You appear like a coder padawan and you are mistaken. You may think you have found the culprit - most likely you have not.
You - as developer - should know how easy it is to create code which can leave enormous amount of garbage in system memory. Such garbage is usually hung processes left running without the promise ever returning or processes indefinately looping consuming more and more memory until system is exhausted and no more swap is available.
So your finding is in reality a bandaid and does not solve the real issue your code is causing.
i do exactly the same stuff using terminator for days with hibernation and no freeze so far
i suspected konsole because when im only browsing web (not working) i have no issues
so i started using terminator to check and so far no freezes for days , with konsole it happens at pure random time and random cpu usage , it hangs between 1 and 3 times a day
im nodejs developer , thank you manjaro kde team for making my job easier
to clarify more, these random frezzes nearly made me crazy as it happens at pure random
i love manjaro kde
i dont remmeber exactly but i think i never had random freezes with windows with this pc . only manjaro kde is installed now on ssd nvme
i tried many kernels
i tried disable compositing
i tried disable timeshif or reduce the frequency of backups
i tried also manjaro gnome, i like it but i cant use it much because it doesnt 100% supports hibernation like kde, with gnome i had freezes but i cant tell the reason. but now with terminator i had no single freeze lead to pc totally crash . i experience some times plasma lags but the pc does not totally crash like with konsole
i did not remove konsole, i only unpin it from the panel and i dont use it
I really donât think konsole is your issue here.
Think about it - if there really was such issue with konsole - it would have been screamed out on a variety of forums including the apps source code repo.
From what you say the issue has been following you everywhere ⌠across kernels, across various system settings - you even tried reducing your snapshots?
Instead of looking at your code you are looking at the system?
While system regressions certainly happens - I really donât think a wildly used virtual console app like konsole is the cause of your intermittent freezes - it is more likely infinite looping deadlocks in your code.
With nodejs, angular every kind of javascript - even when you are using typescript - you are working with code which requires enormous amount of coding dicipline to avoid even the most elementary bugs.
I know - I have sometimes blamed systems - but to my own displease - I have always found it to be my code - so instead of gaffa taping your code - blaming the system - and using another terminal emulator - an emulator which is evidently better at handling deadlocks - you should implement logging and log everything until you pinpoint the issue.
To illustrate.
I have an issue bugging me at the moment - I have been blaming Firefox browser - until I stripped down my css and html and found the browser does it right - but for some reason - and only with Firefox - never chrome based browsers - my code fails to behave as expected when formatting the pages for printing.
I could blame the browser - but it is not there - it is my code somewhere - I just have to find it.
yes, i was confused because with terminator i have no issue for days with hibernation
but it happens yesterday with terminator. (with konsole it happens more frequent)
now i doubt that there is an issue with google-chrome or brave that spikes the cpu usage before total freeze and crash
some times it happens directly after receiving a notification in gogole-chrome
restarting my expressjs project sometimes spikes the cpu usage also
apps i used daily:
chrome: popular websites, nothing special, 5-30 tabs
brave: youtube + popular sites, 5-10 tabs
terminal app: angular project, expressjs project, rabbitmq with elasticsearch code , 3-5 tabs
thunderbird
vscode launched from terminal with code .
bluetooth speaker
elasticsearch and java
rabbitmq
mongodb
system disk 512gb ssd nvme m.2 EXT4
second disk hdd 1tb EXT4
24gb ram | 25.5gb swap with hibernation, no problem with hibernation
thank you, i read this solution once but i think that if creating a new user is a solution, plasma is not stable enough
i like gnome but i need 100% support of hibernation like kde plasma do
Not so long ago I was involved in a discussion on stability.
I donât think an efficient system exist - unless you build it ground up the Arch way.
If you choose any distribution you are presented with an initial layout defined by the philosophy driving the developers.
Stability has a different meaning dependinng on who you ask.
Plasma has never been stable for me - perhaps because I didnât knew enough.
A couple of months ago I started experimenting - adding kwin to lxqt.
The experiment went well - and I thought - let me try the plasma desktop and I added the necessary components - and that went well too.
The key to a somewhat stable system is to have just enough components to achieve your workflow as adding more increases complexity and with increased complexity comes a degree of instability as thereâs more components in play.
The amount of pressure you put on your desktop also adds a degree of instablility - especially with browsers - on a developer machine - if you are not very careful in coding your web apps - you can create a service worker which will crash your system without warning.
You mention several browsers with numerous tabs open - how many of them is running a worker service script in the background?
I see you changed the title of the topic - I am pleased I made you think - keep thinking.
In my experience - It is rarely the system itself that fails - but how it is used - perhaps strained - which makes it misbehave or crash.
after long hours googling âinput/output errorâ i think that the problem is related to power management because i remember i got freezes many times directly or a couple minutes after waking from idle ( screen off). waking from hibernation works for hours though
i loaded defaults values in bios, maybe i changed something and i forget about it
in archlinux formum, some user had random freezes issue and fixed it by replacing wireless card
RTL8192CE
i have
RTL8821CE
before kernel 5.0, i had to install
rtl8821ce-dkms-git
to be able to use wifi and bluetooth, but after 5.0 i dont have to install that package because wifi and bluetooth work after clean install of manjaro with kernel +5.0
do i have to install that package even wifi and bluetooth work without issues ?
