-linux kernel: audit: type=1334 audit(1657279264.070:238): prog-id=47 op=UNLOAD
Jul 08 16:51:04 prayag-linux PackageKit[907]: get-updates transaction /15_baaceacb from uid 1000 finished with success after 2ms
Jul 08 16:51:04 prayag-linux kscreenlocker_greet[171030]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Jul 08 16:51:04 prayag-linux kscreenlocker_greet[171030]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Jul 08 16:51:04 prayag-linux NetworkManager[500]: <warn> [1657279264.6841] platform-linux: do-change-link[3]: failure changing link: failure 1 (Operation not permitted)
Jul 08 16:51:04 prayag-linux NetworkManager[500]: <warn> [1657279264.6842] device (wlp21s0f0u2): set-hw-addr: failed to reset MAC address to 14:EB:B6:A8:E0:FF (unmanage) (NME_UNSPEC)
Jul 08 16:51:04 prayag-linux systemd[1]: Reached target Sleep.
Jul 08 16:51:04 prayag-linux systemd[1]: Starting System Suspend...
Jul 08 16:51:04 prayag-linux systemd-sleep[171073]: Entering sleep state 'suspend'...
Jul 08 16:51:04 prayag-linux kernel: PM: suspend entry (deep)
Jul 08 16:52:40 prayag-linux kernel: Filesystems sync: 0.008 seconds
Jul 08 16:52:40 prayag-linux kernel: Freezing user space processes ... (elapsed 0.008 seconds) done.
Jul 08 16:52:40 prayag-linux kernel: OOM killer disabled.
Jul 08 16:52:40 prayag-linux kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Jul 08 16:52:40 prayag-linux kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jul 08 16:52:40 prayag-linux kernel: serial 00:05: disabled
Jul 08 16:52:40 prayag-linux kernel: parport_pc 00:04: disabled
Jul 08 16:52:40 prayag-linux kernel: sd 5:0:0:0: [sdb] Synchronizing SCSI cache
Jul 08 16:52:40 prayag-linux kernel: sd 5:0:0:0: [sdb] Stopping disk
Jul 08 16:52:40 prayag-linux kernel: sd 4:0:0:0: [sda] Synchronizing SCSI cache
Jul 08 16:52:40 prayag-linux kernel: sd 4:0:0:0: [sda] Stopping disk
Jul 08 16:52:40 prayag-linux kernel: [drm] free PSP TMR buffer
Jul 08 16:52:40 prayag-linux kernel: ACPI: Preparing to enter system sleep state S3
Jul 08 16:52:40 prayag-linux kernel: PM: Saving platform NVS memory
Jul 08 16:52:40 prayag-linux kernel: Disabling non-boot CPUs ...
Jul 08 16:52:40 prayag-linux kernel: smpboot: CPU 1 is now offline
Jul 08 16:52:40 prayag-linux kernel: smpboot: CPU 2 is now offline
Jul 08 16:52:40 prayag-linux kernel: smpboot: CPU 3 is now offline
Jul 08 16:52:40 prayag-linux kernel: smpboot: CPU 4 is now offline
Jul 08 16:52:40 prayag-linux kernel: smpboot: CPU 5 is now offline
Jul 08 16:52:40 prayag-linux kernel: smpboot: CPU 6 is now offline
Jul 08 16:52:40 prayag-linux kernel: smpboot: CPU 7 is now offline
Jul 08 16:52:40 prayag-linux kernel: ACPI: Low-level resume complete
Jul 08 16:52:40 prayag-linux kernel: PM: Restoring platform NVS memory
Jul 08 16:52:40 prayag-linux kernel: ------------[ cut here ]------------
Jul 08 16:52:40 prayag-linux kernel: WARNING: CPU: 0 PID: 171073 at drivers/iommu/amd/init.c:850 amd_iommu_enable_interrupts+0x2ec/0x330
