On my laptop (framework laptop, core I7 Tiger Lake) manjaro KDE appears to get confused and thinks it shouldn’t display anything on the laptop screen. This can be fixed by connecting to an external display, which often immediately solves the issue, and if it does not, it can be fixed by changing display configuration. Does anyone know the reason this happens and how I can prevent it in the future? Thank you so much.
output from:
inxi -Fazy
mhwd -l && mhwd -li
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ee39e3d2-dac7-4989-823e-9c97d4169fb8 rw quiet apparmor=1
security=apparmor resume=UUID=fcdf48f2-bf41-4a6e-9af9-a489f71c3856
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Framework product: Laptop v: AC
serial: <superuser required>
Mobo: Framework model: FRANBMCP0C v: AC serial: <superuser required>
UEFI: INSYDE v: 03.06 date: 10/18/2021
ID-1: BAT1 charge: 51.1 Wh (100.0%) condition: 51.1/55.0 Wh (92.9%)
volts: 16.9 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: discharging
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 951 high: 1119 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 981 2: 1040 3: 620
4: 1079 5: 998 6: 1119 7: 678 8: 1096 bogomips: 47936
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Realtek Laptop Camera type: USB driver: uvcvideo bus-ID: 3-7:2
chip-ID: 0bda:5634 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: intel gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2256x1504 s-dpi: 168 s-size: 341x227mm (13.43x8.94")
s-diag: 410mm (16.13")
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x095f built: 2019
res: 2256x1504 hz: 60 dpi: 205 gamma: 1.2 size: 280x190mm (11.02x7.48")
diag: 343mm (13.5") ratio: 3:2 modes: 2256x1504
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp170s0 state: up mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:4 chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 3.73 TiB used: 949.06 GiB (24.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 3.73 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFM13.4 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 2.7 TiB size: 2.66 TiB (98.39%) used: 949.06 GiB (34.8%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 69.88 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 296 Uptime: 1m wakeups: 149 Memory: 62.6 GiB used: 3.3 GiB (5.3%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.0 alt: 11 clang: 13.0.1 Packages: 2376 apt: 0 pacman: 2361
lib: 532 flatpak: 6 snap: 9 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
> 0000:00:02.0 (0300:8086:9a49) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
output from this also:
find /etc/X11/ -name "*.conf"
journalctl -b0 -p4 --no-pager
find /etc/X11/ -name "*.conf" ✔
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf
Jul 13 00:02:21 The-Turing-Machine-X kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Jul 13 00:02:21 The-Turing-Machine-X kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jul 13 00:02:21 The-Turing-Machine-X kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Jul 13 00:02:21 The-Turing-Machine-X kernel: pci 0000:00:07.1: DPC: RP PIO log size 0 is invalid
Jul 13 00:02:21 The-Turing-Machine-X kernel: pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
Jul 13 00:02:21 The-Turing-Machine-X kernel: pci 0000:00:07.3: DPC: RP PIO log size 0 is invalid
Jul 13 00:02:21 The-Turing-Machine-X kernel: pnp 00:02: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 13 00:02:21 The-Turing-Machine-X kernel: nvme nvme0: missing or invalid SUBNQN field.
Jul 13 00:02:21 The-Turing-Machine-X kernel: i8042: Warning: Keylock active
Jul 13 00:02:21 The-Turing-Machine-X kernel: usb: port power management may be unreliable
Jul 13 00:02:21 The-Turing-Machine-X kernel: vboxdrv: loading out-of-tree module taints kernel.
Jul 13 00:02:21 The-Turing-Machine-X kernel: VBoxNetAdp: Successfully started.
Jul 13 00:02:21 The-Turing-Machine-X kernel: VBoxNetFlt: Successfully started.
