system info:
System: Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <filter> UEFI: American Megatrends LLC. v: G713QM.311 date: 06/27/2021
Battery: ID-1: BAT0 charge: 55.0 Wh (60.0%) condition: 91.6/90.0 Wh (101.8%) volts: 15.8 min: 15.9 model: AS3GWAF3KC GA50358
type: Li-ion serial: <filter> status: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Memory: RAM: total: 15.06 GiB used: 3.7 GiB (24.6%)
CPU: Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 rev: 0 cache:
L2: 4 MiB bogomips: 102241
Speed: 1197 MHz min/max: 1200/4462 MHz boost: enabled Core speeds (MHz): 1: 1197 2: 1197 3: 1197 4: 1197 5: 1197
6: 1197 7: 1198 8: 1197 9: 1197 10: 1198 11: 1198 12: 1197 13: 1197 14: 1197 15: 1197 16: 1197
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp
rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Graphics: Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 470.57.02
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia
resolution: 1920x1200~60Hz s-dpi: 96
OpenGL: renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 05:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: JMTek LLC. USB PnP Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.2.4:7
chip-ID: 0c76:1620 class-ID: 0300
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 8086:2723
class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 5.89 TiB used: 1.48 TiB (25.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM512GD3JX013N size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 41000C20 temp: 31.9 C scheme: GPT
ID-2: /dev/sda type: USB vendor: Western Digital model: WDS480G2G0A-00JH30 size: 447.14 GiB type: SSD
serial: <filter> scheme: GPT
ID-3: /dev/sdb type: USB vendor: Western Digital model: WD My Passport 2627 size: 3.64 TiB type: N/A
serial: <filter> rev: 4008 scheme: GPT
ID-4: /dev/sdc type: USB vendor: Western Digital model: WDS480G2G0A-00JH30 size: 447.13 GiB type: SSD
ID-5: /dev/sdd type: USB vendor: Lenovo model: USB Hard Drive size: 931.51 GiB type: N/A serial: <filter> rev: 3U
scheme: GPT
Partition: ID-1: / size: 422.37 GiB used: 36.84 GiB (8.7%) fs: ext4 dev: /dev/sdc2 label: N/A
uuid: 581c79c3-b5ca-4ee2-9d67-c226c64d502f
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/sdc1 label: NO_LABEL uuid: 75B0-09E2
ID-3: /media/aurora/fastmedia size: 447.14 GiB used: 371.61 GiB (83.1%) fs: ntfs dev: /dev/sda1 label: fastDATA_1
uuid: 42D6C57FD6C57427
ID-4: /media/aurora/media size: 3.64 TiB used: 1.03 TiB (28.3%) fs: ntfs dev: /dev/sdb1 label: Data4TB
uuid: 3CBAA0BDBAA07554
ID-5: /run/media/aurora/f8be4f07-2be3-446f-be1d-0ba2be4b50f8 size: 915.81 GiB used: 52.06 GiB (5.7%) fs: ext4
dev: /dev/sdd1 label: N/A uuid: f8be4f07-2be3-446f-be1d-0ba2be4b50f8
Swap: ID-1: swap-1 type: partition size: 16.64 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdc3 label: N/A
uuid: ae036e38-c2e4-4d71-ac66-4cfc9e1b4d52
Unmounted: ID-1: /dev/nvme0n1p1 size: 260 MiB fs: vfat label: SYSTEM uuid: C839-BD33
ID-2: /dev/nvme0n1p2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 size: 456.24 GiB fs: bitlocker label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 size: 750 MiB fs: ntfs label: RECOVERY uuid: FCE20CA0E20C616E
ID-5: /dev/nvme0n1p5 size: 19.5 GiB fs: ntfs label: RESTORE uuid: C8D2C855D2C84A00
ID-6: /dev/nvme0n1p6 size: 200 MiB fs: vfat label: MYASUS uuid: F0C8-80F8
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-3:2 info: ASUSTek N-KEY Device type: Keyboard driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:1866 class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s power: 100mA chip-ID: 05e3:0610
Hub-5: 3-1.2:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-1.2.1:5 info: SINO WEALTH Gaming KB type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 258a:002a class-ID: 0300
Device-2: 3-1.2.2:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 3-1.2.4:7 info: JMTek LLC. USB PnP Audio Device type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid
interfaces: 4 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0c76:1620 class-ID: 0300
Device-4: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-7: 4-1:3 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s chip-ID: 05e3:0612 class-ID: 0900
Device-1: 4-1.1:4 info: Lenovo Portable HDD type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 17ef:455a class-ID: 0806 serial: <filter>
Device-2: 4-1.3:5 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E SATA 6Gb/s bridge ASM1153 SATA 3Gb/s bridge
ASM1153E SATA 6Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s chip-ID: 174c:55aa class-ID: 0806
serial: <filter>
Device-3: 4-1.4:6 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E SATA 6Gb/s bridge ASM1153 SATA 3Gb/s bridge
serial: <filter>
Device-4: 4-2:2 info: Western Digital My Passport 2627 type: Mass Storage driver: usb-storage interfaces: 1
rev: 3.1 speed: 5 Gb/s power: 896mA chip-ID: 1058:2627 class-ID: 0806 serial: <filter>
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
GPU: device: nvidia screen: :0.0 temp: 53 C device: amdgpu temp: 53.0 C
Info: Processes: 393 Uptime: 2h 53m wakeups: 11 Init: systemd v: 248 Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1
Packages: pacman: 1450 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
Hey,
1 Overview:
I got myself a new laptop, an Asus ROG strix G17, around 2 weeks ago. Since then, I have been trying to get manjaro working on it. I have managed to get optimus-manager
working, installed the asusctl
and many asus specific features up and running, like limiting battery charge, controlling keyboard LEDs etc.
2 Problem:
The only problem I have is that the system performs slow when I do specific tasks like watching youtube and twitch, navigating discord, there is a noticeable delay between sending a pic in discord and the confirmation screen showing up etc. Games take a long time to boot, one of them didn???t even work (dirt rally). My main goal is to reduce/eliminate this sluggish system, games aren’t a priority.
3 Things I have tried:
3.1 Downgrading kernel to 5.12, 5.10
5.12 didn’t do anything, and with 5.10, the built-in keyboard of the laptop was not working properly, as reported by phoronix in their review of strix G15 advantage edition.
I cannot go below kernel 5.9, as this is required for the limiting battery charge on asus laptops. Should I try 5.9?
3.2 Modifying kwin.sh
There was a similar post like mine, with the solution being to add the following lines in /etc/profile.d/kwin.sh:
xport KWIN_COMPOSE=O2ES
export KWIN_TRIPLE_BUFFER=1
It didn’t solve anything but made the system worse.
3.3 Running the system in different graphic modes.
I have tried all the possible drivers, and all the possible settings, like libre drivers, proprietary drivers, hybrid drivers, running system on integrated, hybrid, Nvidia graphics, and no luck.
I checked the graphics mode after switching with
optimus-manager --print-mode
Thank you for reading!