Jul 08 16:52:40 prayag-linux kernel: Modules linked in: qrtr ns squashfs loop snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio vfat fat snd_hda_intel snd_intel_dspcfg edac_mce_amd soundwire_intel kvm_amd soundwire_generic_allocation soundwire_cadence amdgpu snd_hda_codec kvm snd_hda_core snd_hwdep irqbypass ppdev wmi_bmof soundwire_bus crct10dif_pclmul crc32_pclmul snd_soc_core ghash_clmulni_intel aesni_intel crypto_simd 8821au(OE) gpu_sched cryptd snd_compress i2c_algo_bit glue_helper ttm ac97_bus rapl snd_pcm_dmaengine drm_kms_helper r8169 snd_pcm snd_timer pcspkr mousedev joydev ccp cec realtek snd syscopyarea mdio_devres sysfillrect sp5100_tco sysimgblt cfg80211 fb_sys_fops soundcore rng_core k10temp i2c_piix4 libphy rfkill parport_pc parport gpio_amdpt video mac_hid gpio_generic pinctrl_amd wmi acpi_cpufreq uinput drm ipmi_devintf ipmi_msghandler sg fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid crc32c_intel sr_mod cdrom xhci_pci
Jul 08 16:52:40 prayag-linux kernel: CPU: 0 PID: 171073 Comm: systemd-sleep Tainted: G W OE 5.10.126-1-MANJARO #1
Jul 08 16:52:40 prayag-linux kernel: Hardware name: MSI MS-7A39/A320M GAMING PRO (MS-7A39), BIOS 1.D0 04/27/2018
Jul 08 16:52:40 prayag-linux kernel: RIP: 0010:amd_iommu_enable_interrupts+0x2ec/0x330
Jul 08 16:52:40 prayag-linux kernel: Code: 48 8b 00 48 8b 73 38 4c 09 f0 48 89 46 18 e9 16 fe ff ff 0f 0b 48 8b 1b 48 81 fb 70 80 35 bc 0f 85 73 fd ff ff e9 70 ff ff ff <0f> 0b 48 8b 1b 48 81 fb 70 80 35 bc 0f 85 5c fd ff ff e9 59 ff ff
Jul 08 16:52:40 prayag-linux kernel: RSP: 0018:ffffbee1817efd00 EFLAGS: 00010046
Jul 08 16:52:40 prayag-linux kernel: RAX: 0000001484b9e7bc RBX: ffff985f0004a000 RCX: 0000000000000000
Jul 08 16:52:40 prayag-linux kernel: RDX: 0000000000009414 RSI: 0000000000008ca0 RDI: 0000001484b953a8
Jul 08 16:52:40 prayag-linux kernel: RBP: 0000000080000000 R08: 0000000000203000 R09: 0000000000000023
Jul 08 16:52:40 prayag-linux kernel: R10: ffffffffbc25b348 R11: 00000000fffff7fc R12: 000ffffffffffff8
Jul 08 16:52:40 prayag-linux kernel: R13: 0800000000000000 R14: 0008000000000000 R15: 00000000001e8480
Jul 08 16:52:40 prayag-linux kernel: FS: 00007efdfbbfae80(0000) GS:ffff986017c00000(0000) knlGS:0000000000000000
Jul 08 16:52:40 prayag-linux kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 08 16:52:40 prayag-linux kernel: CR2: 00007f4bc80029e6 CR3: 000000011c0c0000 CR4: 00000000003506f0
Jul 08 16:52:40 prayag-linux kernel: Call Trace:
Jul 08 16:52:40 prayag-linux kernel: amd_iommu_reenable+0x39/0x40
Jul 08 16:52:40 prayag-linux kernel: lapic_resume+0x273/0x2d0
Jul 08 16:52:40 prayag-linux kernel: syscore_resume+0x4b/0x170
Jul 08 16:52:40 prayag-linux kernel: suspend_devices_and_enter+0x6db/0x7f0
Jul 08 16:52:40 prayag-linux kernel: pm_suspend.cold+0x325/0x36e
Jul 08 16:52:40 prayag-linux kernel: state_store+0x68/0xc0
Jul 08 16:52:40 prayag-linux kernel: kernfs_fop_write_iter+0x11a/0x1f0
Jul 08 16:52:40 prayag-linux kernel: new_sync_write+0x113/0x1b0
Jul 08 16:52:40 prayag-linux kernel: vfs_write+0x1ec/0x280
