I have build a new system few days ago. Initially was running other os with kde plasma and wayland. System was unstable and will crash at the first 20 - 30 min after boot, even sometimes just after boot. This was happening never on idle, but when moving or doing something also the system load was less than 5% and all temps where normal. The crash was looking like hardware issue where display turns black for a second and comes on with strange colors and shapes. I thinking that it was only display issue as the music was still playing, anywayโฆ reboot was needed.
Decided to get rid of it, did some testing with live usbโs and it seems that the problem went away with them. So i installed Manjaro with Kde Plasma and X11. Everything runs smooth and great, no problems, the previous issues went away. Then at some point i experienced random logout and system was reset, was thinking that probably i hit something, but after feel hours it happened again and it started to happen much more often even 2-3 min after boot. Its kinda anoying, looked at the logs but could not find any error. Decided to try Wayland again and got crash in the first 5 min similar like the one explained above.
Cpu is Amd Ryzen 5 5600
Mobo Asrock B550m PG Riptide
gpu Gigabyte Aorus rx580 XTR 8gb (the only part that is second hand)
2 x 8 gb Kingston 3600mhz cl17 running at standart profile 2400mhz for now
The drivers for the gpu are the ones that came with the install. Not sure where to look for the problem
Posting the whole output of journalctl as i may miss something from the obvious errors:
journalctl -b-1 -p4 --no-pager
ัะตะฟ 23 10:11:25 acrofil-manjaro kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
ัะตะฟ 23 10:11:25 acrofil-manjaro kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
ัะตะฟ 23 10:11:25 acrofil-manjaro systemd-fstab-generator[265]: Failed to create unit file '/run/systemd/generator/swapfile.swap', as it already exists. Duplicate entry in '/etc/fstab'?
ัะตะฟ 23 10:11:25 acrofil-manjaro (sd-execu[258]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
ัะตะฟ 23 10:11:25 acrofil-manjaro systemd-vconsole-setup[288]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
ัะตะฟ 23 10:11:25 acrofil-manjaro systemd-vconsole-setup[288]: Fonts will not be copied to remaining consoles
ัะตะฟ 23 10:11:26 acrofil-manjaro systemd-vconsole-setup[404]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
ัะตะฟ 23 10:11:26 acrofil-manjaro systemd-vconsole-setup[404]: Fonts will not be copied to remaining consoles
ัะตะฟ 23 10:11:32 acrofil-manjaro kernel: sddm-greeter[606]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
ัะตะฟ 23 10:11:32 acrofil-manjaro sddm-greeter[606]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffcbc8eb9a0), parent's thread is QThread(0x55e59f244be0), current thread is QThread(0x55e59f3a4120)
ัะตะฟ 23 10:11:32 acrofil-manjaro sddm-greeter[606]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
ัะตะฟ 23 10:11:33 acrofil-manjaro sddm-greeter[606]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
ัะตะฟ 23 10:11:33 acrofil-manjaro sddm-greeter[606]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
ัะตะฟ 23 10:11:33 acrofil-manjaro sddm-greeter[606]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
ัะตะฟ 23 10:11:33 acrofil-manjaro sddm-greeter[606]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
ัะตะฟ 23 10:11:33 acrofil-manjaro sddm-greeter[606]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.17'
ัะตะฟ 23 10:11:33 acrofil-manjaro sddm-greeter[606]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.18'
ัะตะฟ 23 10:11:55 acrofil-manjaro ksplashqml[682]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
ัะตะฟ 23 10:11:55 acrofil-manjaro ksplashqml[682]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
ัะตะฟ 23 10:11:56 acrofil-manjaro ksmserver[747]: Qt: Session management error: networkIdsList argument is NULL
ัะตะฟ 23 10:11:56 acrofil-manjaro kwin_x11[750]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
ัะตะฟ 23 10:11:56 acrofil-manjaro kwin_x11[750]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
ัะตะฟ 23 10:11:56 acrofil-manjaro kded5[749]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
ัะตะฟ 23 10:11:56 acrofil-manjaro ksmserver[747]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
ัะตะฟ 23 10:11:56 acrofil-manjaro plasmashell[800]: Checking screens: available: (QScreen(0x5619f76bc4b0, name="DisplayPort-1")) redundant: QHash() fake: QSet() all: (QScreen(0x5619f76bc4b0, name="DisplayPort-1"))
ัะตะฟ 23 10:11:56 acrofil-manjaro plasmashell[800]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
ัะตะฟ 23 10:11:56 acrofil-manjaro plasmashell[800]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
