I just downloaded manjaro KDE. I opened up pamac(add or remove software) and did a system update. Now when grub shows up(It works fine) and when i select manjaro i just see the asus logo screen and it stays like that forever.
I found a workaround to make it boot by pressing ctrl+alt+f5(to bring up terminal) and pressing ctrl+alt+f5 again to bring up the login screen
My laptop is ASUS Vivobook Gaming with core i5 8th gen and an NVIDIA GTX 1650 graphics card.
What could be the issue and how can i solve it?
Things i tried:
- Use 5.4 LTS version of kernel
- using the following commands on terminal
sudo pacman -Syyu haveged
sudo systemctl enable haveged --now
This are the current versions of stuff i have installed
KDE Plasma Version: 5.21.3
KDE Frameworks Version: 5.80.0
Qt Version: 5.15.2
Kernel Version: 5.9.16-1-MANJARO
OS Type: 64-bit
Processors: 8 × Intel® Core™ i5-8300H CPU @ 2.30GHz
Memory: 7.6 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics 630```
inxi:
Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=cfc0e054-46a1-4063-802e-d9fc201915a2 ro apparmor=1
security=apparmor udev.log_priority=3k
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GT_F571GT
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X571GT v: 1.0 serial: <filter>
UEFI: American Megatrends v: X571GT.306 date: 05/08/2020
ID-1: BAT1 charge: 26.0 Wh (63.6%) condition: 40.9/42.3 Wh (96.5%)
volts: 3.6 min: 11.6 model: ASUS A32-K55 type: Li-ion serial: N/A
status: Discharging
RAM: total: 7.63 GiB used: 2.15 GiB (28.1%)
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE cache: L2: 8 MiB bogomips: 36812
Speed: 900 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 901 5: 902 6: 900 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:4 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Message: No LVM data was found.
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
Local Storage: total: 476.94 GiB used: 21.05 GiB (4.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 rotation: SSD serial: <filter> rev: 002C scheme: GPT
ID-1: / raw-size: 97.87 GiB size: 95.83 GiB (97.92%) used: 21.03 GiB (21.9%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: cfc0e054-46a1-4063-802e-d9fc201915a2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 25.4 MiB (9.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 6222-BB7A
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 378.16 GiB fs: ntfs label: OS
uuid: B8E2249CE224613C
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 650 MiB fs: ntfs label: RECOVERY
uuid: 44F4BB72F4BB64B8
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:2 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4c5e class-ID: 0301
Device-2: 1-4:6 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-3: 1-6:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-4: 1-7:4 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-5: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 255 Uptime: 3m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: N/A Packages: 1234 pacman: 1233 lib: 376 flatpak: 1
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
journal-ctl:
ar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_TZ.ETMD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 27 16:54:50 themachine kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GPLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GUPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TUPC], AE_ALREADY_EXISTS (20200717/dswload2-326)
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20200717/dswload>
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20200717/dswload>
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20200717/dswload>
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20200717/dswload>
Mar 27 16:54:50 themachine kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20200717/dswload>
and several more entries along the same line