Jul 08 16:52:40 prayag-linux kernel: ksys_write+0x63/0xe0
Jul 08 16:52:40 prayag-linux kernel: do_syscall_64+0x33/0x40
Jul 08 16:52:40 prayag-linux kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
Jul 08 16:52:40 prayag-linux kernel: RIP: 0033:0x7efdfc5e3c27
Jul 08 16:52:40 prayag-linux kernel: Code: 0f 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 51 c3 48 83 ec 28 48 89 54 24 18 48 89 74 24
Jul 08 16:52:40 prayag-linux kernel: RSP: 002b:00007fff62dd70f8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Jul 08 16:52:40 prayag-linux kernel: RAX: ffffffffffffffda RBX: 0000000000000004 RCX: 00007efdfc5e3c27
Jul 08 16:52:40 prayag-linux kernel: RDX: 0000000000000004 RSI: 00007fff62dd71e0 RDI: 0000000000000004
Jul 08 16:52:40 prayag-linux kernel: RBP: 00007fff62dd71e0 R08: 0000563ae64df4d0 R09: 0000000000000000
Jul 08 16:52:40 prayag-linux kernel: R10: 0000563ae5834143 R11: 0000000000000246 R12: 0000000000000004
Jul 08 16:52:40 prayag-linux kernel: R13: 0000563ae64db3c0 R14: 0000000000000004 R15: 00007efdfc6db940
Jul 08 16:52:40 prayag-linux kernel: ---[ end trace f23d38afc81a5387 ]---
Jul 08 16:52:40 prayag-linux kernel: RSP: 0018:ffffbee1817efd28 EFLAGS: 00010046
Jul 08 16:52:40 prayag-linux kernel: RAX: 00000027d0058544 RBX: ffff985f0004a000 RCX: 0000000000000000
Jul 08 16:52:40 prayag-linux kernel: RDX: 0000000000009414 RSI: 0000000000008ca0 RDI: 00000027d004f130
Jul 08 16:52:40 prayag-linux kernel: RBP: 0000000080000000 R08: 0000000000000000 R09: 0000000000000010
Jul 08 16:52:40 prayag-linux kernel: ---[ end trace f23d38afc81a5388 ]---
Jul 08 16:52:40 prayag-linux kernel: Enabling non-boot CPUs ...
Jul 08 16:52:40 prayag-linux kernel: x86: Booting SMP configuration:
Jul 08 16:52:40 prayag-linux kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Jul 08 16:52:40 prayag-linux kernel: microcode: CPU1: patch_level=0x0810100b
Jul 08 16:52:40 prayag-linux kernel: ACPI: \_PR_.P001: Found 2 idle states
Jul 08 16:52:40 prayag-linux kernel: CPU1 is up
Jul 08 16:52:40 prayag-linux kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
Jul 08 16:52:40 prayag-linux kernel: microcode: CPU2: patch_level=0x0810100b
Jul 08 16:52:40 prayag-linux kernel: ACPI: \_PR_.P002: Found 2 idle states
Jul 08 16:52:40 prayag-linux kernel: CPU2 is up
Jul 08 16:52:40 prayag-linux kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Jul 08 16:52:40 prayag-linux kernel: microcode: CPU3: patch_level=0x0810100b
Jul 08 16:52:40 prayag-linux kernel: ACPI: \_PR_.P003: Found 2 idle states
Jul 08 16:52:40 prayag-linux kernel: CPU3 is up
Jul 08 16:52:40 prayag-linux kernel: smpboot: Booting Node 0 Processor 4 APIC 0x4
Jul 08 16:52:40 prayag-linux kernel: microcode: CPU4: patch_level=0x0810100b
Jul 08 16:52:40 prayag-linux kernel: ACPI: \_PR_.P004: Found 2 idle states
Jul 08 16:52:40 prayag-linux kernel: CPU4 is up
Jul 08 16:52:40 prayag-linux kernel: smpboot: Booting Node 0 Processor 5 APIC 0x5
Jul 08 16:52:40 prayag-linux kernel: microcode: CPU5: patch_level=0x0810100b