ัะตะฟ 23 10:11:56 acrofil-manjaro backlighthelper[900]: org.kde.powerdevil: no kernel backlight interface found
ัะตะฟ 23 10:11:56 acrofil-manjaro ksystemstats[866]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Fan %1" msgid_plural: "" msgctxt: "@title %1 is a number"
ัะตะฟ 23 10:11:56 acrofil-manjaro org_kde_powerdevil[833]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
ัะตะฟ 23 10:11:56 acrofil-manjaro org_kde_powerdevil[833]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
ัะตะฟ 23 10:11:56 acrofil-manjaro org_kde_powerdevil[833]: org.kde.powerdevil: Handle button events action could not check for screen configuration
ัะตะฟ 23 10:11:56 acrofil-manjaro org_kde_powerdevil[833]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
ัะตะฟ 23 10:11:56 acrofil-manjaro kded5[749]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
ัะตะฟ 23 10:11:56 acrofil-manjaro kded5[749]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
ัะตะฟ 23 10:11:56 acrofil-manjaro plasmashell[800]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
ัะตะฟ 23 10:11:56 acrofil-manjaro kioslave5[1115]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
ัะตะฟ 23 10:11:57 acrofil-manjaro pulseaudio[1022]: stat('/etc/pulse/default.pa.d'): No such file or directory
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:22:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:94:13: Unable to assign [undefined] to int
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml:54:9: Unable to assign [undefined] to int
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:61:17: Unable to assign [undefined] to int
ัะตะฟ 23 10:11:57 acrofil-manjaro plasmashell[800]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_07_00.4.analog-stereo.monitor"
ัะตะฟ 23 10:11:58 acrofil-manjaro plasmashell[800]: qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
ัะตะฟ 23 10:11:58 acrofil-manjaro plasmashell[800]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/FullRepresentation.qml:23:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:11:58 acrofil-manjaro plasmashell[800]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml:54:9: Unable to assign [undefined] to int
ัะตะฟ 23 10:11:58 acrofil-manjaro plasmashell[800]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml:21:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:11:58 acrofil-manjaro plasmashell[800]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/applet/CompactApplet.qml:190:19: QML MouseEventListener: Binding loop detected for property "height"
ัะตะฟ 23 10:12:08 acrofil-manjaro kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=821, emitted seq=823
ัะตะฟ 23 10:12:08 acrofil-manjaro kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process kwin_x11 pid 750 thread kwin_x11:cs0 pid 773
ัะตะฟ 23 10:12:09 acrofil-manjaro kernel: amdgpu 0000:05:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_0.2.1.0 test failed (-110)
ัะตะฟ 23 10:12:09 acrofil-manjaro kernel: [drm:gfx_v8_0_hw_fini [amdgpu]] *ERROR* KCQ disable failed
ัะตะฟ 23 10:12:09 acrofil-manjaro kernel: amdgpu: cp is busy, skip halt cp
ัะตะฟ 23 10:12:09 acrofil-manjaro kernel: amdgpu: rlc is busy, skip halt rlc
ัะตะฟ 23 10:12:10 acrofil-manjaro kaccess[1000]: The X11 connection broke: I/O error (code 1)
ัะตะฟ 23 10:12:10 acrofil-manjaro kscreen_backend_launcher[1015]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro pamac-tray-plasma[1003]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro kded5[749]: The X11 connection broke: I/O error (code 1)
ัะตะฟ 23 10:12:10 acrofil-manjaro msm_kde_notifier[980]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro org_kde_powerdevil[833]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro kwalletd5[665]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro gmenudbusmenuproxy[831]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro ksmserver[747]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro kwin_x11[750]: kwin_scene_opengl: A graphics reset attributable to the current GL context occurred.
ัะตะฟ 23 10:12:10 acrofil-manjaro kglobalaccel5[790]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro kdeconnectd[982]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro xembedsniproxy[835]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro plasmashell[800]: The X11 connection broke: I/O error (code 1)
ัะตะฟ 23 10:12:10 acrofil-manjaro polkit-kde-authentication-agent-1[832]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-kscreen.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro xdg-desktop-portal-kde[834]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro kglobalaccel5[790]: The X11 connection broke: I/O error (code 1)
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro kactivitymanagerd[829]: The X11 connection broke (error 1). Did the X11 server die?