Jul 13 00:02:21 The-Turing-Machine-X systemd-modules-load[269]: Failed to find module 'ashmem_linux'
Jul 13 00:02:21 The-Turing-Machine-X systemd-modules-load[269]: Failed to find module 'binder_linux'
Jul 13 00:02:21 The-Turing-Machine-X systemd-modules-load[269]: Failed to find module 'nvidia-uvm'
Jul 13 00:02:21 The-Turing-Machine-X systemd-udevd[292]: /usr/lib/udev/rules.d/39-libtvcontrol.rules:4 Unknown group 'plugdev', ignoring
Jul 13 00:02:21 The-Turing-Machine-X systemd-udevd[292]: /usr/lib/udev/rules.d/39-libtvcontrol.rules:4 Invalid value "/bin/sh -c 'for I in /sys/bus/usb/drivers/cytherm/$kernel*; do echo `basename $I` > /sys/bus/usb/drivers/cytherm/unbind ; done'" for RUN (char 79: invalid substitution type), ignoring.
Jul 13 00:02:21 The-Turing-Machine-X systemd-udevd[292]: /usr/lib/udev/rules.d/99-anbox.rules:1 Ignoring NAME="%k", as it will take no effect.
Jul 13 00:02:21 The-Turing-Machine-X systemd-udevd[292]: /usr/lib/udev/rules.d/99-anbox.rules:2 Ignoring NAME="%k", as it will take no effect.
Jul 13 00:02:21 The-Turing-Machine-X systemd-modules-load[269]: Failed to find module 'tuxedo_io'
Jul 13 00:02:21 The-Turing-Machine-X systemd-modules-load[269]: Failed to find module 'tuxedo_keyboard'
Jul 13 00:02:21 The-Turing-Machine-X kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 13 00:02:22 The-Turing-Machine-X kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:02 [mem 0xfedc0000-0xfedc7fff]
Jul 13 00:02:22 The-Turing-Machine-X kernel: caller tgl_uncore_imc_freerunning_init_box+0xba/0x110 [intel_uncore] mapping multiple BARs
Jul 13 00:02:22 The-Turing-Machine-X kernel: iwlwifi 0000:aa:00.0: api flags index 2 larger than supported by driver
Jul 13 00:02:22 The-Turing-Machine-X kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.090723, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: reopen_one_log: Unable to open new log file '/usr/local/samba/var/log.smbd': No such file or directory
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.090762, 0] ../../source3/smbd/server.c:1741(main)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: smbd version 4.16.2 started.
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.093535, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.093636, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.093890, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.093961, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.093977, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[735]: [2022/07/13 00:02:23.094018, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[857]: [2022/07/13 00:02:23.104962, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:23 The-Turing-Machine-X smbd[857]: reopen_one_log: Unable to open new log file '/usr/local/samba/var/log.smbd': No such file or directory
Jul 13 00:02:23 The-Turing-Machine-X smbd[857]: [2022/07/13 00:02:23.105479, 0] ../../lib/util/debug.c:1224(reopen_one_log)
Jul 13 00:02:24 The-Turing-Machine-X sddm-greeter[1019]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fffb8a1edd0), parent's thread is QThread(0x55699a01d1c0), current thread is QThread(0x55699a1362b0)
Jul 13 00:02:24 The-Turing-Machine-X sddm-greeter[1019]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jul 13 00:02:24 The-Turing-Machine-X kernel: kauditd_printk_skb: 290 callbacks suppressed
Jul 13 00:02:25 The-Turing-Machine-X sddm-greeter[1019]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze/actions/24/edit-copy.svg: Unsupported image format
Jul 13 00:02:25 The-Turing-Machine-X sddm-greeter[1019]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jul 13 00:02:25 The-Turing-Machine-X sddm-greeter[1019]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jul 13 00:02:25 The-Turing-Machine-X sddm-greeter[1019]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jul 13 00:02:26 The-Turing-Machine-X sddm-greeter[1019]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.29'
Jul 13 00:02:31 The-Turing-Machine-X kernel: kauditd_printk_skb: 27 callbacks suppressed
Jul 13 00:02:31 The-Turing-Machine-X ksplashqml[1604]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Jul 13 00:02:31 The-Turing-Machine-X ksplashqml[1604]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Jul 13 00:02:31 The-Turing-Machine-X klauncher[1636]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jul 13 00:02:32 The-Turing-Machine-X kcminit_startup[1640]: QDBusConnection: error: could not send signal to service "" path "//home/sarankdirector/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/sarankdirector/.kde4/share/config/kdeglobals
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jul 13 00:02:32 The-Turing-Machine-X ksmserver[1688]: Qt: Session management error: networkIdsList argument is NULL
Jul 13 00:02:32 The-Turing-Machine-X kded5[1647]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
Jul 13 00:02:32 The-Turing-Machine-X plasmashell[1700]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jul 13 00:02:32 The-Turing-Machine-X plasmashell[1700]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jul 13 00:02:32 The-Turing-Machine-X org_kde_powerdevil[1704]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jul 13 00:02:32 The-Turing-Machine-X kded5[1647]: kscreen.kded: PowerDevil SuspendSession action not available!