Jul 08 16:52:40 prayag-linux kernel: ACPI: \_PR_.P005: Found 2 idle states
Jul 08 16:52:40 prayag-linux kernel: CPU5 is up
Jul 08 16:52:40 prayag-linux kernel: smpboot: Booting Node 0 Processor 6 APIC 0x6
Jul 08 16:52:40 prayag-linux kernel: microcode: CPU6: patch_level=0x0810100b
Jul 08 16:52:40 prayag-linux kernel: ACPI: \_PR_.P006: Found 2 idle states
Jul 08 16:52:40 prayag-linux kernel: CPU6 is up
Jul 08 16:52:40 prayag-linux kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Jul 08 16:52:40 prayag-linux kernel: microcode: CPU7: patch_level=0x0810100b
Jul 08 16:52:40 prayag-linux kernel: ACPI: \_PR_.P007: Found 2 idle states
Jul 08 16:52:40 prayag-linux kernel: CPU7 is up
Jul 08 16:52:40 prayag-linux kernel: ACPI: Waking up from system sleep state S3
Jul 08 16:52:40 prayag-linux kernel: xhci_hcd 0000:15:00.0: xHC error in resume, USBSTS 0x401, Reinit
Jul 08 16:52:40 prayag-linux kernel: usb usb1: root hub lost power or was reset
Jul 08 16:52:40 prayag-linux kernel: usb usb2: root hub lost power or was reset
Jul 08 16:52:40 prayag-linux kernel: sd 5:0:0:0: [sdb] Starting disk
Jul 08 16:52:40 prayag-linux kernel: sd 4:0:0:0: [sda] Starting disk
Jul 08 16:52:40 prayag-linux kernel: parport_pc 00:04: activated
Jul 08 16:52:40 prayag-linux kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
Jul 08 16:52:40 prayag-linux kernel: [drm] PSP is resuming...
Jul 08 16:52:40 prayag-linux kernel: serial 00:05: activated
Jul 08 16:52:40 prayag-linux kernel: [drm] reserve 0x400000 from 0xf43fc00000 for PSP TMR
Jul 08 16:52:40 prayag-linux kernel: ata1: SATA link down (SStatus 0 SControl 300)
Jul 08 16:52:40 prayag-linux kernel: ata9: SATA link down (SStatus 0 SControl 300)
Jul 08 16:52:40 prayag-linux kernel: usb 1-2: reset high-speed USB device number 2 using xhci_hcd
Jul 08 16:52:40 prayag-linux kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jul 08 16:52:40 prayag-linux kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 08 16:52:40 prayag-linux kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jul 08 16:52:40 prayag-linux kernel: ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jul 08 16:52:40 prayag-linux kernel: ata5.00: configured for UDMA/133
Jul 08 16:52:40 prayag-linux kernel: ata2.00: configured for UDMA/100
Jul 08 16:52:40 prayag-linux kernel: ata6.00: configured for UDMA/133
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: RAS: optional ras ta ucode is not available
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: RAP: optional rap ta ucode is not available
Jul 08 16:52:40 prayag-linux kernel: [drm] kiq ring mec 2 pipe 1 q 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu: dpm has been enabled
Jul 08 16:52:40 prayag-linux kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Jul 08 16:52:40 prayag-linux kernel: amdgpu 0000:38:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Jul 08 16:52:40 prayag-linux kernel: OOM killer enabled.
Jul 08 16:52:40 prayag-linux kernel: Restarting tasks ...
