When installing manjaro, is it necessary to have an internet connection via Ethernet? I have a laptop and normally use wireless WiFi, to know if it is necessary to have Ethernet connected
It’s not necessary to have an internet connection to be able to install Manjaro (or most Linux distros) from the USB installer.
Everything that’s needed for a complete installation is on the ISO / USB.
Wifi should be okay to let you run updates after the initial installation.
