I am new to linux and have installed Manjaro 20 on a Dell laptop, and a main desktop PC rig (dual booting atm).
One thing I have noticed is when using the Desktop Shortcut key (Super + D), the opened windows get minimised and fly towards the 4 corners of the screen however the animation leaves a ghosted image on the corners of the screen. This happens on both laptop and main PC. The laptop was built about a year ago. PC built today. Ensure all updates/drivers are updated. Other than that Manjaro has been looking neat!
I’m unable to similar issues in any forums/wiki. Appreciate the help. Thanks.
Apologies if i’ve not followed any etiquette.
*sorry unable to embed screenshot or an imgur hyperlink. sorry if my explanation is bad and not descriptive.
Then scroll down in the right-hand pane until you see the section labeled “Show Desktop Animation”. The effect is called “Window Aperture”. You can disable it there.
Thank you both for the prompt replies. Unfortunate that is the normal behaviour. I found out at least for me if I toggle between to screen only the back to extended screen display, the ghost effect is gone.
In anycase, I have disabled it and my OCD is no longer triggered
Thanks all!