Jul 08 16:52:40 prayag-linux kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp21s0f0u2: link becomes ready
Jul 08 16:52:40 prayag-linux kernel: done.
Jul 08 16:52:40 prayag-linux kernel: PM: suspend exit
Jul 08 16:52:40 prayag-linux kernel: audit: type=1131 audit(1657279360.710:239): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:40 prayag-linux kernel: audit: type=1130 audit(1657279360.733:240): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:40 prayag-linux kernel: audit: type=1131 audit(1657279360.733:241): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:40 prayag-linux audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:40 prayag-linux kernel: Generic FE-GE Realtek PHY r8169-0-1b00:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-1b00:00, irq=IGNORE)
Jul 08 16:52:40 prayag-linux audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:40 prayag-linux audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:40 prayag-linux rtkit-daemon[860]: The canary thread is apparently starving. Taking action.
Jul 08 16:52:40 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-DSCP-POLICY clear_all
Jul 08 16:52:40 prayag-linux wpa_supplicant[1086]: nl80211: deinit ifname=wlp21s0f0u2 disabled_11b_rates=0
Jul 08 16:52:40 prayag-linux systemd-sleep[171073]: System returned from sleep state.
Jul 08 16:52:40 prayag-linux rtkit-daemon[860]: Demoting known real-time threads.
Jul 08 16:52:40 prayag-linux systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jul 08 16:52:40 prayag-linux rtkit-daemon[860]: Demoted 0 threads.
Jul 08 16:52:40 prayag-linux systemd[1]: systemd-suspend.service: Deactivated successfully.
Jul 08 16:52:40 prayag-linux ModemManager[521]: <info> [sleep-monitor] system is resuming
Jul 08 16:52:40 prayag-linux systemd[1]: Finished System Suspend.
Jul 08 16:52:40 prayag-linux systemd[1]: systemd-suspend.service: Consumed 46.118s CPU time.
Jul 08 16:52:40 prayag-linux systemd[1]: Stopped target Sleep.
Jul 08 16:52:40 prayag-linux systemd[1]: Reached target Suspend.
Jul 08 16:52:40 prayag-linux systemd[1]: Stopped target Suspend.
Jul 08 16:52:40 prayag-linux systemd-logind[458]: Operation 'sleep' finished.
Jul 08 16:52:40 prayag-linux NetworkManager[500]: <info> [1657279360.7419] manager: sleep: wake requested (sleeping: yes enabled: yes)
Jul 08 16:52:40 prayag-linux NetworkManager[500]: <info> [1657279360.7421] device (enp27s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 08 16:52:40 prayag-linux NetworkManager[500]: <info> [1657279360.9649] device (wlp21s0f0u2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 08 16:52:40 prayag-linux NetworkManager[500]: <info> [1657279360.9668] device (p2p-dev-wlp21s0f0u2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 08 16:52:40 prayag-linux kernel: r8169 0000:1b:00.0 enp27s0: Link is Down
Jul 08 16:52:40 prayag-linux NetworkManager[500]: <info> [1657279360.9676] manager: NetworkManager state is now DISCONNECTED
Jul 08 16:52:41 prayag-linux NetworkManager[500]: <info> [1657279361.0080] device (wlp21s0f0u2): supplicant interface state: internal-starting -> disconnected
Jul 08 16:52:41 prayag-linux NetworkManager[500]: <info> [1657279361.0081] device (p2p-dev-wlp21s0f0u2): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Jul 08 16:52:41 prayag-linux NetworkManager[500]: <info> [1657279361.0085] Wi-Fi P2P device controlled by interface wlp21s0f0u2 created
Jul 08 16:52:41 prayag-linux NetworkManager[500]: <info> [1657279361.0088] manager: (p2p-dev-wlp21s0f0u2): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/9)
Jul 08 16:52:41 prayag-linux NetworkManager[500]: <info> [1657279361.0091] device (p2p-dev-wlp21s0f0u2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 08 16:52:41 prayag-linux NetworkManager[500]: <info> [1657279361.0095] device (wlp21s0f0u2): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jul 08 16:52:41 prayag-linux NetworkManager[500]: <info> [1657279361.0102] device (p2p-dev-wlp21s0f0u2): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 08 16:52:42 prayag-linux rtkit-daemon[860]: Supervising 0 threads of 0 processes of 0 users.