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro plasmashell[800]: QtDBus: cannot relay signals from parent QObject(0x5619f8b07660 "") unless they are emitted in the object's thread QThread(0x5619f75fcbd0 ""). Current thread is QSGRenderThread(0x5619f949e810 "").
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-kglobalaccel.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro pulseaudio[1022]: ICE I/O error handler called
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro plasmashell[800]: QBasicTimer::stop: Failed. Possibly trying to stop from a different thread
ัะตะฟ 23 10:12:10 acrofil-manjaro plasmashell[800]: QObject::~QObject: Timers cannot be stopped from another thread
ัะตะฟ 23 10:12:10 acrofil-manjaro plasmashell[800]: QSocketNotifier: Socket notifiers cannot be enabled or disabled from another thread
ัะตะฟ 23 10:12:10 acrofil-manjaro plasmashell[800]: QtDBus: cannot relay signals from parent QObject(0x5619f7c08f50 "") unless they are emitted in the object's thread QThread(0x5619f75fcbd0 ""). Current thread is QSGRenderThread(0x5619f949e810 "").
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-ksmserver.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro startplasma-x11[666]: org.kde.startup: "kdeinit5_shutdown" () exited with code 255
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-kded.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: plasma-powerdevil.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro systemd[651]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:10 acrofil-manjaro pulseaudio[1022]: X11 I/O error handler called
ัะตะฟ 23 10:12:10 acrofil-manjaro pulseaudio[1022]: X11 I/O error exit handler called, preparing to tear down X11 modules
ัะตะฟ 23 10:12:11 acrofil-manjaro kwin_x11[750]: kwin_scene_opengl: Waiting for glGetGraphicsResetStatus to return GL_NO_ERROR timed out!
ัะตะฟ 23 10:12:11 acrofil-manjaro kwin_x11[750]: The X11 connection broke: I/O error (code 1)
ัะตะฟ 23 10:12:11 acrofil-manjaro systemd[651]: plasma-kwin_x11.service: Failed with result 'exit-code'.
ัะตะฟ 23 10:12:11 acrofil-manjaro sddm-greeter[1387]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fff39d72740), parent's thread is QThread(0x5597bc920be0), current thread is QThread(0x5597bca7fe20)
ัะตะฟ 23 10:12:11 acrofil-manjaro sddm-greeter[1387]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
ัะตะฟ 23 10:12:11 acrofil-manjaro sddm-greeter[1387]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
ัะตะฟ 23 10:12:11 acrofil-manjaro sddm-greeter[1387]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
ัะตะฟ 23 10:12:11 acrofil-manjaro sddm-greeter[1387]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
ัะตะฟ 23 10:12:11 acrofil-manjaro sddm-greeter[1387]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
ัะตะฟ 23 10:12:16 acrofil-manjaro ksplashqml[1435]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
ัะตะฟ 23 10:12:16 acrofil-manjaro ksplashqml[1435]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
ัะตะฟ 23 10:12:16 acrofil-manjaro ksmserver[1496]: Qt: Session management error: networkIdsList argument is NULL
ัะตะฟ 23 10:12:16 acrofil-manjaro kded5[1498]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
ัะตะฟ 23 10:12:16 acrofil-manjaro kwin_x11[1499]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
ัะตะฟ 23 10:12:16 acrofil-manjaro kwin_x11[1499]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
ัะตะฟ 23 10:12:16 acrofil-manjaro ksmserver[1496]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.75'
ัะตะฟ 23 10:12:16 acrofil-manjaro plasmashell[1552]: Checking screens: available: (QScreen(0x56081ff534b0, name="DisplayPort-1")) redundant: QHash() fake: QSet() all: (QScreen(0x56081ff534b0, name="DisplayPort-1"))
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
ัะตะฟ 23 10:12:17 acrofil-manjaro ksystemstats[1609]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Fan %1" msgid_plural: "" msgctxt: "@title %1 is a number"
ัะตะฟ 23 10:12:17 acrofil-manjaro backlighthelper[1654]: org.kde.powerdevil: no kernel backlight interface found
ัะตะฟ 23 10:12:17 acrofil-manjaro org_kde_powerdevil[1581]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
ัะตะฟ 23 10:12:17 acrofil-manjaro org_kde_powerdevil[1581]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
ัะตะฟ 23 10:12:17 acrofil-manjaro kded5[1498]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.75'
ัะตะฟ 23 10:12:17 acrofil-manjaro kded5[1498]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
ัะตะฟ 23 10:12:17 acrofil-manjaro kded5[1498]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
ัะตะฟ 23 10:12:17 acrofil-manjaro org_kde_powerdevil[1581]: org.kde.powerdevil: Handle button events action could not check for screen configuration
ัะตะฟ 23 10:12:17 acrofil-manjaro org_kde_powerdevil[1581]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