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kf.config.core: "\"restore3\" - conversion of \"0,561,0,1443\" to QRect failed"
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kf.config.core: "\"fsrestore4\" - conversion of \"0,0,0,0\" to QRect failed"
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: kwin_core: XCB error: 10 (BadAccess), sequence: 827, resource id: 1313, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 913, resource id: 20971527, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 917, resource id: 20971528, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 974, resource id: 20971529, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 978, resource id: 20971530, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:32 The-Turing-Machine-X org_kde_powerdevil[1704]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jul 13 00:02:32 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1113, resource id: 62914565, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:33 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1368, resource id: 14680152, major code: 3 (GetWindowAttributes), minor code: 0
Jul 13 00:02:33 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1369, resource id: 14680152, major code: 14 (GetGeometry), minor code: 0
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jul 13 00:02:33 The-Turing-Machine-X gnome-keyring-daemon[2002]: discover_other_daemon: 1
Jul 13 00:02:33 The-Turing-Machine-X pulseaudio[1729]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jul 13 00:02:33 The-Turing-Machine-X bluetoothd[1078]: Failed to set mode: Blocked through rfkill (0x12)
Jul 13 00:02:33 The-Turing-Machine-X kded5[1647]: kf.bluezqt: PendingCall Error: "Blocked through rfkill"
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: Entry is not valid "kontact.desktop" QSharedPointer(0x5579bd8f8d90)
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5579bd8f8f80)
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5579bd8fc230)
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: Entry is not valid "kontact.desktop" QSharedPointer(0x5579bd8fc4d0)
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5579bd8fc230)
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x5579bd877b80)
Jul 13 00:02:33 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:22:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:94:13: Unable to assign [undefined] to int
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/HiddenItemsView.qml:32:5: QML GridView: Binding loop detected for property "cellWidth"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5579be034370) QQmlContext(0x5579be0b18c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 13 00:02:34 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2642, resource id: 4194357, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jul 13 00:02:34 The-Turing-Machine-X kwin_x11[1650]: kwin_core: XCB error: 152 (BadDamage), sequence: 2644, resource id: 14680107, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5579be310f30) QQmlContext(0x5579be0b18c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 13 00:02:34 The-Turing-Machine-X plasmashell[1700]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jul 13 00:02:35 The-Turing-Machine-X plasmashell[1700]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jul 13 00:02:35 The-Turing-Machine-X plasmashell[1700]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jul 13 00:02:36 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4662, resource id: 37748908, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:36 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4667, resource id: 37748909, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:02:36 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Jul 13 00:02:36 The-Turing-Machine-X kernel: kauditd_printk_skb: 14 callbacks suppressed
Jul 13 00:02:36 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5511, resource id: 14680525, major code: 3 (GetWindowAttributes), minor code: 0
Jul 13 00:02:36 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5512, resource id: 14680525, major code: 14 (GetGeometry), minor code: 0
Jul 13 00:02:58 The-Turing-Machine-X kded5[1647]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Jul 13 00:02:58 The-Turing-Machine-X kded5[1647]: kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
Jul 13 00:03:49 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27372, resource id: 77594630, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:04:17 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33231, resource id: 77594630, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:04:52 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35932, resource id: 77594630, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:04:54 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36136, resource id: 77594630, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:06:21 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Jul 13 00:06:21 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61903, resource id: 37748942, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:06:21 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61908, resource id: 37748943, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:06:21 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62316, resource id: 14686302, major code: 3 (GetWindowAttributes), minor code: 0
Jul 13 00:06:21 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 62317, resource id: 14686302, major code: 14 (GetGeometry), minor code: 0
Jul 13 00:06:21 The-Turing-Machine-X dolphin[4611]: kf.kio.core: "The file or folder /run/media/sarankdirector/NO_LABEL does not exist."