Jul 08 16:52:43 prayag-linux ModemManager[521]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:15:00.0/usb1/1-2': not supported by any plugin
Jul 08 16:52:43 prayag-linux ModemManager[521]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:15:00.2/0000:16:04.0/0000:1b:00.0': not supported by any plugin
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4459] policy: auto-activating connection 'Bharat Jain_5GHz' (b03a4758-7f4f-443d-932f-9a5373ddec45)
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4466] device (wlp21s0f0u2): Activation: starting connection 'Bharat Jain_5GHz' (b03a4758-7f4f-443d-932f-9a5373ddec45)
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4467] device (wlp21s0f0u2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4471] manager: NetworkManager state is now CONNECTING
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4476] device (wlp21s0f0u2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4479] device (wlp21s0f0u2): Activation: (wifi) access point 'Bharat Jain_5GHz' has security, but secrets are required.
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4479] device (wlp21s0f0u2): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4776] device (wlp21s0f0u2): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4781] device (wlp21s0f0u2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4786] device (wlp21s0f0u2): Activation: (wifi) connection 'Bharat Jain_5GHz' has security, and secrets exist. No new secrets needed.
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4787] Config: added 'ssid' value 'Bharat Jain_5GHz'
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4787] Config: added 'scan_ssid' value '1'
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4787] Config: added 'bgscan' value 'simple:30:-70:86400'
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4787] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4788] Config: added 'auth_alg' value 'OPEN'
Jul 08 16:52:47 prayag-linux NetworkManager[500]: <info> [1657279367.4788] Config: added 'psk' value '<hidden>'
Jul 08 16:52:47 prayag-linux DiscoverNotifier[829]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
Jul 08 16:52:47 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: Trying to associate with 24:0b:88:53:97:fd (SSID='Bharat Jain_5GHz' freq=5240 MHz)
Jul 08 16:52:49 prayag-linux dbus-daemon[453]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.634' (uid=1000 pid=171312 comm="kcheckpass -m classic -S 42")
Jul 08 16:52:49 prayag-linux dbus-daemon[453]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jul 08 16:52:49 prayag-linux kcheckpass[171312]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jul 08 16:52:49 prayag-linux audit[171314]: USER_AUTH pid=171314 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="prayag" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:49 prayag-linux kernel: audit: type=1100 audit(1657279369.307:242): pid=171314 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="prayag" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Jul 08 16:52:49 prayag-linux kwin_x11[783]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45789, resource id: 85983286, major code: 18 (ChangeProperty), minor code: 0
Jul 08 16:52:56 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-STARTED-CHANNEL-SWITCH freq=5240 ht_enabled=1 ch_offset=-1 ch_width=80 MHz cf1=5210 cf2=0
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.0678] device (wlp21s0f0u2): supplicant interface state: disconnected -> associating
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.0678] device (p2p-dev-wlp21s0f0u2): supplicant management interface state: disconnected -> associating
Jul 08 16:52:56 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: Associated with 24:0b:88:53:97:fd
Jul 08 16:52:56 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Jul 08 16:52:56 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=IN
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.5993] device (wlp21s0f0u2): supplicant interface state: associating -> associated
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.5994] device (p2p-dev-wlp21s0f0u2): supplicant management interface state: associating -> associated
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.7059] device (wlp21s0f0u2): supplicant interface state: associated -> 4way_handshake
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.7060] device (p2p-dev-wlp21s0f0u2): supplicant management interface state: associated -> 4way_handshake
Jul 08 16:52:56 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: WPA: Key negotiation completed with 24:0b:88:53:97:fd [PTK=CCMP GTK=TKIP]
Jul 08 16:52:56 prayag-linux wpa_supplicant[1086]: wlp21s0f0u2: CTRL-EVENT-CONNECTED - Connection to 24:0b:88:53:97:fd completed [id=0 id_str=]
Jul 08 16:52:56 prayag-linux wpa_supplicant[1086]: bgscan simple: Failed to enable signal strength monitoring
Jul 08 16:52:56 prayag-linux kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp21s0f0u2: link becomes ready
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.7260] device (wlp21s0f0u2): supplicant interface state: 4way_handshake -> completed
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.7261] device (wlp21s0f0u2): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Bharat Jain_5GHz"
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.7261] device (p2p-dev-wlp21s0f0u2): supplicant management interface state: 4way_handshake -> completed
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.7264] device (wlp21s0f0u2): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jul 08 16:52:56 prayag-linux NetworkManager[500]: <info> [1657279376.7273] dhcp4 (wlp21s0f0u2): activation: beginning transaction (timeout in 45 seconds)
Jul 08 16:52:56 prayag-linux avahi-daemon[451]: Joining mDNS multicast group on interface wlp21s0f0u2.IPv6 with address fe80::1685:a568:989e:92dc.