ัะตะฟ 23 10:12:17 acrofil-manjaro kioslave5[1796]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:22:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:94:13: Unable to assign [undefined] to int
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml:54:9: Unable to assign [undefined] to int
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
ัะตะฟ 23 10:12:17 acrofil-manjaro plasmashell[1552]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
ัะตะฟ 23 10:12:17 acrofil-manjaro pulseaudio[1758]: stat('/etc/pulse/default.pa.d'): No such file or directory
ัะตะฟ 23 10:12:18 acrofil-manjaro plasmashell[1552]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
ัะตะฟ 23 10:12:18 acrofil-manjaro plasmashell[1552]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
ัะตะฟ 23 10:12:18 acrofil-manjaro plasmashell[1552]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:61:17: Unable to assign [undefined] to int
ัะตะฟ 23 10:12:18 acrofil-manjaro plasmashell[1552]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_07_00.4.analog-stereo.monitor"
ัะตะฟ 23 10:12:19 acrofil-manjaro plasmashell[1552]: qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
ัะตะฟ 23 10:12:19 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/FullRepresentation.qml:23:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:12:19 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.barchart/contents/ui/BarChart.qml:54:9: Unable to assign [undefined] to int
ัะตะฟ 23 10:12:19 acrofil-manjaro plasmashell[1552]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
ัะตะฟ 23 10:12:19 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/FullRepresentation.qml:22:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:12:19 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:94:13: Unable to assign [undefined] to int
ัะตะฟ 23 10:12:19 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
ัะตะฟ 23 10:12:20 acrofil-manjaro plasmashell[1552]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
ัะตะฟ 23 10:12:20 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml:21:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:12:20 acrofil-manjaro plasmashell[1552]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/applet/CompactApplet.qml:190:19: QML MouseEventListener: Binding loop detected for property "height"
ัะตะฟ 23 10:12:21 acrofil-manjaro plasmashell[1552]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
ัะตะฟ 23 10:12:21 acrofil-manjaro plasmashell[1552]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/FullRepresentation.qml:21:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
ัะตะฟ 23 10:12:21 acrofil-manjaro plasmashell[1552]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/applet/CompactApplet.qml:190:19: QML MouseEventListener: Binding loop detected for property "height"
ัะตะฟ 23 10:12:21 acrofil-manjaro pulseaudio[1758]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
ัะตะฟ 23 10:13:15 acrofil-manjaro nm-openvpn[22287]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
ัะตะฟ 23 10:13:17 acrofil-manjaro nm-openvpn[22287]: NOTE: setsockopt TCP_NODELAY=1 failed
ัะตะฟ 23 10:13:41 acrofil-manjaro kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=14592, emitted seq=14594
ัะตะฟ 23 10:13:41 acrofil-manjaro kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process kwin_x11 pid 1499 thread kwin_x11:cs0 pid 1524
ัะตะฟ 23 10:13:42 acrofil-manjaro kernel: amdgpu 0000:05:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_0.2.1.0 test failed (-110)
ัะตะฟ 23 10:13:42 acrofil-manjaro kernel: [drm:gfx_v8_0_hw_fini [amdgpu]] *ERROR* KCQ disable failed
errors in the log
Also after the reboot have not experience any logouts and i feel like they happen 1 or 2 times and then never happen again until i shut down and boot again.
there are some amdgpu issuesโฆ
create a new test user, reboot and log in with it, and see if it happens also with the test user, so that we can see if its a system wide thingโฆ
also how is the gpu connected to the mobo? via cable or directly plugged in?
if it happens again with the test user try with the 5.15 kernel and also with the 5.10โฆ
I will be off for a week, but yestarday tested with kernel 5.15 and was the same situation, will try going to 5.10 too.
The gpu is connected directly to the mobo pci slot, the power is delivered with 1 x 8 pin and 1 x 6 pin from the psu to the gpu.
I have read some where that people had success with that kind of problem/error when downclock abit the mhz of the gpu ram using CoreCtrl
Been testing with test user for two days and around 3 - 4 hours so far, have not experienced the same crashes again. Something to mentionโฆ when created and logged with the new user i decided to uninstall CoreCtrl so it may be related with the issue? I had CoreCtrl on previous installations too. Will continue monitoring it, will try switching to the old user to see if it happens again.