Jul 13 00:06:24 The-Turing-Machine-X dolphin[4611]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Jul 13 00:06:24 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63995, resource id: 77594645, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:06:25 The-Turing-Machine-X kate[4663]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Jul 13 00:06:26 The-Turing-Machine-X dolphin[4611]: inotify_add_watch(/root) failed: (Permission denied)
Jul 13 00:06:26 The-Turing-Machine-X kioslave5[4644]: kf.kio.slaves.thumbnail: Failed to load "calligrathumbnail" "The shared library was not found."
Jul 13 00:06:26 The-Turing-Machine-X dolphin[4611]: inotify_add_watch(/lost+found) failed: (Permission denied)
Jul 13 00:06:26 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65428, resource id: 79691787, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:06:27 The-Turing-Machine-X kioslave5[4707]: kf.kio.slaves.thumbnail: Failed to load "calligrathumbnail" "The shared library was not found."
Jul 13 00:07:04 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15604, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:08:48 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Jul 13 00:09:25 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4240, resource id: 83886091, major code: 18 (ChangeProperty), minor code: 0
Jul 13 00:10:24 The-Turing-Machine-X kded5[1647]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Jul 13 00:10:24 The-Turing-Machine-X kscreenlocker_greet[5348]: Qt: Session management error: networkIdsList argument is NULL
Jul 13 00:10:24 The-Turing-Machine-X kscreenlocker_greet[5348]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze/actions/24/edit-copy.svg: Unsupported image format
Jul 13 00:10:25 The-Turing-Machine-X kscreenlocker_greet[5348]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Jul 13 00:10:25 The-Turing-Machine-X kscreenlocker_greet[5348]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Jul 13 02:10:26 The-Turing-Machine-X kernel: done.
Jul 13 02:10:26 The-Turing-Machine-X rtkit-daemon[1767]: The canary thread is apparently starving. Taking action.
Jul 13 02:10:26 The-Turing-Machine-X plasmashell[1700]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5579bee5cda0) QQmlContext(0x5579be0b18c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 13 02:10:26 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jul 13 02:10:26 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jul 13 02:10:26 The-Turing-Machine-X plasmashell[1700]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Jul 13 02:10:26 The-Turing-Machine-X plasmashell[1700]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Jul 13 09:06:39 The-Turing-Machine-X kernel: done.
Jul 13 09:06:42 The-Turing-Machine-X bluetoothd[1078]: Failed to set mode: Blocked through rfkill (0x12)
Jul 13 09:06:42 The-Turing-Machine-X kded5[1647]: kf.bluezqt: PendingCall Error: "Blocked through rfkill"
Jul 13 09:07:08 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31237, resource id: 4194358, major code: 18 (ChangeProperty), minor code: 0
Jul 13 09:07:08 The-Turing-Machine-X kwin_x11[1650]: kwin_core: XCB error: 152 (BadDamage), sequence: 31260, resource id: 14695332, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jul 13 09:07:08 The-Turing-Machine-X kwin_x11[1650]: kwin_core: XCB error: 3 (BadWindow), sequence: 31261, resource id: 20971532, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 13 09:07:08 The-Turing-Machine-X kwin_x11[1650]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31262, resource id: 20971532, major code: 2 (ChangeWindowAttributes), minor code: 0
delete this:
sudo rm /etc/X11/xorg.conf
reboot and see if it helped
Did it, but the problem only seems to appear every few days, i’ll let you know what happens.