Jul 08 16:52:56 prayag-linux avahi-daemon[451]: New relevant interface wlp21s0f0u2.IPv6 for mDNS.
Jul 08 16:52:56 prayag-linux avahi-daemon[451]: Registering new address record for fe80::1685:a568:989e:92dc on wlp21s0f0u2.*.
Jul 08 16:52:56 prayag-linux kwin_x11[783]: org.kde.bismuth: Client added: KWin::X11Client(0x558a34933500)
Jul 08 16:52:56 prayag-linux kwin_x11[783]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 08 16:52:56 prayag-linux kwin_x11[783]: org.kde.bismuth: arrange
Jul 08 16:52:56 prayag-linux kwin_x11[783]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 08 16:52:56 prayag-linux kwin_x11[783]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x558a34933500)
^C
inxi -Fazy
Kernel: 5.10.126-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=6be5b829-c1db-43a8-815e-2790aa3c8703 rw quiet apparmor=1
security=apparmor resume=UUID=74203097-8395-4852-9908-cab854f5b2ab
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: MSI model: A320M GAMING PRO (MS-7A39) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.D0
date: 04/27/2018
Info: model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen built: 2017-19 process: GF 14nm family: 0x17 (23)
model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1471 high: 1546 min/max: 1600/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1470 2: 1419
3: 1424 4: 1421 5: 1546 6: 1537 7: 1532 8: 1422 bogomips: 57622
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN 5 process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1,HDMI-A-2 bus-ID: 38:00.0
chip-ID: 1002:15dd class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung SyncMaster
serial: <filter> built: 2009 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes:
max: 1600x900 min: 720x400
OpenGL: renderer: AMD Radeon Vega 11 Graphics (raven LLVM 13.0.1 DRM 3.40
5.10.126-1-MANJARO)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 38:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 38:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.126-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.52 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: down mac: <filter>
Device-2: TP-Link Archer T2U PLUS [RTL8821AU] type: USB driver: rtl8821au
bus-ID: 1-2:2 chip-ID: 2357:0120 class-ID: 0000 serial: <filter>
IF: wlp21s0f0u2 state: up mac: <filter>
Local Storage: total: 1.59 TiB used: 493.11 GiB (30.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT250P2SSD8
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P2CR048 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC34 scheme: MBR
ID-1: / raw-size: 115.88 GiB size: 113.5 GiB (97.95%)
used: 27.69 GiB (24.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 25.6 MiB (2.5%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 100 GiB size: 97.87 GiB (97.87%)
used: 28.49 GiB (29.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 16 GiB used: 47.9 MiB (0.3%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 45.9 C mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 292 Uptime: 7h 52m wakeups: 4 Memory: 6.79 GiB
used: 4.54 GiB (66.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1526
pacman: 1521 lib: 417 flatpak: 5 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.19