If the crashes return on both users i will go for older Kernels.
i misunderstood โฆ i thought you wanted to install itโฆ if i had knew you had it installed, i would recommended to remove it + its configs and testโฆ
4+ hours with no issue and just under 10 min 4 crashes/logouts. First crash was even before i had chance to enter my password at the login screen on fresh boot.
this is the last error from the log
ะพะบั 02 19:06:11 acrofil-manjaro kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=29497, emitted seq=29499
ะพะบั 02 19:06:11 acrofil-manjaro kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process kwin_x11 pid 1965 thread kwin_x11:cs0 pid 1993
ะพะบั 02 19:06:12 acrofil-manjaro kernel: amdgpu 0000:05:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_0.2.1.0 test failed (-110)
ะพะบั 02 19:06:12 acrofil-manjaro kernel: [drm:gfx_v8_0_hw_fini [amdgpu]] *ERROR* KCQ disable failed
ะพะบั 02 19:06:13 acrofil-manjaro org_kde_powerdevil[844]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
ะพะบั 02 19:06:13 acrofil-manjaro kwin_x11[758]: kwin_scene_opengl: A graphics reset not attributable to the current GL context occurred.
ะพะบั 02 19:06:13 acrofil-manjaro pamac-tray-plasma[1009]: The X11 connection broke (error 1). Did the X11 server die?
Installed Windows and pc was crashing with black screen and driver timeout error
Bought second used gpu from the rx 500 family. Instantly after installation of the gpu and booting up got screen with artifacts and crash like how it was crashing with Wayland. With this card i did.not get logout so i was forced to restart each time. Same errors, except this time i got few VCPU trying to reset or something and my screen was trying to recover but keep crashing.
Tried on windows to see if its only linux related, live usb. All the same
Older kernels
Gave the gpu to a friend for few days, nothing, no problems
Run many memtests over 24 hours, nothing
Bought new ram kit anyway. Crashed on second day.
I could not go without crash for a long consecutive days in row. Longest was 3 days without powering off, but.pc was used actively for 2 - 4 hours a day and crashed on day 3. Most of the time pc will crash few hours after boot or very rare the next day.
Here i already suspect mobo or cpu to be faulty.
So i bought another gpuโฆ this time nvidia that doesnโt need power connection. Did fresh reinstall with proprietary drivers as i wanted to be perfect environment for the testing and did not had so much data to backup anyway.
5 days in a row since install and over 24 hours of active uptime and over 10 boots its error free and 0 problems like previous ones. Only thing that was suspicious at first was on day 1 when i was setting my desktop something happened and my panel was removed just after i had it setup to my liking, but no errors in the log. And also some times i feel little lag but i think this could be from the weak gpu (from 2014) and my resolution is 1920 x 1200.
So mobo and cpu should be fine then. Still cant understand why amd gpus where so problematic.
What i have not done is mobo bios update. But my bios is from the end of 2022 and those amd gpus are from 2017 so i dont see how this could be bios related.
I doubt that i have bought 2 dead gpus and also they where working perfect under stress tests and benchmarks also gaming. No issues at all, low temps everything was fine. Pc was.crashing with non intensive tasks or even just after boot up on simple mouse move or button click.
I wanted to go with amd gpu becouse of free drivers and better linux support, but now i will have to go with nvidia.
that was some nice testingโฆ
if the amdgpu was working fine on your friends pc, the gpu was not faultyโฆ something in your pc doesnt sit well with amd and linuxโฆ
but at least you have a working system now
Yes, something in my amd system doesnโt want to work properly with amd gpus or at least the rx 500 family. At least iam relieved that its not mobo or cpu issue as they are new and would be sad if they where faulty + the process of rma, waiting etc.
Iam about to receive another nvidia gpu but more powerfull and few years newer that requires power connections so will test if its psu to gpu issue (i doubt but still)
How should i perform the switch? After i switch them and boot up just reinstall drivers? Iam using video-nvidia
Just go for BIOS update if you want to test the amd gpu:s again. I had to wait 1 year after buying my new computer to have linux not randomly wait during boot for some SATA thing to time out before the boot continued. It was just a normal BIOS update with nothing relevant mentioned as being fixed.
I want to try amd again but not any time soon. And feels to risky to buy expensive card (i mean new or newer than rx580) only to find out that i have same issues. It kinda sucks. I got Evga gtx 1070ti ftw and just installed it hopefully no problems. I plan on keeping that card at least a year or even more.
brahma, thank you for your time and support with my issue.
